Comprehensive Guide to Wyze Surveillance Cameras
When it comes to securing your home or business, choosing the right surveillance camera is crucial. Wyze offers a diverse lineup of smart cameras designed to meet various security needs, from indoor monitoring to outdoor protection with advanced features like 2.5K video resolution, weather resistance, and intelligent lighting. Explore the standout features of each Wyze surveillance camera to find the perfect fit for your security setup.
Wyze Cam Pan v3: Versatile 360° Indoor/Outdoor Security
The Wyze Cam Pan v3 is a redesigned powerhouse for both indoor and outdoor surveillance. Its 360° pan and 180° tilt capabilities allow you to monitor every corner of your space without blind spots. Built with IP65 weather resistance, it’s ready to withstand rain, snow, and dust, making it ideal for outdoor use when paired with the Wyze Outdoor Power Adapter.
- 360° Pan & 180° Tilt: Complete coverage with smooth motorized movement.
- Weather Resistant (IP65): Durable for outdoor environments.
- Color Options: Available in sleek Black and White.
- Flexible Packs: Choose from 1, 2, or 3 camera packs to cover multiple areas.
Experience peace of mind with a camera that adapts to your environment, whether monitoring your front porch or living room.
Wyze Cam Pan v3 weatherproof outdoor security
Wyze Cam v4: Crystal-Clear 2.5K QHD Resolution with Enhanced Night Vision
For those seeking unmatched video clarity, the Wyze Cam v4 delivers stunning 2.5K QHD resolution paired with Enhanced Color Night Vision. This camera is perfect for both indoor and outdoor use, featuring a motion-activated spotlight to deter unwanted visitors.
- 2.5K QHD Video: Sharp, detailed footage day and night.
- Enhanced Color Night Vision: See vibrant colors even in low light.
- Motion-Activated Spotlight: Adds an extra layer of security.
- Wi-Fi 6 Support: Faster, more reliable connectivity.
- Smart Assistant Compatible: Works seamlessly with Alexa and Google Assistant.
- Multiple Colors: Black, Clear, Grey, and White options.
Protect your home with a camera that combines high-resolution imaging and smart home integration for effortless monitoring.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoors
The Wyze Cam Floodlight v2 is designed to dominate the dark with powerful 2800 lumens LEDs and 2K video quality. Its 160° wide-angle lens ensures broad coverage, while AI-powered light control and dusk-to-dawn automation provide smart, hands-free operation.
- 2800 Lumens LED Floodlight: Bright illumination for enhanced security.
- 2K Video with Color Night Vision: Clear footage even at night.
- 160° Wide-Angle View: Covers large outdoor areas.
- Two-Way Talk: Communicate directly through the camera.
- IP65 Weather Resistance: Built to withstand harsh weather.
- Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Illuminate your driveway or backyard with a camera that combines powerful lighting and intelligent security features.
Wyze Cam Floodlight v2 brightens and secures outdoor spaces
Wyze Battery Cam Pro: Wire-Free 2.5K HDR Security with Radar Detection
For flexible placement without the hassle of wires, the Wyze Battery Cam Pro offers 2.5K HDR video resolution and advanced radar + PIR motion detection. Its rechargeable battery packs provide long-lasting power, and the integrated spotlight and siren enhance security.
- Wire-Free Design: No hub or wiring required.
- 2.5K HDR Video: High dynamic range for clear images.
- Radar + PIR Motion Detection: Accurate and reliable alerts.
- Removable Rechargeable Batteries: Easy to swap and recharge.
- IP65 Weatherproof: Suitable for outdoor use.
- Dual-Band Wi-Fi Support: Connects to 2.4 & 5 GHz networks.
Ideal for those who want powerful security cameras without the constraints of wiring.
Wyze Cam OG: Affordable and Fast Indoor/Outdoor Monitoring
The Wyze Cam OG is the next generation of Wyze’s popular camera, offering quicker live streaming, 3X faster notifications, and improved two-way audio. It also features a built-in spotlight for added security and works indoors or outdoors.
- 1080p Full HD Video: Clear and smooth footage.
- 120° Field of View: Wide coverage area.
- Improved Two-Way Audio: Clear communication.
- Built-in Spotlight: Enhances night visibility.
- Indoor/Outdoor Use: Versatile placement.
- Available in Black and White: Matches your decor.
A budget-friendly option that doesn’t compromise on essential security features.
Wyze Bulb Cam: 2-in-1 Outdoor Security Camera and Smart LED Light
The Wyze Bulb Cam uniquely combines a 2K HD security camera with a smart LED light bulb, fitting into most standard light fixtures. It offers color night vision, instant motion alerts, and local video storage without subscription fees.
- 2K HD Video with Color Night Vision: Clear day and night monitoring.
- Smart LED Light Bulb: Dual functionality for lighting and security.
- Easy Installation: Fits most outdoor fixtures.
- Instant Motion Alerts: Stay informed in real-time.
- Local Video Storage: No monthly fees.
- IP65 Rated: Weather-resistant for outdoor use.
Perfect for discreet security that blends seamlessly with your outdoor lighting.
