Wyze Cam V3 Pan Bundle: Dual Cameras, SD Cards & 24/7 Recording
Wyze Cam V3 Pan Security Bundle: Dual Cameras with Preinstalled SD Cards and 24/7 Recording
When it comes to home security, having reliable, high-quality cameras that offer continuous monitoring is essential. The Wyze Cam V3 Pan Security Bundle is designed to provide comprehensive coverage with dual cameras, preinstalled microSD cards, and 24/7 local recording capabilities. This bundle is perfect for users who want peace of mind with smart, always-on surveillance.
Dual Cameras for Complete Coverage
The bundle includes two Wyze Cam V3 cameras, renowned for their versatility and performance. These cameras feature:
  • Pan and Tilt Functionality: Cover every angle of your property with smooth pan and tilt controls, ensuring no blind spots.
  • 2.5K QHD Resolution: Crystal-clear video quality captures every detail, day or night.
  • Enhanced Color Night Vision: Unlike traditional infrared night vision, Wyze Cam V3 offers vibrant color footage even in low light.
  • Weather-Resistant Design: Rated IP65, these cameras are built to withstand outdoor conditions, making them ideal for both indoor and outdoor use.
  • Motion-Activated Spotlight: The built-in spotlight activates on motion detection, deterring intruders and improving night visibility.
These features make the dual-camera setup perfect for monitoring front and back yards, garages, or multiple entry points simultaneously. Outdoor Security Camera in Use Stay secure day and night with Wyze Cam V3’s enhanced night vision and spotlight
Preinstalled MicroSD Cards for Seamless 24/7 Recording
Each camera in the bundle comes with a preinstalled microSD card, enabling continuous local recording without the hassle of purchasing storage separately. Key benefits include:
  • 24/7 Local Recording: Never miss a moment with round-the-clock video capture stored directly on the microSD card.
  • Large Storage Capacity: Supports up to 512GB microSD cards, allowing for days or even weeks of footage depending on settings.
  • Class 10 and UHS-3 (U3) Speed: Ensures smooth, high-quality video recording without lag or dropped frames.
  • Easy Playback and Export: Access recorded footage anytime via the Wyze app, with options to save clips or snapshots.
This setup eliminates reliance on cloud subscriptions for basic recording needs, providing a cost-effective and private solution.
Advanced Features for Smart Home Integration
The Wyze Cam V3 Pan Security Bundle is packed with smart features that enhance usability and integration:
  • Wi-Fi 6 Support: Faster, more reliable wireless connectivity for smooth streaming and quick alerts.
  • Compatibility with Alexa and Google Assistant: Control your cameras hands-free and integrate them into your smart home routines.
  • Person Detection and Motion Zones: Customize detection areas to reduce false alerts and focus on what matters most.
  • Two-Way Audio and Built-In Siren: Communicate through the camera or scare off intruders with a loud siren.
  • Multiple Mounting Options: Flexible installation with stand, wall mount, ceiling mount, or magnetic adhesive mounts.
These features make the bundle a powerful, user-friendly security solution for any home. Indoor Child Monitoring with Wyze Cam Monitor your home and loved ones effortlessly with Wyze Cam’s smart features
Why Choose the Wyze Cam V3 Pan Security Bundle?
"The Wyze Cam V3 Pan Security Bundle offers unmatched value with dual cameras, preinstalled microSD cards, and 24/7 recording, all wrapped in a weather-resistant, smart home compatible package."
  • Complete Security Coverage: Dual cameras with pan and tilt cover more area than fixed cameras.
  • Continuous Recording: Preinstalled microSD cards ensure you never miss important footage.
  • Smart and Easy to Use: Wi-Fi 6, voice assistant compatibility, and app control simplify home monitoring.
  • Durable and Weatherproof: Perfect for indoor and outdoor use, rain or shine.
  • Affordable and Reliable: High-end features at a budget-friendly price point.
Summary of Key Specs
FeatureWyze Cam V3 Pan Security Bundle
Cameras2 x Wyze Cam V3 with pan & tilt
Resolution2.5K QHD (2560x1440)
Night VisionEnhanced Color Night Vision + Motion Spotlight
Recording24/7 local recording on preinstalled microSD
StoragemicroSD card preinstalled, supports up to 512GB
ConnectivityWi-Fi 6
Smart Home IntegrationAlexa, Google Assistant
Weather ResistanceIP65 (Outdoor compatible)
AudioTwo-way talk, built-in siren
Mounting OptionsStand, wall, ceiling, magnetic adhesive
Enhance Your Setup with Wyze Cam V3 Spotlight Kit
For even better night-time security, consider adding the Wyze Cam V3 Spotlight Kit accessory. It features:
  • 70 Lumens Brightness: Powerful illumination to brighten dark areas.
  • Motion-Activated: Lights up only when needed to save energy.
  • IP65 Rated: Weatherproof for outdoor use.
  • Easy USB Connection: Simple plug-and-play setup.
This accessory complements the cameras perfectly, enhancing visibility and deterrence.
