Affordable Refurbished Outdoor Security Cameras with Color Night Vision and Long Battery Life
When it comes to securing your home or outdoor space without breaking the bank, finding an affordable security camera that offers advanced features like color night vision and long battery life is essential. Wyze offers a range of refurbished outdoor security cameras that combine affordability, durability, and smart technology to keep your property safe day and night.
Wyze Cam v4: The Ultimate Outdoor Security Solution
Wyze Cam v4 stands out as the clearest and most advanced Wyze camera yet, delivering exceptional value for its price.
Key Features:
- 2.5K QHD Resolution: Capture crystal-clear video with Quad HD clarity, ensuring every detail is visible.
- Enhanced Color Night Vision: Unlike traditional black-and-white night vision, Wyze Cam v4 uses enhanced hardware to reveal vibrant colors even in low-light conditions, giving you superhero-like vision after dark.
- Motion-Activated Spotlight & Siren: Automatically light up your yard and deter intruders with a bright spotlight and a loud 99 dB siren.
- IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
- 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without subscription fees.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for seamless streaming.
- Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Easy Installation: Screw-free magnetic mount makes setup quick and tool-free.
Wyze Cam v4 is perfect for homeowners looking for a high-quality, wired outdoor camera with advanced night vision and smart features at an affordable price point.
Durable and weather-resistant for all seasons
Wyze Cam Pan v3: 360° Pan and Tilt with Weatherproof Design
For those who want comprehensive coverage of their outdoor space, the Wyze Cam Pan v3 offers dynamic pan and tilt capabilities combined with rugged outdoor durability.
Highlights:
- 360° Pan and 180° Tilt: Covers every angle of your property with smooth, quiet motorized movement.
- Automatic Motion Tracking: The camera detects and follows moving objects automatically, ensuring nothing escapes its view.
- Color Night Vision with Starlight Sensor: See vibrant colors even in near darkness, enhancing security during nighttime.
- IP65 Weatherproof Rating: Designed to endure rain, snow, and extreme temperatures.
- Two-Way Audio: Communicate through the camera using the Wyze app.
- Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
- Requires Outdoor Power Adapter for Outdoor Use: Ensures continuous power for reliable operation.
Wyze Cam Pan v3 is ideal for users who want a versatile, motorized outdoor camera with excellent night vision and smart tracking features.
Wyze Cam OG: Budget-Friendly Outdoor Camera with Spotlight
If you’re looking for a straightforward, budget-friendly outdoor camera with solid night vision and a built-in spotlight, the Wyze Cam OG is a great choice.
Features:
- 1080p Full HD Video: Clear and smooth video quality for everyday monitoring.
- Color Night Vision: Equipped with 4 IR LEDs and a CMOS-Starlight sensor to provide color images at night.
- Built-in 40 Lumen Spotlight: Illuminates your outdoor area to deter unwanted visitors.
- IP65 Weather Resistance: Reliable performance in various weather conditions.
- Two-Way Audio with Noise Cancellation: Clear communication through the camera.
- 90 dB User-Activated Siren: Adds an extra layer of security.
- Supports up to 256GB microSD Card: Local storage without monthly fees.
- Fast Live Streaming: 50% faster than previous Wyze models.
Wyze Cam OG is perfect for those who want a dependable, easy-to-use outdoor camera with color night vision and spotlight functionality at a very affordable price.
Wyze Cam OG Telephoto: Enhanced Zoom for Detailed Outdoor Surveillance
For users needing detailed zoom capabilities in an outdoor camera, the Wyze Cam OG Telephoto offers a 3x telephoto lens with all the essential features.
Specifications:
- 3x Telephoto Lens: Narrow field of view (27° diagonal) for focused surveillance on distant objects.
- 1080p Video Resolution: Crisp video quality with 20 FPS during the day and 10 FPS at night.
- Color Night Vision: Same CMOS-Starlight sensor technology for vibrant night images.
- IP65 Weather Resistance: Suitable for outdoor use in various climates.
- Two-Way Audio & Siren: Communicate and deter intruders effectively.
- Supports Local Storage: Up to 256GB microSD card compatibility.
- Smart Assistant Integration: Works with Alexa, Google Assistant, and IFTTT.
This camera is ideal for monitoring specific outdoor areas where zoomed-in detail is critical, such as gates, driveways, or backyards.
