Smart Light Switches & Plugs for Home Automation | Wyze
Smart Light Switch Solutions for Your Connected Home
Upgrade your home lighting with the latest smart light switch technology designed to bring convenience, control, and automation right to your fingertips. Whether you want to control your lights remotely, integrate with other smart devices, or create customized lighting scenes, these smart switches offer the perfect blend of innovation and ease of use.
Wyze Switch: Transform Your Lighting Experience
The Wyze Switch is a versatile connected home device that turns your regular lights into smart lights instantly. With the Wyze Switch, you can control your lighting from anywhere using the Wyze app, making it easy to manage your home’s ambiance whether you’re inside or away.
  • Multi-tap Control: Beyond just switching lights on and off, the Wyze Switch allows multi-tap commands to control other Wyze devices such as Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
  • Flexible Packaging: Available in 1 Pack or 3 Pack options, perfect for upgrading multiple rooms or your entire home.
  • Affordable Smart Upgrade: Priced at $14.99 for a single switch, it’s an economical way to start your smart home journey.
Experience seamless integration and smart control that adapts to your lifestyle.
Wyze Switch in Kitchen Setting Smart light switch enhancing kitchen convenience
Enhance Outdoor Lighting with Smart Control
Smart switches are not just for indoor use. Control your outdoor lighting and devices with smart plugs designed to withstand the elements and provide reliable performance.
Wyze Plug Outdoor: Smart Power for Your Outdoor Devices
The Wyze Plug Outdoor is designed to power your outdoor lights, holiday decorations, and garden gadgets with smart convenience.
  • Weather-Resistant: Built to endure rain or shine, ensuring your outdoor devices stay powered no matter the weather.
  • App Control: Schedule, monitor energy usage, and control your outdoor devices remotely via the Wyze app.
  • Flexible Packs: Available in 1 Pack or 2 Pack, ideal for managing multiple outdoor zones.
  • Affordable Pricing: Starting at $15.99, it’s a cost-effective way to bring smart control outside.
Make your backyard smarter and more energy-efficient with easy-to-use outdoor smart plugs.
Wyze Plug: Indoor Smart Plug for Everyday Devices
Complement your smart switch setup with the Wyze Plug, perfect for making any standard device smart.
  • Versatile Use: Control lamps, fans, coffee makers, and more with simple app commands.
  • Multiple Pack Sizes: Choose from 2 Pack or 4 Pack options to cover more devices.
  • Energy Monitoring: Keep track of your device usage and save on electricity bills.
  • Seamless Integration: Works with voice assistants like Alexa and Google Assistant for hands-free control.
Wyze Plug Indoor Lifestyle Smart plug controlling home appliances effortlessly
Why Choose Wyze Smart Switches and Plugs?
Wyze smart switches and plugs are designed with your convenience and home automation needs in mind. They offer:
  • Easy Installation: Simple setup that fits standard fixtures and outlets.
  • Remote Access: Control your lighting and devices from anywhere using the Wyze app.
  • Smart Home Integration: Compatible with popular voice assistants and other Wyze smart devices.
  • Affordable Pricing: High-quality smart home products without breaking the bank.
Step into the future of home lighting and device control with Wyze’s smart switch and plug solutions.
Summary of Smart Switch and Plug Options
ProductKey FeaturesPrice RangePack Options
Wyze SwitchMulti-tap control, app remote access$14.99 - $41.981 Pack, 3 Pack
Wyze PlugIndoor smart plug, energy monitoring$24.98 - $39.982 Pack, 4 Pack
Wyze Plug OutdoorWeather-resistant, outdoor control$15.99 - $34.981 Pack, 2 Pack
Upgrade your home lighting and device control today with Wyze smart switches and plugs — smart, simple, and designed for modern living.
