Affordable 1080p DIY Home Security Cameras with Full Color Night Vision
Protecting your home has never been easier or more affordable. If you're searching for reliable DIY home security cameras that offer crisp 1080p resolution and full-color night vision, Wyze offers a range of smart cameras designed to fit your budget and security needs. From versatile indoor/outdoor models to innovative lighting-integrated cameras, these options provide advanced features without breaking the bank.
Wyze Cam OG – Classic 1080p with Color Night Vision
Crisp 1080p Resolution & Enhanced Night Vision
Wyze Cam OG delivers sharp 1080p HD video with a 120° field of view, ensuring you capture wide, detailed footage of your home. Equipped with a CMOS-Starlight Sensor and 4 IR LEDs, it provides full-color night vision that reveals vibrant details even in low-light conditions, far surpassing traditional black-and-white night vision.
Smart Features for Everyday Security
- Built-in spotlight (40 lumens) and 90-decibel siren for deterrence
- Upgraded two-way audio with noise and echo cancellation for clear communication
- Supports local storage up to 256GB microSD (no subscription required)
- Custom detection zones and instant smoke & CO alerts keep you informed
- IP65 weather resistance for reliable indoor/outdoor use
Wyze Cam OG is perfect for those who want a straightforward, dependable 1080p camera with full-color night vision and smart alerts.
Wyze Cam Pan v3 – 360° Pan & Tilt with Color Night Vision
Weather-resistant Wyze Cam Pan v3 keeps watch in all seasons
Complete Coverage with Pan, Tilt & Motion Tracking
Wyze Cam Pan v3 offers a full 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your room or yard. Its automatic motion tracking quietly follows movement, ensuring nothing escapes its view.
Brilliant Color Night Vision & Weatherproof Design
Thanks to its Starlight Sensor, this camera provides vivid color night vision, capturing details that traditional IR cameras miss. Rated IP65 for weather resistance, it’s suitable for outdoor use when paired with the Wyze Outdoor Power Adapter.
Additional Highlights
- Two-way audio for real-time conversations
- Customizable patrol routes with Pan Scan™
- Privacy Mode to disable camera view instantly
- Local storage support and smart notifications
Wyze Cam Pan v3 is ideal for users who want dynamic, wide-area surveillance with full-color night vision and weatherproof durability.
Wyze Cam OG Telephoto – Zoom in on Details with 1080p Clarity
Telephoto Lens for Focused Surveillance
The Wyze Cam OG Telephoto features a 3x telephoto lens that narrows the field of view to capture distant objects with precision. It maintains 1080p resolution and full-color night vision, making it perfect for monitoring specific areas like driveways or entryways.
Key Features
- 1920 x 1080 video resolution with 20 FPS daytime and 10 FPS nighttime
- 4 IR LEDs for enhanced night vision
- Noise and echo-canceling two-way audio
- IP65 weather resistance for indoor/outdoor use
- Supports up to 256GB microSD local storage
This camera is a great choice if you need detailed zoomed-in footage without sacrificing night vision quality.
Wyze Bulb Cam – 2-in-1 Security Camera and Smart Light
Wyze Bulb Cam blends security and lighting seamlessly
Innovative Security Meets Smart Lighting
Wyze Bulb Cam combines a 2K HD security camera with a smart LED light bulb, providing bright illumination and clear video surveillance in one device. It supports full-color night vision, so you get vibrant footage even in the darkest conditions.
Features That Brighten Your Security
- 2K HD video resolution with color night vision
- Instant motion alerts and local video storage (no subscription needed)
- Fits most standard light fixtures for easy installation
- Control lighting remotely via the Wyze app
Perfect for outdoor areas like porches or garages, the Bulb Cam offers a discreet and effective security solution with the added benefit of smart lighting.
Why Choose Wyze for Your DIY Home Security?
Affordable, feature-rich, and easy to install, Wyze cameras empower you to build a comprehensive home security system without professional help or high costs.
- Full Color Night Vision: See more detail and color in low light, improving identification and deterrence.
- 1080p and Higher Resolutions: Clear, crisp video to capture important details.
- Weather Resistance: Many models rated IP65 for reliable outdoor use.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless control.
- Local Storage Options: Save footage without mandatory subscriptions.