Why Choose Refurbished Wyze Outdoor Cameras?
Affordable refurbished Wyze cameras provide the same trusted features and reliability as new models but at a fraction of the cost. They are thoroughly tested and certified to ensure quality, making them a smart choice for budget-conscious consumers who want advanced outdoor security.
Summary: Best Affordable Refurbished Outdoor Cameras with Color Night Vision
Model | Resolution | Night Vision Type | Weatherproof | Battery/Power | Special Features | Price Range (Refurbished) |
Wyze Cam v4 | 2.5K QHD | Enhanced Color Night | IP65 | Wired (continuous) | Spotlight, Siren, Wi-Fi 6, Magnetic Mount | ~$36+ |
Wyze Cam Pan v3 | 1080p | Color Night Vision | IP65 | Wired (adapter req.) | 360° Pan/Tilt, Motion Tracking | ~$40+ |
Wyze Cam OG | 1080p | Color Night Vision | IP65 | Wired | Built-in Spotlight, Siren | ~$30+ |
Wyze Cam OG Telephoto | 1080p | Color Night Vision | IP65 | Wired | 3x Telephoto Lens | ~$26+ |
Enhance Your Outdoor Security Today
Investing in a refurbished Wyze outdoor security camera with color night vision and long-lasting power is a cost-effective way to protect your home. Whether you want ultra-clear 2.5K video, 360° coverage, or telephoto zoom, Wyze has an option tailored to your needs and budget.
What are the benefits of choosing a refurbished Wyze outdoor security camera?
Refurbished Wyze outdoor security cameras offer the same trusted features and reliability as new models but at a significantly lower price. Each camera is thoroughly tested and certified to ensure quality, making them a smart and budget-friendly choice for advanced outdoor security.Which Wyze outdoor security camera has the best night vision?
The Wyze Cam v4 features enhanced color night vision, providing vibrant and clear images even in low-light conditions. It uses advanced hardware to deliver superior night-time visibility compared to traditional black-and-white night vision cameras.Are Wyze outdoor security cameras weatherproof?
Yes, all featured Wyze outdoor security cameras, including the Wyze Cam v4, Cam Pan v3, Cam OG, and Cam OG Telephoto, have an IP65 weather resistance rating. This means they are designed to withstand rain, snow, and harsh outdoor conditions.Do Wyze outdoor cameras require a subscription for video recording?
No, Wyze outdoor cameras support local recording to a microSD card (up to 256GB), allowing for 24/7 continuous recording without any monthly subscription fees.What is the video resolution of Wyze outdoor security cameras?
Wyze outdoor security cameras offer different resolutions: the Wyze Cam v4 provides 2.5K QHD resolution for crystal-clear video, while the Wyze Cam Pan v3, Cam OG, and Cam OG Telephoto offer 1080p Full HD video quality.Which Wyze camera is best for 360-degree outdoor coverage?
The Wyze Cam Pan v3 is ideal for comprehensive outdoor coverage, featuring 360° pan and 180° tilt capabilities, automatic motion tracking, and a weatherproof design.Can I use voice assistants with Wyze outdoor security cameras?
Yes, Wyze outdoor security cameras are compatible with popular smart assistants such as Alexa, Google Assistant, and IFTTT, allowing for convenient voice control and automation.Which Wyze camera is best for zooming in on distant objects outdoors?
The Wyze Cam OG Telephoto is designed for detailed outdoor surveillance, featuring a 3x telephoto lens and a narrow 27° field of view, making it perfect for monitoring gates, driveways, or backyards.Do Wyze outdoor cameras have built-in spotlights or sirens?
Yes, several Wyze outdoor cameras include security features such as built-in spotlights and sirens. For example, the Wyze Cam v4 has a motion-activated spotlight and a 99 dB siren, while the Wyze Cam OG features a 40-lumen spotlight and a 90 dB user-activated siren.How easy is it to install a Wyze outdoor security camera?
Wyze outdoor security cameras are designed for easy installation. The Wyze Cam v4, for example, features a screw-free magnetic mount for quick, tool-free setup. Other models may require an outdoor power adapter for continuous operation.What is the price range for refurbished Wyze outdoor security cameras?
Refurbished Wyze outdoor security cameras are very affordable, with prices typically ranging from around $26 for the Wyze Cam OG Telephoto to about $40 for the Wyze Cam Pan v3, depending on the model and features.
