Compact Doorbell Camera with Portrait and Landscape View: Wyze Duo Cam Doorbell
When it comes to securing your home with a compact, versatile doorbell camera that offers both portrait and landscape viewing modes, the
Wyze Video Doorbell v2 stands out as a top choice. Designed for clarity, convenience, and seamless integration with your smart home, this doorbell camera delivers exceptional features that meet modern security needs.
Wyze Video Doorbell v2: Crystal Clear 2K Video and Flexible Viewing
The Wyze Video Doorbell v2 is engineered to provide a sharp, detailed view of your porch and entryway with its impressive 2K resolution. Whether you prefer a portrait or landscape orientation, this doorbell camera adapts to your installation needs, ensuring you capture every visitor and package with precision.
- 2K HD Video Quality: Enjoy high-definition video that captures every detail from head to toe.
- Local microSD Storage: Continuous 24/7 recording with onboard microSD card slot means you never miss a moment before or after the doorbell rings.
- Two-Way Audio: Communicate directly with visitors through the Wyze app, no matter where you are.
- Motion-Activated Voice Deterrence: Automatically warn unwanted guests with a voice prompt when motion is detected.
- Pre-Roll Motion Recording: Capture 3-6 seconds before motion events to get the full context.
- Weatherproof Design: Rated IP65 to withstand rain, snow, and harsh weather conditions.
- Works with Existing Chimes: Includes a chime controller to keep your traditional doorbell sound.
- Smart Home Compatibility: Integrates with Alexa and Google Home for voice commands and live feed viewing.
- Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
- 30° Corner Mount Kit Included: Achieve the perfect angle for your doorbell camera.
"Leave no dong un-dinged" with Wyze Video Doorbell v2 — the perfect blend of compact design and powerful features.
Secure your home with Wyze Video Doorbell v2, capturing every moment in stunning detail.
Enhance Your Smart Home Ecosystem with Wyze Switch
While the Wyze Video Doorbell v2 secures your entryway, the
Wyze Switch complements your smart home by turning ordinary lights into smart lights you can control from anywhere. This compact WiFi light switch is perfect for automating your home lighting and integrating with other Wyze devices.
- Multi-Tap Controls: Customize single, double, triple taps, and press-and-hold actions to control lights, locks, robot vacuums, and sprinklers.
- Smart Control with Wyze Bulbs: Keeps power flowing to smart bulbs to maintain automations without interruption.
- Timers and Schedules: Automate your lighting to fit your lifestyle, including vacation mode to simulate occupancy.
- Power Loss Recovery: Automatically reconnects and restores settings after power outages.
- Easy Installation: Fits standard switch boxes and works seamlessly with the Wyze app.
This switch is an ideal companion to your Wyze Video Doorbell, creating a fully connected and responsive smart home environment.
Control your home lighting effortlessly with Wyze Switch, enhancing your smart home experience.
Optional Lighting and Camera Bundles for Complete Home Coverage
For those looking to expand their smart home security and lighting, Wyze offers bundles like the
Cam v4 + Lamp Socket v2 Bundle. This combo powers the Wyze Cam v4 without needing an outlet, making it perfect for flexible placement and enhanced outdoor lighting.
- Convenient Power Source: The lamp socket powers Wyze Cam v4 directly, eliminating the need for nearby outlets.
- Motion-Activated Lights: Automatically illuminate your space when motion is detected.
- Dusk to Dawn Scheduling: Lights turn on and off based on natural light levels.
- Compact and Durable: Made from polycarbonate and plastic, suitable for damp locations.
This bundle is perfect for users who want to complement their doorbell camera with additional smart lighting and surveillance.
Why Choose Wyze for Your Doorbell Camera Needs?
Wyze combines affordability, advanced technology, and user-friendly design to deliver smart home products that fit seamlessly into your lifestyle. The Wyze Video Doorbell v2’s ability to switch between portrait and landscape views makes it uniquely adaptable to your home’s architecture and security needs. Paired with Wyze Switch and optional lighting bundles, you get a comprehensive smart home system that’s easy to install, control, and expand.
