Wyze Video Doorbell v2: Local & Cloud Storage Options Explained
Wyze Video Doorbell v2 Storage Options
When it comes to securing your home with a smart video doorbell, storage options are a critical factor. The Wyze Video Doorbell v2 stands out with its versatile and user-friendly storage capabilities, designed to keep your footage safe and accessible.
Local Storage with microSD Card
One of the most notable features of the Wyze Video Doorbell v2 is its built-in microSD card slot. This onboard storage allows for 24/7 continuous local recording, meaning you can capture every moment on your porch without relying solely on cloud services. The local storage option provides peace of mind by keeping your video footage directly accessible on the device, reducing dependency on internet connectivity.
  • Supports microSD cards for continuous recording
  • Allows you to review footage before and after motion events or doorbell presses
  • No monthly fees required for local storage use
  • Compatible with microSD cards up to 128GB (sold separately or bundled)
Cloud Storage with Cam Plus Subscription
For users who want enhanced features, Wyze offers the Cam Plus subscription. This cloud-based service provides: Unlimited event video cloud storage
  • AI-powered person, package, and vehicle detection
  • Smarter, real-time notifications
  • Motion-activated voice deterrence
The Cam Plus plan starts with a free 30-day trial and then continues at $2.99/month per camera, offering a seamless way to store and access your videos remotely.
Refurbished Wyze Video Doorbell v2 Storage
If you're considering a budget-friendly option, the Refurbished Wyze Video Doorbell v2 also supports the same local microSD storage capabilities as the new model. It supports microSD cards up to 256GB in FAT32 format, providing ample space for continuous recording. This refurbished model is fully tested and guaranteed to work like new, offering the same 2K video quality and storage flexibility at a reduced price.
Additional Storage-Related Features of Wyze Video Doorbell v2
Pre-roll Motion Recording
Thanks to its wired power setup, the Wyze Video Doorbell v2 can capture 3-6 seconds of pre-roll video before a motion event starts. This feature ensures you don’t miss any critical moments leading up to detected activity.
Compatibility with Existing Chimes
The doorbell includes a chime controller that works with your home’s existing mechanical chime, so you don’t lose the traditional doorbell sound when upgrading to smart video doorbell technology.
Weatherproof and Reliable
Rated IP65 weatherproof, the Wyze Video Doorbell v2 is built to withstand harsh weather conditions, ensuring your local storage and video capture remain uninterrupted year-round.
Why Choose Wyze Video Doorbell v2 for Storage?
"Wyze Video Doorbell v2 offers the perfect balance of local and cloud storage options, giving you control, flexibility, and peace of mind."
  • Local microSD storage means no monthly fees and instant access to footage
  • Cloud storage with Cam Plus adds AI detection and unlimited video history
  • Refurbished option provides the same storage benefits at a lower cost
  • Pre-roll recording captures crucial moments before motion events
  • Weatherproof design ensures reliable operation in all conditions
Homeowner checking Wyze Video Doorbell on smartphone Alt text: Homeowner monitoring front door with Wyze Video Doorbell v2 on smartphone
Related Accessories for Optimal Coverage
To complement your Wyze Video Doorbell v2 and maximize your video coverage, consider the Wyze Video Doorbell v2 Wedge Kit. This accessory allows you to adjust the viewing angle, eliminating blind spots and ensuring your local storage captures every important detail.
Summary
The Wyze Video Doorbell v2 is a top choice for anyone looking for flexible, reliable storage options in a smart doorbell. Whether you prefer local microSD storage for continuous recording or enhanced cloud storage with Cam Plus, Wyze provides a solution tailored to your needs. The refurbished model offers the same great features at a budget-friendly price, making smart home security accessible to all.
