Wyze Video Doorbell v2: 2K Video, Local Storage & Smart Features
Wyze Video Doorbell v2 Features
The Wyze Video Doorbell v2 is a top-tier wired video doorbell designed to provide crystal-clear security and convenience for your home. With its advanced 2K video resolution and local microSD storage, it captures every detail on your porch with stunning clarity. Whether you're at home or away, this doorbell keeps you connected and in control.
Crystal-Clear 2K Video Resolution
Experience head-to-toe viewing with immaculate 2K (2048 x 1536) resolution. This high-definition video quality ensures you never miss a visitor’s face or package details. The wide field of view covers your entire porch area, providing comprehensive monitoring.
Local MicroSD Storage for 24/7 Recording
Unlike many smart doorbells, the Wyze Video Doorbell v2 includes a built-in microSD card slot for continuous local recording. This means you can review footage from before and after any event without relying solely on cloud storage, giving you peace of mind and control over your data.
Two-Way Audio and Real-Time Alerts
Communicate instantly with visitors using the two-way talk feature via the Wyze app. Whether it’s a delivery person or a guest, you can respond quickly and clearly. Real-time motion alerts notify you immediately when someone approaches your door.
Motion-Activated Voice Deterrence
Enhance your home security with motion-activated voice deterrence. When enabled, the doorbell automatically plays a voice prompt warning visitors that they are being recorded, helping to deter unwanted activity. This feature requires a Cam Plus or Cam Protect subscription.
Pre-Roll Motion Recording
Thanks to its wired power setup, the doorbell captures 3-6 seconds of pre-roll video before motion events. This feature ensures you get the full context of any activity, not just what happens after motion is detected.
Weatherproof and Night Vision Ready
Rated IP65 for weather resistance, the Wyze Video Doorbell v2 withstands rain, snow, and harsh outdoor conditions. Its award-winning starlight sensor delivers vibrant color night vision, so your porch is monitored clearly even in low light.
Compatibility and Smart Home Integration
The doorbell works seamlessly with your existing mechanical chime thanks to the included chime controller, preserving the traditional doorbell sound. It also integrates with Alexa and Google Home, allowing you to view live feeds and receive smart alerts through voice assistants.
Included 30° Corner Kit for Perfect Viewing Angle
Every Wyze Video Doorbell v2 comes with a 30° angled mounting wedge to help you achieve the ideal viewing angle, especially useful for porches with stairs or angled door frames. Homeowner answering door with Wyze Video Doorbell v2 Enhance your home security with Wyze Video Doorbell v2
For homes with unique porch layouts, the Wyze Video Doorbell v2 Wedge Kit is the perfect accessory to optimize your doorbell’s field of view.
Adjustable Angles for Maximum Coverage
The kit includes a 15° horizontal wedge and two 7.5° vertical wedges, allowing you to customize the doorbell’s angle to eliminate blind spots. This is especially helpful for porches with stairs or slanted sidings.
Durable Weather-Resistant Build
Made from thick, heavy-duty plastic, the wedge kit is designed to last through all weather conditions, complementing the doorbell’s IP65 rating.
Seamless Compatibility
Designed specifically for the Wyze Video Doorbell v2, the wedge kit maintains all the doorbell’s features including 2K video, color night vision, two-way audio, and voice deterrence.
Essential Security Bundle Featuring Wyze Video Doorbell v2
For a comprehensive home security solution, consider the Essential Security Bundle which includes the Wyze Video Doorbell v2 along with other advanced devices.
What’s Included?
  • Wyze Video Doorbell v2: Crisp 2K video and two-way audio to monitor your front door.
  • Wyze Lock Bolt: A smart lock with fingerprint sensor and backlit keypad for secure, keyless entry.
  • Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, automatic motion tracking, and color night vision.
  • Two Wyze Cam OG Cameras: Versatile plug-in cameras with motion-activated spotlights and color night vision for indoor or outdoor use.
Benefits of the Bundle
This all-in-one package safeguards your home from every angle, combining video monitoring, smart locking, and motion detection. The Wyze Video Doorbell v2 anchors the bundle with its superior porch protection and smart features.
