Wyze Air Purifier: Remove Wildfire Smoke & Formaldehyde Fast
Wyze Air Purifier for Wildfire Smoke and Formaldehyde Removal
When wildfire smoke and harmful gases like formaldehyde invade your indoor air, having a reliable air purifier is essential for your health and comfort. The Wyze Air Purifier is expertly designed to tackle these specific air quality challenges with advanced filtration technology, smart features, and whisper-quiet operation — all without breaking the bank.
Breathe easier and protect your home environment with Wyze’s tailored air purification solutions.
Why Choose Wyze Air Purifier?
The Wyze Air Purifier stands out as a premium yet affordable device that offers powerful air cleaning capabilities. It is engineered to cover medium to large rooms (450-550 sq. ft.) and comes with multiple filter options to address different air quality concerns, including wildfire smoke and formaldehyde. High CADR Ratings:
  • Wildfire Filter: 342 m³/h (201 CFM)
  • Formaldehyde Filter: 317 m³/h (186 CFM)
  • Allergen Filter: 350 m³/h (206 CFM)
  • Ultra-quiet Operation: As low as 21 decibels, perfect for bedrooms and living spaces.
  • Smart Controls & AQ Alerts: Monitor air quality in real-time with laser particle detection accurate to 0.3 microns, updating 100 times per second.
  • Smart Home Compatibility: Works seamlessly with Google Home and Alexa for voice control and automation.
  • Filter Life: Approximately 6 months per filter, ensuring long-lasting performance.
The purifier’s sleek gray plastic design measures 9.5 x 9.4 x 18.5 inches and weighs between 8.75 to 9.32 lbs depending on the filter installed, making it easy to place anywhere in your home. Wyze Air Purifier in Kitchen Experience cleaner air in your living spaces with Wyze Air Purifier.
Specialized Filters for Targeted Air Quality Needs
Wyze offers custom filters designed to address specific pollutants, making it ideal for those concerned about wildfire smoke and formaldehyde exposure:
Wildfire Filter (Special Use)
  • Designed to capture fine particulate matter from wildfire smoke.
  • CADR: 342 m³/h (201 CFM)
  • Weight: 9.32 lbs (4.23 kg)
  • Price: $194.99
  • Effectively reduces smoke particles and odors, improving indoor air quality during wildfire seasons.
Formaldehyde Filter (Premium)
  • Targets formaldehyde and other volatile organic compounds (VOCs) commonly found in new furniture, building materials, and household products.
  • CADR: 317 m³/h (186 CFM)
  • Weight: 9 lbs (4.08 kg)
  • Price: $174.99
  • Removes up to 98.9% of TVOCs, ensuring safer air for sensitive individuals.
Allergen Filter (Standard)
  • Captures dust, pollen, pet dander, and other common allergens.
  • CADR: 350 m³/h (206 CFM)
  • Weight: 8.75 lbs (3.97 kg)
  • Price: $169.99
  • Ideal for everyday air purification needs.
Wyze Air Filter Replacement Options
To maintain optimal performance, Wyze also offers replacement filters compatible with the Wyze Air Purifier. These filters come in the same three variants — Allergen, Formaldehyde, and Wildfire — allowing you to customize your air purification based on seasonal or situational needs. Filter Features:
  • HEPA 12 and HEPA 13 types for superior particle capture.
  • Activated carbon layer for odor and gas absorption.
  • TVOC removal efficiency up to 98.9%.
  • Filter Dimensions: 8.1" x 8.1" x 11.3"
  • Filter Life: 4 to 12 months depending on filter type and usage.
  • Prices: Range from $37.99 to $63.99.
Changing Wyze Air Purifier Filter Easily replace your Wyze Air Purifier filter to keep your air fresh and clean.
Summary
The Wyze Air Purifier with its specialized wildfire and formaldehyde filters is an excellent choice for anyone looking to improve indoor air quality during wildfire seasons or in environments with chemical pollutants. Its smart features, quiet operation, and effective filtration make it a standout product in the connected home category. By pairing the purifier with the appropriate Wyze Air Filter replacements, you can ensure your home stays protected from smoke, allergens, and harmful gases all year round.