FeatureWyze Video Doorbell v2 (Refurbished)Wyze Video Doorbell v2Wyze Video Doorbell (Wired)
ConditionRefurbished, tested & guaranteedNewNew
Price$29.98$44.98$29.99 (Doorbell Only), $34.99 (With Chime)
Video Resolution2K (2048 x 1536)2K (2048 x 1536)1080p Full HD (2048 x 1536 sensor)
Local StoragemicroSD card slot for 24/7 local recordingmicroSD card slot for 24/7 local recordingmicroSD card support
Two-way AudioYesYesYes
Motion-activated Voice DeterrenceYes (requires Cam Plus subscription)Yes (requires Cam Plus subscription)No
Pre-roll Motion Recording3-6 seconds3-6 secondsNo
Works with Existing ChimeYes, includes chime controllerYes, includes chime controllerNo, existing chime will not work after install
Weather ResistanceIP65IP65IP65
Night VisionColor Night Vision with starlight sensorColor Night Vision with starlight sensorInfrared night vision (4 x 940nm IR LEDs)
Field of ViewNot specifiedNot specified120° Vertical x 88° Horizontal
ConnectivityWired (hardwired)Wired (hardwired)Wired (hardwired)
Compatibility with Alexa/Google HomeYesYesYes
Quick Responses (preset messages)YesYesNo
Custom Detection ZonesYesYesNo
WarrantyNot specified (final sale)Standard Wyze warrantyStandard Wyze warranty
Return PolicyFinal sale, no returns30-day hassle-free returnsNot specified
What storage options are available with the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers both local storage via a built-in microSD card slot and cloud storage through the Cam Plus subscription. This allows users to choose between 24/7 continuous local recording or unlimited event video cloud storage with advanced features.
How does local storage work on the Wyze Video Doorbell v2?Local storage on the Wyze Video Doorbell v2 is enabled by inserting a microSD card (up to 128GB for new models and up to 256GB in FAT32 format for refurbished models). This allows for 24/7 continuous recording, so you can review footage before and after motion events or doorbell presses without any monthly fees.
Is there a monthly fee for using local storage on the Wyze Video Doorbell v2?No, there are no monthly fees required for using local storage with a microSD card on the Wyze Video Doorbell v2. All footage is stored directly on the device and is accessible at any time.
What is the Cam Plus subscription and what does it offer?The Cam Plus subscription is a cloud-based service for the Wyze Video Doorbell v2 that provides unlimited event video cloud storage, AI-powered person, package, and vehicle detection, smarter real-time notifications, and motion-activated voice deterrence. It starts with a free 30-day trial and costs $2.99/month per camera.
Does the refurbished Wyze Video Doorbell v2 support the same storage options?Yes, the refurbished Wyze Video Doorbell v2 supports the same local microSD storage capabilities as the new model, with compatibility for microSD cards up to 256GB in FAT32 format. It also offers the same 2K video quality and storage flexibility at a lower price.
What is pre-roll motion recording on the Wyze Video Doorbell v2?Pre-roll motion recording is a feature that captures 3-6 seconds of video before a motion event starts. This ensures you don’t miss any important moments leading up to detected activity, providing a more complete view of events at your door.
Is the Wyze Video Doorbell v2 weatherproof?Yes, the Wyze Video Doorbell v2 is rated IP65 weatherproof, making it reliable for year-round use in various weather conditions. This ensures your local storage and video capture remain uninterrupted.
Can I use my existing doorbell chime with the Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 includes a chime controller that is compatible with your home’s existing mechanical chime, so you can keep your traditional doorbell sound while upgrading to smart technology.
What accessories are available to enhance the Wyze Video Doorbell v2’s coverage?The Wyze Video Doorbell v2 Wedge Kit is available as an accessory to help adjust the viewing angle of your doorbell. This eliminates blind spots and ensures your local storage captures every important detail.
Why should I choose the Wyze Video Doorbell v2 for home security storage?The Wyze Video Doorbell v2 offers flexible storage options, including local microSD storage with no monthly fees and cloud storage with advanced AI features. Its weatherproof design, pre-roll recording, and compatibility with refurbished models make it a reliable and cost-effective choice for smart home security.
What are the benefits of using local storage with the Wyze Video Doorbell v2?Can you explain how the Cam Plus subscription enhances the storage options for the Wyze Video Doorbell v2?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Video Doorbell v2?
