Best Controller Units for Connecting Wyze Doorbells to Old Chimes
When upgrading your home security with Wyze doorbells, one common challenge is integrating the new smart devices with your existing mechanical door chimes. To ensure seamless compatibility and maintain the classic doorbell sound, choosing the right controller unit or chime accessory is essential. This guide highlights the best Wyze products designed to connect your Wyze doorbell to old chimes effortlessly.
Wyze Chime Controller: The Ideal Bridge for Old Mechanical Chimes
Overview
The
Wyze Chime Controller is a standalone unit specifically designed to work with Wyze Video Doorbell v2 and Duo Cam Doorbell. It acts as a smart interface between your modern Wyze doorbell and traditional mechanical chimes, enabling you to keep your existing chime hardware while enjoying smart doorbell features.
Key Features
- Compatibility: Works with nearly every mechanical chime, making it perfect for older homes.
- Easy Installation: Simple wiring process with a compact design (47mm x 32mm x 15mm) and 13cm wire length.
- Power Requirements: Supports AC16V/AC24V, ≥10VA, suitable for most household chime transformers.
- Durability: Operates reliably in temperatures from -20°C to 50°C.
- Included: Comes with one chime controller unit for quick setup.
The Wyze Chime Controller is the go-to solution if you want to connect your Wyze Video Doorbell v2 or Duo Cam Doorbell to your existing mechanical chime without replacing it.
Wyze Universal Wi-Fi Chime: Wireless Convenience Without Wiring Hassles
Overview
For those who prefer a wireless solution, the
Wyze Universal Wi-Fi Chime offers a fuss-free way to get notified when someone rings your Wyze doorbell. It requires no complicated wiring and plugs directly into a standard power outlet.
Key Features
- Universal Compatibility: Works with all Wyze Cams and doorbells.
- Multiple Tones: Choose from 17 different chime tones to suit your preference.
- Smart Automations: Can chime based on camera detections, such as someone approaching your kitchen or front door.
- Connectivity: Uses Wi-Fi (2.4 GHz) and Bluetooth BLE 5.0 for reliable communication.
- Compact Design: Small footprint (81 x 53 x 38 mm) fits discreetly in any room.
- Indoor Use: Designed for indoor environments with operating temperatures from -4°F to 122°F (-20°C to 50°C).
This chime is perfect if you want to avoid rewiring and still enjoy smart notifications with your Wyze doorbell.
Wyze Video Doorbell v2 with Included Chime Controller: All-in-One Wired Solution
Overview
The
Wyze Video Doorbell v2 is Wyze’s clearest and most capable wired video doorbell, offering 2K resolution and advanced features. It comes bundled with a dedicated
Wyze Chime Controller, making it an excellent choice for users with existing mechanical chimes.
Key Features
- High-Resolution Video: 2K (2048 x 1536) video with a wide 135° horizontal field of view.
- Smart Alerts: Real-time notifications, two-way audio, and motion-activated voice deterrence.
- Chime Controller Included: Ensures compatibility with old mechanical chimes without extra purchases.
- Weather Resistant: Rated IP65 for outdoor durability.
- Storage Options: Supports local microSD storage up to 256GB and cloud storage with Wyze Security Plan.
- Easy Installation: Comes with a full installation kit including wire caps, wall plate, wedge, and screws.
If you want a complete wired doorbell system that integrates smoothly with your old chime, the Wyze Video Doorbell v2 bundle is the best choice.
Wyze Standalone Chime: Simple Accessory for Wyze Wired Doorbells
Overview
The
Wyze Chime is a standalone chime accessory designed to work exclusively with the original Wyze Video Doorbell (wired). It does not support the Pro or v2 models but is a straightforward option for those with the first-generation wired doorbell.
Key Features
- Compatibility: Works only with Wyze Video Doorbell v1 and Wyze Wired Doorbell.
- Classic Doorbell Sounds: Provides traditional chime sounds without smart features.
- Affordable: A budget-friendly option for basic chime needs.
Choose this if you have the original Wyze wired doorbell and want a simple chime accessory.
The Front Porch Security Bundle: Comprehensive Smart Home Solution
Overview
For those looking to upgrade their entire front porch security, the
Front Porch Security Bundle combines the Wyze Video Doorbell, Wyze Chime, and Wyze Lock. This bundle offers a complete smart home experience with video, audio, and remote door locking.
Key Features
- Video Doorbell: 1080p HD video with two-way audio.
- Wyze Chime: Multiple sound options including classic and modern tones.
- Wyze Lock: Remote locking/unlocking and lock history tracking.
- Smart Assistant Integration: Compatible with Alexa and Google Assistant.
