Wyze Cam Pan v3 Starter Pack for Home Surveillance
When it comes to securing your home with smart, reliable, and versatile cameras, the
Wyze Cam Pan v3 Starter Pack stands out as an exceptional choice. Designed for both indoor and outdoor use, this starter pack offers comprehensive surveillance capabilities with advanced features that ensure your home stays safe around the clock.
Why Choose Wyze Cam Pan v3 for Home Surveillance?
The Wyze Cam Pan v3 is a redesigned security camera that delivers 360° horizontal pan and 180° vertical tilt, providing full coverage of your home environment. Its IP65 weather resistance rating means it can withstand rain, snow, and dust, making it perfect for outdoor monitoring when paired with the Wyze Outdoor Power Adapter (sold separately).
Key Features of Wyze Cam Pan v3
- 360° Pan & 180° Tilt: Complete panoramic coverage with smooth rotation up to 110° per second.
- 1080p Full HD Video: Crisp and clear video quality with H.264 encoding.
- Color Night Vision: Equipped with 4 IR LEDs (850 nm) for clear night-time footage.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for real-time communication.
- Smart Alerts: Push notifications keep you informed of any detected motion or sound.
- Storage Options: Supports up to 256 GB microSD card for local storage and cloud options.
- Connectivity: Compatible with 2.4 GHz Wi-Fi networks and integrates seamlessly with Alexa, Google Assistant, and IFTTT.
- Durability: Polycarbonate body with a matte finish, weighing just 11.29 oz (320 g).
- Operating Range: Works in temperatures from -20°C to 50°C (-4°F to 122°F).
This camera is ideal for monitoring pets, children, or your property, indoors or outdoors, with a sleek design available in black or white.
Wyze Cam Pan v3 weather-resistant outdoor surveillance
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
For those looking to enhance their home security experience, the
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera with an added 30-day trial of Cam Plus. This subscription service unlocks advanced AI features such as person detection, package detection, and unlimited video event recording.
Bundle Highlights
- Includes one Wyze Cam Pan v3 with all the features listed above.
- Comes with a power adapter, mounting kit, and quick start guide for easy setup.
- Enables color night vision for clearer images in low light.
- Push notifications and two-way audio for instant communication.
- Compatible with Android 9.0+ and iOS 15.0+ devices.
This bundle is perfect for users who want to maximize their surveillance capabilities with smart AI-powered alerts and extended video history.
Enhance Your Setup with Wyze Accessories
Wyze Cam Pan v3 Skins by dBrand
Personalize and protect your Wyze Cam Pan v3 with stylish vinyl skins available in Green Camo or Triple Black. These precision-cut skins prevent scratches and add a unique look to your camera without compromising functionality.
Wyze Cam Pan v3 USB Cable
Keep your camera powered with an official replacement USB cable designed specifically for the Wyze Cam Pan v3. Affordable and reliable, this cable ensures your camera stays connected without interruption.
Pan v3 + Lamp Socket v2 Bundle
Make your outdoor lighting smarter and more convenient by powering your Wyze Cam Pan v3 through the
Lamp Socket v2. This accessory allows you to power the camera without needing a traditional outlet, ideal for porch or garden setups.
- Compatible with Wyze Cam Pan v3 and other Wyze Cam models.
- Supports 120V power input with Bluetooth and Wi-Fi connectivity.
- Suitable for damp locations with a durable polycarbonate and plastic build.
Experience Smart Home Security with Wyze Cam Pan v3
The Wyze Cam Pan v3 Starter Pack is a comprehensive solution for anyone seeking reliable, high-quality home surveillance. Its weather-resistant design, wide field of view, and smart features make it a top choice for indoor and outdoor security needs.
"With 360° coverage and color night vision, Wyze Cam Pan v3 keeps your home safe day and night."
Communicate instantly with two-way audio
Technical Specifications at a Glance
Feature | Specification |
Video Resolution | 1920 x 1080 (1080p) |
Pan & Tilt Range | 360° horizontal, 180° vertical |
Night Vision | 4 IR LEDs (850 nm), color night vision |
Audio | Built-in speaker & microphone, 2-way |
Connectivity | 802.11 b/g/n 2.4 GHz Wi-Fi |
Storage | Up to 256 GB microSD, cloud options |
Weather Resistance | IP65 rated for outdoor use |
Operating Temperature | -20°C to 50°C (-4°F to 122°F) |
Dimensions | 124mm x 60mm x 63mm |
Weight | 11.29 oz (320 g) |
Secure your home with the Wyze Cam Pan v3 Starter Pack and enjoy peace of mind with smart, reliable surveillance that adapts to your lifestyle.
What is included in the Wyze Cam Pan v3 Starter Pack?
The Wyze Cam Pan v3 Starter Pack includes the Wyze Cam Pan v3 security camera, a power adapter, a mounting kit, and a quick start guide. It is designed for both indoor and outdoor surveillance, offering comprehensive coverage and advanced features.Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is IP65 weather-resistant, making it suitable for outdoor use. It can withstand rain, snow, and dust, especially when paired with the Wyze Outdoor Power Adapter (sold separately).What are the key features of the Wyze Cam Pan v3?
Key features of the Wyze Cam Pan v3 include 360° horizontal pan, 180° vertical tilt, 1080p Full HD video, color night vision with 4 IR LEDs, two-way audio, smart alerts, support for up to 256 GB microSD card, cloud storage options, and compatibility with Alexa, Google Assistant, and IFTTT.Does the Wyze Cam Pan v3 support night vision?
Yes, the Wyze Cam Pan v3 features color night vision and is equipped with 4 IR LEDs (850 nm) to provide clear footage even in low-light or nighttime conditions.How does the Wyze Cam Pan v3 provide full coverage?
The Wyze Cam Pan v3 offers 360° horizontal panning and 180° vertical tilting, allowing it to cover an entire room or outdoor area with smooth rotation up to 110° per second.What storage options are available for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 supports local storage with a microSD card of up to 256 GB and also offers cloud storage options for video recordings.What is the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the Wyze Cam Pan v3 camera and a 30-day trial of Cam Plus, which unlocks advanced AI features such as person detection, package detection, and unlimited video event recording.Which smart home platforms are compatible with Wyze Cam Pan v3?
The Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.What devices are required to use the Wyze Cam Pan v3?
The Wyze Cam Pan v3 is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher.Are there accessories available for the Wyze Cam Pan v3?
Yes, accessories for the Wyze Cam Pan v3 include dBrand vinyl skins for personalization and protection, an official replacement USB cable, and the Lamp Socket v2 for powering the camera through a light socket.What is the operating temperature range for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 operates in temperatures ranging from -20°C to 50°C (-4°F to 122°F), making it suitable for various indoor and outdoor environments.How does the two-way audio feature work on the Wyze Cam Pan v3?
The Wyze Cam Pan v3 has a built-in speaker and microphone with noise and echo cancellation, allowing you to communicate in real-time with people or pets through the Wyze app.Can I personalize the look of my Wyze Cam Pan v3?
Yes, you can personalize your Wyze Cam Pan v3 with dBrand vinyl skins, available in Green Camo or Triple Black, which protect against scratches and add a unique style.What is the video resolution of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 records video in 1080p Full HD resolution (1920 x 1080), ensuring crisp and clear footage.How do smart alerts work on the Wyze Cam Pan v3?
Smart alerts on the Wyze Cam Pan v3 send push notifications to your device whenever motion or sound is detected, keeping you informed of any activity in real time.
