Single Pole Smart Light Switch for Home Automation & Control
Single Pole Smart Light Switch for Automation and Remote Control
Upgrade your home lighting with the latest in smart home technology. Whether you're looking to automate your lights, control them remotely, or integrate with other smart devices, a single pole smart light switch is the perfect solution. Discover how the Wyze Switch and complementary Wyze smart lighting products can transform your living space with convenience, style, and intelligence.
Wyze Switch: Your Smart Light Switch Solution
Transform Any Light into a Smart Light
The Wyze Switch is designed to replace your traditional single pole light switch, instantly turning your normal lights into smart lights controllable from anywhere. With WiFi connectivity and the Wyze app, you can:
  • Turn lights on/off remotely
  • Set schedules and timers for automated lighting
  • Enable Vacation Mode to simulate occupancy when away
  • Recover automatically after power outages
Multi-Device Control with Custom Actions
Wyze Switch goes beyond simple light control. It integrates seamlessly with other Wyze devices, allowing you to:
  • Single-press to toggle lights
  • Double-press to lock Wyze smart locks
  • Triple-press to activate Wyze Robot Vacuum
  • Press-and-hold to control Wyze Sprinkler Controller
This multi-tap functionality personalizes your smart home experience, making automation effortless.
Easy Installation and Compatibility
Installing the Wyze Switch is straightforward, fitting standard single pole switch wiring. It works best with Wyze Bulbs but also supports regular bulbs, ensuring your smart home upgrade is smooth and flexible.
"All your lights just got smarter." – Wyze Switch
Wyze Switch in Kitchen Lifestyle Control your kitchen lighting with voice assistants and smart switches.
Enhance Your Lighting with Wyze Bulbs
Wyze Bulb Color: Vibrant Smart Lighting
Pair your Wyze Switch with the Wyze Bulb Color to unlock a world of color and ambiance. This smart bulb offers:
  • 16 million colors to customize any room’s mood
  • Brightness tuning from 30 lumens to 1100 lumens for perfect lighting
  • White light temperature control from warm to cool
  • Brilliant 90+ CRI for true-to-life colors
  • Custom presets and automation for routines, notifications, and music sync
Whether it’s game day, a cozy night, or a party, Wyze Bulb Color brings your lighting to life.
Wyze Bulb White: Classic Smart Lighting
For those who prefer a clean, bright white light, the Wyze Bulb White is an excellent choice. Features include:
  • Adjustable brightness from 30 to 800 lumens
  • Color temperature range from 2700K (warm) to 6500K (cool)
  • High CRI rating for natural color rendering
  • Long lifespan of 25,000 hours
  • Compatible with Alexa, Google Assistant, and IFTTT
Use Wyze Bulb White for everyday lighting needs with smart control and energy efficiency. Wyze Bulb Color in Living Room Create vibrant, colorful lighting scenes in your living room.
Why Choose Wyze for Your Smart Home Lighting?
  • Seamless Ecosystem: Wyze Switch and Wyze Bulbs work together flawlessly, preserving power to bulbs for uninterrupted automations.
  • Affordable Smart Home: Competitive pricing with options for single or multi-packs.
  • Reliable Connectivity: Operates on 2.4GHz WiFi with quick recovery after power loss.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free operation.
  • Custom Automations: Set schedules, timers, and multi-device actions to fit your lifestyle.
Conclusion
For anyone seeking a reliable, easy-to-install single pole smart light switch with advanced automation and remote control, the Wyze Switch paired with Wyze Bulb Color or Wyze Bulb White offers a comprehensive smart lighting solution. Enhance your home’s ambiance, security, and convenience with Wyze’s connected home products.
