Wyze Video Doorbell Pro Night Vision: Ultimate Home Security Solution
When it comes to securing your front door with crystal-clear video and advanced night vision, the
Wyze Video Doorbell Pro stands out as a top choice. Designed for both wired and wireless installation, this smart doorbell offers a wider view, higher resolution, and smart detection features that keep your home safe day and night.
Alongside the Pro model, the
Wyze Video Doorbell v2 and the
Front Porch Security Bundle provide excellent alternatives and complementary options for comprehensive porch security.
Wyze Video Doorbell Pro: Advanced Night Vision and Smart Features
Crystal-Clear HD Video & Ultra-Wide Viewing Angle
The Wyze Video Doorbell Pro delivers crystal-clear HD video with an ultra-wide viewing angle, allowing you to see more of your porch and surroundings. Its advanced camera technology ensures you never miss a detail, even in low light.
Night Vision Capabilities
Equipped with motion-activated security lights and smart night vision, the Doorbell Pro enhances visibility after dark. It uses infrared technology combined with a motion-activated light to illuminate visitors or potential intruders, providing clear video footage at night.
Smart Detection & Fast Notifications
With Cam Plus integration, the Doorbell Pro offers smart detection alerts for people, packages, vehicles, and pets. This ensures you receive relevant notifications quickly, helping you respond promptly to any activity.
Easy Installation & Versatile Power Options
Install the Doorbell Pro in just 30 seconds using screws or a screw-free adhesive plate. It supports both hardwired and battery power, giving you flexibility depending on your home setup.
Two-Way Audio & Customizable Chimes
Communicate with visitors through two-way audio and choose from 20 unique chime tunes with 8 sound levels, making your doorbell experience personalized and convenient.
Smart Home Integration
Seamlessly integrates with Alexa and Google Assistant for voice control and smart home automation.
"Wider view. Higher resolution. Extraordinary price." — Wyze Video Doorbell Pro
Experience smart home security with Wyze Video Doorbell Pro.
Wyze Video Doorbell v2: Wired Doorbell with 2K Video and Night Vision
High-Resolution 2K Video
Wyze Video Doorbell v2 offers 2K (2048 x 1536) video resolution, providing sharper and more detailed footage compared to standard HD doorbells.
CMOS Starlight Sensor & Night Vision
Featuring a CMOS Starlight Sensor and 6 x 940nm IR lights, this doorbell captures clear video even in complete darkness. The night vision operates at 15 FPS, ensuring smooth video playback at night.
Wide Field of View
With a 135° horizontal and 166.8° diagonal field of view, the Doorbell v2 covers a broad area, reducing blind spots around your front door.
Local and Cloud Storage Options
Supports local microSD storage up to 256GB and cloud storage with a Wyze Security Plan, so you can save and review footage anytime.
Two-Way Audio and Voice Deterrence
Communicate with visitors or deter unwanted guests with motion-activated voice deterrence and two-way audio.
Weather Resistant & Durable
Built with polycarbonate body and resin lens, the Doorbell v2 is IP65 rated for weather resistance, making it reliable in various climates.
The Front Porch Security Bundle: Complete Smart Home Entry Solution
All-in-One Porch Security
This bundle combines the Wyze Video Doorbell and Chime with the Wyze Lock, offering a comprehensive front porch security system.
1080p HD Video & Two-Way Audio
View your front porch in crisp 1080p HD and communicate with visitors using two-way audio.
Remote Lock Control & History
Lock or unlock your door remotely via the Wyze app and monitor lock history for added security.
Smart Home Compatibility
Works with Alexa and Google Assistant, allowing voice commands and automation.
Included Accessories
The bundle includes the Wyze Lock, Lock Gateway, Video Doorbell, Chime, mounting hardware, and extension wires for easy installation.
Why Choose Wyze for Night Vision Video Doorbells?
Wyze offers a range of video doorbells with advanced night vision capabilities, smart detection, and seamless integration with your smart home ecosystem. Whether you prefer the ultra-wide, battery-powered
Wyze Video Doorbell Pro or the wired, high-resolution
Wyze Video Doorbell v2, Wyze ensures your home is protected around the clock.
"Protect your home day and night with Wyze’s smart video doorbells featuring superior night vision and smart alerts."
