Best Compatible Mounts for Wyze Cams with 1/4"-20 Standard Thread – Secure, Versatile Mounting Solutions
The Best Compatible Mounts for Wyze Cams with 1/4"-20 Standard Mount
Looking for a reliable, versatile, and secure way to mount your Wyze cameras using the industry-standard 1/4"-20 thread? Whether you want to install your camera outdoors, on a ceiling, or in a hard-to-reach spot, choosing the right mount is essential for optimal performance and peace of mind. Below, we highlight the top compatible mounting solutions for Wyze Cams that use the 1/4"-20 standard mount, focusing on durability, flexibility, and ease of installation.
Why Choose a 1/4"-20 Standard Mount for Wyze Cams?
The 1/4"-20 thread is the universal mounting standard for cameras and accessories, ensuring compatibility and stability. Wyze has designed several of its cameras and accessories to work seamlessly with this standard, making it easy to find the perfect mounting solution for your needs.
Wyze Universal Mount (Long): The Ultimate Versatile Mount
Heavy-Duty, Adjustable, and Built for Wyze Cams
The Wyze Universal Mount (Long) is specifically engineered for Wyze cameras that use the 1/4"-20 standard mount. Its longer neck and robust construction make it ideal for a variety of mounting scenarios, from ceilings to patios and more.
  • Made for Wyze Cams: Compatible with Wyze Cam v1, v2, v3, v3 Pro, Pan v1/v2/v3, Outdoor v1/v2, and Battery Cam Pro.
  • Heavy-Duty Metal Construction: Built to last, with a load-bearing capacity of up to 2 kg (70 oz).
  • Flexible Installation: Adjustable design allows for precise camera positioning.
  • Easy to Install: Comes with all necessary hardware, including wall anchors and screws.
  • Matte White Finish: Blends seamlessly with most home exteriors and interiors.
  • Dimensions: 2 in x 2 in x 3.8 in; Weight: 2 oz (57 g).
"A durable camera mount with a longer neck. Designed to provide versatile mounting applications such as the ceiling or patio. Made for Wyze Cameras that use a standard 1/4”-20 mount."
Not compatible with Wyze Cam OG or OG Telephoto. Wyze camera mounted outdoors on a patio, showcasing lifestyle use and security benefits
Wyze Battery Cam Pro: Built-In 1/4"-20 Mounting for Maximum Flexibility
Wire-Free Security with Standard Mount Compatibility
The Wyze Battery Cam Pro is designed for users who want a wire-free, weatherproof camera with the flexibility of the 1/4"-20 standard mount. This camera is perfect for outdoor installations where running power cables is not feasible.
  • 2.5K HDR Video Resolution: Crisp, clear footage day or night.
  • Removable, Rechargeable Battery Packs: Up to 6 months of battery life.
  • IP65 Weatherproof: Built to withstand the elements.
  • Integrated Spotlight & Siren: Enhanced security features.
  • Mounting Methods: 1/4”-20 standard thread for universal compatibility.
  • Wall Mount Included: Easy installation right out of the box.
  • Dual-Band WiFi (2.4 & 5 GHz): Reliable connectivity.
"Wyze Battery Cam Pro features a 1/4”-20 standard mount, making it compatible with a wide range of universal camera mounts for flexible placement."
Installation Made Easy: Secure Your Wyze Cam Anywhere
Tips for the Best Mounting Experience
  • Choose the Right Location: Select a spot that provides the best field of view for your security needs.
  • Use the Included Hardware: Both the Wyze Universal Mount (Long) and Wyze Battery Cam Pro come with all necessary mounting accessories.
  • Weatherproof Your Setup: Both products are designed for outdoor use, ensuring durability and performance in any season.
Easy outdoor installation of Wyze Cam Floodlight, demonstrating lifestyle and security benefits
Why These Mounts Are the Best Choice for Wyze Cams
  • Universal Compatibility: The 1/4"-20 standard ensures you can use these mounts with a wide range of Wyze cameras and other devices.
  • Durability: Heavy-duty materials and weather-resistant design mean your camera stays secure, rain or shine.
  • Flexibility: Adjustable mounts and wire-free options let you place your camera exactly where you need it.
"If you can plug in a cable, then you can enjoy the security of a Wyze camera. No more scary junction boxes and expensive electricians."
Conclusion
For anyone seeking a compatible mount for Wyze cams with the 1/4"-20 standard, the Wyze Universal Mount (Long) and Wyze Battery Cam Pro offer the perfect blend of flexibility, durability, and ease of use. Secure your home or business with confidence, knowing your Wyze camera is mounted safely and optimally. Wyze Cam Floodlight in use on a deck at dusk, highlighting lifestyle and security
Optimize your Wyze camera setup today with these top-rated, compatible mounting solutions!
