Wyze Cam v4 with Built-In Siren: Advanced Home Security Camera
Discover the Wyze Cam v4 with Built-In Siren: Ultimate Home Security Solution
When it comes to securing your home, the Wyze Cam v4 stands out as a top-tier choice, especially with its built-in siren feature. This smart security camera combines advanced technology, versatile mounting options, and powerful alert systems to keep your property safe and monitored 24/7. Whether you want indoor or outdoor protection, Wyze offers multiple configurations tailored to your needs.
Wyze Cam v4: Powerful Features with Built-In Siren
The Wyze Cam v4 is designed to deliver crystal-clear security footage and immediate alerts with its integrated siren. Here’s why it’s a must-have:
Key Specifications
  • Built-In Siren: A loud 99dB waterproof siren that can be triggered remotely to deter intruders instantly.
  • Video Quality: Stunning 2.5K QHD (2560x1440) resolution with 8x digital zoom for detailed monitoring.
  • Color Night Vision: Equipped with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for vibrant night-time footage.
  • Sensor: CMOS Starlight Sensor ensures clear images even in low light.
  • Field of View: Wide 115.8° diagonal, 98.5° horizontal, and 53.1° vertical angles cover more area.
  • Audio: Two-way talk with noise and echo cancellation for clear communication.
  • Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for fast, reliable connections.
  • Weather Resistance: Rated IP65, suitable for indoor and outdoor use.
  • Mounting Options: Flexible installation with stand, wall mount, ceiling mount, or magnetic adhesive mount.
  • Storage: Supports microSD cards up to 512GB for local storage, plus cloud options with subscription.
  • Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT integrations.
Included in the Box
  • Wyze Cam v4 camera
  • Wall mount plate and tape
  • Screw kit
  • Indoor USB power adapter and 6-foot micro USB cable
  • Quick start guide
The built-in siren feature is a game-changer, providing an immediate audible deterrent that enhances your home security beyond just video monitoring.
Wyze Cam v4 Outdoor Bundle: Enhanced Protection for Your Exterior
For those seeking robust outdoor security, the Wyze Cam v4 Outdoor Bundle offers everything you need:
Outdoor Bundle Highlights
  • Enhanced Color Night Vision: See vivid colors even in low light, thanks to advanced spotlight technology.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, improving visibility and scaring off potential threats.
  • 24/7 Local Recording: Continuous recording to a microSD card ensures no moment is missed.
  • Wi-Fi 6 Support: Faster and more stable wireless connection for outdoor environments.
  • Smart Alerts: Motion and sound detection with customizable detection zones.
  • Smoke and CO Alerts: Integrated safety notifications for your home environment.
  • Weatherproof Design: Built to withstand outdoor conditions with IP65 rating.
  • Included Items: Wyze Cam v4, outdoor power adapter, and 128GB microSD card.
This bundle is perfect for monitoring driveways, backyards, and entry points with the added convenience of wired power and extended storage.
Home Security Camera in Use
Wyze Cam v4 + FREE 32GB MicroSD Card: Ready to Record Right Away
If you want a great deal with immediate recording capability, the Wyze Cam v4 + FREE 32GB MicroSD Card package is ideal:
  • Same powerful 2.5K QHD resolution and color night vision.
  • Motion-activated spotlight and person detection for precise alerts.
  • Supports Wi-Fi 6 for smooth connectivity.
  • Requires outdoor power adapter for wired operation.
  • Includes a free 32GB microSD card for local video storage.
  • Perfect for users who want to start recording instantly without additional purchases.
Cam v4 + Lamp Socket v2 Bundle: Smart Power and Lighting Integration
Take your Wyze Cam v4 setup to the next level with the Lamp Socket v2 Bundle:
  • Convenient Power Source: Powers your Wyze Cam v4 directly from a lamp socket, eliminating the need for a separate outlet.
  • Motion-Activated Lights: Automatically turns on connected lights when motion is detected.
  • Dusk to Dawn Scheduling: Lights operate based on natural light conditions for energy efficiency.
  • Linkability: Connect multiple devices without limits for a comprehensive smart home system.
  • Compatible with Wyze Cam v3, v3 Pro, OG, Pan v3, and v4.
  • Ideal for users wanting to integrate security cameras with smart lighting for enhanced safety.
Whole Home Security Starter Kit: Comprehensive Protection Package
For a complete security solution, the Whole Home Security Starter Kit bundles the Wyze Cam v4 with other essential devices:
  • Includes 1x Wyze Cam v4, 1x Wyze Video Doorbell v2, and 1x Wyze Home Monitoring Starter Kit.
  • Available in Black, Grey, or White to match your home decor.
  • Provides multi-angle coverage and smart alerts for doors and windows.
  • Perfect for new users looking to establish a full home security ecosystem.
Why Choose Wyze Cam v4 with Built-In Siren?
The Wyze Cam v4 is more than just a camera; it’s a smart security system with a powerful built-in siren that actively protects your home. Its combination of high-resolution video, color night vision, and smart integrations makes it a leader in affordable home security.
Whether you want to monitor indoors or outdoors, the Wyze Cam v4 and its bundles offer flexible, reliable, and feature-rich options to keep your home safe day and night.