Product Highlights at a Glance
FeatureWyze Air PurifierWyze Air Filter Replacement
Filter TypesAllergen, Wildfire, FormaldehydeAllergen, Wildfire, Formaldehyde
CADR (Wildfire)342 m³/h (201 CFM)342 m³/h (186 CFM)
CADR (Formaldehyde)317 m³/h (186 CFM)317 m³/h (186 CFM)
Noise LevelAs low as 21 dBAN/A
Smart FeaturesAQ alerts, laser particle sensor, Alexa & Google Home compatibleN/A
Filter Life6 months4-12 months
Price Range$169.99 - $194.99$37.99 - $63.99
TypeConnected HomeConnected Home
DescriptionClears air with premium filters, 350 CADR, whisper-quiet operation (21 dB), smart controls, AQ alerts, laser particle detectionCustom filters for specific needs: allergens, formaldehyde, wildfire smoke, pet odors, germs, gases
CADR (Clean Air Delivery Rate)350 CADR (350 m³/h)N/A
Noise Level21 to 54 decibels (whisper-quiet, quieter than a purring kitten)N/A
Filters AvailableAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)
Filter TechnologyTrue HEPA, granulated carbon, catalyst materialsAllergen: Pre-Filter + HEPA 13 + Granulated Carbon
Formaldehyde: Pre-Filter + True HEPA 12 + Granulated Carbon with Activated Manganese
Wildfire: Pre-Filter + True HEPA 12 + Chemically Modified Granulated Carbon
Filter Replacement PriceIncluded with purifier variants:
- Allergen Filter: $169.99
- Formaldehyde Filter: $194.99
- Wildfire Filter: $174.99
Standalone filters:
- Allergen Filter: $37.99
- Formaldehyde Filter: $63.99
- Wildfire Filter: $40.99
Filter Replacement ProcessSimple and quick filter changes with handy handle3 easy steps: remove old filter, insert new filter, resume use
Smart FeaturesAuto Mode, fan speed control, dimmable display, child lock, Google Home and Alexa compatible, laser particle sensor (0.3 microns), AQ alerts, indoor/outdoor air quality trackingN/A
Air Quality SensorLaser particle sensor checking ultra-fine particles 100 times per secondN/A
Air Volume Processed12,000 cubic feet per hourN/A
Noise Comparison21 dB (quieter than a purring kitten at 25 dB)N/A
Price$169.99 - $194.99 depending on filter variant$37.99 - $63.99 depending on filter type
Subscription OptionYes, filter subscription availableYes, filter subscription available
Warranty30-day hassle-free returns30-day hassle-free returns
What makes the Wyze Air Purifier effective against wildfire smoke?The Wyze Air Purifier is equipped with a specialized Wildfire Filter designed to capture fine particulate matter from wildfire smoke. With a high Clean Air Delivery Rate (CADR) of 342 m³/h (201 CFM), it effectively reduces smoke particles and odors, improving indoor air quality during wildfire seasons.
How does the Wyze Air Purifier remove formaldehyde and VOCs?The Wyze Air Purifier offers a Formaldehyde Filter that targets formaldehyde and other volatile organic compounds (VOCs) commonly found in new furniture, building materials, and household products. This filter removes up to 98.9% of TVOCs, ensuring safer air for sensitive individuals.
What room size can the Wyze Air Purifier cover?The Wyze Air Purifier is engineered to cover medium to large rooms, ranging from 450 to 550 square feet, making it suitable for bedrooms, living rooms, and other spacious areas.
How quiet is the Wyze Air Purifier during operation?The Wyze Air Purifier operates as quietly as 21 decibels, making it ideal for use in bedrooms and living spaces without causing disturbance.
What smart features does the Wyze Air Purifier offer?The Wyze Air Purifier features real-time air quality monitoring with a laser particle sensor accurate to 0.3 microns, updating 100 times per second. It also offers air quality alerts and is compatible with Google Home and Alexa for voice control and smart home automation.
What types of filters are available for the Wyze Air Purifier?Wyze offers three types of filters for its air purifier: the Allergen Filter (for dust, pollen, and pet dander), the Wildfire Filter (for smoke particles), and the Formaldehyde Filter (for VOCs and chemical pollutants).
How often should I replace the Wyze Air Purifier filter?Wyze Air Purifier filters typically last about 6 months, but replacement intervals can range from 4 to 12 months depending on the filter type and usage conditions.
Are Wyze Air Filter replacements easy to install?Yes, Wyze Air Filter replacements are designed for easy installation, allowing you to quickly swap out old filters and maintain optimal air purification performance.
What is the price range for Wyze Air Purifier and replacement filters?The Wyze Air Purifier is priced between $169.99 and $194.99, depending on the filter type. Replacement filters range from $37.99 to $63.99.
What are the dimensions and weight of the Wyze Air Purifier?The Wyze Air Purifier measures 9.5 x 9.4 x 18.5 inches and weighs between 8.75 to 9.32 lbs, depending on the installed filter.
What type of filtration technology does the Wyze Air Purifier use?The Wyze Air Purifier uses HEPA 12 and HEPA 13 filters for superior particle capture, along with an activated carbon layer for odor and gas absorption.
Is the Wyze Air Purifier compatible with smart home systems?Yes, the Wyze Air Purifier works seamlessly with Google Home and Alexa, allowing for voice control and integration into your smart home ecosystem.
What are the specific features of the Wyze Air Purifier that make it effective against wildfire smoke?How does the smart control feature of the Wyze Air Purifier work?Do you have any ongoing sales or discounts for the Wyze Air Purifier?
