Wyze Cam v4 Trio: 3-Pack Smart Security Cameras for Home & Business
Discover the Wyze Cam v4 Trio: Ultimate Home Security Solution
If you're searching for a reliable, high-quality security camera set, the Wyze Cam v4 Trio is the perfect choice. This bundle offers three Wyze Cam v4 units, providing comprehensive coverage for your home or business. Known for its advanced features, durable design, and smart integrations, the Wyze Cam v4 is a top contender in the smart camera market.
Why Choose the Wyze Cam v4 Trio?
The Wyze Cam v4 Trio pack is designed to give you peace of mind with multiple cameras working seamlessly together. Whether you want to monitor different rooms, entrances, or outdoor spaces, this trio pack ensures you never miss a moment.
Key Features of Wyze Cam v4
Crystal-clear 2.5K QHD Video Resolution Capture every detail with stunning 2560x1440 resolution, ensuring sharp and clear footage day and night. Enhanced Color Night Vision Unlike traditional infrared night vision, Wyze Cam v4 offers vibrant color night vision thanks to its 4 IR LEDs and 2 white spotlight LEDs (72 lumens), so you can see more clearly in low light. Wide Field of View With a diagonal field of view of 115.8°, horizontal 98.5°, and vertical 53.1°, these cameras cover a broad area, reducing blind spots. Robust Weather Resistance (IP65) Suitable for both indoor and outdoor use, the Wyze Cam v4 withstands harsh weather conditions, operating in temperatures from -4°F to 122°F (-20°C to 50°C). Smart Connectivity and Compatibility Supports Wi-Fi 6 and 2.4 GHz Wi-Fi for fast, reliable connections. Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation. Two-Way Audio with Built-in Siren Communicate directly through the camera with noise and echo cancellation, or use the 99dB waterproof speaker siren to deter intruders. Flexible Mounting Options Includes stand, wall mount, ceiling mount, and magnetic wall mount with adhesive, allowing versatile installation anywhere. Local and Cloud Storage Options Supports microSD cards up to 512 GB for local recording, plus optional cloud storage with subscription plans.
What’s Included in the Wyze Cam v4 Trio Pack?
Each trio pack contains three Wyze Cam v4 units, each with:
  • Wyze Cam v4 camera
  • Quick Start Guide
  • Wall Mount Plate and Tape
  • Screw Kit
  • Indoor USB Power Adapter
  • 6-Foot Flat micro USB to USB-A Cable
This bundle is perfect for those who want to secure multiple areas with one purchase, offering excellent value and convenience.
Ideal Use Cases for the Wyze Cam v4 Trio
  • Home Security: Monitor front door, backyard, and garage simultaneously.
  • Small Business: Keep an eye on entrances, cash registers, and stock rooms.
  • Pet Monitoring: Watch your pets in different rooms or outdoor spaces.
  • Vacation Homes: Ensure your property is safe even when you’re away.
“The Wyze Cam v4 Trio offers unmatched clarity and smart features at an affordable price, making it a must-have for modern home security.”
Technical Specifications at a Glance
FeatureSpecification
Video Resolution2.5K QHD (2560x1440)
Field of View115.8° DFOV / 98.5° HFOV / 53.1° VFOV
SensorCMOS Starlight Sensor
Night Vision4 IR LEDs + 2 White Spotlight LEDs
Audio99dB Waterproof Speaker, Two-Way Talk
ConnectivityWi-Fi 6, 2.4 GHz Wi-Fi, Bluetooth 5.2
StoragemicroSD up to 512 GB, Cloud (Subscription)
Weather ResistanceIP65
Operating Temperature-4°F to 122°F (-20°C to 50°C)
Dimensions2in x 2in x 2 3/8in
Weight0.49 lb (222 g)
Enhance Your Security Setup with the Wyze Cam v4 Trio
Investing in the Wyze Cam v4 Trio means you get three powerful cameras with advanced features, easy installation, and smart home compatibility. Whether you want to protect your home, monitor your pets, or keep an eye on your business, this trio pack delivers exceptional value and performance.
Home Security with Wyze Cam v4 Trio Alt text: Family monitoring home security with Wyze Cam v4 Trio
Summary
The Wyze Cam v4 Trio is a smart, versatile, and affordable security solution that offers:
  • High-resolution 2.5K video
  • Color night vision with spotlight LEDs
  • Weatherproof design for indoor/outdoor use
  • Multiple mounting options
  • Seamless integration with smart home systems
Protect what matters most with the Wyze Cam v4 Trio — your eyes when you’re away.
