Wyze Wildfire Filter Subscription Service for Reducing Wildfire Smoke Pollutants
Wildfire smoke can severely impact indoor air quality, introducing harmful pollutants that affect your health and comfort. Wyze offers a specialized solution with its
Wyze Air Purifier and
Wyze Air Filter equipped with the
Wildfire Filter variant, designed specifically to combat wildfire smoke pollutants and improve the air you breathe.
Wyze Air Purifier with Wildfire Filter: Advanced Smoke Protection
Powerful Air Cleaning Performance
The Wyze Air Purifier is engineered to deliver premium air purification with a Clean Air Delivery Rate (CADR) of
342 m³/h (201 CFM) for wildfire smoke particles. This means it can efficiently clean the air in rooms sized between
450 to 550 square feet, making it ideal for living rooms, bedrooms, or home offices.
Specialized Wildfire Filter
The Wildfire Filter is a special-use filter variant designed to target smoke generated from wildfires, industrial emissions, and traffic pollution. It features:
- HEPA-grade filtration capturing 99.97% of particulate matter including fine smoke particles.
- Activated carbon layer to absorb harmful gases and odors associated with wildfire smoke.
- High TVOC removal efficiency of 97.1%, reducing volatile organic compounds that can irritate your respiratory system.
Smart Features for Continuous Air Quality Monitoring
- Laser particle sensor detects particles as small as 0.3 microns, providing real-time air quality data.
- Smart app control via the Wyze app allows you to monitor air quality, receive alerts, and control the purifier remotely.
- Voice assistant compatibility with Google Home and Alexa for hands-free operation.
- Whisper-quiet operation at just 21 decibels on low settings, ensuring peaceful use day and night.
Dimensions & Design
- Size: 9.5" x 9.4" x 18.5" (243 mm x 240 mm x 472 mm)
- Weight with Wildfire Filter: 9.32 lb (4.23 kg)
- Sleek gray plastic design fits seamlessly into modern home decor.
"A luxury air purifier, without the luxury price." — Wyze
Enjoy cleaner air at home with Wyze Air Purifier.
Wyze Air Filter Wildfire Variant: Customize Your Air Purification
Tailored Filter Options for Specific Needs
Wyze Air Filter offers three filter types, with the
Wildfire Filter designed for special use against wildfire smoke pollutants. This filter is compatible with Wyze Air Purifiers and can be purchased separately or as part of a subscription service to ensure you always have a fresh filter ready.
Key Specifications of the Wildfire Filter
- Dimensions: 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
- Weight: 1.9 lb (0.87 kg)
- Pre-filter included for capturing larger particles and extending filter life.
- HEPA Type: HEPA 12
- Activated carbon for gas and odor absorption.
- TVOC removal efficiency: 97.1%
- Particulate matter CADR: 342 m³/h (186 CFM)
- Service life: 4 to 12 months depending on usage and air quality.
Subscription Service Benefits
- Regular filter replacement ensures optimal air purification without the hassle of remembering to reorder.
- Filters are shipped directly to your door, making it easy to maintain clean air during wildfire seasons.
- Customizable filter plans to fit your home’s specific air quality needs.
Easy filter replacement keeps your air fresh and safe.
Why Choose Wyze for Wildfire Smoke Air Quality?
Comprehensive Pollutant Removal
Wyze Air Purifiers with the Wildfire Filter remove a wide range of indoor pollutants including:
- Fine particulate matter from wildfire smoke
- Harmful gases and volatile organic compounds (VOCs)
- Allergens, pet dander, viruses, and bacteria
Smart and User-Friendly
- The Wyze app provides real-time air quality index (AQI) updates and filter life notifications.
- Continuous operation recommended to maintain clean air 24/7.
- No ozone generation — Wyze Air Purifiers are CARB-certified and safe for your home environment.
Easy Setup and Integration
- Simple plug-and-play setup with the Wyze app.
- Compatible with smart home ecosystems like Alexa and Google Assistant.
