Universal 1/4"-20 Mount for Wyze Cams – Secure Any Camera
Universal Mount for Wyze Cams with 1/4"-20 Thread Compatibility
If you're looking for a versatile and reliable universal mount compatible with Wyze cameras that use the standard 1/4"-20 thread, the Wyze Universal Mount (Long) is the perfect solution. Designed specifically for Wyze cameras, this mount offers flexibility, durability, and ease of installation, making it ideal for various mounting scenarios including ceilings, patios, walls, and more.
Wyze Universal Mount (Long) – The Ideal Mounting Solution
Durable and Adjustable Design
The Wyze Universal Mount (Long) features a heavy-duty metal construction with a longer neck, providing enhanced reach and positioning options. Its adjustable design allows you to tilt and angle your camera precisely where you need it, ensuring optimal coverage and security.
  • Material: Heavy-duty metal for long-lasting durability
  • Finish: Matte white for a clean, unobtrusive look
  • Dimensions: 2 in x 2 in x 3.8 in
  • Weight: Lightweight at 2 oz (57 g) for easy handling
  • Load Bearing: Supports up to 70 oz (2 kg), suitable for all compatible Wyze cameras
Easy Installation
Installation is straightforward with included hardware:
  • Comes with 3 drywall anchors and 3 Philips screws
  • Compatible drill bit sizes provided for hassle-free mounting
  • Mounts securely on walls, ceilings, patios, or any flat surface
Compatibility
This mount is compatible with a wide range of Wyze cameras that use the 1/4"-20 mount thread, including:
  • Wyze Cam v1, v2, v3, and v3 Pro
  • Wyze Cam Pan v1, v2, and v3
  • Wyze Cam Outdoor v1 and v2
  • Wyze Battery Cam Pro
Note: This mount is not compatible with Wyze Cam OG or OG Telephoto models.
Wyze Cam v4 – The Perfect Camera to Pair with the Universal Mount
Superior Video Quality and Features
The Wyze Cam v4 is one of the most advanced Wyze cameras available, making it an excellent choice to use with the Wyze Universal Mount (Long). It offers:
  • 2.5K Quad HD resolution for crystal-clear video
  • Color Night Vision with enhanced hardware to capture vibrant details even in low light
  • Wide Dynamic Range (WDR) for rich, vibrant colors and better image quality
  • IP65 Weather Resistance allowing outdoor placement without worry
  • Integrated Spotlight and Siren for added security and deterrence
  • Advanced Two-Way Talk with improved audio clarity
Easy Setup and Smart Features
  • Bluetooth® setup eliminates the need for QR codes
  • Magnetic base for screw-free mounting (though the universal mount offers more versatile placement)
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
  • Supports continuous 24/7 recording with microSD cards up to 512GB (sold separately)
Versatile Mounting Options
While the Wyze Cam v4 includes a magnetic mount, pairing it with the Wyze Universal Mount (Long) expands your installation possibilities, especially for ceiling or patio mounts where magnetic mounting is less practical.
Why Choose the Wyze Universal Mount with Wyze Cam v4?
  • Universal 1/4"-20 Thread Compatibility: Fits most Wyze cameras, including the latest v4 model
  • Durable and Weather-Resistant Setup: Perfect for indoor and outdoor use
  • Flexible Mounting Locations: Ceiling, wall, patio, or any flat surface
  • Enhanced Security Coverage: Position your camera exactly where you need it for maximum protection
Elevate your home security setup with the combination of the Wyze Cam v4 and the Wyze Universal Mount (Long) for a seamless, professional-grade installation.
Summary
ProductKey FeaturesPrice
Wyze Cam v42.5K QHD, Color Night Vision, IP65, Spotlight$100.00
Wyze Universal MountHeavy-duty metal, adjustable, 1/4"-20 thread$9.99
Wyze Cam Mounted Outdoors Alt text: Wyze Cam v4 mounted outdoors on patio with universal mount
Final Thoughts
For anyone seeking a universal mount solution compatible with Wyze cameras featuring the 1/4"-20 thread, the Wyze Universal Mount (Long) is a top choice. When paired with the feature-rich Wyze Cam v4, you get a powerful, flexible, and weather-resistant security system that can be installed virtually anywhere. Upgrade your home security today with this perfect mounting combo!
