Wyze Cam 20ft USB Extension Cable for Flexible Camera Placement
Wyze Cam 20ft USB Extension Cable for Long Distance Power and Flexible Placement
When it comes to setting up your Wyze Cam in the perfect spot, power cable length can often be a limiting factor. The Wyze Cam USB Extension Cable - 20ft is the ideal solution for extending your camera’s reach, allowing for flexible placement without worrying about proximity to power outlets. Whether you have a Wyze Cam v2, v3, v4, or other compatible models, this extension cable ensures your security camera stays powered up no matter where you want to install it.
Wyze Cam USB Extension Cable - 20ft: Freedom to Place Anywhere
Key Features:
  • Length: 20 feet of USB extension cable, significantly longer than standard cables.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Flexible Placement: Perfect for indoor or outdoor setups where power outlets are far from the desired camera location.
  • Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your Wyze Cam setup.
  • Easy to Use: Simply plug it in between your camera and power source to extend the cable length without any complicated installation.
Say goodbye to short cables and enjoy the freedom of placing your Wyze Cam exactly where you need it.
Wyze Cam v4: The Ultimate Camera to Pair with Your Extension Cable
Why Choose Wyze Cam v4?
The Wyze Cam v4 is the latest and most advanced Wyze camera, designed to deliver superior image quality and smart features that keep your home safe and secure.
  • 2.5K Quad HD Resolution: Capture crystal-clear video with four times the detail of 1080p.
  • Color Night Vision: See vibrant colors even in low-light conditions, thanks to enhanced hardware.
  • IP65 Weather Resistance: Durable enough for outdoor use in any weather.
  • Integrated Spotlight & Siren: Motion-activated spotlight and a loud siren to deter intruders.
  • Advanced Audio: Enhanced two-way talk with clearer sound quality.
  • Easy Setup: Bluetooth® connectivity and magnetic mount make installation a breeze.
  • Smart Features: Auto-zoom with AI tracking, motion and sound detection, smoke & CO alerts.
  • MicroSD Card Support: Record continuously with local storage up to 512GB (microSD card sold separately).
Pairing the Wyze Cam v4 with the 20ft USB extension cable means you can place this powerful camera exactly where you need it, even if the nearest power outlet is far away. Wyze Cam v4 in use outdoors Experience flexible placement with Wyze Cam v4 and 20ft USB extension cable.
Cam v4 + Lamp Socket v2 Bundle: Power Your Camera Without an Outlet
For even more placement flexibility, consider the Cam v4 + Lamp Socket v2 Bundle. This innovative bundle allows you to power your Wyze Cam v4 through a standard lamp socket, eliminating the need for a nearby power outlet altogether.
Bundle Highlights:
  • Convenient Power Source: Use existing lamp sockets to power your Wyze Cam v4.
  • Compatible with Multiple Wyze Cams: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Motion-Activated Lights: The lamp socket supports smart lighting features.
  • Dusk to Dawn Scheduling: Automate your camera’s power based on lighting conditions.
  • Compact and Lightweight: Measures 56.5mm x 56.5mm x 65mm and weighs only 80g.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for easy setup.
  • Safe and Certified: FCC, IC, UL496, CA65, TSCA, and RoHS certified.
This bundle is perfect for those who want to maximize placement options without running long cables or installing new outlets.
Why Use a 20ft USB Extension Cable with Wyze Cams?
Extending your Wyze Cam’s power cable with a 20ft USB extension cable offers unmatched flexibility in camera placement, ensuring you never have to compromise on the perfect angle or location.
  • Ideal for Outdoor and Indoor Use: Extend your camera’s reach to cover blind spots or hard-to-reach areas.
  • Avoid Unsightly Cable Runs: Keep cables neat and hidden by routing them along walls or ceilings.
  • Compatible with Multiple Wyze Models: One cable fits many cameras, making it a versatile accessory.
  • Affordable and Reliable: Durable cable construction ensures consistent power delivery.
Conclusion
For anyone looking to enhance their Wyze Cam setup with longer power cable reach, the Wyze Cam USB Extension Cable - 20ft is a must-have accessory. When combined with the powerful Wyze Cam v4 or the Cam v4 + Lamp Socket v2 Bundle, you gain ultimate flexibility in camera placement and power options. Whether securing your home, monitoring your property, or keeping an eye on loved ones, these products work together to provide a seamless, reliable, and smart security solution.
