Best 1080p Indoor Cameras with Invisible Infrared for Home
Best 1080p Indoor Cameras with Invisible Infrared Lights for Home Security
When it comes to securing your home, having a reliable indoor camera with clear 1080p resolution and invisible infrared night vision is essential. Invisible infrared lights ensure discreet monitoring without disturbing your household or alerting intruders. Below, we highlight top Wyze cameras that perfectly fit this need, combining high-quality video, smart features, and seamless integration for your home security.
Wyze Cam Pan v3: Versatile 1080p Indoor/Outdoor Security Camera
Key Features and Benefits
  • 1080p Full HD Resolution: Capture crisp and clear video footage indoors with 121° diagonal field of view.
  • Invisible Infrared Night Vision: Equipped with color night vision using a Starlight sensor, it delivers detailed images in low light without visible IR glow.
  • 360° Pan and 180° Tilt: Covers every corner of your room with smooth pan and tilt functionality, controlled remotely via the Wyze app.
  • Automatic Motion Tracking: The camera detects motion, follows it quietly, and records automatically, ensuring no suspicious activity goes unnoticed.
  • Two-Way Audio: Communicate directly through the camera with clear sound, perfect for interacting with family or pets.
  • Privacy Mode: When you want privacy, the camera physically points downward and disables recording.
  • IP65 Weather Resistant: Though perfect for indoor use, it can also be used outdoors with the optional Wyze Outdoor Power Adapter.
  • Local and Cloud Storage: Supports microSD cards up to 256GB for continuous local recording, plus optional cloud storage with Cam Plus.
The Wyze Cam Pan v3 is a smart choice for those who want a flexible indoor camera that can also brave outdoor conditions when needed.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 offers weather resistance and versatile placement options.
Wyze Cam v4: Enhanced 1080p Indoor Camera with Invisible Infrared Lights
Why Choose Wyze Cam v4?
  • 1080p HD Video with Enhanced Color Night Vision: See vibrant colors even in near darkness thanks to advanced hardware and Wide Dynamic Range (WDR).
  • Invisible Infrared LEDs: Night vision is clear and discreet, avoiding the typical red glow of traditional IR cameras.
  • Motion-Activated Spotlight and Siren: Adds an extra layer of security by illuminating dark areas and deterring intruders.
  • Two-Way Audio with Advanced Audio Coding: Enjoy crystal-clear conversations through the camera.
  • IP65 Weather Resistance: Suitable for indoor and outdoor use with the right power setup.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection for smooth video streaming.
  • Screw-Free Magnetic Mount: Easy installation without tools.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Wyze Cam v4 is perfect for users who want a high-performance indoor camera with invisible infrared night vision and smart spotlight features for enhanced home security.
Wyze Cam v4 two-way audio with pet Communicate easily with family or pets using Wyze Cam v4’s two-way audio.
The Front Porch Security Bundle: Complete 1080p Home Security Solution
Bundle Highlights
  • Wyze Video Doorbell: 1080p HD video with invisible 940nm infrared LEDs for night vision, allowing you to monitor your front porch clearly without visible IR glow.
  • Two-Way Audio: Speak and listen through the doorbell to greet visitors or deter unwanted guests.
  • Wyze Lock: Control your door lock remotely and monitor lock history via the Wyze app.
  • Wyze Chime: Customizable doorbell sounds with multiple tones and an intruder alarm.
  • IP65 Weather Resistance: Designed to withstand outdoor conditions.
  • Smart Home Compatibility: Works with Alexa and Google Assistant for seamless integration.
This bundle is ideal for those looking to secure their home's entry point with 1080p video and invisible infrared night vision, combined with smart lock control for full front porch security.
Why Choose Wyze Cameras for Your Home Security?
Wyze cameras stand out for their combination of affordability, advanced features, and user-friendly design. Their invisible infrared lights provide discreet night vision, ensuring your home is monitored without drawing attention. With options like pan and tilt, motion tracking, two-way audio, and smart home compatibility, Wyze offers comprehensive solutions for indoor security needs.
Summary of 1080p Indoor Cameras with Invisible Infrared Lights
ProductResolutionNight Vision TypePan & TiltTwo-Way AudioWeather ResistantLocal StoragePrice (Starting)
Wyze Cam Pan v31080pColor Night Vision (Invisible IR)YesYesYes (IP65)microSD up to 256GB$39.98
Wyze Cam v41080pEnhanced Color Night Vision (Invisible IR)NoYesYes (IP65)microSD up to 256GB$35.98
Front Porch Security Bundle1080p (Doorbell)Invisible IR LEDs (940nm)NoYesYes (IP65)Cloud & Local$124.96+
Invest in a Wyze indoor camera with invisible infrared lights today to enjoy clear, discreet, and reliable home security around the clock.