Wyze Bulb Cam: smart security and lighting combined
Why Choose Wyze Surveillance Cameras?
Wyze cameras stand out for their combination of affordability, advanced features, and smart home compatibility. Whether you need a wire-free solution, a camera with powerful floodlights, or a versatile pan-and-tilt model, Wyze offers options tailored to your security needs. Their weather-resistant designs ensure reliable performance indoors and outdoors, while high-resolution video and intelligent alerts keep you connected and informed.
Secure your home with confidence using Wyze’s innovative surveillance cameras designed for every environment and budget.
Summary of Wyze Surveillance Cameras
Model | Resolution | Key Features | Weather Resistant | Power Source |
Wyze Cam Pan v3 | 1080p | 360° pan/180° tilt, IP65 | Yes | Wired (Outdoor adapter sold separately) |
Wyze Cam v4 | 2.5K QHD | Enhanced color night vision, spotlight | Yes | Wired |
Wyze Cam Floodlight v2 | 2K | 2800 lumens floodlight, AI light control | Yes | Wired |
Wyze Battery Cam Pro | 2.5K HDR | Wire-free, radar + PIR detection | Yes | Rechargeable battery |
Wyze Cam OG | 1080p | Fast live streaming, built-in spotlight | Yes | Wired |
Wyze Bulb Cam | 2K | 2-in-1 camera and smart LED bulb | Yes | Wired (light fixture) |
Secure your property with Wyze’s trusted surveillance cameras and enjoy smart, reliable protection day and night.
What are the main features of Wyze Cam Pan v3?
The Wyze Cam Pan v3 offers 360° pan and 180° tilt for complete coverage, IP65 weather resistance for indoor and outdoor use, and is available in Black and White. It can be purchased in 1, 2, or 3 camera packs and requires the Wyze Outdoor Power Adapter for outdoor installation.Does Wyze Cam v4 support night vision?
Yes, the Wyze Cam v4 features Enhanced Color Night Vision, allowing you to see vibrant colors even in low-light conditions for superior nighttime security.Is the Wyze Cam Floodlight v2 suitable for outdoor use?
Absolutely. The Wyze Cam Floodlight v2 is IP65 weather resistant, features a powerful 2800 lumens LED floodlight, 2K video with color night vision, and a 160° wide-angle view, making it ideal for outdoor security.What makes the Wyze Battery Cam Pro unique?
The Wyze Battery Cam Pro is a wire-free security camera with 2.5K HDR video, radar and PIR motion detection, removable rechargeable batteries, and IP65 weatherproofing. It supports dual-band Wi-Fi and does not require a hub or wiring.Is the Wyze Cam OG a good budget security camera?
Yes, the Wyze Cam OG is an affordable option that offers 1080p Full HD video, 120° field of view, improved two-way audio, a built-in spotlight, and is suitable for both indoor and outdoor use.How does the Wyze Bulb Cam work?
The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED light bulb. It fits most standard outdoor light fixtures, offers color night vision, instant motion alerts, local video storage without monthly fees, and is IP65 weather resistant.Are Wyze surveillance cameras weather resistant?
Yes, most Wyze surveillance cameras, including the Cam Pan v3, Cam v4, Cam Floodlight v2, Battery Cam Pro, Cam OG, and Bulb Cam, are IP65 weather resistant, making them suitable for both indoor and outdoor use.Do Wyze cameras require a subscription for video storage?
The Wyze Bulb Cam offers local video storage without monthly fees. Other Wyze cameras may offer both local and cloud storage options, but local storage does not require a subscription.Can Wyze cameras be integrated with smart home assistants?
Yes, many Wyze cameras, such as the Cam v4 and Cam Floodlight v2, are compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.What video resolutions do Wyze surveillance cameras offer?
Wyze cameras offer a range of video resolutions: Wyze Cam Pan v3 and Cam OG provide 1080p Full HD, Cam v4 and Battery Cam Pro offer 2.5K QHD/HDR, Cam Floodlight v2 delivers 2K video, and Bulb Cam features 2K HD resolution.Which Wyze camera is best for wire-free installation?
The Wyze Battery Cam Pro is the best option for wire-free installation, featuring rechargeable batteries and no need for a hub or wiring.Do Wyze cameras have two-way audio?
Yes, several Wyze cameras, including the Cam OG and Cam Floodlight v2, offer improved two-way audio, allowing you to communicate directly through the camera.What is the field of view for Wyze cameras?
Wyze cameras offer various fields of view: the Cam OG has a 120° field of view, while the Cam Floodlight v2 provides a 160° wide-angle view for broader coverage.Are there color options available for Wyze cameras?
Yes, Wyze cameras come in multiple color options. For example, the Cam Pan v3 is available in Black and White, and the Cam v4 is available in Black, Clear, Grey, and White.Why should I choose Wyze surveillance cameras for my home or business?
Wyze surveillance cameras offer a combination of affordability, advanced features like high-resolution video, weather resistance, smart home compatibility, and flexible installation options, making them a reliable choice for both home and business security.
