Refurbished Wyze Cam Pro: Advanced AI Home Security Camera
Refurbished Wyze Cam Pro with Advanced Edge AI for Home Security
When it comes to securing your home with smart technology, the Wyze Cam series offers reliable, affordable, and feature-rich options. Although the exact "Wyze Cam Pro" with advanced edge AI is not listed, the Refurbished Wyze Cam v2 stands out as a classic, budget-friendly security camera with essential smart features that enhance home security. Below, we explore the key specs and benefits of the Wyze Cam v2 and complementary accessories that can elevate your home security setup.
Wyze Cam v2: Affordable Refurbished Security with Smart Features
Key Features and Specifications
  • 1080p Full HD Video: Crystal-clear video quality ensures you never miss a detail.
  • Night Vision: Equipped with four 850nm infrared LEDs, it provides visibility up to 30 feet in complete darkness.
  • Motion Tagging & Custom Detection Zones: Smart motion detection with customizable zones and sensitivity settings to reduce false alerts.
  • Two-Way Audio: Built-in microphone and speaker allow you to listen and talk through the camera remotely.
  • Wide-Angle Lens: 110° field of view with a 2.8mm focal length lens captures a broad area.
  • Continuous Recording & Time Lapse: Supports continuous video recording and time-lapse features for versatile monitoring.
  • Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant for voice control.
  • Design & Mounting: Compact 3-axis design with flexible mounting options including metal plate and adhesive tape.
The refurbished Wyze Cam v2 is an excellent choice for those seeking a cost-effective, reliable home security camera with essential smart features.
Enhance Your Setup with Wyze Accessories
Wyze Cam Mounting Kit
  • Designed specifically for Wyze Cam v2, v3, and v3 Pro.
  • Includes a mounting bracket, adhesive tape, and a longer 5-foot Micro USB cable.
  • Easy installation for optimal camera placement indoors or outdoors.
Lamp Socket v2 (Compatible with Wyze Cam v3/v3 Pro/v4 and others)
  • Powers your Wyze Cam without needing a nearby power outlet.
  • Features motion-activated lights and dusk-to-dawn scheduling.
  • Connects via standard E26 socket, compatible with LED or CFL bulbs under 20W.
  • Ideal for making your exterior lighting smarter and more secure.
These accessories help you customize and optimize your Wyze Cam system for better coverage and convenience.
Why Choose Refurbished Wyze Cam v2 for Home Security?
  • Cost-Effective: Get premium features at a fraction of the price.
  • Trusted Brand: Wyze is known for delivering smart home products with excellent value.
  • Smart AI Features: While not the latest edge AI, the motion tagging and customizable detection zones provide intelligent monitoring.
  • Easy Integration: Works with popular smart home ecosystems for seamless control.
Summary
The Refurbished Wyze Cam v2 is a smart, budget-friendly security camera perfect for home monitoring. Paired with accessories like the Wyze Cam Mounting Kit and Lamp Socket v2, you can create a flexible and powerful home security system. Whether you want to keep an eye on your front door, backyard, or any indoor space, Wyze offers reliable solutions that fit your needs.