FeatureWyze Cam v4 (Standard)Wyze Cam v4 (American Worker Support)
Price$35.98$100.00
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Color VariantsBlack, Grey, White, Clear (Clear sold out)Default (no color variants specified)
Pack Options1 Pack, 2 Pack, 3 Pack1 Pack only
Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
Wide Dynamic Range (WDR)YesYes
Weather ResistanceIP65IP65
AudioEnhanced Two-Way Talk (AAC, improved mic & amp)Enhanced Two-Way Talk (AAC, improved mic & amp)
Spotlight + SirenMotion-activated spotlight and 99 dB sirenMotion-activated spotlight and 99 dB siren
Local Recording24/7 local recording to microSD card (up to 256GB)24/7 local recording to microSD card (up to 512GB)
Wi-Fi SupportWi-Fi 6Wi-Fi 6
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Motion & Sound DetectionYesYes
Motion Detection ZonesYesYes
Smoke & CO AlertsYesYes
MountingMagnetic mount with metal plateMagnetic mount with metal plate
SetupBluetooth® setup, no QR codeBluetooth® setup, no QR code
Subscription RequiredNo (Cam Plus optional)No (Cam Plus optional)
MicroSD Card IncludedNoNo
AvailabilityIn stockIn stock
Shipping TimeAs soon as available2-2000 days (variable)
What is included in the Wyze Cam v4 Trio pack?The Wyze Cam v4 Trio pack includes three Wyze Cam v4 cameras, three quick start guides, three wall mount plates and tapes, three screw kits, three indoor USB power adapters, and three 6-foot flat micro USB to USB-A cables. This bundle is designed to provide comprehensive security coverage for multiple areas.
What video quality does the Wyze Cam v4 offer?The Wyze Cam v4 features crystal-clear 2.5K QHD video resolution (2560x1440), ensuring sharp and detailed footage both day and night.
Does the Wyze Cam v4 have color night vision?Yes, the Wyze Cam v4 is equipped with enhanced color night vision. It uses 4 IR LEDs and 2 white spotlight LEDs (72 lumens) to provide vibrant, full-color images even in low-light conditions.
Is the Wyze Cam v4 suitable for outdoor use?Absolutely. The Wyze Cam v4 is IP65 weather resistant, making it suitable for both indoor and outdoor use. It operates reliably in temperatures ranging from -4°F to 122°F (-20°C to 50°C).
What smart home systems is the Wyze Cam v4 compatible with?The Wyze Cam v4 supports Wi-Fi 6 and 2.4 GHz Wi-Fi, and is compatible with Alexa, Google Assistant, and IFTTT for seamless voice control and smart home automation.
Can I communicate through the Wyze Cam v4?Yes, the Wyze Cam v4 features two-way audio with noise and echo cancellation, allowing you to communicate directly through the camera. It also includes a built-in 99dB waterproof speaker siren to deter intruders.
What are the mounting options for the Wyze Cam v4?The Wyze Cam v4 offers flexible mounting options, including a stand, wall mount, ceiling mount, and a magnetic wall mount with adhesive. This allows for versatile installation in various locations.
How does the Wyze Cam v4 store video footage?The Wyze Cam v4 supports local storage with microSD cards up to 512 GB and also offers optional cloud storage through subscription plans, giving you flexible options for recording and accessing your footage.
What are the ideal use cases for the Wyze Cam v4 Trio?The Wyze Cam v4 Trio is perfect for home security (monitoring front doors, backyards, and garages), small business surveillance (entrances, cash registers, stock rooms), pet monitoring, and securing vacation homes.
What are the technical specifications of the Wyze Cam v4?Key technical specifications include: 2.5K QHD video resolution (2560x1440), 115.8° diagonal field of view, CMOS Starlight Sensor, 4 IR LEDs + 2 white spotlight LEDs for night vision, 99dB waterproof speaker with two-way talk, Wi-Fi 6 and 2.4 GHz Wi-Fi connectivity, Bluetooth 5.2, microSD support up to 512 GB, IP65 weather resistance, operating temperature from -4°F to 122°F, and compact dimensions (2in x 2in x 2 3/8in, 0.49 lb).
Why should I choose the Wyze Cam v4 Trio for my security needs?The Wyze Cam v4 Trio offers high-resolution video, advanced color night vision, weatherproof design, multiple mounting options, and smart home integration—all at an affordable price. It's an excellent choice for anyone seeking reliable and versatile security coverage for their home or business.
What are the key features of the Wyze Cam v4?Can you tell me more about the installation options for the Wyze Cam v4 Trio?Are there any ongoing promotions or discounts for the Wyze Cam v4 Trio?