Wyze’s lineup offers flexible options to suit any home environment, whether you want wide coverage, zoomed-in detail, or integrated lighting.
Summary of Affordable 1080p Full Color Night Vision Cameras
Camera Model | Resolution | Night Vision Type | Special Features | Price Range (Approx.) |
Wyze Cam OG | 1080p | Full Color Night Vision | Spotlight, Siren, IP65 Weatherproof | $29.98+ |
Wyze Cam Pan v3 | 1080p | Full Color Night Vision | 360° Pan/Tilt, Motion Tracking | $39.98+ |
Wyze Cam OG Telephoto | 1080p | Full Color Night Vision | 3x Telephoto Zoom | $25.98+ |
Wyze Bulb Cam | 2K HD | Full Color Night Vision | 2-in-1 Light & Camera | $49.98 |
Conclusion
For affordable, high-quality DIY home security cameras with full-color night vision, Wyze offers some of the best options on the market. Whether you want a versatile pan-and-tilt camera, a telephoto zoom for focused monitoring, or a smart bulb camera that doubles as a light, Wyze has you covered with easy setup, smart features, and reliable performance.
Secure your home day and night with vibrant, detailed video and smart alerts — all without breaking your budget.
What are the best affordable 1080p home security cameras with full color night vision?
Wyze offers a range of affordable DIY home security cameras with crisp 1080p resolution and full-color night vision. Popular models include the Wyze Cam OG, Wyze Cam Pan v3, Wyze Cam OG Telephoto, and Wyze Bulb Cam, each designed to provide advanced features and reliable performance without breaking the bank.How does full color night vision work on Wyze security cameras?
Wyze security cameras use advanced CMOS-Starlight Sensors and IR LEDs to deliver full-color night vision. This technology allows the cameras to capture vibrant, detailed footage even in low-light conditions, far surpassing traditional black-and-white night vision.What features does the Wyze Cam OG offer for home security?
The Wyze Cam OG provides 1080p HD video, a 120° field of view, full-color night vision, a built-in spotlight and siren, upgraded two-way audio, custom detection zones, instant smoke and CO alerts, IP65 weather resistance, and supports local storage up to 256GB microSD without requiring a subscription.Can Wyze security cameras be used outdoors?
Yes, many Wyze cameras, including the Wyze Cam OG, Wyze Cam Pan v3, and Wyze Cam OG Telephoto, are rated IP65 for weather resistance, making them suitable for both indoor and outdoor use.What is the Wyze Cam Pan v3 and how does it provide complete coverage?
The Wyze Cam Pan v3 is a 1080p security camera with 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your space. It features automatic motion tracking, full-color night vision, weatherproof design, two-way audio, customizable patrol routes, privacy mode, and local storage support.What makes the Wyze Cam OG Telephoto ideal for focused surveillance?
The Wyze Cam OG Telephoto features a 3x telephoto lens that narrows the field of view, enabling you to capture distant objects with precision. It maintains 1080p resolution, full-color night vision, and is perfect for monitoring specific areas like driveways or entryways.What is the Wyze Bulb Cam and how does it enhance home security?
The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED light bulb. It offers full-color night vision, instant motion alerts, local video storage, easy installation in standard light fixtures, and remote lighting control via the Wyze app, making it ideal for porches or garages.Do Wyze cameras require a subscription for video storage?
No, Wyze cameras support local storage via microSD cards (up to 256GB), allowing you to save footage without a mandatory subscription. This makes them a cost-effective solution for home security.Are Wyze security cameras compatible with smart home systems?
Yes, Wyze cameras are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, enabling seamless integration and control within your smart home ecosystem.What are the price ranges for Wyze home security cameras?
Wyze home security cameras are designed to be affordable, with prices starting at approximately $25.98 for the Wyze Cam OG Telephoto, $29.98 for the Wyze Cam OG, $39.98 for the Wyze Cam Pan v3, and $49.98 for the Wyze Bulb Cam.Why should I choose Wyze for my DIY home security system?
Wyze offers affordable, feature-rich, and easy-to-install security cameras with full-color night vision, high-definition video, weather resistance, smart home integration, and local storage options. This makes Wyze an excellent choice for building a comprehensive DIY home security system without professional installation or high costs.
