Wyze Refurbished Floodlight Cameras with Dual USB Port
Looking for a reliable, feature-packed floodlight camera that offers excellent security and smart home integration? Wyze refurbished floodlight cameras provide top-tier performance at a budget-friendly price, with the added convenience of a dual USB port for extra device connectivity. Whether you want to brighten your yard, monitor your property, or deter unwanted visitors, Wyze has a solution tailored for you.
(Refurbished) Wyze Cam Floodlight v1: Bright, Smart, and Affordable
Key Features and Specifications
- Camera Resolution: 1080p Full HD for clear video footage.
- Field of View: 121 degrees to cover wide areas.
- Lighting: Two floodlight heads delivering 2600 lumens of bright, baddie-banishing light.
- AI Detection: Smart detection for people, pets, vehicles, and packages.
- Connectivity: 2.4 GHz WiFi.
- Audio: Two-way audio for real-time communication.
- Additional USB Port: Yes, for powering or charging compatible devices.
- Weather Resistance: IP65 rating ensures durability in all weather conditions.
- Motion Detection Range: Up to 30 feet with 3 PIR sensors.
- Siren: Loud 105dB siren to deter intruders.
- Automation: Dusk-to-dawn lighting automation.
This refurbished model is fully tested and guaranteed to work like new, offering a cost-effective way to secure your home with bright lighting and smart detection.
Outdoor security with smart lighting and camera
(Refurbished) Wyze Cam Floodlight Pro: Next-Level Security and Clarity
Enhanced Video and Lighting
- Video Resolution: Stunning 2.5K QHD (2560 x 1440) for crystal-clear footage.
- Field of View: Ultra-wide 180° lens to cover your entire yard.
- Lighting: Powerful 3000 lumen LED lights with adjustable and dimmable settings.
- AI Computer Vision: Advanced motion detection that selectively triggers lights and alerts for people, vehicles, and more.
- WiFi Support: Dual-band 2.4 GHz and 5 GHz for faster, more reliable connections.
- Color Night Vision: See vivid colors even in low light.
- Two-Way Audio: Communicate directly through the camera.
- Siren: 105dB siren for effective deterrence.
- Weather Resistance: IP65 rated for outdoor durability.
- Installation: DIY setup in under 20 minutes.
- Extra USB Port: Included for added device connectivity.
The Floodlight Pro is like having a personal security guard with bright, intelligent lighting and superior video quality.
Stay connected and secure with two-way communication
Why Choose Wyze Refurbished Floodlight Cameras?
Benefits of Refurbished Products
- Like New Quality: Each unit is fully tested and guaranteed to perform like new.
- Cost Savings: Get premium features at a fraction of the original price.
- Final Sale: Great deals with Wyze’s trusted quality assurance.
- Sustainability: Refurbished products reduce waste and environmental impact.
Dual USB Port Advantage
Both the Wyze Cam Floodlight v1 and Floodlight Pro models come with an extra USB port, allowing you to power or charge additional smart devices or accessories conveniently from the floodlight unit itself. This feature adds versatility to your outdoor setup, making it easier to integrate other smart home gadgets.
Summary of Wyze Floodlight Camera Options
Feature | Wyze Cam Floodlight v1 (Refurbished) | Wyze Cam Floodlight Pro (Refurbished) |
Video Resolution | 1080p Full HD | 2.5K QHD (2560 x 1440) |
Field of View | 121° | 180° |
Lumens | 2600 | 3000 |
AI Detection | People, Pets, Vehicles, Packages | AI Computer Vision for selective alerts |
WiFi | 2.4 GHz | 2.4 & 5 GHz Dual Band |
Two-Way Audio | Yes | Yes |
Siren | 105dB | 105dB |
Weather Resistance | IP65 | IP65 |
Extra USB Port | Yes | Yes |
Price | $39.99 | $89.98 |
Secure your home with Wyze’s refurbished floodlight cameras — smart, bright, and budget-friendly solutions that keep you connected and protected day and night.
