Subscribe to Wyze Wildfire Air Filter for Superior Smoke Protection
Subscribe to Wyze Wildfire Air Filter for Efficient Smoke Pollutant Capture
When wildfire smoke threatens your indoor air quality, having a specialized air filter subscription can make all the difference. Wyze offers a dedicated Wildfire Air Filter designed to capture smoke pollutants effectively, ensuring your home stays fresh and safe. Paired with the Wyze Air Purifier and a convenient subscription service, you can breathe easier knowing your air is continuously protected.
Wyze Wildfire Air Filter: Specialized Smoke Pollutant Capture
Tailored for Wildfire Smoke
The Wyze Wildfire Air Filter is a special use filter engineered specifically to combat the harmful effects of wildfire smoke. It features:
  • Pre-filter + True HEPA 12 + Activated Carbon composition to trap fine particulate matter and absorb smoke odors.
  • Particulate Matter CADR: 342 m³/h (201 CFM), efficiently filtering smoke particles.
  • TVOC Removal Efficiency: 97.1%, reducing volatile organic compounds common in wildfire smoke.
  • Service Life: 4 to 12 months, depending on air quality and usage.
  • Weight: 1.9 lb (0.87 kg), compact and easy to handle.
This filter is ideal for those living in wildfire-prone areas or anyone concerned about smoke and airborne pollutants.
"Customize your air like you customize your burger. Well done! Hold the formaldehyde!" – Wyze
Wyze Air Purifier: The Perfect Companion for Your Wildfire Filter
Powerful and Smart Air Cleaning
The Wyze Air Purifier is designed to work seamlessly with the Wildfire Air Filter, providing a comprehensive air purification solution:
  • Pre-installed Wildfire Filter variant available.
  • High CADR: 342 m³/h (201 CFM) for wildfire filter, ensuring rapid air cleaning.
  • Effective Area: Covers 450-550 ft², suitable for most rooms.
  • Noise Levels: Whisper-quiet operation starting below 21 dBA.
  • Smart Features: Laser particle detection with 0.3-micron accuracy, air quality alerts, and compatibility with Google Home and Alexa.
  • Dimensions: 9.5" x 9.4" x 18.5" (243 mm x 240 mm x 472 mm).
  • Weight: 9.32 lb (4.23 kg) with wildfire filter installed.
This purifier balances performance and quiet operation, making it perfect for bedrooms, living rooms, or home offices. Man replacing air purifier filter in home setting Keep your air fresh with easy filter replacement
Wyze Air Filter Subscription: Hassle-Free Replacement Filters
Convenient and Cost-Effective
To maintain optimal air quality, regular filter replacement is essential. Wyze offers a subscription service for the Wildfire Air Filter, ensuring you never run out of clean air protection:
  • Filter Types Available: Allergen, Formaldehyde, and Wildfire filters.
  • Subscription Pricing: Wildfire Filter at $63.99 per replacement.
  • Filter Composition: Pre-filter + True HEPA 12 + Activated Carbon.
  • Service Life: 4 to 12 months per filter.
  • Dimensions & Weight: Matches the original filter for easy swap.
With subscription, you receive timely filter replacements delivered to your door, helping you maintain peak air purification without the hassle of remembering to reorder.
Why Choose Wyze for Wildfire Smoke Protection?
  • Specialized Wildfire Filter: Designed specifically for smoke and pollutant capture.
  • Smart Air Purifier Integration: Real-time air quality monitoring and smart home compatibility.
  • Subscription Convenience: Never worry about expired filters with scheduled deliveries.
  • Proven Efficiency: High CADR and TVOC removal rates ensure cleaner, safer air.
  • Affordable Quality: Premium air purification without a luxury price tag.
Protect your home and family from wildfire smoke with Wyze’s smart, efficient, and easy-to-use air filtration system.
Summary of Wyze Wildfire Air Filter Products
ProductDescriptionPriceKey Features
Wyze Wildfire Air FilterSpecial use filter for wildfire smoke$63.99HEPA 12, Activated Carbon, 342 m³/h CADR
Wyze Air Purifier (Wildfire Filter variant)Air purifier with pre-installed wildfire filter$194.99Smart controls, 450-550 ft² coverage, whisper-quiet
Wyze Air Filter SubscriptionReplacement filters delivered regularly$63.99 per filterConvenient, timely replacements
By subscribing to the Wyze Wildfire Air Filter and pairing it with the Wyze Air Purifier, you ensure your indoor air remains clean and safe from smoke pollutants all year round.