Experience peace of mind with Wyze’s compact, versatile, and powerful doorbell camera solutions.
Summary of Featured Products
Product Name | Key Features | Price Range |
Wyze Video Doorbell v2 | 2K video, local storage, two-way audio, IP65 | $44.98 |
Wyze Switch | Smart light control, multi-tap actions | $14.99 |
Cam v4 + Lamp Socket v2 Bundle | Powers Cam v4, motion-activated lights | $49.96 |
What is the Wyze Video Doorbell v2 and what makes it unique?
The Wyze Video Doorbell v2 is a compact, high-definition doorbell camera that offers both portrait and landscape viewing modes. It features 2K video resolution, local microSD storage for continuous recording, two-way audio, motion-activated voice deterrence, and weatherproof IP65 design. Its flexible installation and smart home compatibility make it a standout choice for modern home security.Does the Wyze Video Doorbell v2 support both portrait and landscape installation?
Yes, the Wyze Video Doorbell v2 is designed to be installed in either portrait or landscape orientation, allowing you to choose the best view for your entryway and ensuring you capture every visitor and package.What video quality does the Wyze Video Doorbell v2 provide?
The Wyze Video Doorbell v2 delivers crystal clear 2K HD video quality, capturing detailed footage from head to toe for enhanced security and peace of mind.Can I store video recordings locally on the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 features a local microSD card slot for continuous 24/7 recording, so you never miss a moment before or after the doorbell rings.Is the Wyze Video Doorbell v2 weatherproof?
Absolutely. The Wyze Video Doorbell v2 is rated IP65, making it weatherproof and capable of withstanding rain, snow, and harsh outdoor conditions.Does the Wyze Video Doorbell v2 work with existing doorbell chimes?
Yes, the Wyze Video Doorbell v2 includes a chime controller, allowing it to work seamlessly with your existing traditional doorbell chime.Is the Wyze Video Doorbell v2 compatible with Alexa and Google Home?
Yes, the Wyze Video Doorbell v2 integrates with Alexa and Google Home, enabling voice commands and live feed viewing for a smarter home experience.What is motion-activated voice deterrence on the Wyze Video Doorbell v2?
Motion-activated voice deterrence is a feature that automatically plays a voice prompt to warn unwanted guests when motion is detected, enhancing your home’s security.What is pre-roll motion recording on the Wyze Video Doorbell v2?
Pre-roll motion recording captures 3-6 seconds of video before a motion event occurs, providing you with the full context of what triggered the alert.What is included with the Wyze Video Doorbell v2 for installation?
The Wyze Video Doorbell v2 comes with a 30° corner mount kit, allowing you to achieve the perfect angle for your doorbell camera installation.What is the Wyze Switch and how does it enhance my smart home?
The Wyze Switch is a compact WiFi light switch that turns ordinary lights into smart lights. It offers multi-tap controls, timers, schedules, power loss recovery, and seamless integration with the Wyze app, making it easy to automate and control your home lighting from anywhere.Can the Wyze Switch control other Wyze devices?
Yes, the Wyze Switch supports multi-tap controls, allowing you to customize actions to control Wyze lights, locks, robot vacuums, and sprinklers for a fully connected smart home.What is the Cam v4 + Lamp Socket v2 Bundle and how does it work?
The Cam v4 + Lamp Socket v2 Bundle allows you to power the Wyze Cam v4 directly from a lamp socket, eliminating the need for nearby outlets. It also features motion-activated lights and dusk-to-dawn scheduling for enhanced outdoor lighting and security.Why should I choose Wyze for my doorbell camera and smart home needs?
Wyze offers affordable, advanced, and user-friendly smart home products. The Wyze Video Doorbell v2’s flexible viewing modes, paired with the Wyze Switch and optional lighting bundles, provide a comprehensive, easy-to-install, and expandable smart home security system.How much does the Wyze Video Doorbell v2 cost?
The Wyze Video Doorbell v2 is priced at $44.98, offering premium features like 2K video, local storage, and smart home integration at an affordable price.
