How to Install and Stack Dual Wyze Cam OG Cameras with Kit
How to Install and Stack Dual Wyze Cam OG Cameras with the Kit Guide
If you're looking to enhance your home security with dual Wyze Cam OG cameras, stacking them using the Wyze Cam OG Stack Kit is a smart and space-saving solution. This guide will walk you through the installation and stacking process, highlighting the features of the Wyze Cam OG cameras and the Stack Kit to help you get the most out of your setup.
Wyze Cam OG: Powerful and Versatile Security Camera
Key Features
  • 1080p Full HD Video Resolution: Crystal-clear live streaming and recordings with 1920 x 1080 resolution.
  • Wide 120° Field of View: Covers a broad area for comprehensive monitoring.
  • Built-in Spotlight & Siren: 40 lumens spotlight and a 90-decibel siren for enhanced security.
  • Improved Two-Way Audio: Noise and echo cancellation for clear communication.
  • Night Vision: Equipped with 4 IR LEDs (850nm) for color night vision.
  • Weather Resistant: Rated IP65 for indoor and outdoor use.
  • Local Storage Support: Up to 256 GB microSD card compatibility.
  • Fast Live Streaming: 50% faster than previous Wyze Cam models.
  • Compact Design: Small footprint (1.89 in³) and lightweight (4.1 oz) for flexible placement.
Installation Overview
The Wyze Cam OG is designed for easy mounting on walls, ceilings, or flat surfaces. It comes with a 6 ft power cable and a 5V/1A power adapter. Simply connect the camera to power, mount it using the included hardware, and connect to your 2.4 GHz Wi-Fi network via the Wyze app.
The Wyze Cam OG is perfect for both indoor and outdoor surveillance, providing reliable security with smart features at an affordable price.
Wyze Cam OG in Home Setting Alt text: Wyze Cam OG mounted indoors monitoring a living room
Wyze Cam OG Stack Kit: Simplify Dual Camera Setup
What’s Included
  • Stack Mount for securely stacking two cameras vertically.
  • Dual Micro USB Power Cable (6 ft) to power both cameras from a single outlet.
  • 5V/1.5A Indoor Power Adapter.
  • Quick Start Guide for easy installation.
Benefits of the Stack Kit
  • Space-Saving Design: Stack two Wyze Cam OG or Wyze Cam OG Telephoto cameras to monitor different angles without clutter.
  • Single Power Source: The USB splitter cable powers both cameras, reducing cable mess.
  • Versatile Mounting: The stack mount is designed to hold cameras firmly in place on walls, shelves, or other surfaces.
How to Stack and Install
1. Attach the stack mount to your desired surface using screws or adhesive. 2. Mount the first Wyze Cam OG camera onto the stack mount. 3. Place the second camera on top of the first using the stack mount’s secure slots. 4. Connect both cameras to the dual USB power cable. 5. Plug the power adapter into an outlet. 6. Set up each camera individually in the Wyze app for live streaming and notifications.
Stacking cameras allows you to have a wide-angle view from the bottom camera and a closer look from the top camera (especially if using the Telephoto model).
Wyze Cam OG Stack Kit Bundle: Dual Camera Solution with Everything Included
Bundle Highlights
  • Includes one Wyze Cam OG Standard and one Wyze Cam OG Telephoto camera.
  • Comes with the Wyze Cam OG Stack Kit for easy dual mounting.
  • 32GB microSD card included for local storage.
  • Two built-in spotlights (40 lumens each) for color night vision.
  • Fast notifications and two-way audio.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
  • Weather-resistant IP65 rating for indoor/outdoor use.
  • 1-year warranty for peace of mind.
Why Choose the Bundle?
This bundle is ideal if you want a comprehensive dual-camera setup with both wide-angle and telephoto views. The included stack kit and accessories make installation straightforward, while the microSD card ensures you have local video storage right out of the box. Wyze Cam OG Stack Kit Bundle Setup Alt text: Dual Wyze Cam OG cameras stacked on a wall monitoring outdoor space
Tips for Optimal Installation and Use
  • Mounting Location: Choose a location with a clear view and within range of your 2.4 GHz Wi-Fi network.
  • Power Source: Use the included power adapter and USB splitter to minimize cables.
  • App Setup: Use the Wyze app to configure detection zones, notifications, and two-way audio.
  • Stacking Order: Place the wide-angle Wyze Cam OG on the bottom and the Telephoto on top for layered coverage.
  • Weather Protection: Although IP65 rated, avoid extreme weather exposure for longer device life.
With the Wyze Cam OG and Stack Kit, you can easily create a dual-camera security system that is both efficient and effective.
Summary
Stacking dual Wyze Cam OG cameras using the Wyze Cam OG Stack Kit is a practical way to maximize your home security coverage. Whether you choose the standard cameras or the bundle with telephoto lens, this setup offers:
  • Easy installation with included mounting hardware and power accessories.
  • Dual views with wide-angle and telephoto lenses.
  • Reliable indoor/outdoor performance with weather resistance.
  • Fast live streaming and smart notifications.
  • Local storage and smart home integration.
Upgrade your security system today with Wyze Cam OG and the Stack Kit for a seamless dual-camera experience.