Feature | (Refurbished) Wyze Cam Floodlight v1 | (Refurbished) Wyze Cam Floodlight Pro | Wyze Cam Floodlight Pro |
Price | $39.99 (Refurbished) | $89.98 (Refurbished) | $149.98 |
Camera Resolution | 1080p Full HD | 2.5K QHD (2560x1440) | 2.5K QHD (2560x1440) |
Field of View | 121° | 180° | 180° |
Lighting | 2 floodlight heads, 2600 lumens | 3 adjustable floodlight heads, 3000 lumens | 3 dimmable light panels, 3000 lumens |
Color Night Vision | Yes | Yes | Yes |
Motion Detection | 3 PIR sensors, 270° customizable, up to 30 ft | AI computer vision, motion detection by object | AI computer vision, motion detection by object |
AI Detection (with Cam Plus) | People, Pets, Vehicle, Package | People, Pets, Vehicle, Package | People, Pets, Vehicle, Package |
Two-way Audio | Yes | Yes | Yes |
Siren | 105 dB | 105 dB | 105 dB |
Wi-Fi | 2.4 GHz | 2.4 & 5 GHz dual-band | 2.4 & 5 GHz dual-band |
Power Supply | Hardwired 110-120V AC | Hardwired 110-120V AC | Hardwired 110-120V AC |
Weather Resistance | IP65 | IP65 | IP65 |
Storage | Supports microSD (up to 256 GB) | Supports microSD (up to 256 GB) | Supports microSD (up to 256 GB) |
Dimensions | Not specified | 10.2" x 9.1" x 7.8" (25.91 x 23.11 x 19.81 cm) | 10.2" x 9.1" x 7.8" (25.91 x 23.11 x 19.81 cm) |
Weight | Not specified | 2.9 lbs (1.32 kg) | 2.9 lbs (1.32 kg) |
Ambient Light Mode | No | Yes | Yes |
Motion-Activated Voice Deterrence | No | Yes | Yes |
Extra USB Port | Yes (for second Wyze Cam v3) | Not specified | Not specified |
Installation | Wired, DIY | Wired, DIY with optional plug-in mount | Wired, DIY with optional plug-in mount |
Warranty | Not specified | 1 Year | 1 Year |
Phone Compatibility | Android 9.0+, iOS 15.0+ | Android 9.0+, iOS 15.0+ | Android 9.0+, iOS 15.0+ |
Integrations | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT |
Frame Rate (Day/Night) | Not specified | 20 FPS / 15 FPS | 20 FPS / 15 FPS |
What are Wyze refurbished floodlight cameras?
Wyze refurbished floodlight cameras are pre-owned devices that have been fully tested, restored, and guaranteed to work like new. They offer advanced security features, smart home integration, and cost savings compared to new models.What is the difference between Wyze Cam Floodlight v1 and Floodlight Pro (refurbished)?
The Wyze Cam Floodlight v1 features 1080p Full HD video, a 121° field of view, 2600 lumens of lighting, and 2.4 GHz WiFi. The Floodlight Pro offers 2.5K QHD video, a 180° ultra-wide field of view, 3000 lumens, dual-band WiFi (2.4 & 5 GHz), advanced AI computer vision, and color night vision for superior clarity and coverage.Do Wyze refurbished floodlight cameras come with a warranty?
Yes, all Wyze refurbished floodlight cameras are fully tested and guaranteed to perform like new, ensuring reliable quality and performance.What are the key features of the Wyze Cam Floodlight v1 (refurbished)?
The Wyze Cam Floodlight v1 (refurbished) offers 1080p Full HD video, 121° field of view, 2600 lumens of bright lighting, AI detection for people, pets, vehicles, and packages, two-way audio, a 105dB siren, IP65 weather resistance, and an extra USB port for device connectivity.What are the main features of the Wyze Cam Floodlight Pro (refurbished)?
The Wyze Cam Floodlight Pro (refurbished) provides 2.5K QHD video resolution, a 180° ultra-wide field of view, 3000 lumen adjustable LED lights, advanced AI computer vision, dual-band WiFi, color night vision, two-way audio, a 105dB siren, IP65 weather resistance, and an extra USB port.How does the dual USB port benefit Wyze floodlight camera users?
Both Wyze Cam Floodlight v1 and Floodlight Pro models include an extra USB port, allowing users to power or charge additional smart devices or accessories directly from the floodlight unit, enhancing outdoor smart home integration and convenience.Are Wyze refurbished floodlight cameras weather resistant?
Yes, both the Wyze Cam Floodlight v1 and Floodlight Pro (refurbished) are IP65 rated, making them durable and weather resistant for reliable outdoor use in various conditions.What is the installation process for Wyze refurbished floodlight cameras?
Wyze floodlight cameras are designed for easy DIY installation, with the Floodlight Pro model specifically noted for setup in under 20 minutes.What types of motion detection and alerts do Wyze floodlight cameras offer?
Wyze Cam Floodlight v1 provides AI detection for people, pets, vehicles, and packages, while the Floodlight Pro uses advanced AI computer vision for selective alerts, ensuring you receive relevant notifications.Why should I choose a refurbished Wyze floodlight camera?
Choosing a refurbished Wyze floodlight camera offers like-new quality at a lower price, reduces environmental impact, and provides all the smart security features you need to protect your home.
What are the key features of the Wyze Cam Floodlight v1?Can you explain the benefits of choosing a refurbished Wyze product?Do you have any deals, ongoing sales, discounts, or promotions?
