Smart Doorbells with Automatic Motion-Activated Recording
When it comes to securing your home entrance, a smart doorbell that automatically activates recording upon motion detection is essential. Wyze offers cutting-edge solutions that combine high-resolution video, smart alerts, and seamless integration with your home setup. Among these, the
Wyze Duo Cam Doorbell stands out for its dual-camera design and advanced features, ensuring you never miss a moment at your doorstep.
Wyze Duo Cam Doorbell: Dual Cameras for Complete Coverage
The Wyze Duo Cam Doorbell is designed to provide comprehensive monitoring with two cameras working in tandem:
- Dual Field of View: The top camera offers a wide 132° x 100° view in stunning 2K resolution, while the bottom camera covers a 121° x 60° angle in 1080p. This combination captures both the visitor’s face and packages left on the ground.
- Motion-Activated Recording: Automatically starts recording when motion is detected, ensuring you capture every important event without manual intervention.
- Compatible with Wyze Universal Wi-Fi Chime: Get instant audible alerts anywhere in your home when motion is detected or the doorbell is pressed.
- Flexible Installation: Mount anywhere using 3M adhesive or screws, powered by a removable battery pack or wired AC power (16-24V).
- Local Storage Support: Store up to 256 GB on a microSD card for continuous or event-based recording.
This doorbell is perfect for those who want detailed, multi-angle video coverage with smart notifications and easy installation.
Wyze Video Doorbell v2: Wired Power with 2K Clarity and Smart Features
For users preferring a wired doorbell with advanced capabilities, the Wyze Video Doorbell v2 offers:
- Crystal-Clear 2K Video: Capture every detail on your porch with high-resolution video.
- Pre-Roll Motion Recording: Wired power enables 3-6 seconds of pre-roll footage before motion events, so you don’t miss the start of any activity.
- Motion-Activated Voice Deterrence: Automatically plays a voice prompt to warn visitors they are being recorded, enhancing security.
- Two-Way Audio: Communicate with visitors in real-time through the Wyze app.
- Works with Existing Chimes: Includes a chime controller to keep your traditional doorbell sound.
- Weatherproof (IP65): Built to withstand rain, snow, and harsh weather conditions.
- Custom Detection Zones: Focus motion alerts on specific areas to reduce false alarms.
This wired doorbell is ideal for those wanting reliable power and enhanced security features with smart automation.
Wyze Universal Wi-Fi Chime: Never Miss a Ding-Dong
Complement your Wyze doorbell with the
Wyze Universal Wi-Fi Chime for audible alerts anywhere in your home:
- Plug-and-Play Setup: No wiring needed; simply plug it in and connect via Wi-Fi.
- Smart Automations: Configure the chime to ring not only when the doorbell is pressed but also when motion is detected by your Wyze cameras.
- Works with All Wyze Cameras: Especially optimized for Wyze Duo Cam Doorbell and other video doorbells.
- Stay Informed: Hear alerts in any room, so you never miss visitors or deliveries.
This accessory enhances your smart doorbell system by providing convenient, customizable chime notifications.
Enhance Your Home Security with Wyze Cam v4 and Wyze Cam Pan v3
While the Wyze Duo Cam Doorbell and Video Doorbell v2 focus on your front door, consider adding these cameras for broader home coverage:
Wyze Cam v4
- 2.5K QHD Resolution: Crystal-clear video with enhanced color night vision.
- Motion-Activated Spotlight: Automatically lights up when motion is detected.
- Wi-Fi 6 Support: Faster and more reliable connectivity.
- IP65 Weatherproof: Suitable for indoor and outdoor use.
- Local Storage: Supports microSD cards up to 512 GB.
- Smart Home Integration: Works with Alexa and Google Assistant.
Wyze Cam Pan v3
- 360° Pan and 180° Tilt: Complete room coverage with remote control.
- 1080p HD Video: Clear video day and night with IR LEDs.
- IP65 Weather Resistant: Durable for outdoor use (with optional power adapter).
- Two-Way Audio: Talk and listen through the camera.
- Smart Alerts: Push notifications for motion detection.
These cameras complement your smart doorbell by covering other vulnerable areas around your home.
Why Choose Wyze Smart Doorbells?