FeatureWyze SwitchWyze Plug OutdoorWyze Plug
TypeConnected Home - Smart Light SwitchConnected Home - Outdoor Smart PlugConnected Home - Indoor Smart Plug
Price (1 Pack)$14.99$15.99Not available (2 Pack $24.98)
Price (Multi-Pack)3 Pack - $41.98 (Sold out)2 Pack - $34.982 Pack - $24.98, 4 Pack - $39.98
DescriptionTurns normal lights into smart lights; multi-tap controls other Wyze devicesOutdoor smart plug with energy monitoring and weather resistanceIndoor smart plug to make devices smart
ControlWyze app, multi-tap actions for other Wyze devicesWyze app, voice commands (Alexa)Wyze app, voice commands (Alexa, Google Assistant, IFTTT)
ConnectivityWiFi (2.4 GHz)WiFi (2.4 GHz), long range (up to 300 ft open space)WiFi (2.4 GHz)
Weather ResistanceIndoor useIP64 Weather Resistant (rain, dust, snow)Indoor use only
Power OutputN/A (switch)15 AMP Output with Overload Protection15A Max
Special FeaturesMulti-tap custom actions, Smart Control with Wyze Bulbs, Power Loss Recovery, Vacation ModeEnergy monitoring, two independent outlets, long WiFi rangeCompatible with Alexa, Google Assistant, IFTTT
AutomationTimers, schedules, vacation modeSchedules, energy consumption alertsSchedules, automations
Integration with Wyze EcosystemYes, controls Wyze Cams, Locks, Robot Vacuum, Sprinkler ControllerYes, via Wyze appYes, via Wyze app
InstallationEasy to install light switchPlug-in outdoor outletPlug-in indoor outlet
What is the Wyze Switch and how does it work?The Wyze Switch is a smart light switch that transforms your regular lights into smart lights. It allows you to control your lighting from anywhere using the Wyze app, and supports multi-tap commands to control other Wyze devices like Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
Can I control Wyze smart switches and plugs remotely?Yes, all Wyze smart switches and plugs can be controlled remotely through the Wyze app, allowing you to manage your home’s lighting and devices from anywhere.
Are Wyze smart switches and plugs compatible with voice assistants?Yes, Wyze smart switches and plugs are compatible with popular voice assistants such as Amazon Alexa and Google Assistant, enabling hands-free control of your devices.
What are the pack options and pricing for Wyze Switch, Wyze Plug, and Wyze Plug Outdoor?The Wyze Switch is available in 1 Pack ($14.99) and 3 Pack ($41.98). The Wyze Plug comes in 2 Pack ($24.98) and 4 Pack ($39.98) options. The Wyze Plug Outdoor is offered in 1 Pack ($15.99) and 2 Pack ($34.98).
How do I install Wyze smart switches and plugs?Wyze smart switches and plugs are designed for easy installation and fit standard fixtures and outlets. Detailed installation instructions are provided with each product to ensure a simple setup process.
Can Wyze smart plugs be used outdoors?Yes, the Wyze Plug Outdoor is specifically designed for outdoor use. It is weather-resistant and can power outdoor lights, holiday decorations, and garden gadgets reliably in any weather.
What devices can I control with the Wyze Plug?The Wyze Plug is ideal for controlling a variety of indoor devices such as lamps, fans, coffee makers, and more. It also features energy monitoring to help you track and manage your electricity usage.
Does the Wyze Switch support integration with other Wyze devices?Yes, the Wyze Switch supports multi-tap control, allowing you to trigger other Wyze devices like Wyze Cams, Wyze Lock, and Wyze Robot Vacuum directly from the switch.
How does energy monitoring work with Wyze Plugs?Wyze Plugs feature built-in energy monitoring, enabling you to track the energy usage of connected devices through the Wyze app. This helps you manage your electricity consumption and potentially save on energy bills.
Why should I choose Wyze smart switches and plugs for my home?Wyze smart switches and plugs offer easy installation, remote access, compatibility with voice assistants, seamless integration with other Wyze devices, and affordable pricing, making them an excellent choice for upgrading your home’s lighting and device control.
What features does the Wyze Switch offer for controlling lights?Can the Wyze Switch integrate with other Wyze devices?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Switch?
