Wyze Video Doorbell v2 Field of View and Features
When it comes to securing your front porch with crystal-clear video and wide coverage, the
Wyze Video Doorbell v2 stands out as a top choice. This wired video doorbell offers an impressive field of view and advanced features designed to keep you connected and informed no matter where you are.
Wide and Detailed Field of View
The Wyze Video Doorbell v2 boasts a
135° horizontal and
103° vertical field of view, providing a broad and detailed perspective of your porch area. This expansive viewing angle ensures you capture head-to-toe footage of visitors, packages, and any activity happening right at your doorstep. The diagonal field of view extends to approximately
166.8°, giving you an even wider coverage to minimize blind spots.
This wide-angle lens combined with
2K (2048 x 1536) resolution means you get sharp, high-definition video that captures fine details, such as facial features and package labels, day or night.
Enhanced Video Quality and Night Vision
Equipped with a
CMOS Starlight Sensor and an aperture of
F2.0, the doorbell delivers vibrant and clear video even in low-light conditions. The advanced sensor technology supports
color night vision, allowing you to see visitors and surroundings as clearly as during the day. This is especially useful for nighttime security and package monitoring.
Smart Features for Superior Security
- Two-way audio with noise and echo cancellation lets you communicate directly with visitors through the Wyze app.
- Motion-activated voice deterrence warns unwanted guests that they are being recorded, helping to prevent suspicious activity.
- Pre-roll motion recording captures 3-6 seconds before motion events, so you don’t miss any critical moments.
- Local microSD storage supports continuous 24/7 recording, giving you peace of mind that footage is saved even without cloud access.
- Compatible with your existing mechanical chime via the included chime controller, so you keep the traditional doorbell sound.
Comparison: Wyze Video Doorbell (Wired) Field of View
For those considering other Wyze wired doorbell options, the original
Wyze Video Doorbell (Wired) offers a slightly different field of view:
- 120° vertical by 88° horizontal field of view.
- Full HD 1080p video quality.
- 4:3 aspect ratio for a more traditional video frame.
- Includes 6 white LED fill lights and 4 infrared LEDs for night vision.
While it provides solid coverage and video quality, the newer Wyze Video Doorbell v2’s wider field of view and higher 2K resolution deliver a more immersive and detailed security experience.
Refurbished Wyze Video Doorbell v2 Option
If you’re looking for a budget-friendly alternative without sacrificing quality, the
Refurbished Wyze Video Doorbell v2 offers the same wide
135° horizontal and
103° vertical field of view and 2K video clarity at a reduced price. Fully tested and guaranteed to work like new, this option is perfect for those who want premium features with added savings.
Why Choose Wyze Video Doorbell v2 for Your Home Security?
"Answer your door from anywhere with our clearest and most capable wired video doorbell yet."
The Wyze Video Doorbell v2 is designed to provide comprehensive porch protection with its wide field of view, high-resolution video, and smart security features. Whether you want to monitor deliveries, screen visitors, or deter unwanted activity, this doorbell offers the perfect balance of coverage and clarity.
Its compatibility with Alexa and Google Home further enhances your smart home ecosystem, allowing you to view live feeds and receive alerts hands-free.
Summary of Wyze Video Doorbell v2 Field of View Specs
Feature | Wyze Video Doorbell v2 | Wyze Video Doorbell (Wired) | Refurbished Wyze Video Doorbell v2 |
Horizontal Field of View | 135° | 88° | 135° |
Vertical Field of View | 103° | 120° | 103° |
Diagonal Field of View | 166.8° | Not specified | 166.8° |
Video Resolution | 2K (2048 x 1536) | 1080p Full HD | 2K (2048 x 1536) |
Night Vision | Color Night Vision (Starlight Sensor) | Infrared Night Vision | Color Night Vision (Starlight Sensor) |
Two-way Audio | Yes | Yes | Yes |
Local microSD Storage | Yes | No | Yes |
Enhance Your Doorbell View with the Wyze Video Doorbell v2 Wedge Kit
For porches with angled door frames or stairs, the
Wyze Video Doorbell v2 Wedge Kit accessory allows you to adjust the doorbell’s mounting angle for optimal coverage. This kit includes:
- 1x 15° horizontal wedge
- 2x 7.5° vertical wedges
Made from thick, weather-resistant plastic, the wedge kit helps eliminate blind spots and ensures your doorbell captures the perfect view of your porch.
Conclusion
The
Wyze Video Doorbell v2 offers one of the widest and clearest fields of view available in smart wired doorbells today. With its 2K resolution, expansive 135° horizontal and 103° vertical viewing angles, and advanced night vision, it provides superior porch security and peace of mind.
Whether you choose the new model, the original wired doorbell, or the refurbished version, Wyze delivers excellent video doorbell solutions tailored to your home’s needs.
Experience wide-angle porch security with Wyze Video Doorbell v2
What is the field of view of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 features a 135° horizontal and 103° vertical field of view, with a diagonal field of view of approximately 166.8°. This wide coverage ensures you capture head-to-toe footage of visitors and packages, minimizing blind spots at your doorstep.What video resolution does the Wyze Video Doorbell v2 offer?
The Wyze Video Doorbell v2 delivers sharp, high-definition video with a 2K resolution (2048 x 1536), allowing you to see fine details such as facial features and package labels clearly.Does the Wyze Video Doorbell v2 have night vision?
Yes, the Wyze Video Doorbell v2 is equipped with a CMOS Starlight Sensor and F2.0 aperture, providing advanced color night vision. This allows you to see visitors and your porch area clearly even in low-light or nighttime conditions.What smart security features are included with the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 includes two-way audio with noise and echo cancellation, motion-activated voice deterrence, pre-roll motion recording (capturing 3-6 seconds before motion events), and local microSD storage for continuous 24/7 recording.Can I use my existing mechanical chime with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 is compatible with your existing mechanical chime when installed using the included chime controller, so you can keep your traditional doorbell sound.How does the Wyze Video Doorbell v2 compare to the original Wyze Video Doorbell (Wired)?
The Wyze Video Doorbell v2 offers a wider field of view (135° horizontal, 103° vertical) and higher 2K resolution compared to the original Wyze Video Doorbell (Wired), which has an 88° horizontal and 120° vertical field of view with 1080p Full HD video. The v2 also features color night vision, while the original uses infrared night vision.Is there a refurbished option for the Wyze Video Doorbell v2?
Yes, the Refurbished Wyze Video Doorbell v2 offers the same wide 135° horizontal and 103° vertical field of view and 2K video clarity as the new model, but at a reduced price. It is fully tested and guaranteed to work like new.Does the Wyze Video Doorbell v2 support local storage?
Yes, the Wyze Video Doorbell v2 supports local microSD storage for continuous 24/7 recording, ensuring your footage is saved even without cloud access.Is the Wyze Video Doorbell v2 compatible with Alexa and Google Home?
Yes, the Wyze Video Doorbell v2 works with Alexa and Google Home, allowing you to view live feeds and receive alerts hands-free as part of your smart home ecosystem.What is the Wyze Video Doorbell v2 Wedge Kit and how does it help?
The Wyze Video Doorbell v2 Wedge Kit is an accessory that includes a 15° horizontal wedge and two 7.5° vertical wedges. Made from weather-resistant plastic, it allows you to adjust the doorbell’s mounting angle for optimal coverage, especially on angled door frames or stairs, helping to eliminate blind spots.
