Subscribe to Wyze Wildfire Air Filter for Fire Pollution
Subscribe to Wyze Wildfire Air Filter Replacement for Fire Pollution
When wildfire smoke and fire pollution threaten your indoor air quality, having a reliable air filter replacement subscription is essential. Wyze offers a specialized Wildfire Air Filter designed to protect your home from harmful particles and gases caused by fire pollution. Paired with the Wyze Air Purifier and a convenient subscription service, you can breathe easier knowing your air is continuously purified and fresh.
Wyze Wildfire Air Filter: Special Use for Fire Pollution
Tailored Filtration for Wildfire Smoke
Wyze’s Wildfire Filter is engineered specifically for environments affected by wildfire smoke and fire pollution. It combines a Pre-filter, True HEPA 12 filter, and Activated Carbon to efficiently capture particulate matter and harmful gases.
  • Particulate Matter CADR: 342 m³/h (201 CFM)
  • TVOC Removal Efficiency: 97.1%
  • Service Life: 4 to 12 months
  • Weight: 1.9 lb (0.87 kg)
  • Dimensions: 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
This filter is ideal for those living in wildfire-prone areas or experiencing poor air quality due to fire pollution, ensuring your indoor air remains safe and clean.
"Customize your air like you customize your burger. Well done! Hold the formaldehyde!" – Wyze
Why Choose the Wildfire Filter?
  • Specially designed to reduce smoke particles and dangerous gases from wildfire pollution.
  • Activated carbon layer helps absorb odors and volatile organic compounds (VOCs).
  • Compatible with Wyze Air Purifier for seamless integration.
Wyze Air Filter Subscription: Hassle-Free Replacement
Keep Your Air Purifier Performing at Its Best
The Wyze Air Filter Subscription service ensures you never run out of fresh filters. Choose the Wildfire Filter subscription to receive timely replacements, maintaining optimal air quality without the hassle of manual reordering.
  • Available filter types: Allergen, Formaldehyde, Wildfire
  • Filter composition for Wildfire: Pre-filter + True HEPA 12 + Activated Carbon
  • Service life per filter: 4 to 12 months
  • Dimensions and weight match the original filters for perfect fit
Subscribing guarantees you always have a fresh filter ready, especially critical during wildfire seasons when air quality can deteriorate rapidly.
Wyze Air Purifier: The Perfect Companion for Wildfire Filters
Powerful Air Cleaning with Smart Features
The Wyze Air Purifier is designed to work seamlessly with the Wildfire Air Filter, providing comprehensive air purification for spaces between 450-550 ft².
  • CADR for Wildfire Filter: 342 m³/h (201 CFM)
  • Noise Level: Whisper-quiet operation starting at 21 dBA
  • Smart Controls: Compatible with Google Home and Alexa for voice control
  • Laser Particle Sensor: Detects particles as small as 0.3 microns, measuring air quality 100 times per second
  • Filter Life: Approximately 6 months per filter
  • Dimensions: 9.5" x 9.4" x 18.5" (243 mm x 240 mm x 472 mm)
  • Weight: 9.32 lb (4.23 kg) with Wildfire Filter installed
This purifier not only cleans the air but also provides real-time air quality alerts and smart home integration, making it a must-have for anyone concerned about wildfire smoke and indoor pollution. Man replacing air filter in Wyze Air Purifier Alt text: Man replacing air filter in Wyze Air Purifier at home
Why Subscribe to Wyze Wildfire Air Filter Replacement?
  • Consistent Air Quality: Regular filter changes ensure your purifier works at peak efficiency.
  • Convenience: Automatic deliveries mean you never forget to replace your filter.
  • Cost-Effective: Subscription pricing helps you save compared to one-off purchases.
  • Peace of Mind: Protect your family from harmful wildfire smoke and pollutants year-round.
Lifestyle image of clean indoor air environment Alt text: Lifestyle image showing clean indoor air with Wyze Air Purifier
Summary: The Complete Solution for Fire Pollution Air Quality
  • Wyze Wildfire Air Filter: Specialized filter for wildfire smoke and fire pollution.
  • Wyze Air Filter Subscription: Hassle-free, timely filter replacements.
  • Wyze Air Purifier: Smart, powerful purifier optimized for wildfire filters.
Together, these products form a comprehensive system to protect your home from the dangers of fire pollution, ensuring you and your loved ones breathe clean, healthy air every day.