- Share device control with family members for convenient management.
"Indoor air is on average 4-5x more polluted than outdoor air. Protect your home with Wyze." — Wyze
Conclusion
For those concerned about wildfire smoke pollutants, the
Wyze Air Purifier paired with the
Wildfire Filter subscription service offers an effective, affordable, and smart solution. With powerful filtration, smart monitoring, and easy maintenance, Wyze helps you breathe cleaner, healthier air even during wildfire seasons.
Product Summary
Product | Filter Type | Price (USD) | CADR (m³/h) | Filter Life (Months) | Weight (lb) |
Wyze Air Purifier | Wildfire Filter | 194.99 | 342 | 6 | 9.32 |
Wyze Air Filter | Wildfire Filter | 63.99 | 342 | 4-12 | 1.9 |
What is the Wyze Wildfire Filter Subscription Service?
The Wyze Wildfire Filter Subscription Service is a convenient program that delivers replacement Wildfire Filters for your Wyze Air Purifier directly to your door on a regular schedule. This ensures you always have a fresh filter ready, maintaining optimal air purification and protection against wildfire smoke pollutants.How does the Wyze Air Purifier with Wildfire Filter protect against wildfire smoke?
The Wyze Air Purifier with the Wildfire Filter is specifically designed to combat wildfire smoke pollutants. It uses HEPA-grade filtration to capture 99.97% of fine smoke particles, an activated carbon layer to absorb harmful gases and odors, and offers a high TVOC removal efficiency of 97.1% to reduce volatile organic compounds.What size room can the Wyze Air Purifier clean effectively?
The Wyze Air Purifier is engineered to clean the air in rooms sized between 450 to 550 square feet, making it ideal for living rooms, bedrooms, and home offices.How often should I replace the Wyze Wildfire Filter?
The service life of the Wyze Wildfire Filter ranges from 4 to 12 months, depending on your usage and local air quality. The Wyze app provides filter life notifications to help you know when it's time for a replacement.What pollutants does the Wyze Wildfire Filter remove?
The Wyze Wildfire Filter removes fine particulate matter from wildfire smoke, harmful gases, volatile organic compounds (VOCs), allergens, pet dander, viruses, and bacteria, providing comprehensive indoor air purification.Is the Wyze Air Purifier safe for home use?
Yes, the Wyze Air Purifier is CARB-certified and does not generate ozone, making it safe for use in your home environment.Can I control the Wyze Air Purifier remotely?
Yes, you can control the Wyze Air Purifier remotely using the Wyze app, which allows you to monitor air quality, receive alerts, and manage the purifier from anywhere. It is also compatible with Google Home and Alexa for voice control.What are the benefits of subscribing to the Wyze Wildfire Filter replacement service?
Subscribing to the Wyze Wildfire Filter replacement service ensures you receive regular filter shipments, so you never forget to replace your filter. This helps maintain optimal air quality, especially during wildfire seasons, and offers customizable plans to fit your specific needs.How easy is it to replace the Wyze Wildfire Filter?
Replacing the Wyze Wildfire Filter is simple and user-friendly. The filter is designed for easy installation, and the Wyze app provides notifications when it's time to change the filter.Does the Wyze Air Purifier operate quietly?
Yes, the Wyze Air Purifier operates at a whisper-quiet 21 decibels on low settings, ensuring it won't disturb your daily activities or sleep.What are the dimensions and weight of the Wyze Air Purifier and Wildfire Filter?
The Wyze Air Purifier measures 9.5" x 9.4" x 18.5" and weighs 9.32 lb with the Wildfire Filter installed. The Wildfire Filter itself measures 8.1" x 8.1" x 11.3" and weighs 1.9 lb.Is the Wyze Air Purifier easy to set up and integrate with smart home systems?
Yes, the Wyze Air Purifier features a simple plug-and-play setup and is compatible with smart home ecosystems like Alexa and Google Assistant. You can also share device control with family members for convenient management.