Product Summary
Wyze Cam USB Extension Cable - 20ft Extend your camera’s power cable by 20 feet for flexible placement. Compatible with multiple Wyze Cam models. Wyze Cam v4 Advanced 2.5K QHD camera with color night vision, IP65 weather resistance, spotlight, siren, and AI tracking. Cam v4 + Lamp Socket v2 Bundle Power your Wyze Cam v4 through a lamp socket with smart lighting features and easy setup.
Enhance your Wyze Cam experience today with the perfect combination of extended power and smart camera technology!
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Cam v4 + Lamp Socket v2 Bundle
TypeAccessoryCameraBundle (Camera + Lamp Socket)
Price$7.99$100.00 (regular), $35.98 (some bundles)$49.96
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraWyze Cam v3, v3 Pro, v4, OG, Pan v3
Cable Length20 ft USB extension6 ft flat micro USB to USB-A cableIncluded with camera (6 ft cable)
ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Weather ResistanceN/AIP65Lamp Socket: Not weatherproof, suitable for damp locations
Power SourceUSB poweredWired (5V/1A)Camera wired; Lamp Socket powered (120V~, 60Hz)
Special FeaturesExtends USB cable lengthColor Night Vision, Motion-Activated Spotlight, Wi-Fi 6, 24/7 local recording, Alexa/Google Assistant compatibilityPowers Wyze Cam without outlet, Motion-Activated Lights, Dusk to Dawn Scheduling
DimensionsN/A2in x 2in x 2 3/8in56.5mm x 56.5mm x 65mm
WeightN/A0.49 lb (222 g)80 g
Warranty30-day hassle-free returns1 Year1 Year
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic mountN/A
ConnectivityUSBWi-Fi 6, Bluetooth 5.2802.11 b/g/n 2.4GHz Wi-Fi, Bluetooth
Additional NotesExtends reach for compatible Wyze CamsSupports microSD up to 512GB, AI Auto-Zoom, Person DetectionIncandescent bulbs not supported; use CFL or LED under 20W
What is the Wyze Cam 20ft USB Extension Cable used for?The Wyze Cam 20ft USB Extension Cable is designed to extend the power reach of your Wyze Cam, allowing you to place your camera farther from power outlets for more flexible and convenient placement indoors or outdoors.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
How long is the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable is 20 feet long, providing significantly more reach than standard camera power cables.
Is the Wyze Cam 20ft USB Extension Cable suitable for outdoor use?Yes, the 20ft USB Extension Cable is ideal for both indoor and outdoor Wyze Cam setups, making it easy to place your camera in hard-to-reach or outdoor locations.
How do I install the Wyze Cam USB Extension Cable?Installation is simple—just plug the extension cable between your Wyze Cam and the power source. No complicated setup or tools are required.
What are the benefits of using a 20ft USB extension cable with Wyze Cams?Using a 20ft USB extension cable allows for flexible camera placement, helps cover blind spots, keeps cables neat and hidden, and is compatible with multiple Wyze Cam models.
What features does the Wyze Cam v4 offer?The Wyze Cam v4 features 2.5K Quad HD resolution, color night vision, IP65 weather resistance, an integrated spotlight and siren, advanced two-way audio, Bluetooth connectivity, AI tracking, motion and sound detection, smoke and CO alerts, and microSD card support up to 512GB.
Can I power my Wyze Cam v4 without a nearby power outlet?Yes, with the Cam v4 + Lamp Socket v2 Bundle, you can power your Wyze Cam v4 through a standard lamp socket, eliminating the need for a nearby power outlet.
What is included in the Cam v4 + Lamp Socket v2 Bundle?The Cam v4 + Lamp Socket v2 Bundle includes a Wyze Cam v4 and a Lamp Socket v2, allowing you to power your camera through a lamp socket and enjoy smart lighting features like motion-activated lights and dusk to dawn scheduling.
Is the Wyze Cam USB Extension Cable affordable?Yes, the Wyze Cam USB Extension Cable is priced at just $7.99, making it a cost-effective accessory for enhancing your Wyze Cam setup.
What are the key features of the Wyze Cam USB Extension Cable?Is the Wyze Cam USB Extension Cable compatible with all Wyze Cam models?Do you have any ongoing sales or discounts for the Wyze Cam products?