Refurbished Wyze Video Doorbell v2
If you’re looking for a budget-friendly option without compromising quality, the Refurbished Wyze Video Doorbell v2 offers the same great features at a reduced price.
Like-New Quality Guaranteed
Each refurbished unit is fully tested and guaranteed to work like new, backed by a 1-year warranty. It includes all the essentials: 2K video, local microSD storage, two-way audio, and motion-activated voice deterrence.
Same Advanced Specs
  • 2K resolution with 135° horizontal and 103° vertical field of view
  • Starlight sensor for color night vision
  • IP65 weather resistance
  • Compatible with Alexa, Google Assistant, and IFTTT
Why Choose Wyze Video Doorbell v2?
With its high-resolution video, local storage, two-way communication, and smart deterrence features, the Wyze Video Doorbell v2 stands out as a reliable and affordable choice for modern home security.
Family using smart home devices including Wyze Video Doorbell Integrate Wyze Video Doorbell v2 into your smart home ecosystem
Summary of Wyze Video Doorbell v2 Features
FeatureDescription
Video Resolution2K (2048 x 1536) HD video
Local StoragemicroSD card slot for continuous recording
Two-Way AudioTalk to visitors via Wyze app
Motion-Activated Voice DeterrenceAutomated voice warnings with subscription
Pre-Roll Recording3-6 seconds before motion event
Weather ResistanceIP65 rated for all weather conditions
Night VisionColor night vision with starlight sensor
Chime CompatibilityWorks with existing mechanical chimes
Smart Home IntegrationAlexa and Google Home compatible
Included Accessories30° corner wedge for optimal mounting angle
Enhance your home security today with the Wyze Video Doorbell v2 and its accessories, designed to keep your front porch safe and connected like never before.
FeatureWyze Video Doorbell v2Wyze Video Doorbell v2 Wedge KitEssential Security Bundle(Refurbished) Wyze Video Doorbell v2
TypeWired Video DoorbellAccessory (Wedge Kit)Bundle (includes Wyze Video Doorbell v2 + others)Refurbished Wired Video Doorbell
Video Resolution2K (2048 x 1536)N/A1080p HD (Wyze Video Doorbell v2 in bundle listed as 1080p HD)2K (2048 x 1536)
Local StoragemicroSD slot (up to 256GB)N/AmicroSD local storage (Wyze Video Doorbell v2)microSD slot (up to 256GB)
Cloud StorageOptional with Cam Plus subscriptionN/AOptional with Cam PlusOptional with Wyze Security Plan
Two-Way AudioYesN/AYesYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)N/AYesYes
Pre-roll Motion Recording3-6 secondsN/AYesYes
Weather ResistanceIP65Weather-resistant plasticIP65 (Wyze Video Doorbell v2)IP65
Field of View135° horizontal, 103° vertical, 166.8° diagonalN/ANot specified (Wyze Video Doorbell v2 in bundle)135° horizontal, 103° vertical, 166.8° diagonal
Night VisionColor Night Vision (Starlight sensor)N/AColor Night Vision (Wyze Video Doorbell v2)Color Night Vision (Starlight sensor)
Compatibility with ChimeWorks with existing chime (chime controller included)N/AIncluded (Wyze Video Doorbell v2 + Chime)Works with existing chime (chime controller included)
Included ItemsDoorbell + Chime Controller, Wall Plate, Wedge (30°), Installation Kit, Wire Caps, Extension Wires, Screws, Quick Start Guide1x 15° Horizontal + 2x 7.5° Vertical wedgesWyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2× Wyze Cam OGSame as new: Doorbell + Chime Controller, Wall Plate, Wedge (30°), Installation Kit, Wire Caps, Extension Wires, Screws, Quick Start Guide
Price$44.98$8.99 (Wedge Kit Only), $51.97 (Doorbell + Wedge Kit)$199.99$29.98
WarrantyNot specifiedNot specifiedNot specified1-Year
Additional FeaturesAI detections with Cam Plus, Alexa & Google Home integration, Custom detection zones, Quick preset responsesAdjusts viewing angle for porches with stairs or angled door framesIncludes smart lock with fingerprint sensor, pan-tilt camera, and two Wyze Cam OG camerasSame features as new, fully tested and guaranteed
Power Requirements16V-24V AC, ≥10VAN/AIncluded devices powered individually16V-24V AC, ≥10VA
Phone CompatibilityAndroid 9.0+, iOS 15.0+N/AAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+
What is the video resolution of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features a crystal-clear 2K (2048 x 1536) video resolution, providing head-to-toe viewing and capturing every detail on your porch with stunning clarity.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 includes a built-in microSD card slot for continuous local recording, allowing you to review footage before and after any event without relying solely on cloud storage.