FeatureWyze Air FilterWyze Air Filter SubscriptionWyze Air Purifier
Product TypeConnected Home - Air Filter AccessoriesHardware Subscription - Replacement FiltersConnected Home - Air Purifier
DescriptionCustom air filters for specific needs (pet odors, allergens, germs, gases)Replacement filters for Wyze Air PurifierAir purifier with smart controls, AQ alerts, laser particle detection
VariantsAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter, Formaldehyde Filter, Wildfire FilterPre-installed filter: Allergen, Formaldehyde, Wildfire
Price Range$37.99 - $63.99$37.99 - $63.99$169.99 - $194.99
Filter CompositionAllergen: Pre-Filter + HEPA 13 + Granulated Carbon
Formaldehyde: Pre-Filter + True HEPA 12 + Granulated Carbon with Activated Manganese
Wildfire: Pre-Filter + True HEPA 12 + Chemically Modified Granulated Carbon
Same as Wyze Air FilterSame as Wyze Air Filter
Filter LifeNot specified (replacement recommended every 6 months)Not specified (replacement recommended every 6 months)6 months
Subscription OptionNoYesNo
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
DimensionsNot applicableNot applicable9.5 in x 9.4 in x 18.5 in (243 mm x 240 mm x 472 mm)
WeightNot specifiedNot specifiedAllergen Filter: 8.75 lb (3.97 kg)
Formaldehyde Filter: 9 lb (4.08 kg)
Wildfire Filter: 9.32 lb (4.23 kg)
Operating TemperatureNot applicableNot applicable14°F - 104°F (-10°C - 40°C)
Noise LevelNot applicableNot applicableLevel 1: <20.8 dBA
Level 2: <24.6 dBA
Level 3: <44.5 dBA
Level 4: <52.1 dBA
CADR (Clean Air Delivery Rate)Not applicableNot applicableAllergen: 350 m³/h (206 CFM)
Wildfire: 342 m³/h (201 CFM)
Formaldehyde: 317 m³/h (186 CFM)
Effective AreaNot applicableNot applicable450-550 sq. ft
PowerNot applicableNot applicable120V/60 Hz, 3.5 to 45W
Smart Home CompatibilityNot specifiedNot specifiedGoogle Home, Alexa
Special FeaturesCustomize air filtering to specific needsReplacement filters for convenienceSmart controls, AQ alerts, laser particle detection (0.3 microns), measures air quality 100 times/sec
Model NumberNot specifiedNot specifiedWSAPUR
What is the Wyze Wildfire Air Filter and how does it protect against wildfire smoke?The Wyze Wildfire Air Filter is a specialized filter designed specifically to capture smoke pollutants from wildfires. It uses a combination of a pre-filter, True HEPA 12, and activated carbon to trap fine particulate matter and absorb smoke odors, ensuring your indoor air remains clean and safe during wildfire events.
How effective is the Wyze Wildfire Air Filter at removing smoke and pollutants?The Wyze Wildfire Air Filter offers a high Clean Air Delivery Rate (CADR) of 342 m³/h (201 CFM) for smoke particles and achieves a 97.1% removal efficiency for volatile organic compounds (TVOCs) commonly found in wildfire smoke, making it highly effective at improving indoor air quality.
How long does the Wyze Wildfire Air Filter last before needing replacement?The service life of the Wyze Wildfire Air Filter ranges from 4 to 12 months, depending on your air quality and usage. Regular replacement is recommended to maintain optimal air purification performance.
What are the benefits of subscribing to the Wyze Air Filter Subscription service?With the Wyze Air Filter Subscription, you receive timely replacement filters delivered directly to your door, ensuring you never run out of clean air protection. The subscription is convenient, cost-effective, and helps you maintain peak air quality without the hassle of remembering to reorder.
Which filter types are available with the Wyze Air Filter Subscription?The Wyze Air Filter Subscription offers Allergen, Formaldehyde, and Wildfire filters, allowing you to choose the best option for your specific air quality needs.
How much does the Wyze Wildfire Air Filter cost?The Wyze Wildfire Air Filter is priced at $63.99 per replacement filter. This price applies whether you purchase individually or through the subscription service.
What makes the Wyze Air Purifier a good companion for the Wildfire Air Filter?The Wyze Air Purifier is designed to work seamlessly with the Wildfire Air Filter, offering high CADR for rapid air cleaning, coverage for rooms up to 550 ft², whisper-quiet operation, and smart features like laser particle detection, air quality alerts, and compatibility with Google Home and Alexa.
How easy is it to replace the Wyze Wildfire Air Filter?Replacing the Wyze Wildfire Air Filter is simple and hassle-free. The filter is compact, lightweight (1.9 lb), and designed to match the original filter dimensions, making it easy to swap out when needed.
Why should I choose Wyze for wildfire smoke protection?Wyze offers a specialized Wildfire Air Filter with proven efficiency, smart air purifier integration, convenient subscription options, and affordable pricing. Their system is designed to provide reliable protection against smoke and airborne pollutants, ensuring cleaner, safer air for your home.
What is the coverage area of the Wyze Air Purifier with the Wildfire Filter installed?The Wyze Air Purifier with the Wildfire Filter installed effectively covers areas between 450 and 550 square feet, making it suitable for most bedrooms, living rooms, or home offices.
How does the Wyze Air Filter subscription service work?What are the benefits of using the Wyze Air Purifier with the Wildfire Air Filter?Are there any ongoing promotions or discounts for the Wyze Air Filter subscription?