- All-in-One: Everything you need for front porch security in one package.
This bundle is ideal if you want a fully integrated smart home entry system with chime compatibility.
Summary
Product | Best For | Compatibility with Old Chimes | Price (USD) |
Wyze Chime Controller | Connecting Wyze Doorbell v2/Duo to old chimes | Nearly all mechanical chimes | 17.99 |
Wyze Universal Wi-Fi Chime | Wireless chime without rewiring | Works with all Wyze doorbells | 19.98 |
Wyze Video Doorbell v2 Bundle | Wired doorbell with included chime controller | Old mechanical chimes via controller | 44.98 |
Wyze Standalone Chime | Basic chime for original Wyze wired doorbell | Only Wyze Video Doorbell v1 | 13.99 |
Front Porch Security Bundle | Complete smart home entry system | Includes Wyze Chime for doorbell | From 123.99 |
Enhance Your Home with the Right Wyze Chime Solution
Choosing the right controller or chime accessory is crucial for integrating your Wyze doorbell with an old mechanical chime. Whether you prefer a wireless chime, a dedicated controller unit, or a full smart home bundle, Wyze offers versatile options to fit your needs.
Experience seamless doorbell notifications and maintain the charm of your traditional chime with Wyze’s smart accessories.
Enhance your home security with Wyze doorbells and compatible chime controllers.
Easy installation of Wyze Video Doorbell v2 with included chime controller.
Complete front porch security with Wyze Video Doorbell, Chime, and Lock.
Make your Wyze doorbell work perfectly with your existing chime by selecting the right controller unit or chime accessory today!
How can I connect my Wyze doorbell to an old mechanical chime?
To connect your Wyze doorbell to an old mechanical chime, use the Wyze Chime Controller. This standalone unit is designed to work with Wyze Video Doorbell v2 and Duo Cam Doorbell, acting as a bridge between your smart doorbell and traditional chime hardware for seamless integration.Which Wyze products are compatible with existing mechanical door chimes?
The Wyze Chime Controller is compatible with nearly all mechanical chimes and works with Wyze Video Doorbell v2 and Duo Cam Doorbell. The Wyze Video Doorbell v2 bundle also includes a chime controller for easy integration with old chimes.What is the Wyze Chime Controller and how does it work?
The Wyze Chime Controller is a compact device that connects your Wyze Video Doorbell v2 or Duo Cam Doorbell to your existing mechanical chime. It ensures your traditional chime rings when someone presses your smart doorbell, without needing to replace your current chime system.Is there a wireless chime option for Wyze doorbells?
Yes, the Wyze Universal Wi-Fi Chime offers a wireless solution for all Wyze doorbells and cameras. It plugs into a standard power outlet, requires no wiring, and provides multiple chime tones and smart automation features.Can I use the Wyze Universal Wi-Fi Chime with any Wyze doorbell?
The Wyze Universal Wi-Fi Chime is universally compatible with all Wyze Cams and doorbells, making it a flexible choice for wireless notifications throughout your home.What is included in the Wyze Video Doorbell v2 bundle?
The Wyze Video Doorbell v2 bundle includes the 2K resolution video doorbell, a dedicated Wyze Chime Controller for compatibility with old mechanical chimes, and a full installation kit with wire caps, wall plate, wedge, and screws.Which Wyze chime accessory should I use with the original Wyze wired doorbell?
For the original Wyze Video Doorbell (wired), use the Wyze Standalone Chime. This accessory is designed specifically for the first-generation Wyze wired doorbell and provides classic doorbell sounds.What is the Front Porch Security Bundle from Wyze?
The Front Porch Security Bundle combines the Wyze Video Doorbell, Wyze Chime, and Wyze Lock for a comprehensive smart home entry system. It offers video, audio, and remote locking features, and is compatible with Alexa and Google Assistant.Do I need to rewire my home to use a Wyze chime with my doorbell?
No, if you choose the Wyze Universal Wi-Fi Chime, you do not need to rewire your home. It plugs directly into a power outlet and connects wirelessly to your Wyze doorbell or camera.What are the power requirements for the Wyze Chime Controller?
The Wyze Chime Controller supports AC16V/AC24V, ≥10VA, making it suitable for most household chime transformers.Are Wyze chime accessories weather resistant?
The Wyze Video Doorbell v2 is rated IP65 for outdoor durability, but the Wyze Chime Controller and Wyze Universal Wi-Fi Chime are designed for indoor use only.Can I customize the chime sound with Wyze chime accessories?
Yes, the Wyze Universal Wi-Fi Chime offers 17 different chime tones to choose from. The Wyze Standalone Chime also provides multiple sound options, including classic and modern tones.