FeatureWyze Cam v4Wyze Universal Mount (Long)
Product TypeCameraCamera Accessory (Mount)
Price$100.00 (special American worker support version) / $35.98 - $107.94 (varies by bundle/color)$9.99
PurposeHome security camera with 2.5K QHD video, color night vision, spotlight, siren, 24/7 recordingDurable mount with longer neck for versatile mounting options
Resolution2.5K QHD (2560x1440)N/A
Night VisionEnhanced Color Night Vision + B&WN/A
Weather ResistanceIP65 (weather resistant for indoor/outdoor use)Heavy-duty metal, weather resistant
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)Ceiling, patio, fences, trees, siding, etc.
CompatibilityWorks with Alexa, Google Assistant, IFTTTCompatible with Wyze Cameras using standard 1/4”-20 mount
Not Compatible WithN/ANot compatible with Wyze Cam OG or OG Telephoto
Power SourceWired (6-foot micro USB cable included)N/A
Dimensions2in x 2in x 2 3/8inNot specified
Weight0.49 lb (222 g)Not specified
InstallationScrew-free magnetic mount, Bluetooth setupAdjustable, flexible, easy installation
Additional FeaturesMotion-activated spotlight, 99 dB siren, AI auto-zoom, Wi-Fi 6 supportLonger neck for versatile mounting angles
Warranty1 Year30-day hassle-free returns
What is the Wyze Universal Mount (Long) and what cameras is it compatible with?The Wyze Universal Mount (Long) is a heavy-duty, adjustable metal mount designed for Wyze cameras that use the standard 1/4"-20 thread. It is compatible with Wyze Cam v1, v2, v3, v3 Pro, Wyze Cam Pan v1, v2, v3, Wyze Cam Outdoor v1, v2, and Wyze Battery Cam Pro. It is not compatible with Wyze Cam OG or OG Telephoto models.
What are the key features of the Wyze Universal Mount (Long)?The Wyze Universal Mount (Long) features a durable heavy-duty metal construction, a longer neck for enhanced reach, and an adjustable design for precise camera positioning. It has a matte white finish, supports up to 70 oz (2 kg), and is lightweight at just 2 oz (57 g).
How do I install the Wyze Universal Mount (Long)?Installation is easy with the included hardware: 3 drywall anchors and 3 Philips screws. Compatible drill bit sizes are provided for hassle-free mounting. The mount can be securely installed on walls, ceilings, patios, or any flat surface.
Can the Wyze Universal Mount (Long) be used outdoors?Yes, the Wyze Universal Mount (Long) is made from heavy-duty metal and is suitable for both indoor and outdoor use, making it ideal for mounting on patios, ceilings, and other outdoor locations.
Is the Wyze Universal Mount (Long) compatible with the Wyze Cam v4?Yes, the Wyze Universal Mount (Long) is fully compatible with the Wyze Cam v4, which uses the standard 1/4"-20 thread. This combination allows for flexible and secure mounting options.
What are the benefits of using the Wyze Universal Mount (Long) with Wyze Cam v4?Pairing the Wyze Universal Mount (Long) with the Wyze Cam v4 provides flexible mounting options, enhanced security coverage, and a durable, weather-resistant setup. It allows you to position your camera exactly where you need it for optimal protection.
What are the main features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K Quad HD resolution, color night vision, wide dynamic range (WDR), IP65 weather resistance, an integrated spotlight and siren, advanced two-way talk, Bluetooth setup, and compatibility with Alexa, Google Assistant, and IFTTT. It also supports continuous 24/7 recording with microSD cards up to 512GB.
Does the Wyze Cam v4 come with a mount?Yes, the Wyze Cam v4 includes a magnetic base for screw-free mounting. However, for more versatile placement, especially on ceilings or patios, the Wyze Universal Mount (Long) is recommended.
What is the price of the Wyze Universal Mount (Long) and Wyze Cam v4?The Wyze Universal Mount (Long) is priced at $9.99, and the Wyze Cam v4 is available for $100.00.
Why should I choose the Wyze Universal Mount (Long) for my Wyze camera?The Wyze Universal Mount (Long) offers universal 1/4"-20 thread compatibility, durable metal construction, flexible mounting locations, and is suitable for both indoor and outdoor use. It ensures your Wyze camera is securely positioned for maximum security coverage.
What are the installation requirements for the Wyze Universal Mount?Can the Wyze Universal Mount be used for outdoor installations?Do you have any deals, ongoing sales, discounts, or promotions?
