Wyze Cam 20ft USB Extension Cable for Pan v2 & v3 Cameras
Wyze Cam USB Extension Cable 20ft for Pan v2 and v3
If you're looking to extend the reach of your Wyze Cam Pan v2 or Pan v3, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This cable provides the freedom to position your cameras exactly where you need them without worrying about limited cable length. Compatible with multiple Wyze camera models, it ensures seamless power delivery and reliable connectivity.
Wyze Cam USB Extension Cable - 20ft: Features and Benefits
Long Reach for Flexible Placement
The 20-foot length of this USB extension cable allows you to place your Wyze Cam Pan v2 or v3 in optimal locations, whether indoors or outdoors, without being restricted by short power cables. This is especially useful for monitoring large areas or hard-to-reach spots.
Broad Compatibility
This extension cable supports a wide range of Wyze cameras, including:
  • Wyze Cam v2
  • Wyze Cam v3 and v3 Pro
  • Wyze Cam v4
  • Wyze Cam Pan v2 and Pan v3
  • Wyze Cam OG Standard and Telephoto
This versatility makes it a must-have accessory for any Wyze camera owner looking to enhance their setup.
Durable and Weather-Resistant
Rated IP67 for weather resistance, the cable is built to withstand outdoor conditions, making it suitable for use with outdoor cameras like the Pan v3. It operates reliably in temperatures ranging from -22°F to 122°F (-30°C to 50°C), ensuring consistent performance year-round.
Quality Power Delivery
With an output power of 5V 2A and AWG 18# wire gauge, this cable ensures stable and efficient power supply to your cameras, preventing interruptions and maintaining continuous surveillance.
Wyze Cam Pan v3: The Ideal Camera for Extended Coverage
Pan and Tilt with Smart Tracking
The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical coverage, making it perfect for monitoring large spaces. Its AI-powered motion tracking automatically follows movement, so you never miss a detail.
Crisp 1080p HD Video and Color Night Vision
Enjoy clear, high-definition video day and night with color night vision, ensuring your home stays protected around the clock.
Two-Way Audio and Local Storage
Communicate through the camera with two-way audio and record footage locally with a microSD card slot, providing flexible storage options.
Enhance Your Pan v3 Setup with the Lamp Socket v2 Bundle
Power Your Pan v3 Without an Outlet
The Pan v3 + Lamp Socket v2 Bundle lets you power your Pan v3 camera directly from a standard E26 lamp socket, eliminating the need for a nearby power outlet. This is ideal for outdoor lighting fixtures or hard-to-wire locations.
Smart and Safe Design
  • Supports 120V~, 60Hz power input
  • Compatible with LED or CFL bulbs under 20W (incandescent bulbs not recommended)
  • Suitable for damp locations (not fully weatherproof)
  • Compact size (56.5mm x 56.5mm x 65mm) and lightweight (80g)
This bundle is a smart solution to make your exterior lighting smarter and your camera setup cleaner.
Why Choose Wyze for Your Home Security?
Wyze offers a range of innovative security products designed to work seamlessly together. Whether you’re using the Pan v3 camera with the 20ft USB extension cable or powering it via the lamp socket, Wyze provides flexible, affordable, and reliable solutions to keep your home safe.
"Extend your camera’s reach and power options with Wyze accessories designed for convenience and durability."
Summary
  • Wyze Cam USB Extension Cable - 20ft: Extend your camera’s power cable length with a durable, weather-resistant 20ft USB extension compatible with Pan v2, Pan v3, and other Wyze cameras.
  • Wyze Cam Pan v3: Pan and tilt camera with 360° coverage, motion tracking, and color night vision.
  • Pan v3 + Lamp Socket v2 Bundle: Power your Pan v3 camera from a lamp socket for flexible outdoor installation without an outlet.
Outdoor security camera in use Alt text: Wyze Cam Pan v3 monitoring a backyard at dusk USB extension cable powering camera Alt text: Wyze Cam USB extension cable connected to outdoor camera Lamp socket powering outdoor camera Alt text: Wyze Cam Pan v3 powered by lamp socket in porch light
FeatureWyze Cam USB Extension Cable - 20ftEssential Security BundlePan v3 + Lamp Socket v2 Bundle
TypeAccessoryBundleBundle
Price$7.99$199.99 (compare at $224.90)$53.96 (compare at $56.96)
Included Items20ft USB extension cableWyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2× Wyze Cam OGWyze Cam Pan v3, Lamp Socket v2
CompatibilityWyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard & TelephotoN/A (includes multiple devices)Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam OG, Wyze Cam Pan v3
DescriptionExtends USB cable length to 20ft for Wyze camerasComprehensive home protection with video doorbell, smart lock, pan-tilt camera, and 2 OG camsPowers Pan v3 without outlet; smart lamp socket with E26 connector
FeaturesUSB extension cableVideo doorbell with 1080p HD, two-way audio; smart lock with fingerprint sensor; pan-tilt camera with motion tracking; OG cams with spotlightsPan v3 camera with 360° horizontal & 180° vertical coverage; lamp socket with power input 120V~, 60Hz, max 20W lamp power
ConnectivityUSBWi-Fi, Bluetooth (varies by device)Wi-Fi 2.4GHz, Bluetooth
Dimensions / WeightN/AN/ALamp Socket: 56.5mm x 56.5mm x 65mm; 80 g
Power InputUSBVaries by deviceLamp Socket: 120V~, 60Hz
Weather ResistanceN/AVaries by deviceLamp Socket: Not weatherproof, suitable for damp locations
Warranty30-day hassle-free returns30-day hassle-free returns1-Year
CollectionsShop All, Camera AccessoriesShop All, Sales: Deals, Discounts, and moreShop All, Sales: Deals, Discounts, and more
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam Pan v2, Pan v3, and other compatible Wyze cameras, allowing you to position your cameras in optimal locations without being limited by short power cables.
Which Wyze cameras are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam Pan v2, Wyze Cam Pan v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
Is the Wyze Cam USB Extension Cable weather-resistant?Yes, the Wyze Cam USB Extension Cable is rated IP67 for weather resistance, making it suitable for both indoor and outdoor use. It operates reliably in temperatures ranging from -22°F to 122°F (-30°C to 50°C).
How long is the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable is 20 feet long, providing ample length to position your cameras exactly where you need them.
Does the Wyze Cam USB Extension Cable provide reliable power delivery?Yes, the cable features an output power of 5V 2A and uses AWG 18# wire gauge to ensure stable and efficient power supply to your Wyze cameras, preventing interruptions and maintaining continuous surveillance.
What are the key features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical coverage, AI-powered motion tracking, crisp 1080p HD video, color night vision, two-way audio, and local storage via a microSD card slot.
How can I power my Wyze Cam Pan v3 without a nearby outlet?You can use the Pan v3 + Lamp Socket v2 Bundle to power your Wyze Cam Pan v3 directly from a standard E26 lamp socket, eliminating the need for a nearby power outlet. This is ideal for outdoor lighting fixtures or hard-to-wire locations.
Is the Lamp Socket v2 suitable for outdoor use?The Lamp Socket v2 is suitable for damp locations but is not fully weatherproof. It is designed to work with LED or CFL bulbs under 20W and supports 120V~, 60Hz power input.
Why should I choose Wyze accessories for my home security setup?Wyze offers innovative, flexible, and affordable security solutions. Their accessories, like the 20ft USB extension cable and Lamp Socket v2, are designed for convenience, durability, and seamless integration with Wyze cameras to keep your home safe.
Can you tell me more about the features of the Wyze Cam Pan v3?Is the Wyze Cam USB Extension Cable compatible with other Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions?
