Affordable Indoor Outdoor Security Cameras with Motion Pan Tilt and Color Night Vision
Looking for an affordable security camera that works both indoors and outdoors, offers motion pan-tilt capabilities, and features vibrant color night vision? Wyze offers a range of smart cameras designed to keep your home safe day and night without breaking the bank. Below, we highlight the best Wyze cameras that meet these needs, combining advanced features, weather resistance, and smart home compatibility.
Wyze Cam v4: The Ultimate Affordable Security Camera
Crystal-Clear 2.5K QHD Resolution & Enhanced Color Night Vision
Wyze Cam v4 delivers stunning 2.5K Quad HD video quality, capturing every detail with vibrant colors even in low-light conditions thanks to its enhanced color night vision. Unlike traditional black-and-white night vision, this camera reveals rich, true-to-life colors after dark, making it easier to identify people and objects.
Motion-Activated Spotlight & Siren
Equipped with a motion-activated spotlight and a 99 dB siren, the Wyze Cam v4 not only records but also deters intruders effectively. The spotlight lights up your property when motion is detected, while the siren can be triggered remotely for added security.
Pan and Tilt Features
While the Wyze Cam v4 itself does not have pan-tilt, it offers a wide field of view (115.9° diagonal) and smart AI auto-zoom with tracking to focus on important motion events, giving you dynamic coverage.
Weather Resistant & Versatile Installation
Rated IP65 for weather resistance, this camera is perfect for both indoor and outdoor use. Its magnetic mount allows for easy installation without tools, and it supports 24/7 local recording with microSD cards up to 256GB.
Smart Home Integration
Compatible with Alexa and Google Assistant, Wyze Cam v4 fits seamlessly into your smart home ecosystem, allowing voice control and automation.
"The clearest Wyze Cam ever made with superhero vision at night."
Wyze Cam v4 providing reliable indoor and outdoor security
Wyze Cam Pan v3: Full 360° Pan and 180° Tilt with Weatherproof Design
Complete Pan and Tilt Coverage
Wyze Cam Pan v3 offers a full 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your room or outdoor area. This camera automatically tracks motion, following moving objects quietly without disturbing your environment.
IP65 Weather Resistance for Outdoor Use
Designed for both indoor and outdoor use, the Pan v3 is fully weatherproof with an IP65 rating. When paired with the Wyze Outdoor Power Adapter (sold separately), it withstands rain, snow, and harsh weather conditions.
Color Night Vision with Starlight Sensor
Equipped with a Starlight Sensor, the Pan v3 delivers vivid color night vision, ensuring you never miss a detail after dark.
Privacy Mode & Two-Way Audio
Privacy Mode lets you disable the camera’s view by pointing it downward when you want to relax without surveillance. Two-way audio allows you to communicate through the camera via the Wyze app, perfect for talking to family or pets.
Customizable Motion Detection
Set custom detection zones and receive instant alerts for motion or sound, including smoke and carbon monoxide alarms.
"Award-winning pan and tilt security, now weatherproof and smarter."
Wyze Cam Pan v3 braving snowy outdoor conditions
Wyze Cam OG: Reliable Indoor/Outdoor Security with Spotlight and Motion Detection
1080p Full HD Video with Color Night Vision
Wyze Cam OG features a 120° field of view and 1080p resolution, delivering clear video day and night. Its 4 IR LEDs combined with a built-in 40-lumen spotlight provide bright color night vision.
Motion Detection & 2-Way Audio
This camera supports motion alerts and two-way audio with noise and echo cancellation, allowing clear communication through the camera.
Weather Resistant & Compact Design
With an IP65 rating, Wyze Cam OG is suitable for indoor and outdoor use. Its compact 1.89-inch cube design makes it easy to place anywhere.
Smart Features
Supports custom detection zones, smoke and CO alerts, and integrates with Alexa, Google Assistant, and IFTTT for smart home control.
"Next generation Wyze Cam with faster live streaming and built-in spotlight."
Wyze Cam OG Telephoto: Zoomed-In Security with Telephoto Lens
3x Telephoto Lens for Detailed Zoom
The Wyze Cam OG Telephoto offers the same great features as the OG model but adds a 3x telephoto lens for focused zoom on distant objects. Perfect for monitoring specific areas with precision.
1080p HD Video & Color Night Vision
Captures clear 1080p video with color night vision using 4 IR LEDs and a built-in spotlight.
Indoor/Outdoor Use with IP65 Rating
Weatherproof and compact, this camera is ideal for versatile placement.
Smart Home Compatibility
Works with Alexa, Google Assistant, and IFTTT, plus supports local storage up to 256GB.
"Zoom in on security with telephoto clarity."
Wyze Cam v4 Home Security Bundle: Complete Protection Package
All the Features of Wyze Cam v4, Plus Extras
This bundle includes multiple Wyze Cam v4 units with 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, and 24/7 local recording.