Family Using Home Security App
Summary of Wyze Cam v4 Products Featuring Built-In Siren
Product NamePrice (USD)Key FeaturesIdeal For
Wyze Cam v4$100.00Built-in siren, 2.5K QHD, IP65Indoor/outdoor versatile
Wyze Cam v4 Outdoor Bundle$69.99Outdoor power, spotlight, 128GB SDOutdoor security
Wyze Cam v4 + FREE 32GB MicroSD$35.98Free SD card, color night visionReady-to-use recording
Cam v4 + Lamp Socket v2 Bundle$49.96Powers via lamp socket, motion lightSmart lighting integration
Whole Home Security Starter Kit$155.95Includes doorbell & monitoring kitFull home security setup
Smart Home Security Lifestyle
Protect your home with the Wyze Cam v4 and its powerful built-in siren — a smart, reliable, and affordable security solution designed to give you peace of mind.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 + FREE 32GB MicroSD CardCam v4 + Lamp Socket v2 BundleWhole Home Security Starter Kit
Price$100.00$69.99$35.98$49.96$155.95
Included AccessoriesNoneOutdoor Power Adapter, 128GB microSD CardFREE 32GB microSD CardLamp Socket v2Wyze Cam v4, Wyze Video Doorbell v2, Home Monitoring Starter Kit
Resolution2.5K QHD2.5K QHD2.5K QHD2.5K QHD2.5K QHD
Color Night VisionYesYesYesYesYes
Weather ResistanceIP65IP65IP65Not weatherproof (Lamp Socket)IP65 (Wyze Cam v4)
Motion-Activated SpotlightYesYesYesYesYes
MicroSD Card SupportUp to 512GB (sold separately)128GB included32GB includedRequires microSD card (sold separately)Requires microSD card (sold separately)
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 62.4GHz Wi-Fi (Lamp Socket)Wi-Fi 6
Two-Way TalkEnhancedEnhancedEnhancedEnhancedEnhanced
Siren99 dB99 dB99 dB99 dB99 dB
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Continuous Local RecordingYes (wired)Yes (wired)Yes (wired)Yes (wired)Yes (wired)
Outdoor UseRequires Outdoor Power Adapter (sold separately)Outdoor Power Adapter includedRequires Outdoor Power Adapter (sold separately)Requires Outdoor Power Adapter (sold separately)Requires Outdoor Power Adapter (sold separately)
MountingMagnetic mountMagnetic mountMagnetic mountMagnetic mountMagnetic mount
Additional FeaturesAuto-Zoom with AI, Smoke & CO Alerts, Motion Detection ZonesSame as Wyze Cam v4 + Outdoor Power Adapter & 128GB microSDSame as Wyze Cam v4 + FREE 32GB microSDLamp Socket: Motion-Activated Lights, Dusk to Dawn SchedulingIncludes Video Doorbell v2 and Home Monitoring Kit
What is the Wyze Cam v4 and what makes it unique?The Wyze Cam v4 is a smart home security camera featuring a built-in 99dB waterproof siren, 2.5K QHD video resolution, color night vision, and advanced connectivity options. Its integrated siren can be triggered remotely to deter intruders, making it a standout choice for both indoor and outdoor security.
How does the built-in siren on the Wyze Cam v4 work?The Wyze Cam v4 includes a powerful 99dB waterproof siren that can be activated remotely through the Wyze app. This feature provides an immediate audible deterrent to scare off intruders and enhance your home security beyond just video monitoring.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It can withstand various weather conditions and is ideal for monitoring driveways, backyards, and entry points.
What video quality does the Wyze Cam v4 offer?The Wyze Cam v4 delivers stunning 2.5K QHD (2560x1440) resolution with 8x digital zoom, ensuring detailed and clear security footage both day and night.
Does the Wyze Cam v4 have night vision?Yes, the Wyze Cam v4 features advanced color night vision with 4 IR LEDs and 2 white spotlight LEDs, allowing you to see vibrant, full-color footage even in low-light conditions.
What are the storage options for Wyze Cam v4 recordings?The Wyze Cam v4 supports local storage with microSD cards up to 512GB and also offers cloud storage options through a subscription. Some bundles include a free microSD card for immediate recording capability.
What smart home integrations does the Wyze Cam v4 support?The Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your existing smart home ecosystem.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card. It features enhanced color night vision, a motion-activated spotlight, 24/7 local recording, and a weatherproof design.
How does the Cam v4 + Lamp Socket v2 Bundle enhance home security?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 directly from a lamp socket, eliminating the need for a separate outlet. It also features motion-activated lights, dusk to dawn scheduling, and the ability to link multiple devices for comprehensive smart home security.
What is included in the Whole Home Security Starter Kit?The Whole Home Security Starter Kit includes one Wyze Cam v4, one Wyze Video Doorbell v2, and one Wyze Home Monitoring Starter Kit. It provides multi-angle coverage, smart alerts for doors and windows, and is available in Black, Grey, or White.
Does the Wyze Cam v4 support two-way audio?Yes, the Wyze Cam v4 features two-way talk with noise and echo cancellation, allowing you to communicate clearly with anyone near the camera.
What mounting options are available for the Wyze Cam v4?The Wyze Cam v4 offers flexible installation options, including stand, wall mount, ceiling mount, and magnetic adhesive mount, making it easy to position the camera wherever you need it.
What connectivity options does the Wyze Cam v4 offer?The Wyze Cam v4 supports Wi-Fi 6 and Bluetooth 5.2, ensuring fast and reliable connections for smooth video streaming and smart home integration.
Are there any special deals or bundles available for the Wyze Cam v4?Yes, Wyze offers several bundles, including the Wyze Cam v4 Outdoor Bundle, Wyze Cam v4 + FREE 32GB MicroSD Card, Cam v4 + Lamp Socket v2 Bundle, and the Whole Home Security Starter Kit, each designed to meet different home security needs.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam v4 Outdoor Bundle?Are there any discounts or promotions currently available for the Wyze Cam v4?