FeatureWyze Universal Mount (Long)Wyze Battery Cam Pro
Product TypeCamera Mount (Accessory)Wireless Security Camera
CompatibilityWyze Cams with 1/4"-20 mount (not OG/OG Telephoto)1/4"-20 standard mount, included wall mount
Main FunctionMounting Wyze cameras (ceiling, patio, etc.)2.5K HDR video, security monitoring
MaterialHeavy-duty metalPC plastics, optical glass lens
Adjustable AngleYesYes
Weather ResistanceYes (recommended to protect from extreme weather)IP65 Weatherproof
Mounting OptionsCeiling, wall, patio, fences, trees, sidingWall, ceiling (with Universal Mount), anywhere wire-free
Included HardwareMount, 3x wall anchors, 3x screwsWall mount, USB-C cable, battery pack, screws
Dimensions2 in x 2 in x 3.8 in2.5 x 1.8 x 3.5 in
Weight2 oz (57 g)0.94 lbs
Load-Bearing Capacity70 oz (2 kg)N/A
Power SourceN/ARemovable, rechargeable battery packs
Battery LifeN/AUp to 6 months per charge
Video ResolutionN/A2.5K HDR (2560 x 1440)
Night VisionN/AColor Night Vision, IR LEDs, White LEDs
Motion DetectionN/ARadar + PIR Motion Detection
AudioN/ATwo-way audio, siren
Price$9.99$89.98
Notable ExtrasRequired for ceiling mounting Battery Cam ProIntegrated spotlight & siren, local/cloud storage
What is a 1/4"-20 standard mount and why is it important for Wyze cameras?A 1/4"-20 standard mount is the universal threading size used for most cameras and accessories, including many Wyze cameras. This standard ensures compatibility, stability, and makes it easy to find a wide range of mounting solutions for your Wyze cam.
Which Wyze cameras are compatible with the Wyze Universal Mount (Long)?The Wyze Universal Mount (Long) is compatible with Wyze Cam v1, v2, v3, v3 Pro, Pan v1/v2/v3, Outdoor v1/v2, and Battery Cam Pro. It is not compatible with Wyze Cam OG or OG Telephoto.
What are the key features of the Wyze Universal Mount (Long)?The Wyze Universal Mount (Long) features heavy-duty metal construction, a longer neck for versatile mounting, adjustable design for precise positioning, easy installation with included hardware, and a matte white finish that blends with most home exteriors and interiors.
Is the Wyze Universal Mount (Long) suitable for outdoor use?Yes, the Wyze Universal Mount (Long) is designed for both indoor and outdoor use, offering durability and weather resistance for secure camera installation in any environment.
Does the Wyze Battery Cam Pro support the 1/4"-20 standard mount?Yes, the Wyze Battery Cam Pro features a built-in 1/4"-20 standard mount, making it compatible with a wide range of universal camera mounts for flexible placement.
What are the benefits of using the Wyze Battery Cam Pro for outdoor security?The Wyze Battery Cam Pro offers wire-free installation, 2.5K HDR video resolution, up to 6 months of battery life, IP65 weatherproof rating, integrated spotlight and siren, and dual-band WiFi for reliable outdoor security.
What mounting hardware is included with Wyze camera mounts?Both the Wyze Universal Mount (Long) and Wyze Battery Cam Pro come with all necessary mounting accessories, including wall anchors and screws, for easy and secure installation.
How do I choose the best location to mount my Wyze camera?Select a location that provides the best field of view for your security needs. Ensure the area is within WiFi range and, for outdoor installations, choose a spot that is sheltered from extreme weather when possible.
Are Wyze camera mounts weatherproof?Yes, both the Wyze Universal Mount (Long) and Wyze Battery Cam Pro are designed for outdoor use and are built to withstand various weather conditions, ensuring long-lasting performance.
Why should I use a universal 1/4"-20 mount for my Wyze camera?Using a universal 1/4"-20 mount ensures maximum compatibility with a wide range of Wyze cameras and other devices, provides secure and stable installation, and allows for flexible camera placement indoors or outdoors.
What are the best locations to install the Wyze Universal Mount (Long) for optimal camera performance?Can you provide more details about the installation process for the Wyze Battery Cam Pro?Are there any ongoing promotions or discounts available for purchasing Wyze camera mounts?