Large Storage & Smart Detection
Comes with a 128GB microSD card for extended local storage and supports person detection for smarter alerts.
Multiple Mounting Options
Includes stand, wall mount, ceiling mount, and magnetic adhesive mounts for flexible installation indoors or outdoors.
"Get unmatched security with a complete Wyze Cam v4 bundle."
Why Choose Wyze Cameras for Indoor and Outdoor Security?
- Affordable Pricing: High-end features at budget-friendly prices.
- Color Night Vision: See vibrant colors even in the dark.
- Motion Pan and Tilt: Track movement automatically with Pan v3.
- Weather Resistant: IP65 rating ensures durability in all weather.
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
- Easy Installation: Magnetic mounts and wireless setup options.
- Two-Way Audio: Communicate through your camera anytime.
- Local and Cloud Storage: Flexible recording options with microSD and subscription plans.
Wyze cameras provide a perfect balance of affordability, advanced technology, and versatility for anyone looking to secure their home or business both indoors and outdoors.
Summary Table of Key Features
Model | Resolution | Pan & Tilt | Color Night Vision | Weather Resistant | Price Range |
Wyze Cam v4 | 2.5K QHD | No (AI Auto-Zoom) | Yes | IP65 | $35.98+ |
Wyze Cam Pan v3 | 1080p | 360° Pan, 180° Tilt | Yes | IP65 | $39.98+ |
Wyze Cam OG | 1080p | No | Yes | IP65 | $29.98+ |
Wyze Cam OG Telephoto | 1080p | No | Yes | IP65 | $25.98+ |
Wyze Cam v4 Bundle | 2.5K QHD | No (AI Auto-Zoom) | Yes | IP65 | $169.99 |
Secure your home with Wyze’s affordable, feature-packed indoor/outdoor cameras that offer motion pan tilt and stunning color night vision. Whether you want full panoramic coverage or crystal-clear zoomed-in views, Wyze has the perfect camera for your security needs.
What are the best affordable indoor and outdoor security cameras with color night vision?
Wyze offers a range of affordable security cameras suitable for both indoor and outdoor use, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto. All these models feature color night vision, weather resistance, and smart home integration.Does Wyze Cam v4 have pan and tilt features?
The Wyze Cam v4 does not have mechanical pan and tilt, but it offers a wide 115.9° diagonal field of view and smart AI auto-zoom with tracking to focus on important motion events, providing dynamic coverage.Which Wyze camera offers full 360° pan and 180° tilt?
The Wyze Cam Pan v3 provides full 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your indoor or outdoor space. It also features automatic motion tracking.Are Wyze security cameras weather resistant?
Yes, Wyze security cameras such as the Cam v4, Cam Pan v3, Cam OG, and Cam OG Telephoto are rated IP65 for weather resistance, making them suitable for both indoor and outdoor use.Do Wyze cameras have color night vision?
All current Wyze camera models highlighted, including the Cam v4, Cam Pan v3, Cam OG, and Cam OG Telephoto, feature enhanced color night vision, allowing you to see vibrant, true-to-life colors even in low-light conditions.Can Wyze cameras be integrated with smart home systems?
Yes, Wyze cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What storage options are available for Wyze security cameras?
Wyze cameras support local storage with microSD cards up to 256GB for 24/7 recording, and also offer cloud storage options through subscription plans.How easy is it to install Wyze security cameras?
Wyze cameras are designed for easy installation, featuring magnetic mounts and wireless setup options. Multiple mounting accessories are available for flexible placement indoors or outdoors.Do Wyze cameras support two-way audio?
Yes, Wyze cameras such as the Cam Pan v3 and Cam OG support two-way audio, allowing you to communicate through the camera using the Wyze app.What is the difference between Wyze Cam OG and Wyze Cam OG Telephoto?
The Wyze Cam OG Telephoto includes a 3x telephoto lens for detailed zoom on distant objects, while the standard Wyze Cam OG offers a wider 120° field of view. Both models feature 1080p HD video, color night vision, and weather resistance.What comes with the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 units, a 128GB microSD card for extended local storage, and various mounting options such as stand, wall mount, ceiling mount, and magnetic adhesive mounts.Can Wyze cameras detect smoke or carbon monoxide alarms?
Yes, Wyze cameras like the Cam Pan v3 and Cam OG can send instant alerts when they detect the sound of smoke or carbon monoxide alarms.Do Wyze cameras have motion-activated spotlights and sirens?
The Wyze Cam v4 features a motion-activated spotlight and a 99 dB siren to deter intruders. The Cam OG also includes a built-in spotlight for enhanced night vision.Are Wyze cameras suitable for both home and business security?
Yes, Wyze cameras are versatile and affordable, making them ideal for securing both homes and businesses with advanced features like color night vision, motion tracking, and weather resistance.
