Wyze Doorbell v2: 2K Resolution Porch Security & Smart Features
Wyze Video Doorbell v2: Ultimate 2K Porch Security
When it comes to detailed porch security, the Wyze Video Doorbell v2 stands out as the clearest and most capable wired video doorbell on the market. Designed to give you peace of mind, this smart doorbell delivers crystal-clear 2K resolution video, capturing every visitor and package with stunning detail.
Key Features of Wyze Video Doorbell v2
  • 2K Video Quality: Enjoy immaculate head-to-toe video clarity that ensures you never miss a detail on your porch.
  • Local microSD Storage: Unique to this model, the onboard microSD card slot allows for continuous 24/7 local recording, so you can review footage anytime without relying solely on cloud storage.
  • Two-Way Audio: Communicate instantly with visitors through the Wyze app, whether you're at home or away.
  • Motion-Activated Voice Deterrence: Automatically warn unwanted visitors with a voice prompt when motion is detected (requires Cam Plus subscription).
  • Pre-Roll Motion Recording: Capture 3-6 seconds before motion events, thanks to wired power, giving you context before activity starts.
  • Works with Existing Chimes: Includes a chime controller so your traditional doorbell chime still rings.
  • IP65 Weatherproof: Built to withstand rain, snow, and harsh weather conditions.
  • Color Night Vision: Equipped with an award-winning starlight sensor for vivid color video even in low light.
  • Smart Home Integration: Compatible with Alexa and Google Home for voice commands and live feed viewing.
  • 30° Corner Kit Included: Comes with an angled mounting wedge to optimize your doorbell’s viewing angle and eliminate blind spots.
"Answer your door from anywhere with our clearest and most capable wired video doorbell yet."
Wyze Video Doorbell v2 lifestyle Experience crystal-clear 2K video and two-way audio for detailed porch security.
Enhance Porch Security with Wyze Cam Floodlight v2
For those looking to complement their porch security with powerful lighting and wide-angle surveillance, the Wyze Cam Floodlight v2 is an excellent companion to the Wyze Video Doorbell v2.
Why Choose Wyze Cam Floodlight v2?
  • 2K Video with 160° Wide-Angle View: Capture a broad view of your porch and driveway with sharp 2K resolution.
  • 2800 Lumens LED Floodlights: Bright, adjustable, and motion-activated lights that illuminate your property and deter intruders.
  • Ambient Light Mode: Provides a constant low-level light that brightens automatically when motion is detected.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Two-Way Talk & Loud Siren: Communicate with visitors or scare off unwanted guests with a 105dB siren.
  • 270° PIR Motion Detection: Eliminates blind spots with a wide motion detection area.
  • Dusk-to-Dawn Automation: Automatically turns lights on at sunset and off at sunrise.
  • IP65 Weatherproof: Durable for all weather conditions.
  • Smart Assistant Compatibility: Works seamlessly with Alexa and Google Home.
  • Easy DIY Installation: Optional plug-in mount available for renters or those without junction boxes.
"Dominate the dark with 2800 Lumens LEDs, 2K video with Color Night Vision, and a 160° wide-angle view."
Wyze Cam Floodlight v2 illuminating driveway Brighten your porch and driveway with motion-activated floodlights and 2K video.
Optional Accessories for Perfect Installation and Coverage
To maximize your porch security coverage, especially on angled door frames or porches with stairs, the Wyze Video Doorbell v2 Wedge Kit is the perfect accessory. It allows you to adjust the doorbell’s viewing angle easily, eliminating blind spots and ensuring you capture every important moment.
  • Includes 15° horizontal and 7.5° vertical brackets.
  • Weather-resistant and quick to install.
  • Enhances your doorbell’s field of view for superior security.
Why Choose Wyze for Porch Security?
Wyze combines affordable pricing with advanced technology to deliver smart home security solutions that are easy to install and use. The Wyze Video Doorbell v2 with its 2K resolution and local storage capability ensures you never miss a moment on your porch, while the Wyze Cam Floodlight v2 adds powerful illumination and wide-angle coverage to keep your home safe day and night.
Protect your home with smart, reliable, and detailed porch security solutions from Wyze.
Summary of Featured Products
Wyze Video Doorbell v2 Wyze Cam Floodlight v2 Wyze Video Doorbell v2 Wedge Kit
Enhance your home’s porch security today with Wyze’s cutting-edge 2K video doorbell and floodlight solutions — detailed, reliable, and designed for your peace of mind.
