High-Resolution Weatherproof Security Cameras with Color Night Vision
High Resolution Weatherproof Indoor Outdoor Security Cameras with Color Night Vision, Battery, and Floodlight
When it comes to securing your home or business, having a reliable security camera that performs flawlessly in all conditions is essential. Whether you need crystal-clear high-resolution video, weatherproof durability, color night vision, battery operation, or integrated floodlights, Wyze offers a range of cutting-edge cameras designed to meet your needs both indoors and outdoors. Explore the best Wyze security cameras that combine these features to keep your property safe day and night.
Wyze Cam v4: The Ultimate 2.5K QHD Weatherproof Security Camera
Wyze Cam v4 stands out as the clearest Wyze Cam ever made, delivering stunning 2.5K Quad High Definition video resolution. This wired camera is perfect for both indoor and outdoor use thanks to its IP65 weather resistance, allowing it to withstand rain, snow, and harsh weather conditions.
Key Features:
  • 2.5K QHD Resolution: Capture every detail with crystal-clear video quality.
  • Enhanced Color Night Vision: See vibrant colors even in low-light or nighttime environments, surpassing traditional black-and-white night vision.
  • Motion-Activated Spotlight & Siren: Deter intruders with a built-in spotlight and a loud 99 dB siren.
  • Wide Dynamic Range (WDR): Enjoy rich, vibrant colors and balanced lighting in all conditions.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription fees.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Easy Installation: Screw-free magnetic mount for quick setup.
Wyze Cam v4 is ideal for users who want a high-resolution, weatherproof camera with color night vision and integrated floodlight capabilities. Wyze Cam v4 Outdoor Use Wyze Cam v4 installed outdoors, providing reliable security day and night.
Wyze Cam Pan v3: Weatherproof 360° Pan & Tilt with Color Night Vision
For those who want comprehensive coverage with a single camera, the Wyze Cam Pan v3 offers a fully weatherproof design (IP65 rated) suitable for indoor and outdoor use (requires outdoor power adapter sold separately). This camera features 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your property.
Highlights:
  • 360° Pan & 180° Tilt: Complete coverage with smooth, quiet motorized movement.
  • Automatic Motion Tracking: The camera detects and follows moving objects automatically.
  • Color Night Vision: Equipped with a Starlight sensor for vivid nighttime color footage.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward.
  • Two-Way Audio: Communicate through the camera with clear sound.
  • IP65 Weather Resistance: Built to endure rain, snow, and outdoor elements.
  • Custom Detection Zones: Focus alerts on specific areas of interest.
  • Local Storage Support: Compatible with microSD cards up to 256GB.
This camera is perfect for users who want dynamic, wide-area surveillance with color night vision and weatherproof reliability. Wyze Cam Pan v3 in Snow Wyze Cam Pan v3 performing flawlessly outdoors in snowy weather.
Wyze Cam Floodlight v2: Powerful 2K Video with 2800 Lumens Floodlight
If you want to combine high-resolution video surveillance with powerful lighting, the Wyze Cam Floodlight v2 is an excellent choice. This hardwired outdoor camera features a bright 2800 lumens LED floodlight and 2K video resolution with color night vision, making it perfect for illuminating and monitoring driveways, yards, and entryways.
Features at a Glance:
  • 2K Video Resolution: Crisp 2304 x 1296 video quality with 160° wide-angle view.
  • Color Night Vision: See clear, colorful images even in complete darkness.
  • 2800 Lumens Dimmable Floodlight: Bright, adjustable lighting to deter intruders and light your property.
  • AI-Powered Light Control: Automatically adjusts lighting based on motion and ambient light.
  • Two-Way Audio: Built-in microphone and speaker for communication.
  • 105 dB Siren: Loud alarm to scare off unwanted visitors.
  • IP65 Weather Resistance: Designed to withstand outdoor conditions year-round.
