Stack Mount Accessories for Wyze Cam OG and Telephoto Cameras
If you own the Wyze Cam OG or the Wyze Cam OG Telephoto, optimizing your camera setup with the right stack mount accessory is essential for a clean, efficient, and powerful surveillance system. The
Wyze Cam OG Stack Kit is specifically designed to meet these needs, allowing you to stack and power two Wyze OG or OG Telephoto cameras seamlessly.
Wyze Cam OG Stack Kit: The Ultimate Stack Mount Solution
Designed for Wyze Cam OG and OG Telephoto
The
Wyze Cam OG Stack Kit is the perfect accessory for users who want to mount two Wyze Cam OG or OG Telephoto cameras vertically in a compact and organized manner. This kit is tailored exclusively for these models, ensuring compatibility and ease of use.
What’s Included?
- Stack Mount: A sturdy, matte white mount that securely holds two cameras stacked on top of each other.
- Dual Micro USB Power Cable (6ft): Powers both cameras from a single power source, reducing cable clutter.
- 5V/1.5A Indoor Power Adapter: Reliable power supply designed for indoor use.
- Quick Start Guide: Easy-to-follow instructions for quick installation.
Key Benefits
- Space-saving design: Stack two cameras vertically to maximize your mounting area.
- Simplified power management: One power adapter powers both cameras via the included splitter cable.
- Matte finish: Blends discreetly with your home or office décor.
- Indoor use: Ideal for indoor security setups where multiple cameras are needed.
The Wyze Cam OG Stack Kit is a smart, efficient way to enhance your Wyze OG or OG Telephoto camera setup without the hassle of multiple power cords and bulky mounts.
Wyze Cam OG Telephoto: Enhanced Zoom with Stack Mount Compatibility
Features of Wyze Cam OG Telephoto
The
Wyze Cam OG Telephoto is the 2023 generation of Wyze’s indoor/outdoor camera lineup, now featuring a powerful 3x telephoto lens for detailed zoomed-in views. It offers:
- 1080p Full HD video with CMOS-Starlight Sensor for clear day and night footage.
- 3x telephoto lens with a narrow field of view for focused surveillance.
- 8x digital zoom for enhanced detail.
- Built-in speaker and microphone with noise and echo cancellation for two-way audio.
- Weather resistance rated IP65, suitable for outdoor use.
- Multiple mounting options: stand, wall mount, or ceiling mount with M4 screws.
- Supports local storage up to 256GB microSD card.
- Smart home integrations: Alexa, Google Assistant, and IFTTT.
Why Use the Stack Kit with Wyze Cam OG Telephoto?
Pairing the Wyze Cam OG Telephoto with the Stack Kit allows you to:
- Mount two telephoto cameras stacked for broader coverage or multi-angle views.
- Manage power efficiently with a single adapter and splitter cable.
- Maintain a clean, professional installation with minimal wiring.
Other Mounting Accessories: Compatibility Notes
Wyze Universal Mount (Long)
- Designed for Wyze cameras with a standard 1/4”-20 mount.
- Provides a longer neck for versatile mounting on ceilings or patios.
- Not compatible with Wyze Cam OG or OG Telephoto cameras.
- Ideal for other Wyze models like Wyze Cam v1, v2, v3, and Pan series.
Wyze Cam Mounting Kit
- Includes a mounting bracket, adhesive tape, screws, and a longer Micro USB cable.
- Compatible with Wyze Cam v2, v3, and v3 Pro.
- Not designed for Wyze Cam OG or OG Telephoto.
Enhance Your Wyze Cam OG Setup Today
For Wyze Cam OG and OG Telephoto users, the
Wyze Cam OG Stack Kit is the definitive accessory to stack and power your cameras efficiently. It simplifies installation, reduces cable clutter, and provides a sleek mounting solution tailored to your camera models.
Elevate your home or office security with a neat, powerful, and easy-to-install stack mount solution designed specifically for Wyze Cam OG and OG Telephoto cameras.