FeatureWyze Cam OGWyze Cam OG Stack KitWyze Cam OG Stack Kit Bundle
TypeCameraAccessoryCamera Bundle
Price$29.98 (1 Pack), $59.96 (2 Pack), $89.94 (3 Pack)$9.99$89.99
DescriptionNext-gen Wyze Cam with 120° FOV, built-in spotlight, 3X faster notifications, improved 2-way audio, indoor/outdoor (IP65)USB Cable Splitter, Power Brick, Stack Mount to power and stack two Wyze Cam OG or OG Telephoto camerasIncludes Wyze Cam OG Standard, Wyze Cam OG Telephoto, Stack Kit, power adapters, cables, 32GB microSD card
Field of View120° (approx. 121.4° DFOV)N/AWide-angle (Wyze Cam OG) + 3x Telephoto (Wyze Cam OG Telephoto)
SpotlightBuilt-in 40-lumen spotlightN/A2 spotlights (5000K, 40 lumens each)
Two-way AudioYes, upgraded microphone and speakerN/AYes
Weather ResistanceIP65 (Indoor/Outdoor)N/AIP65 (Indoor/Outdoor)
Power Adapter Input110-240V (AC/DC)Included in kit110-240V (AC/DC)
Power Adapter Output5V/1AIncluded in kit5V/1.5A (for bundle)
Video Resolution1920 x 1080 (1080p)N/A1920 x 1080 (1080p)
Video FPS20 FPS Day, 15 FPS NightN/A20 FPS Day, 15 FPS Night
StorageSupports up to 256GB microSDN/ASupports up to 256GB microSD
Connectivity802.11 b/g/n, 2.4 GHz Wi-FiN/A802.11 b/g/n, 2.4 GHz Wi-Fi
Dimensions1.89 in x 1.89 in x 1.89 in (48mm cube)Stack Mount size not specifiedSame as Wyze Cam OG and Telephoto (48mm cube each)
Weight4.1 oz (116 g)Not specifiedWyze Cam OG: 4.1 oz (116 g)
Included ItemsCamera, power adapter, USB cable, mounting hardwareUSB Cable Splitter, Power Brick, Stack MountWyze Cam OG, Wyze Cam OG Telephoto, Stack Kit, power adapters, dual USB cable, 32GB microSD card, mounting hardware
Special FeaturesBuilt-in spotlight & mini-siren, 3x faster notifications, improved 2-way audio, color night visionAllows stacking and powering two Wyze Cam OG or OG Telephoto cameras from one power sourceCombines wide-angle and telephoto cameras with stack kit for dual views, Alexa/Google/IFTTT integration, built-in siren
Warranty1 Year1 Year (implied)1 Year
What is the Wyze Cam OG Stack Kit and how does it work?The Wyze Cam OG Stack Kit is an accessory designed to securely stack two Wyze Cam OG or Wyze Cam OG Telephoto cameras vertically. It includes a stack mount, dual micro USB power cable, and a power adapter, allowing you to power both cameras from a single outlet and monitor different angles without clutter.
How do I install and stack dual Wyze Cam OG cameras using the Stack Kit?To install and stack dual Wyze Cam OG cameras: 1) Attach the stack mount to your desired surface using screws or adhesive. 2) Mount the first camera onto the stack mount. 3) Place the second camera on top using the secure slots. 4) Connect both cameras to the dual USB power cable. 5) Plug the power adapter into an outlet. 6) Set up each camera individually in the Wyze app for live streaming and notifications.
What are the key features of the Wyze Cam OG security camera?The Wyze Cam OG offers 1080p Full HD video resolution, a wide 120° field of view, built-in 40 lumens spotlight and 90-decibel siren, improved two-way audio with noise and echo cancellation, color night vision with 4 IR LEDs, IP65 weather resistance, support for up to 256GB microSD card, fast live streaming, and a compact, lightweight design.
Can the Wyze Cam OG cameras be used outdoors?Yes, the Wyze Cam OG cameras are IP65 weather-resistant, making them suitable for both indoor and outdoor use. However, for longer device life, it is recommended to avoid exposing them to extreme weather conditions.
What is included in the Wyze Cam OG Stack Kit Bundle?The Wyze Cam OG Stack Kit Bundle includes one Wyze Cam OG Standard, one Wyze Cam OG Telephoto camera, the Wyze Cam OG Stack Kit for dual mounting, a 32GB microSD card for local storage, two built-in spotlights, and all necessary power accessories. It also comes with a 1-year warranty.
How do I power two Wyze Cam OG cameras with the Stack Kit?The Stack Kit includes a dual micro USB power cable and a 5V/1.5A power adapter, allowing you to power both cameras from a single outlet. Simply connect both cameras to the splitter cable and plug the adapter into an electrical outlet.
What are the benefits of stacking Wyze Cam OG cameras?Stacking Wyze Cam OG cameras saves space, reduces cable clutter, and allows you to monitor different angles simultaneously. For optimal coverage, place the wide-angle camera on the bottom and the telephoto camera on top.
Is the Wyze Cam OG compatible with smart home systems?Yes, the Wyze Cam OG is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and voice control.
How do I set up detection zones and notifications for Wyze Cam OG cameras?You can configure detection zones and notifications through the Wyze app. After installing your cameras, use the app to set up custom detection areas, enable notifications, and adjust two-way audio settings for optimal security monitoring.
What type and size of microSD card does the Wyze Cam OG support?The Wyze Cam OG supports microSD cards up to 256GB for local video storage. The Stack Kit Bundle includes a 32GB microSD card to get you started.
What are the key features of the Wyze Cam OG cameras?Can you explain the benefits of using the Wyze Cam OG Stack Kit?How do I set up the Wyze app for my cameras after installation?