  • 24/7 Local Storage: Supports microSD cards up to 256GB.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • Dusk-to-Dawn Automation: Automatically turns on/off based on natural light.
Wyze Cam Floodlight v2 is ideal for those who want a security camera with integrated floodlighting and high-resolution color night vision for outdoor protection. Wyze Cam Floodlight v2 Lighting Driveway Wyze Cam Floodlight v2 illuminating a driveway with motion-activated lighting.
Additional Options: Wyze Cam OG and Wyze Cam OG Telephoto
For users seeking reliable indoor/outdoor cameras with solid 1080p resolution and spotlight features, the Wyze Cam OG and Wyze Cam OG Telephoto offer great value.
  • Wyze Cam OG: 1080p video, built-in 40 lumen spotlight, IP65 weather resistance, two-way audio, and 90 dB siren.
  • Wyze Cam OG Telephoto: Similar to OG but with a 3x telephoto lens for zoomed-in views, perfect for detailed monitoring.
Both models support local storage and smart assistant integration, making them versatile for various security needs.
Why Choose Wyze Security Cameras?
Wyze security cameras combine advanced technology with affordability, offering high-resolution video, color night vision, weatherproof designs, and smart home compatibility. Whether you want a wired or battery-powered solution, floodlight integration, or panoramic coverage, Wyze has a camera tailored for your security needs.
With features like motion-activated spotlights, AI-powered alerts, and easy installation, Wyze cameras provide peace of mind and comprehensive protection for your home or business.
Summary of Featured Cameras
Camera ModelResolutionWeatherproofColor Night VisionFloodlightPan & TiltPower Source
Wyze Cam v42.5K QHD (2560p)IP65YesYesNoWired
Wyze Cam Pan v32.5K QHD (2560p)IP65YesNoYesWired (adapter req)
Wyze Cam Floodlight v22K (2304 x 1296)IP65YesYes (2800 lumens)NoHardwired
Wyze Cam OG1080pIP65IR Night VisionYes (40 lumens)NoWired
Wyze Cam OG Telephoto1080pIP65IR Night VisionYes (40 lumens)NoWired
Secure your property with Wyze’s high-resolution, weatherproof security cameras featuring color night vision and floodlights. Choose the model that fits your needs and enjoy smart, reliable protection around the clock.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2Wyze Cam OGWyze Cam v4 Home Security Bundle
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p+)2K (2304x1296)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt160° diagonal120° diagonalDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionEnhanced Color Night Vision + IR LEDsColor Night Vision (Starlight Sensor)Color Night Vision4 IR LEDs (850nm)4 IR LEDs + 2 white spotlight LEDs (72 lumens)
AudioEnhanced 2-way talk, 99dB sirenTwo-way audioBuilt-in speaker & mic, 2-way talkBuilt-in speaker & mic, noise & echo cancellationImproved 2-way audio, built-in siren
SpotlightMotion-activated spotlightNo2 dimmable LED light panelsBuilt-in spotlight (40 lumens)Motion-activated spotlight
SirenYes, 99dBNo105dB90dB user-activated sirenYes
Weather ResistanceIP65IP65IP65IP65IP65
Power SourceWired (Indoor USB power adapter included)Wired (Outdoor adapter sold separately)HardwiredWired (Indoor power adapter)Wired (Indoor power adapter)
Wi-Fi Support2.4 GHz & Wi-Fi 62.4 GHz2.4 GHz2.4 GHz2.4 GHz & Wi-Fi 6
Local StoragemicroSD up to 512GB (sold separately)microSD up to 256GB (sold separately)microSD up to 256GBmicroSD up to 256GBmicroSD 128GB included
Cloud StorageSubscription availableSubscription availableNot specifiedNot specifiedNot specified
Motion & Sound DetectionYesYesYesYesYes
Motion Detection ZonesYesYesNot specifiedYesYes
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Dimensions2in x 2in x 2 3/8in (51 x 51 x 60 mm)Not specified9.5in x 7.7in x 7.0in (24.13 x 19.56 x 17.78 cm)1.89in x 1.89in x 1.89in (48 mm)2in x 2in x 2 3/8in (51 x 51 x 60 mm)
Weight0.49 lb (222 g)Not specified2.76 lbs (1.25 kg)4.1 oz (116 g)0.49 lb (222 g)
Additional FeaturesAI Auto-Zoom, Bluetooth 5.2, Wide Dynamic Range (WDR), Smoke & CO alertsAuto motion-tracking, Privacy Mode, Pan Scan™ Patrol, Smoke & CO alertsAmbient Light Mode, AI-Powered Light Control, Dusk-to-Dawn automation3X faster notifications, built-in spotlightBundle includes Wyze Cam v4, Outdoor Power Adapter, 128GB microSD card
Price (Single Unit)$35.98$39.98$89.98$29.98$169.99 (bundle)
What are the best Wyze security cameras for indoor and outdoor use?Wyze offers several high-resolution, weatherproof security cameras suitable for both indoor and outdoor use, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Cam OG, and Wyze Cam OG Telephoto. These cameras feature color night vision, motion-activated spotlights or floodlights, and smart home integration.