FeatureWyze Cam Pan v3Wyze Cam v4The Front Porch Security Bundle
TypeIndoor/Outdoor Pan & Tilt Security CameraIndoor/Outdoor Wired Security CameraSmart Home Front Porch Security Bundle
Resolution1080p HD2.5K QHD (2560x1440)1080p HD (Video Doorbell)
Field of View360° pan, 180° tilt115.9° (D) x 98.5° (H) x 53.1° (V)120° Vertical x 88° Horizontal (Video Doorbell)
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionInfrared LED Night Vision (Video Doorbell)
Weather ResistanceIP65 (requires Outdoor Power Adapter for outside use)IP65 Weather ResistantIP65 Weather Resistant (Video Doorbell)
AudioTwo-Way AudioEnhanced Two-Way Talk with Noise/Echo CancellationTwo-Way Audio (Video Doorbell)
Pan & TiltYes (360° pan, 180° tilt)NoNo
SpotlightNo (sold separately)Motion-activated SpotlightNo
SirenNoBuilt-in Siren (99 dB)No
Motion TrackingAutomatic motion tracking with quiet motorAI Auto-Zoom with Smart FocusMotion detection with alerts
Local StoragemicroSD card support up to 256GBmicroSD card support up to 512GBNot applicable (Video Doorbell stores video via cloud/local)
Cloud StorageCam Plus subscription availableCam Plus subscription availableNot specified
ConnectivityWired (requires power adapter)Wired (Wi-Fi 6 support)Wi-Fi 2.4 GHz (Video Doorbell)
Smart Home IntegrationAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Additional FeaturesPrivacy Mode, Pan Scan™ waypoints, Smoke & CO alerts24/7 local recording, Wide Dynamic Range (WDR), Smoke & CO alertsRemote lock/unlock with Wyze Lock, Lock history, Chime sounds
Included ItemsCamera only (Outdoor Power Adapter sold separately)Camera only (Outdoor Power Adapter sold separately)Wyze Lock, Wyze Lock Gateway, Wyze Video Doorbell, Wyze Chime, accessories
Price (Single Unit)$39.98$35.98From $123.99 (varies by bundle)
What are the best 1080p indoor cameras with invisible infrared lights for home security?The best 1080p indoor cameras with invisible infrared lights for home security include the Wyze Cam Pan v3 and Wyze Cam v4. Both models offer clear 1080p HD video, invisible infrared night vision for discreet monitoring, and advanced features like two-way audio, motion tracking, and smart home integration.
How does invisible infrared night vision work in Wyze cameras?Invisible infrared night vision in Wyze cameras uses IR LEDs that do not emit a visible red glow, allowing for discreet monitoring in low-light conditions. This ensures that the camera can capture clear footage at night without disturbing people or alerting intruders.
What are the key features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 features 1080p Full HD resolution, invisible infrared night vision with a Starlight sensor, 360° pan and 180° tilt, automatic motion tracking, two-way audio, privacy mode, IP65 weather resistance, and support for local and cloud storage.
Does the Wyze Cam v4 support invisible infrared night vision?Yes, the Wyze Cam v4 is equipped with invisible infrared LEDs for night vision, providing clear and discreet video footage in low-light environments without the typical red glow of traditional IR cameras.
Can Wyze indoor cameras be used outdoors?Yes, both the Wyze Cam Pan v3 and Wyze Cam v4 are IP65 weather resistant, making them suitable for both indoor and outdoor use when paired with the appropriate power adapter.
What storage options are available for Wyze indoor cameras?Wyze indoor cameras support local storage via microSD cards up to 256GB for continuous recording. Additionally, cloud storage is available through the optional Cam Plus subscription.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell with 1080p HD video and invisible 940nm infrared LEDs, Wyze Lock for remote door control, Wyze Chime with customizable sounds, and smart home compatibility with Alexa and Google Assistant.
Do Wyze cameras offer two-way audio?Yes, both Wyze Cam Pan v3 and Wyze Cam v4 offer two-way audio, allowing you to communicate clearly with family members, pets, or visitors directly through the camera.
Are Wyze cameras compatible with smart home systems?Yes, Wyze cameras are compatible with popular smart home systems, including Alexa, Google Assistant, and IFTTT, enabling voice control and automation.
Why should I choose Wyze cameras for home security?Wyze cameras are an excellent choice for home security due to their combination of affordability, advanced features like invisible infrared night vision, motion tracking, two-way audio, and seamless smart home integration. They provide reliable and discreet monitoring for your home.
What are the main differences between the Wyze Cam Pan v3 and the Wyze Cam v4?Can you explain how the motion tracking feature works on the Wyze Cam Pan v3?Do you have any deals, ongoing sales, discounts, or promotions available for Wyze cameras?
