Bluetooth Deadbolt Smart Lock with USB-C Emergency Charging
Upgrade your home security with the latest in smart lock technology. If you're searching for a
Bluetooth deadbolt smart lock that offers seamless keyless entry and the convenience of
USB-C emergency charging, the
Wyze Lock Bolt stands out as an exceptional choice. Designed to replace your existing deadbolt, this smart lock combines advanced fingerprint recognition, a backlit keypad, and robust security features to keep your home safe and accessible.
Wyze Lock Bolt: The Ultimate Bluetooth Deadbolt Smart Lock
Keyless Entry with Ultra-Fast Fingerprint Reader
Say goodbye to fumbling for keys. The Wyze Lock Bolt features an ultra-fast fingerprint sensor that unlocks your door in less than a second with just a touch of your finger. This Bluetooth-enabled deadbolt smart lock also allows you to unlock your door via the Wyze app, providing multiple convenient access options.
Luxurious Backlit Keypad with Anti-Peep Technology
The exterior keypad is crafted from solid metal and features a backlit design for easy nighttime use. Worried about prying eyes? The Wyze Lock Bolt includes anti-peep technology, allowing you to enter extra random digits before or after your access code to keep your PIN secure from onlookers.
USB-C Emergency Charging for Peace of Mind
One of the standout features of the Wyze Lock Bolt is its USB-C emergency charging port. If the lock’s batteries run out while you’re away, simply connect a USB-C power source for a quick, temporary charge that lets you enter your access code and regain entry without hassle.
Long Battery Life and Auto-Lock Functionality
Powered by 4 AA batteries, the Wyze Lock Bolt offers up to 12 months of battery life under normal use. The lock also includes an auto-lock timer that you can customize via the Wyze app, ensuring your door locks automatically if you forget.
Robust Security and Weatherproof Design
This smart lock is fully pick-proof by eliminating the need for physical keys and is built to withstand the elements with an IPX5 weatherproof rating. Hardware encryption and two-factor authentication within the Wyze app ensure your access codes and fingerprint data remain secure.
Easy Installation and Compatibility
The Wyze Lock Bolt replaces your existing deadbolt in about 20 minutes and fits most exterior doors. It comes in stylish Matte Black and Satin Nickel finishes to complement your home’s exterior.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Secure your home effortlessly with Wyze Lock Bolt’s smart fingerprint access.
Additional Wyze Lock Bolt Replacement Parts
To keep your Wyze Lock Bolt functioning perfectly, Wyze offers a range of replacement parts:
Wyze Lock Bolt Interior Assembly Battery Cover
A replacement cover to protect the battery compartment, ensuring your lock stays sealed and secure.
Wyze Lock Bolt Screws
Replacement screws compatible with the Wyze Lock Bolt for secure installation or maintenance.
Wyze Lock Bolt Interior Assembly Metal Plate
A metal plate designed to anchor the interior assembly firmly to your door.
Wyze Lock Replacement Part Kit
A comprehensive kit for repairs and replacements, compatible with Wyze Lock models.
These parts help maintain your smart lock’s performance and longevity, ensuring your home security remains uncompromised.
Why Choose Wyze Lock Bolt for Your Smart Home?
- Bluetooth Connectivity: Control and monitor your lock locally via the Wyze app without relying on cloud services.
- Fingerprint and Code Access: Store up to 50 fingerprints and 20 access codes for family and guests.
- Emergency Access Codes: Generate one-time use codes remotely for temporary guests, expiring automatically for added security.
- Auto-Lock and One-Touch Lock: Customize auto-lock timing and lock your door instantly with a keypad button or app control.
- Weatherproof and Durable: Built to withstand outdoor conditions with a sleek, modern design.
Manage your lock remotely with the Wyze app for ultimate convenience.
Enhance Your Home Security with Wyze Front Porch Security Bundle
For a complete smart home security solution, consider pairing the Wyze Lock Bolt with the
Wyze Video Doorbell and Chime in the Front Porch Security Bundle. This bundle offers:
- 1080p HD video monitoring of your front porch
- Two-way audio to greet visitors remotely
- Remote lock/unlock and lock history viewing via the Wyze app
- Compatibility with Alexa and Google Assistant for voice control
This all-in-one package ensures your home’s entry points are secure and monitored, providing peace of mind whether you’re home or away.
Summary
The
Wyze Lock Bolt is the perfect Bluetooth deadbolt smart lock for anyone seeking secure, keyless entry with the added convenience of USB-C emergency charging. Its fingerprint sensor, backlit keypad, and robust security features make it a top choice for modern homes. With easy installation and durable design, it’s a smart upgrade for your front door.
What is the Wyze Lock Bolt Bluetooth Deadbolt Smart Lock?
The Wyze Lock Bolt is a Bluetooth-enabled deadbolt smart lock designed to replace your existing deadbolt. It offers keyless entry through an ultra-fast fingerprint reader, a backlit keypad with anti-peep technology, and USB-C emergency charging for added convenience and security.How does the fingerprint recognition work on the Wyze Lock Bolt?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor that unlocks your door in less than a second. You can store up to 50 fingerprints, allowing family members and trusted guests to access your home easily and securely.What is USB-C emergency charging on the Wyze Lock Bolt?
If the Wyze Lock Bolt’s batteries run out, you can use the built-in USB-C emergency charging port to temporarily power the lock. Simply connect a USB-C power source to regain access by entering your code, ensuring you’re never locked out.How long does the Wyze Lock Bolt battery last?
The Wyze Lock Bolt is powered by 4 AA batteries, providing up to 12 months of battery life under normal use. The Wyze app can notify you when the battery is running low.Is the Wyze Lock Bolt weatherproof?
Yes, the Wyze Lock Bolt is built with an IPX5 weatherproof rating, making it suitable for outdoor use and able to withstand various weather conditions.What security features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt is pick-proof by eliminating the need for physical keys. It uses hardware encryption, two-factor authentication in the Wyze app, and anti-peep technology on the keypad to keep your home secure.Can I install the Wyze Lock Bolt myself?
Yes, the Wyze Lock Bolt is designed for easy DIY installation. It replaces your existing deadbolt in about 20 minutes and fits most standard exterior doors.What access options are available with the Wyze Lock Bolt?
You can unlock your door using the fingerprint reader, the backlit keypad, or via Bluetooth through the Wyze app. The lock also supports up to 20 access codes and allows you to generate one-time use codes for guests.Does the Wyze Lock Bolt have an auto-lock feature?
Yes, the Wyze Lock Bolt includes a customizable auto-lock timer that you can set through the Wyze app. This ensures your door locks automatically if you forget.What replacement parts are available for the Wyze Lock Bolt?
Wyze offers several replacement parts for the Lock Bolt, including the interior assembly battery cover, screws, interior assembly metal plate, and a comprehensive replacement part kit compatible with Wyze Lock models.Is the Wyze Lock Bolt compatible with smart home systems?
The Wyze Lock Bolt can be managed via the Wyze app and is compatible with Alexa and Google Assistant when paired with the Wyze Video Doorbell in the Front Porch Security Bundle for voice control and remote management.What is the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell, and Chime. It provides 1080p HD video monitoring, two-way audio, remote lock/unlock, lock history viewing, and smart home integration for comprehensive front door security.