Does Wyze offer security cameras with color night vision?Yes, Wyze security cameras such as the Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam Floodlight v2 feature enhanced color night vision, allowing you to see vivid, colorful images even in low-light or nighttime conditions.
Are Wyze security cameras weatherproof?All featured Wyze security cameras, including Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Cam OG, and Wyze Cam OG Telephoto, are IP65 weather resistant. This means they are designed to withstand rain, snow, and harsh outdoor conditions.
Which Wyze camera has a built-in floodlight?The Wyze Cam Floodlight v2 features a powerful 2800 lumens dimmable LED floodlight, providing bright, adjustable lighting for outdoor security. The Wyze Cam OG and Wyze Cam OG Telephoto also include a built-in 40 lumen spotlight.
What is the video resolution of Wyze security cameras?Wyze security cameras offer various resolutions: Wyze Cam v4 and Wyze Cam Pan v3 provide 2.5K QHD (2560p) resolution, Wyze Cam Floodlight v2 offers 2K (2304 x 1296) resolution, and Wyze Cam OG and Wyze Cam OG Telephoto deliver 1080p Full HD video.
Do Wyze cameras support local video storage?Yes, all featured Wyze cameras support local video storage via microSD cards up to 256GB, allowing for 24/7 continuous recording without subscription fees.
Can Wyze security cameras be integrated with smart home systems?Wyze security cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, enabling voice control and automation.
Does Wyze offer cameras with pan and tilt functionality?Yes, the Wyze Cam Pan v3 features 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your property with smooth, motorized movement.
Are there battery-powered Wyze security cameras?While the content mentions battery operation as a feature to look for, the specific models highlighted (Wyze Cam v4, Cam Pan v3, Floodlight v2, OG, and OG Telephoto) are wired or hardwired. For battery-powered options, please check Wyze’s full product lineup.
What security features do Wyze cameras offer to deter intruders?Wyze cameras include motion-activated spotlights or floodlights, loud sirens (up to 105 dB), and AI-powered alerts to deter intruders and provide real-time notifications.
How easy is it to install Wyze security cameras?Wyze cameras are designed for easy installation, with features like screw-free magnetic mounts (Wyze Cam v4) and simple setup processes. Some models may require a compatible outdoor power adapter.
What is the difference between Wyze Cam OG and Wyze Cam OG Telephoto?The Wyze Cam OG offers 1080p video, a built-in 40 lumen spotlight, and a wide-angle view, while the Wyze Cam OG Telephoto features a 3x telephoto lens for zoomed-in, detailed monitoring. Both are weatherproof and support local storage.
What are the key features of the Wyze Cam v4?Can you tell me more about the color night vision capabilities of the Wyze Cam v4?Do you have any ongoing sales or discounts for the Wyze Cam v4?