Can I talk to visitors through the Wyze Video Doorbell v2?Absolutely. The Wyze Video Doorbell v2 offers two-way audio, enabling you to communicate instantly with visitors via the Wyze app.
What is motion-activated voice deterrence on the Wyze Video Doorbell v2?Motion-activated voice deterrence is a feature that automatically plays a voice prompt warning visitors that they are being recorded, helping to deter unwanted activity. This feature requires a Cam Plus or Cam Protect subscription.
Does the Wyze Video Doorbell v2 record before motion is detected?Yes, thanks to its wired power setup, the Wyze Video Doorbell v2 captures 3-6 seconds of pre-roll video before motion events, ensuring you get the full context of any activity.
Is the Wyze Video Doorbell v2 weatherproof?Yes, the Wyze Video Doorbell v2 is rated IP65 for weather resistance, making it suitable for rain, snow, and harsh outdoor conditions.
Does the Wyze Video Doorbell v2 have night vision?Yes, it features an award-winning starlight sensor that delivers vibrant color night vision, ensuring clear monitoring even in low light conditions.
Is the Wyze Video Doorbell v2 compatible with Alexa and Google Home?Yes, the Wyze Video Doorbell v2 integrates seamlessly with Alexa and Google Home, allowing you to view live feeds and receive smart alerts through your voice assistants.
Can I use my existing mechanical chime with the Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 works with your existing mechanical chime using the included chime controller, preserving your traditional doorbell sound.
What is included with the Wyze Video Doorbell v2 for mounting?Every Wyze Video Doorbell v2 comes with a 30° angled mounting wedge, helping you achieve the ideal viewing angle for your porch.
What is the Wyze Video Doorbell v2 Wedge Kit and how does it help?The Wyze Video Doorbell v2 Wedge Kit includes a 15° horizontal wedge and two 7.5° vertical wedges, allowing you to customize the doorbell’s angle for maximum coverage and to eliminate blind spots, especially on porches with stairs or slanted sidings.
Is the Wyze Video Doorbell v2 Wedge Kit weather-resistant?Yes, the wedge kit is made from thick, heavy-duty plastic designed to withstand all weather conditions, complementing the doorbell’s IP65 rating.
What devices are included in the Essential Security Bundle with Wyze Video Doorbell v2?The Essential Security Bundle includes the Wyze Video Doorbell v2, Wyze Lock Bolt (smart lock with fingerprint sensor and backlit keypad), Wyze Cam Pan v3 (pan-and-tilt camera with color night vision), and two Wyze Cam OG Cameras (with motion-activated spotlights and color night vision).
What are the benefits of the Essential Security Bundle featuring Wyze Video Doorbell v2?The Essential Security Bundle provides comprehensive home security by combining video monitoring, smart locking, and motion detection, safeguarding your home from every angle.
Is there a refurbished version of the Wyze Video Doorbell v2 available?Yes, the Refurbished Wyze Video Doorbell v2 offers the same advanced features as the new model at a reduced price, is fully tested, guaranteed to work like new, and comes with a 1-year warranty.
What features are included in the Refurbished Wyze Video Doorbell v2?The refurbished model includes 2K resolution, 135° horizontal and 103° vertical field of view, starlight sensor for color night vision, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.
Why should I choose the Wyze Video Doorbell v2 for home security?The Wyze Video Doorbell v2 stands out for its high-resolution video, local storage, two-way communication, smart deterrence features, weather resistance, and seamless smart home integration, making it a reliable and affordable choice for modern home security.
What are the benefits of using the Wyze Video Doorbell v2 with the Essential Security Bundle?Can you explain how the two-way audio feature works on the Wyze Video Doorbell v2?Do you have any ongoing sales or discounts for the Wyze Video Doorbell v2?