FeatureWyze Air FilterWyze Air Filter SubscriptionWyze Air Purifier
Product TypeConnected Home - Air Filter AccessoriesHardware Subscription - Replacement FiltersConnected Home - Air Purifier
Filter VariantsAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter, Formaldehyde Filter, Wildfire FilterPre-installed filter: Allergen, Formaldehyde, Wildfire
Price (USD)$37.99 (Allergen), $40.99 (Formaldehyde), $63.99 (Wildfire)$37.99 (Allergen), $40.99 (Formaldehyde), $63.99 (Wildfire)$169.99 (Allergen), $174.99 (Formaldehyde), $194.99 (Wildfire)
Dimensions8.1" x 8.1" x 11.3" (205 x 205 x 286 mm)8.1" x 8.1" x 11.3" (205 x 205 x 286 mm)9.5" x 9.4" x 18.5" (243 x 240 x 472 mm)
Weight1.5 lb (Allergen), 1.7 lb (Formaldehyde), 1.9 lb (Wildfire)1.5 lb (Allergen), 1.7 lb (Formaldehyde), 1.9 lb (Wildfire)8.75 lb (Allergen), 9 lb (Formaldehyde), 9.32 lb (Wildfire)
Pre-filterYesYesYes
HEPA TypeHEPA 13 (Allergen), HEPA 12 (Formaldehyde, Wildfire)True HEPA 13 (Allergen), True HEPA 12 (Formaldehyde, Wildfire)Not specified (built-in filters)
Activated CarbonYesYesYes
TVOC Removal Efficiency92.7% (Allergen), 98.9% (Formaldehyde), 97.1% (Wildfire)92.7% (Allergen), 98.9% (Formaldehyde), 97.1% (Wildfire)Not specified
Particulate Matter CADR362 m³/h (Allergen), 317 m³/h (Formaldehyde), 342 m³/h (Wildfire)362 m³/h (Allergen), 317 m³/h (Formaldehyde), 342 m³/h (Wildfire)350 m³/h (Allergen), 317 m³/h (Formaldehyde), 342 m³/h (Wildfire)
Formaldehyde CADR178 m³/hNot specified178 m³/h
Virus & Bacteria Efficiency99%Not specified99%
Service Life6-12 months (Allergen), 5-12 months (Formaldehyde), 4-12 months (Wildfire)6-12 months (Allergen), 5-12 months (Formaldehyde), 4-12 months (Wildfire)6 months
Filter CompositionNot specifiedPre-filter + True HEPA + Activated Carbon (varies by filter type)Built-in premium filters
Smart Home CompatibilityNot specifiedNot specifiedGoogle Home, Alexa
Noise LevelNot specifiedNot specified21 dBA (whisper-quiet)
Effective AreaNot specifiedNot specified450-550 ft²
Additional FeaturesCustomizable filters for specific needsReplacement filters for Wyze Air PurifierSmart controls, AQ alerts, laser particle detection
What is the Wyze Wildfire Air Filter and how does it protect against fire pollution?The Wyze Wildfire Air Filter is a specialized air filter designed to protect your home from harmful particles and gases caused by wildfire smoke and fire pollution. It features a Pre-filter, True HEPA 12 filter, and Activated Carbon layer to efficiently capture particulate matter and absorb dangerous gases and odors, ensuring your indoor air remains safe and clean.
How does the Wyze Wildfire Air Filter Subscription work?The Wyze Wildfire Air Filter Subscription is a hassle-free service that delivers replacement filters to your door on a regular schedule. By subscribing, you ensure you always have a fresh filter ready, maintaining optimal air quality without the need to manually reorder, especially during wildfire seasons when air quality can deteriorate rapidly.
What are the benefits of subscribing to Wyze Wildfire Air Filter replacements?Subscribing to Wyze Wildfire Air Filter replacements offers consistent air quality, convenience with automatic deliveries, cost savings compared to one-off purchases, and peace of mind knowing your family is protected from harmful wildfire smoke and pollutants year-round.
What makes the Wyze Wildfire Air Filter effective against wildfire smoke?The Wyze Wildfire Air Filter is engineered specifically for environments affected by wildfire smoke. It combines a Pre-filter, True HEPA 12 filter, and Activated Carbon to capture fine particulate matter and remove up to 97.1% of total volatile organic compounds (TVOCs), including dangerous gases and odors from fire pollution.
How long does the Wyze Wildfire Air Filter last before needing replacement?The Wyze Wildfire Air Filter has a service life of 4 to 12 months, depending on air quality and usage. Regular replacement ensures your air purifier continues to operate at peak efficiency.
Is the Wyze Wildfire Air Filter compatible with all Wyze Air Purifiers?Yes, the Wyze Wildfire Air Filter is designed to be fully compatible with the Wyze Air Purifier, ensuring a perfect fit and seamless integration for optimal air purification.
What are the technical specifications of the Wyze Wildfire Air Filter?The Wyze Wildfire Air Filter has a particulate matter CADR of 342 m³/h (201 CFM), TVOC removal efficiency of 97.1%, weighs 1.9 lb (0.87 kg), and measures 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm).
What features does the Wyze Air Purifier offer when used with the Wildfire Filter?The Wyze Air Purifier offers powerful air cleaning for spaces between 450-550 ft², whisper-quiet operation starting at 21 dBA, smart controls compatible with Google Home and Alexa, a laser particle sensor that detects particles as small as 0.3 microns, and real-time air quality alerts. It is optimized for use with the Wildfire Air Filter.
How often should I replace my Wyze Wildfire Air Filter?It is recommended to replace your Wyze Wildfire Air Filter every 4 to 12 months, depending on your local air quality and usage. Subscribing to the filter replacement service ensures you always have a fresh filter when needed.
Why is it important to use a specialized filter during wildfire season?During wildfire season, air quality can deteriorate rapidly due to smoke and harmful gases. Using a specialized filter like the Wyze Wildfire Air Filter ensures your indoor air is effectively purified, protecting your health and providing peace of mind.
How does the Wyze Wildfire Air Filter compare to other air filters on the market?Can I customize my subscription for the Wyze Wildfire Air Filter?What is the process for canceling my Wyze Air Filter subscription?