FeatureWyze Video Doorbell v2Wyze Cam Floodlight v2Wyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellFloodlight CameraAccessory (Wedge Kit)
Video Resolution2K2KN/A
Field of ViewHead-to-toe view160° wide-angleN/A
Local StoragemicroSD card slot (24/7 local recording)microSD card slot (24/7 local recording)N/A
Cloud StorageOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionN/A
Two-Way AudioYesYesN/A
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)Yes (with Cam Plus)N/A
Pre-roll Motion Recording3-6 secondsN/AN/A
Chime CompatibilityWorks with existing chime; includes chime controllerN/AN/A
Night VisionColor Night Vision (Starlight sensor)Color Night VisionN/A
LightingN/A2 x 2800 lumen adjustable, motion-activated LEDsN/A
Weather ResistanceIP65IP65Weather resistant
Smart Assistant CompatibilityAlexa, Google HomeAlexa, Google HomeN/A
Mounting Kit Included30° Corner Kit (angled mounting wedge)N/AIncludes 1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, screws, quick start guide
InstallationWired, includes chime controllerWiredQuick installation
MaterialN/AN/APlastic
ColorN/ABlack, WhiteBlack
Price$44.98$89.98Wedge Kit Only: $8.99; Doorbell v2 + Wedge Kit: $51.97
WarrantyN/AN/A1 year
What is the video resolution of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features crystal-clear 2K resolution, providing immaculate head-to-toe video clarity so you never miss a detail on your porch.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 has an onboard microSD card slot for continuous 24/7 local recording, allowing you to review footage anytime without relying solely on cloud storage.
Can I use my existing doorbell chime with the Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 includes a chime controller, so your traditional doorbell chime will still ring when someone presses the doorbell.
Is the Wyze Video Doorbell v2 weatherproof?Absolutely. The Wyze Video Doorbell v2 is IP65 weatherproof, making it durable and reliable in rain, snow, and harsh weather conditions.
Does the Wyze Video Doorbell v2 have night vision?Yes, it is equipped with an award-winning starlight sensor for vivid color night vision, ensuring clear video even in low-light conditions.
Can I talk to visitors through the Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 features two-way audio, allowing you to communicate instantly with visitors through the Wyze app, whether you are at home or away.
What is pre-roll motion recording on the Wyze Video Doorbell v2?Pre-roll motion recording captures 3-6 seconds of video before a motion event occurs, giving you important context before activity starts. This feature is possible thanks to the doorbell’s wired power.
Is the Wyze Video Doorbell v2 compatible with smart home assistants?Yes, the Wyze Video Doorbell v2 works with Alexa and Google Home, allowing for voice commands and live feed viewing.
What is the Wyze Cam Floodlight v2 and how does it enhance porch security?The Wyze Cam Floodlight v2 is a companion security camera with 2K video resolution, a 160° wide-angle view, and 2800 lumens of motion-activated LED floodlights. It provides powerful lighting, wide surveillance, and features like two-way talk, a loud siren, and 24/7 local recording to enhance your porch and driveway security.
Does the Wyze Cam Floodlight v2 support local recording?Yes, the Wyze Cam Floodlight v2 supports continuous 24/7 local recording to a microSD card (up to 256GB) without any subscription fees.
Is the Wyze Cam Floodlight v2 weatherproof?Yes, the Wyze Cam Floodlight v2 is IP65 weatherproof, making it suitable for all weather conditions.
Can I install the Wyze Cam Floodlight v2 myself?Yes, the Wyze Cam Floodlight v2 is designed for easy DIY installation and offers an optional plug-in mount for renters or those without junction boxes.
What is included in the Wyze Video Doorbell v2 Wedge Kit?The Wyze Video Doorbell v2 Wedge Kit includes 15° horizontal and 7.5° vertical brackets, allowing you to adjust the doorbell’s viewing angle to eliminate blind spots and maximize coverage. The kit is weather-resistant and quick to install.
Why should I choose Wyze for porch security?Wyze offers affordable, advanced smart home security solutions that are easy to install and use. With features like 2K resolution, local storage, powerful floodlights, and smart home integration, Wyze products provide reliable and detailed porch security for your peace of mind.
What are the key features of the Wyze Video Doorbell v2?How does the local microSD storage work for the Wyze Video Doorbell v2?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Video Doorbell v2?