Home Security Camera in Use Alt text: Homeowner monitoring security camera on smartphone
Feature(Refurbished) Wyze Cam v2Wyze Cam Mounting KitWyze Lamp Socket v2
TypeRefurbished Smart CameraAccessoriesAccessories
Price$19.99$5.99$16.98
ColorWhiteN/AWhite
Video Resolution1080p Full HD (1920×1080)N/AN/A
Lens2.8mm focal length, 110º wide angle lensN/AN/A
Sensor1/2.9" CMOS sensorN/AN/A
Night VisionYes, with F2.0 aperture, IR-CUT filter, 4 IR LEDsN/AN/A
Audio2-Way Audio (built-in speaker & microphone)N/AN/A
Motion & Sound DetectionYes, with custom zone detection and sensitivityN/AN/A
Cloud Storage14 days free video clipsN/AN/A
MountingMagnetic base with metal plate and adhesive tapeMounting bracket, adhesive, longer Micro USB cableN/A
Power SourceWiredN/APowers Wyze Cam v3/v3 Pro/v4, Cam OG, Pan v3 via lamp socket
Connectivity802.11 b/g/n, 2.4 GHz Wi-FiN/A802.11 b/g/n 2.4GHz Wi-Fi, Bluetooth
DimensionsNot specifiedNot specified56.5mm x 56.5mm x 65mm
WeightNot specifiedNot specified80 g
Weather ResistanceNot specifiedN/ANot weatherproof, suitable for damp locations
CompatibilityWyze Cam v2Wyze Cam v2, v3, v3 ProWyze Cam v3, v3 Pro, v4, Cam OG, Pan v3
Additional FeaturesLive stream with 8x digital zoom, CO2 & smoke alarm alerts, time lapseSpare mounting plate, longer Micro USB cablePowers camera without power outlet, E26 socket, max lamp power 20W
WarrantyNot specified30-day hassle-free returns1-Year
What are the key features of the refurbished Wyze Cam v2 for home security?The refurbished Wyze Cam v2 offers 1080p Full HD video, night vision up to 30 feet, motion tagging with customizable detection zones, two-way audio, a wide 110° field of view, continuous recording, time-lapse capabilities, and compatibility with Alexa and Google Assistant. Its compact 3-axis design allows for flexible mounting options.
Is the refurbished Wyze Cam v2 a good choice for affordable home security?Yes, the refurbished Wyze Cam v2 is a cost-effective and reliable security camera that provides essential smart features for home monitoring. It is an excellent option for those seeking quality security at a budget-friendly price.
Does the Wyze Cam v2 support night vision?Yes, the Wyze Cam v2 is equipped with four 850nm infrared LEDs, providing clear night vision up to 30 feet in complete darkness.
Can I use voice assistants with the Wyze Cam v2?Absolutely. The Wyze Cam v2 works seamlessly with popular smart assistants like Alexa and Google Assistant, allowing for convenient voice control.
What accessories are available for the Wyze Cam v2?Accessories for the Wyze Cam v2 include the Wyze Cam Mounting Kit, which offers a mounting bracket, adhesive tape, and a longer 5-foot Micro USB cable for easy installation. The Lamp Socket v2 is also available, providing power and motion-activated lighting for compatible Wyze Cams.
How does the Wyze Cam Mounting Kit enhance camera installation?The Wyze Cam Mounting Kit is designed for easy installation of Wyze Cam v2, v3, and v3 Pro. It includes a mounting bracket, adhesive tape, and a longer USB cable, making it simple to place your camera in the optimal location indoors or outdoors.
What is the Lamp Socket v2 and how does it work with Wyze Cams?The Lamp Socket v2 powers your Wyze Cam (compatible with v3, v3 Pro, v4, and others) without needing a nearby outlet. It features motion-activated lights, dusk-to-dawn scheduling, and connects via a standard E26 socket, making it ideal for smarter and more secure exterior lighting.
What smart features does the Wyze Cam v2 offer for intelligent monitoring?The Wyze Cam v2 includes motion tagging, customizable detection zones, and adjustable sensitivity settings to reduce false alerts, providing intelligent and efficient home monitoring.
Why should I choose a refurbished Wyze Cam v2 over a new model?Choosing a refurbished Wyze Cam v2 allows you to enjoy premium security features at a lower price. Wyze is a trusted brand known for value and reliability, and the refurbished model offers essential smart features for effective home security.
Can the Wyze Cam v2 be used for both indoor and outdoor security?While the Wyze Cam v2 is primarily designed for indoor use, it can be installed outdoors in protected areas using compatible accessories like the Wyze Cam Mounting Kit. For full outdoor use, consider weatherproof models like the Wyze Cam v3.
What are the key features of the Wyze Cam v2 that make it suitable for home security?Can you tell me more about the Wyze Cam Mounting Kit and how it works?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