FeatureWyze SwitchWyze Bulb ColorWyze Bulb White
TypeConnected Home - Smart Light SwitchSmart Lighting - Color Smart BulbConnected Home - White Smart Bulb
Price Range$14.99 (1 Pack), $41.98 (3 Pack)$26.26 (2 Pack), $44.44 (4 Pack), $64.98 (6 Pack)$23.99 (2 Pack), $39.99 (4 Pack), $59.99 (6 Pack)
Control MethodWyze app, multi-tap actionsWyze app, voice control (Alexa, Google Assistant, IFTTT)Wyze app, voice control (Alexa, Google Assistant, IFTTT)
ConnectivityWiFi (2.4 GHz)WiFi (802.11 b/g/n 2.4GHz), BluetoothBluetooth, WiFi (2.4 GHz)
Features- Turn normal lights smart- 16 million colors- Tunable white light (2700K-6500K)
- Multi-tap to control Wyze devices- Dimmable, color changing- Dimmable, 800 lumens
- Timers, schedules, vacation mode- Sun Match (auto color temp adjustment)- Sun Match (auto color temp adjustment)
- Power loss recovery- Sleep routines, music mode- Sleep routines
- Integrates with Wyze ecosystem- CRI 90+- CRI 90+
Light OutputN/A (switch controls lights)30 - 1100 lumens800 lumens
Color Temperature RangeN/A1800K - 6500K2700K - 6500K
Color Rendering IndexN/A90+90+
Voice Assistant SupportVia Wyze app integrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
InstallationEasy install, replaces standard switchScrew-in bulbScrew-in bulb
Special NotesDesigned to work with Wyze Bulbs to maintain automationsSuitable for damp locations, no hub requiredSuitable for damp locations, no hub required
WarrantyNot specified1 year1 year
What is a single pole smart light switch and how does the Wyze Switch work?A single pole smart light switch, like the Wyze Switch, replaces your traditional light switch to provide smart control over your lighting. The Wyze Switch connects to your WiFi and allows you to turn lights on or off remotely, set schedules, enable Vacation Mode, and recover automatically after power outages—all through the Wyze app.
Can I control my lights remotely with the Wyze Switch?Yes, the Wyze Switch enables remote control of your lights from anywhere using the Wyze app. You can turn lights on or off, set schedules, and automate your lighting even when you’re not at home.
What smart home devices can the Wyze Switch control?The Wyze Switch can control not only your lights but also other Wyze smart devices. With multi-tap actions, you can lock Wyze smart locks, activate the Wyze Robot Vacuum, and control the Wyze Sprinkler Controller, all from the same switch.
Is the Wyze Switch compatible with regular light bulbs?Yes, the Wyze Switch works with both Wyze Bulbs and regular light bulbs, making it a flexible option for upgrading your home lighting to smart control.
How easy is it to install the Wyze Switch?The Wyze Switch is designed for easy installation and fits standard single pole switch wiring. Most homeowners can install it themselves with basic tools.
What are the benefits of pairing Wyze Switch with Wyze Bulb Color?Pairing the Wyze Switch with Wyze Bulb Color unlocks vibrant, customizable lighting with 16 million colors, adjustable brightness, and white temperature control. You can create custom scenes, set routines, and sync lighting with music for a personalized ambiance.
What features does the Wyze Bulb White offer?The Wyze Bulb White provides adjustable brightness (30 to 800 lumens), a color temperature range from 2700K to 6500K, high CRI for natural color rendering, a long lifespan of 25,000 hours, and compatibility with Alexa, Google Assistant, and IFTTT.
Is the Wyze smart lighting system compatible with voice assistants?Yes, Wyze Switch and Wyze Bulbs are compatible with popular voice assistants like Amazon Alexa and Google Assistant, allowing for hands-free voice control of your lighting.
What makes Wyze smart lighting a good choice for home automation?Wyze smart lighting offers a seamless ecosystem, affordable pricing, reliable 2.4GHz WiFi connectivity, quick recovery after power loss, and advanced automation features like schedules, timers, and multi-device actions, making it an excellent choice for smart home automation.
Can I set schedules and timers with Wyze smart lighting products?Yes, both the Wyze Switch and Wyze Bulbs allow you to set schedules and timers for automated lighting, helping you save energy and enhance home security.
What features does the Wyze Switch offer for controlling lights remotely?Can the Wyze Switch be integrated with other Wyze devices?Do you have any ongoing sales or discounts for the Wyze Switch or related products?