"Wyze smart doorbells combine high-resolution video, smart motion detection, and seamless integration with your home’s existing chimes and smart devices. Whether you want dual-camera coverage or wired reliability, Wyze offers solutions that activate recording automatically when motion is detected, keeping your home safe and connected."
Wyze Cam Pan v3 providing weather-resistant outdoor security
Communicate with visitors using Wyze two-way audio
Summary of Featured Products
- Wyze Duo Cam Doorbell: Dual 2K + 1080p cameras, motion-activated recording, battery or wired power, local storage support.
- Wyze Video Doorbell v2: Wired 2K video, pre-roll recording, voice deterrence, two-way talk, weatherproof.
- Wyze Universal Wi-Fi Chime: Wireless chime alerts triggered by doorbell or motion detection.
- Wyze Cam v4: 2.5K QHD, spotlight, Wi-Fi 6, color night vision, indoor/outdoor.
- Wyze Cam Pan v3: 360° pan/tilt, 1080p, weather resistant, two-way audio.
Upgrade your home security with Wyze smart doorbells and cameras that activate recording automatically when motion is detected, ensuring you stay informed and protected at all times.
What are the key features of the Wyze Duo Cam Doorbell?
The Wyze Duo Cam Doorbell features dual cameras for complete coverage, offering a top camera with a 132° x 100° field of view in 2K resolution and a bottom camera with a 121° x 60° angle in 1080p. It provides motion-activated recording, compatibility with the Wyze Universal Wi-Fi Chime, flexible installation options (adhesive or screws, battery or wired power), and supports local storage up to 256 GB via microSD card.How does motion-activated recording work on Wyze smart doorbells?
Wyze smart doorbells automatically start recording when motion is detected at your doorstep. This ensures that every important event is captured without the need for manual intervention, enhancing your home security and providing peace of mind.What is the difference between the Wyze Duo Cam Doorbell and Wyze Video Doorbell v2?
The Wyze Duo Cam Doorbell offers dual cameras for multi-angle coverage and can be powered by battery or wired AC power, while the Wyze Video Doorbell v2 is a wired-only device with 2K video, pre-roll motion recording, motion-activated voice deterrence, and weatherproof design. Both support smart alerts and two-way audio, but the Duo Cam Doorbell provides more comprehensive video coverage.Can I use my existing chime with Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 includes a chime controller that allows it to work with your existing traditional doorbell chime, so you can keep your familiar doorbell sound while upgrading to smart features.What is the Wyze Universal Wi-Fi Chime and how does it work?
The Wyze Universal Wi-Fi Chime is a plug-and-play accessory that provides audible alerts anywhere in your home when your Wyze doorbell is pressed or when motion is detected by Wyze cameras. It connects via Wi-Fi, requires no wiring, and is compatible with all Wyze cameras, especially optimized for Wyze video doorbells.Does the Wyze Duo Cam Doorbell support local video storage?
Yes, the Wyze Duo Cam Doorbell supports local storage with a microSD card of up to 256 GB, allowing for continuous or event-based recording directly on the device.Are Wyze smart doorbells weatherproof?
The Wyze Video Doorbell v2 is IP65 weatherproof, making it suitable for use in rain, snow, and harsh weather conditions. The Wyze Duo Cam Doorbell is designed for outdoor use, but always check the product specifications for detailed weather resistance ratings.What additional security cameras can I use with Wyze doorbells for complete home coverage?
You can enhance your home security by adding Wyze Cam v4, which offers 2.5K QHD resolution, color night vision, motion-activated spotlight, and Wi-Fi 6 support, or Wyze Cam Pan v3, which provides 360° pan and 180° tilt, 1080p HD video, weather resistance, and two-way audio. These cameras complement your Wyze doorbell by monitoring other areas around your home.Can I communicate with visitors using Wyze smart doorbells?
Yes, both the Wyze Duo Cam Doorbell and Wyze Video Doorbell v2 feature two-way audio, allowing you to talk to and hear from visitors in real-time through the Wyze app.How do custom detection zones work on Wyze Video Doorbell v2?
Custom detection zones on the Wyze Video Doorbell v2 let you specify which areas of the camera’s view should trigger motion alerts. This helps reduce false alarms by focusing on the most important zones, such as your porch or walkway.