Summary of Key Specs
Feature | Wyze Video Doorbell Pro | Wyze Video Doorbell v2 | Front Porch Security Bundle |
Video Resolution | HD (exact resolution not specified) | 2K (2048 x 1536) | 1080p HD |
Night Vision | Motion-activated security light + IR | 6 x 940nm IR lights | 4 x 940nm IR LEDs |
Field of View | Ultra-wide angle (exact degrees not specified) | 135° horizontal, 166.8° diagonal | 120° vertical x 88° horizontal |
Power Options | Battery or Hardwired | Hardwired (16V-24V AC) | Hardwired (16V-24V AC) |
Two-Way Audio | Yes | Yes | Yes |
Smart Detection | Person, package, vehicle, pet | Motion-activated voice deterrence | Motion events + lock history |
Weather Resistance | IP65 | IP65 | IP65 |
Integration | Alexa, Google Assistant | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant |
Enhance Your Home Security Today
Investing in a Wyze video doorbell with night vision means you get reliable, high-quality video surveillance that works day and night. The
Wyze Video Doorbell Pro is perfect for those seeking a quick-install, battery-powered solution with smart detection and wide coverage. For wired setups, the
Wyze Video Doorbell v2 offers superior 2K video clarity and local storage options. The
Front Porch Security Bundle adds smart lock capabilities for a fully integrated front door security system.
Secure your home with Wyze and enjoy peace of mind knowing your front porch is always monitored, even in the darkest conditions.
Wide-angle view and package detection with Wyze Video Doorbell Pro.
What are the main features of the Wyze Video Doorbell Pro?
The Wyze Video Doorbell Pro offers crystal-clear HD video, an ultra-wide viewing angle, advanced night vision with motion-activated security lights, smart detection for people, packages, vehicles, and pets, easy installation with both wired and wireless options, two-way audio, customizable chimes, and seamless integration with Alexa and Google Assistant.How does the night vision work on Wyze Video Doorbells?
Wyze Video Doorbells use infrared (IR) technology and, in the case of the Pro model, motion-activated security lights to provide clear video footage even in complete darkness. The Wyze Video Doorbell v2 features a CMOS Starlight Sensor and 6 x 940nm IR lights for enhanced night vision.What is the video resolution of Wyze Video Doorbell Pro and v2?
The Wyze Video Doorbell Pro delivers HD video (exact resolution not specified), while the Wyze Video Doorbell v2 offers high-resolution 2K video (2048 x 1536) for sharper and more detailed footage.Can I install the Wyze Video Doorbell Pro without wiring?
Yes, the Wyze Video Doorbell Pro supports both battery-powered and hardwired installation. It can be installed in just 30 seconds using screws or a screw-free adhesive plate, making it ideal for renters or those without existing doorbell wiring.Does Wyze Video Doorbell Pro support smart detection and notifications?
Yes, with Cam Plus integration, the Wyze Video Doorbell Pro provides smart detection alerts for people, packages, vehicles, and pets, ensuring you receive fast and relevant notifications.What storage options are available for Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 supports local microSD card storage up to 256GB and cloud storage through a Wyze Security Plan, allowing you to save and review footage anytime.Is the Wyze Video Doorbell weather resistant?
Yes, both the Wyze Video Doorbell Pro and v2 are IP65 rated for weather resistance, making them suitable for use in various climates and weather conditions.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell and Chime, Wyze Lock, Lock Gateway, mounting hardware, and extension wires. This bundle provides 1080p HD video, two-way audio, remote lock control, and smart home compatibility.Can I use Wyze Video Doorbells with Alexa or Google Assistant?
Yes, Wyze Video Doorbell Pro, v2, and the Front Porch Security Bundle all integrate with Alexa and Google Assistant, allowing for voice control and smart home automation.What are the power options for Wyze Video Doorbells?
The Wyze Video Doorbell Pro can be powered by battery or hardwired connection, while the Wyze Video Doorbell v2 and the doorbell in the Front Porch Security Bundle require a hardwired connection (16V-24V AC).How does two-way audio work on Wyze Video Doorbells?
Wyze Video Doorbells feature built-in microphones and speakers, allowing you to communicate with visitors at your door in real time through the Wyze app, enhancing security and convenience.What makes Wyze Video Doorbells a good choice for home security?
Wyze Video Doorbells offer advanced night vision, smart detection, high-resolution video, easy installation, weather resistance, and smart home integration, providing reliable and comprehensive front door security at an affordable price.