Secure your home with the Wyze Cam V3 Pan Security Bundle — dual cameras, preinstalled SD cards, and 24/7 recording for comprehensive, smart surveillance.
FeatureWyze Cam v4 Home Security BundleWyze Cam v4Wyze Cam v4 + FREE 32GB MicroSD CardWyze Cam v3 Spotlight Kit
Price$169.99$35.98 (1 Pack)$35.98$16.98
Included Items4x Wyze Cam v4, 4x Wyze MicroSD Card 128GBWyze Cam v4 (color options: Black, Grey, White)Wyze Cam v4 + 32GB MicroSD Card (Black, Grey, White)Spotlight x1, USB cable splitter x1
Video Resolution2.5K QHD2.5K QHD2.5K QHDN/A
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionN/A
Motion-Activated SpotlightYesYesYesYes (for Wyze Cam v3)
AudioEnhanced 2-way audioEnhanced 2-way audioEnhanced 2-way audioN/A
Local Recording24/7 local recording with microSD (128GB included)24/7 local recording (microSD card required)24/7 local recording (32GB microSD included)N/A
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6N/A
CompatibilityAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantN/A
Motion & Sound DetectionYesYesYesN/A
Motion Detection ZonesYesYesYesN/A
Smoke & CO AlertsYesYesYesN/A
Weather ResistanceWired (requires outdoor power adapter for outdoor use)IP65 rated (weather resistant)IP65 rated (weather resistant)IP65 rated
MicroSD Card Included4x 128GB MicroSD CardsNot included32GB MicroSD Card includedN/A
Smart Detection (Subscription)AvailableAvailableAvailableN/A
Spotlight KitIncluded (built-in spotlight on cameras)Built-in spotlightBuilt-in spotlightSeparate accessory for Wyze Cam v3
WarrantyNot specified1 YearNot specified1 Year
What is included in the Wyze Cam V3 Pan Security Bundle?The Wyze Cam V3 Pan Security Bundle includes two Wyze Cam V3 cameras with pan and tilt functionality, each preinstalled with a microSD card for 24/7 local recording. The bundle also features weather-resistant designs, enhanced color night vision, motion-activated spotlights, and multiple mounting options.
Does the Wyze Cam V3 Pan Security Bundle support 24/7 recording?Yes, both cameras in the Wyze Cam V3 Pan Security Bundle come with preinstalled microSD cards that enable continuous 24/7 local recording, so you never miss a moment.
What video quality does the Wyze Cam V3 Pan Security Bundle offer?The Wyze Cam V3 cameras in the bundle provide 2.5K QHD (2560x1440) resolution, delivering crystal-clear video quality for detailed monitoring day and night.
Are the Wyze Cam V3 cameras weatherproof?Yes, the Wyze Cam V3 cameras are IP65 rated, making them weather-resistant and suitable for both indoor and outdoor use.
How does the enhanced color night vision work on Wyze Cam V3?Wyze Cam V3 features enhanced color night vision, which provides vibrant, full-color video footage even in low-light conditions, unlike traditional infrared night vision.
What is the storage capacity of the preinstalled microSD cards?Each camera comes with a preinstalled microSD card and supports up to 512GB of storage, allowing for days or even weeks of continuous footage depending on your recording settings.
Can I access and export recorded footage from the Wyze Cam V3?Yes, you can easily access, playback, and export recorded footage directly from the Wyze app, with options to save video clips or snapshots.
Is the Wyze Cam V3 Pan Security Bundle compatible with smart home systems?Absolutely. The bundle supports integration with Alexa and Google Assistant, allowing for hands-free control and seamless smart home automation.
What connectivity does the Wyze Cam V3 Pan Security Bundle use?The cameras feature Wi-Fi 6 support, providing faster and more reliable wireless connectivity for smooth video streaming and quick alerts.
Does the Wyze Cam V3 Pan Security Bundle have two-way audio?Yes, the cameras include two-way audio, allowing you to communicate through the camera, as well as a built-in siren to deter intruders.
What mounting options are available for the Wyze Cam V3 cameras?The Wyze Cam V3 cameras offer flexible installation options, including stand, wall mount, ceiling mount, and magnetic adhesive mounts.
What is the Wyze Cam V3 Spotlight Kit and how does it enhance security?The Wyze Cam V3 Spotlight Kit is an accessory that provides 70 lumens of motion-activated illumination, is IP65 weatherproof, and connects easily via USB. It enhances night-time security by improving visibility and deterring intruders.
Do I need a cloud subscription for basic recording with the Wyze Cam V3 Pan Security Bundle?No, the preinstalled microSD cards enable 24/7 local recording, so you do not need a cloud subscription for basic video storage and playback.
What advanced features does the Wyze Cam V3 Pan Security Bundle offer?Advanced features include person detection, customizable motion zones, motion-activated spotlight, enhanced color night vision, Wi-Fi 6 connectivity, smart home integration, two-way audio, and a built-in siren.
Can you tell me more about the features of the Wyze Cam V3 Pan Security Bundle?How does the motion-activated spotlight work on the Wyze Cam V3?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam V3?