Secure your home with versatile Wyze camera mounts and accessories.
Summary of Relevant Products
Product Name | Compatibility | Price (USD) | Key Features |
Wyze Cam OG Stack Kit | Wyze Cam OG, OG Telephoto | 9.99 | Stack mount, dual power cable, power adapter |
Wyze Cam OG Telephoto | Wyze Cam OG Telephoto | 25.98+ | 3x telephoto lens, 1080p, IP65, 8x zoom |
Wyze Universal Mount (Long) | Not compatible with OG series | 9.99 | Long neck, versatile mounting |
Wyze Cam Mounting Kit | Wyze Cam v2, v3, v3 Pro | 5.99 | Mounting bracket, adhesive, USB cable |
What is the Wyze Cam OG Stack Kit and what cameras is it compatible with?
The Wyze Cam OG Stack Kit is a mounting accessory designed specifically for the Wyze Cam OG and Wyze Cam OG Telephoto cameras. It allows you to stack and power two cameras vertically in a compact and organized manner, making it ideal for users who want a clean and efficient surveillance setup.What is included in the Wyze Cam OG Stack Kit?
The Wyze Cam OG Stack Kit includes a sturdy matte white stack mount, a 6ft dual Micro USB power cable for powering two cameras from a single source, a 5V/1.5A indoor power adapter, and a quick start guide for easy installation.Can I use the Wyze Cam OG Stack Kit with other Wyze camera models?
No, the Wyze Cam OG Stack Kit is exclusively designed for the Wyze Cam OG and Wyze Cam OG Telephoto cameras. It is not compatible with other Wyze camera models such as Wyze Cam v2, v3, v3 Pro, or the Pan series.What are the benefits of using the Wyze Cam OG Stack Kit?
The Wyze Cam OG Stack Kit offers a space-saving design by stacking two cameras vertically, simplifies power management with a single adapter and splitter cable, reduces cable clutter, and provides a sleek matte finish that blends with your home or office décor. It is ideal for indoor security setups.Is the Wyze Cam OG Stack Kit suitable for outdoor use?
The Wyze Cam OG Stack Kit is designed for indoor use. While the Wyze Cam OG Telephoto camera itself is weather-resistant and rated IP65 for outdoor use, the stack kit and included power adapter are intended for indoor environments.What are the key features of the Wyze Cam OG Telephoto camera?
The Wyze Cam OG Telephoto features a 3x telephoto lens for detailed zoomed-in views, 1080p Full HD video with a CMOS-Starlight Sensor for clear day and night footage, 8x digital zoom, built-in speaker and microphone with noise and echo cancellation, IP65 weather resistance, multiple mounting options, support for up to 256GB microSD card, and smart home integrations with Alexa, Google Assistant, and IFTTT.Why should I use the Stack Kit with the Wyze Cam OG Telephoto?
Using the Stack Kit with the Wyze Cam OG Telephoto allows you to mount two telephoto cameras stacked for broader coverage or multi-angle views, manage power efficiently with a single adapter and splitter cable, and maintain a clean, professional installation with minimal wiring.Are the Wyze Universal Mount (Long) and Wyze Cam Mounting Kit compatible with Wyze Cam OG or OG Telephoto?
No, the Wyze Universal Mount (Long) and Wyze Cam Mounting Kit are not compatible with Wyze Cam OG or OG Telephoto cameras. The Universal Mount (Long) is designed for Wyze cameras with a standard 1/4”-20 mount, such as Wyze Cam v1, v2, v3, and Pan series. The Wyze Cam Mounting Kit is compatible with Wyze Cam v2, v3, and v3 Pro.How does the dual Micro USB power cable in the Stack Kit help with installation?
The dual Micro USB power cable included in the Wyze Cam OG Stack Kit allows you to power both cameras from a single power source, reducing cable clutter and simplifying your camera installation.Where can I buy the Wyze Cam OG Stack Kit and what is the price?
The Wyze Cam OG Stack Kit is available for purchase on the Wyze website and is priced at $9.99 USD.
