Affordable Refurbished Indoor Smart Cameras with Starlight Sensor and Color Night Vision
Looking for an affordable, high-quality refurbished indoor smart camera that features advanced starlight sensors and vibrant color night vision? Discover the best options from Wyze that combine cutting-edge technology, smart home compatibility, and budget-friendly pricing. These cameras provide crystal-clear video, enhanced night vision, and smart features to keep your home safe and monitored 24/7.
Wyze Cam v4: The Ultimate Indoor Smart Camera with Enhanced Color Night Vision
Stunning 2.5K QHD Resolution & Color Night Vision
Wyze Cam v4 delivers crystal-clear 2.5K Quad HD video, offering unmatched clarity for indoor security. Its enhanced color night vision uses advanced hardware to pierce through darkness, revealing vibrant colors and details that traditional black-and-white night vision cameras miss. This makes it perfect for monitoring your home day and night with vivid imagery.
Smart Features for Ultimate Convenience
- Motion-activated spotlight and 99 dB siren to deter intruders or light your way.
- Wi-Fi 6 support ensures a stronger, more reliable connection.
- Compatibility with Alexa and Google Assistant for seamless smart home integration.
- 24/7 local recording with microSD card support up to 256GB (no subscription required).
- Advanced motion and sound detection with customizable detection zones.
- Smoke and CO alerts notify you instantly if alarms sound.
Easy Setup and Flexible Mounting
Wyze Cam v4 features a screw-free magnetic mount for hassle-free installation anywhere indoors. Its IP65 weather resistance rating also allows for outdoor use with the proper power adapter.
"The clearest Wyze Cam ever made with superhero vision at night."
Enjoy clear two-way audio communication with your pets or family.
Wyze Cam Pan v3: Dynamic 360° Pan & 180° Tilt with Starlight Sensor
Full Room Coverage with Pan & Tilt
Wyze Cam Pan v3 is a versatile indoor/outdoor camera that offers 360° horizontal pan and 180° vertical tilt, allowing you to monitor an entire room or outdoor area with a single device. Its upgraded quiet motor tracks motion automatically, following moving objects smoothly without disturbing your environment.
Enhanced Color Night Vision with Starlight Sensor
Equipped with a starlight sensor, the Pan v3 provides vibrant color night vision, capturing details in low-light conditions that other cameras miss. This makes it ideal for both indoor security and outdoor monitoring when paired with the Wyze Outdoor Power Adapter.
Weather-Resistant & Smart Home Ready
- IP65 weather resistance for reliable outdoor use.
- Motion and sound detection with instant alerts.
- Customizable patrol routes with Pan Scan™.
- Privacy Mode to disable the camera view when needed.
- Two-way audio for real-time communication.
- Compatible with Alexa, Google Assistant, and IFTTT.
"Award-winning pan and tilt security with superhero night vision."
Wyze Cam Pan v3 braves snow and rain, perfect for outdoor security.
Wyze Cam OG: Classic Indoor/Outdoor Camera with CMOS-Starlight Sensor
Reliable 1080p HD Video with Starlight Sensor
Wyze Cam OG features a CMOS-starlight sensor that enhances low-light performance, delivering clear 1080p HD video with color night vision. It uses 4 IR LEDs for night illumination and supports up to 8x digital zoom to focus on important details.
Smart Features for Everyday Security
- Built-in 40-lumen spotlight and 90-decibel siren for added safety.
- Upgraded two-way audio with noise and echo cancellation.
- Supports local storage up to 256GB microSD card.
- Custom detection zones and smoke/CO alerts.
- IP65 weather resistance for indoor or outdoor use.
- Fast live streaming and 3X faster notifications than previous models.
"Next-generation Wyze Cam with quick live-streaming and bright spotlight."
Wyze Cam v4 Outdoor Bundle: Complete Security Solution
For those seeking a ready-to-go package, the Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 camera, a Wyze Outdoor Power Adapter, and a 128GB microSD card for 24/7 local recording. This bundle offers the same advanced 2.5K QHD resolution and enhanced color night vision, optimized for outdoor use with weather resistance and continuous power.
Bundle Highlights
- Enhanced color night vision and motion-activated spotlight.
- Wi-Fi 6 support and smart assistant compatibility.
