Wyze Video Doorbell v2 vs Wyze Video Doorbell Pro: Which One Suits Your Home Best?
When it comes to securing your front porch with a smart video doorbell, Wyze offers two compelling options: the
Wyze Video Doorbell v2 and the
Wyze Video Doorbell Pro. Both models bring advanced features, crisp video quality, and smart home integration, but they cater to slightly different needs and preferences. This guide breaks down their key specs and highlights to help you decide which Wyze doorbell is the perfect fit for your home.
Wyze Video Doorbell v2: Clear, Wired, and Feature-Rich
Stunning 2K Video Quality
The Wyze Video Doorbell v2 delivers sharp 2K resolution (2048 x 1536) video, providing crystal-clear images to capture every detail at your doorstep. Its CMOS Starlight Sensor combined with a 135° horizontal and 103° vertical field of view ensures you get a wide and bright perspective day or night.
Wired Power with Local Storage
This doorbell requires a wired connection (16V-24V AC) and supports local microSD storage up to 256GB, allowing you to save footage directly without relying solely on cloud plans. The H.264 video format and 20 FPS daytime frame rate ensure smooth, high-quality recordings.
Smart Features for Enhanced Security
- Two-way audio with noise and echo cancellation lets you communicate clearly with visitors.
- Motion-activated voice deterrence helps ward off unwanted guests.
- Real-time alerts keep you instantly informed of activity.
- IP65 weather resistance means it’s built to withstand harsh outdoor conditions.
Easy Installation and Accessories
The package includes a Wyze Chime Controller, wall plate, wedge for angled mounting, and all necessary screws and wire caps for a hassle-free setup. For tricky door frames, the optional
Wyze Video Doorbell v2 Wedge Kit adjusts the viewing angle to eliminate blind spots.
"Answer your door from anywhere with our clearest and most capable wired video doorbell yet."
Wyze Video Doorbell v2 installed on a front porch, showcasing its sleek design and smart home integration.
Wyze Video Doorbell Pro: Flexible Power and Wider Coverage
Battery or Wired Power Options
The Wyze Video Doorbell Pro offers the convenience of both wired and battery-powered operation, making it ideal for homes without existing doorbell wiring or for those who want a quick, screw-free installation using the adhesive plate.
Ultra-Wide Viewing Angle and HD Video
With an ultra-wide viewing angle, the Pro model covers more area around your front door. It streams crystal-clear HD video with smart detection capabilities including person, package, vehicle, and pet detection — all enhanced by Cam Plus subscription for faster, smarter alerts.
Enhanced Smart Features
- Motion-activated security light improves visibility and deters intruders.
- Two-way audio with quick response functionality.
- Includes a dual-band Wi-Fi extender chime for faster notifications and customizable sounds (20 unique tunes, 8 sound levels).
- Seamless integration with Alexa and Google Assistant for voice control.
Quick and Versatile Installation
Install the Wyze Video Doorbell Pro in just 30 seconds with screws or the screw-free adhesive plate, perfect for renters or those seeking a no-fuss setup. The included chime ensures you never miss a visitor.
"Wider view. Higher resolution. Extraordinary price."
Wyze Video Doorbell Pro capturing a wide view of the front porch with package detection in action.
Side-by-Side Comparison Summary
Feature | Wyze Video Doorbell v2 | Wyze Video Doorbell Pro |
Video Resolution | 2K (2048 x 1536) | HD (1080p) |
Field of View | 135° horizontal, 103° vertical | Ultra-wide angle (wider than v2) |
Power Source | Wired (16V-24V AC) | Wired or Battery-powered |
Storage Options | Local microSD (up to 256GB), Cloud | Cloud with Cam Plus subscription |
Installation | Wired, with included chime controller | Screw or adhesive plate, includes chime |
Smart Detection | Motion-activated voice deterrence | Person, package, vehicle, pet detection |
Audio | Two-way audio with noise cancellation | Two-way audio with quick responses |
Weather Resistance | IP65 | IP65 |
Additional Features | Motion alerts, digital zoom | Motion-activated security light, dual-band Wi-Fi extender chime |
Conclusion: Which Wyze Video Doorbell Should You Choose?
- Choose the Wyze Video Doorbell v2 if you want the highest video resolution with local storage, wired power, and a comprehensive accessory kit for a traditional wired doorbell setup. It’s perfect for homeowners looking for detailed video and reliable wired power.
- Opt for the Wyze Video Doorbell Pro if you prefer installation flexibility with battery or wired power, a wider field of view, and advanced smart detection features. Its quick install and smart chime make it ideal for renters or those wanting a modern, versatile doorbell solution.
Both models integrate seamlessly with Alexa, Google Assistant, and IFTTT, making them excellent choices for any smart home security setup.
What are the main differences between Wyze Video Doorbell v2 and Wyze Video Doorbell Pro?
The Wyze Video Doorbell v2 offers 2K video resolution, wired power, and local microSD storage up to 256GB. The Wyze Video Doorbell Pro provides HD video, a wider field of view, and flexible power options (wired or battery). The Pro also features advanced smart detection (person, package, vehicle, pet), a motion-activated security light, and a dual-band Wi-Fi extender chime.Does the Wyze Video Doorbell v2 require existing doorbell wiring?
Yes, the Wyze Video Doorbell v2 requires a wired connection with 16V-24V AC power. It is designed for homes with existing doorbell wiring.Can the Wyze Video Doorbell Pro be installed without wiring?
Yes, the Wyze Video Doorbell Pro can be installed using its built-in rechargeable battery, making it ideal for homes without existing doorbell wiring. It also supports screw-free installation with an adhesive plate.Which Wyze doorbell offers local storage for video recordings?
The Wyze Video Doorbell v2 supports local microSD storage up to 256GB, allowing you to save footage directly on the device. The Wyze Video Doorbell Pro relies on cloud storage with a Cam Plus subscription.What smart home integrations are available for Wyze Video Doorbells?
Both Wyze Video Doorbell v2 and Wyze Video Doorbell Pro integrate seamlessly with Alexa, Google Assistant, and IFTTT for voice control and smart home automation.How does the video quality compare between Wyze Video Doorbell v2 and Pro?
The Wyze Video Doorbell v2 delivers higher video quality with 2K resolution (2048 x 1536), while the Wyze Video Doorbell Pro streams in HD (1080p) but offers a wider field of view.What smart detection features are included with Wyze Video Doorbell Pro?
The Wyze Video Doorbell Pro includes advanced smart detection features such as person, package, vehicle, and pet detection, which are enhanced with a Cam Plus subscription for faster and smarter alerts.Are both Wyze Video Doorbells weather resistant?
Yes, both the Wyze Video Doorbell v2 and Wyze Video Doorbell Pro are rated IP65, making them resistant to harsh outdoor weather conditions.What accessories are included with the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 comes with a Wyze Chime Controller, wall plate, wedge for angled mounting, and all necessary screws and wire caps for easy installation. An optional Wedge Kit is available for adjusting the viewing angle.Which Wyze doorbell is best for renters or homes without existing wiring?
The Wyze Video Doorbell Pro is ideal for renters or homes without existing wiring due to its battery-powered option and quick, screw-free installation using the adhesive plate.