- Local recording with included 128GB microSD card.
- IP65 weather resistance for reliable outdoor performance.
Why Choose Wyze Refurbished Smart Cameras?
Wyze refurbished cameras provide an affordable way to access premium indoor smart camera technology with features like starlight sensors and color night vision. These cameras are rigorously tested to ensure quality and reliability, making them a smart choice for budget-conscious consumers who don’t want to compromise on security or image quality.
Summary of Key Features
Feature | Wyze Cam v4 | Wyze Cam Pan v3 | Wyze Cam OG | Wyze Cam v4 Outdoor Bundle |
Video Resolution | 2.5K QHD | 2.5K QHD | 1080p HD | 2.5K QHD |
Night Vision | Enhanced Color Night | Color Night Vision | Color Night Vision | Enhanced Color Night |
Sensor Type | Advanced CMOS | CMOS-Starlight Sensor | CMOS-Starlight Sensor | Advanced CMOS |
Field of View | 115.9° diagonal | 360° pan / 180° tilt | 120° | 115.9° diagonal |
Weather Resistance | IP65 | IP65 | IP65 | IP65 |
Two-Way Audio | Yes | Yes | Yes | Yes |
Spotlight & Siren | Yes | Yes | Yes | Yes |
Local Storage Support | Up to 256GB microSD | Up to 256GB microSD | Up to 256GB microSD | Included 128GB microSD |
Smart Assistant Compatible | Alexa, Google | Alexa, Google, IFTTT | Alexa, Google | Alexa, Google |
Price (Single Unit) | $35.98 | $39.98 | $29.98 | $69.99 (Bundle) |
Invest in a Wyze refurbished indoor smart camera with starlight sensor and color night vision today to enjoy affordable, reliable, and smart home security that works day and night.
What are the benefits of buying a refurbished Wyze indoor smart camera?
Refurbished Wyze indoor smart cameras offer premium features like starlight sensors and color night vision at an affordable price. Each camera is rigorously tested for quality and reliability, making them a cost-effective choice for those seeking high-quality home security without compromising on performance.Which Wyze refurbished camera has the best night vision?
The Wyze Cam v4 features enhanced color night vision with advanced hardware, providing vibrant and clear images even in complete darkness. Its starlight sensor technology reveals details and colors that traditional black-and-white night vision cameras miss.Can Wyze refurbished cameras be used outdoors?
Yes, Wyze refurbished cameras such as the Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam OG are IP65 weather-resistant, making them suitable for both indoor and outdoor use when paired with the appropriate power adapter.What is the video resolution of Wyze refurbished smart cameras?
Wyze Cam v4 and Wyze Cam Pan v3 offer 2.5K QHD resolution for crystal-clear video, while Wyze Cam OG provides reliable 1080p HD video quality.Do Wyze refurbished cameras support local video storage?
Yes, all Wyze refurbished cameras support local video storage with microSD cards up to 256GB, allowing for 24/7 continuous recording without the need for a subscription. The Wyze Cam v4 Outdoor Bundle includes a 128GB microSD card.Are Wyze refurbished cameras compatible with smart home assistants?
Wyze refurbished cameras are compatible with Alexa and Google Assistant for seamless smart home integration. The Wyze Cam Pan v3 also supports IFTTT for additional automation options.What smart security features do Wyze refurbished cameras offer?
Wyze refurbished cameras include advanced motion and sound detection, customizable detection zones, motion-activated spotlights, loud sirens, smoke and CO alerts, and two-way audio for real-time communication.How easy is it to install a Wyze refurbished indoor smart camera?
Wyze Cam v4 features a screw-free magnetic mount for hassle-free installation anywhere indoors. All Wyze cameras are designed for easy setup and flexible mounting options.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera, a Wyze Outdoor Power Adapter, and a 128GB microSD card, providing a complete solution for outdoor security with enhanced color night vision and continuous local recording.What is the price range for Wyze refurbished indoor smart cameras?
Wyze refurbished indoor smart cameras are budget-friendly, with prices starting at $29.98 for the Wyze Cam OG, $35.98 for the Wyze Cam v4, $39.98 for the Wyze Cam Pan v3, and $69.99 for the Wyze Cam v4 Outdoor Bundle.
