Refurbished Wyze Telephoto Cameras with Fast Notifications and Two-Way Audio
Looking for a reliable, refurbished Wyze telephoto camera that offers fast notifications and seamless two-way audio? Wyze’s refurbished lineup delivers exceptional home security solutions with advanced features, including telephoto zoom, quick alerts, and crystal-clear communication. Whether you want to monitor your indoor spaces or keep an eye on the outdoors, these cameras combine affordability with cutting-edge technology.
(Refurbished) Wyze Cam OG Telephoto
Powerful 3x Telephoto Zoom for Detailed Surveillance
The Wyze Cam OG Telephoto is designed to capture the finer details with its 3x telephoto lens, allowing you to zoom in on distant subjects without losing image quality. This makes it perfect for spotting potential intruders or monitoring pets and packages from afar.
Fast and Responsive Notifications
Equipped with an improved chipset and revamped software, this camera sends motion notifications 3 times faster than other Wyze models. Every second counts when it comes to security, and this camera ensures you’re alerted instantly.
Enhanced Two-Way Audio
Communicate clearly with visitors or family members using the upgraded microphone and speaker system. The improved two-way audio offers enhanced clarity, making conversations natural and easy.
Indoor/Outdoor Durability
With an IP65 weather resistance rating, the Wyze Cam OG Telephoto is built to withstand harsh weather conditions, making it suitable for both indoor and outdoor use. Whether rain or shine, your security remains uninterrupted.
Color Night Vision & Siren
Enjoy vivid color night vision that captures every detail even in low light. Plus, a 90-decibel user-activated siren helps deter unwanted visitors effectively.
"Back to the basics, with a huge leap forward."
(Refurbished) Wyze Cam v2 – The Classic Home Security Camera
Crisp 1080p Full HD Video
The Wyze Cam v2 offers 1080p full HD resolution with a 110º wide-angle lens, ensuring you see every important moment clearly. Its 1/2.9" CMOS sensor delivers sharp images day and night.
Night Vision Up to 30 Feet
Equipped with four 850nm infrared LEDs and an IR-CUT filter, this camera provides enhanced night vision that works even in total darkness, keeping your home secure around the clock.
Fast Motion and Sound Alerts
Customize motion detection zones and sensitivity to receive notifications only when it matters. The camera also listens for smoke and CO alarms, sending immediate alerts to your phone for quick action.
Flexible Mounting and Two-Way Audio
The innovative 3-axis design and magnetic base allow you to mount the camera anywhere without screws. Use the built-in speaker and microphone to talk and listen through the Wyze app, perfect for checking in on loved ones or pets.
Compatible with Alexa and Google Assistant
Use voice commands to view live streams on compatible devices, making it easy to monitor your home hands-free.
(Refurbished) Wyze Cam OG – Spotlight and Smart Indoor/Outdoor Security
Bright Built-In Spotlight
The Wyze Cam OG features two 5000K, 40-lumen spotlights that illuminate your space, enhancing security and visibility during nighttime.
1080p Full HD with Wide Field of View
With a 121.4º diagonal field of view, this camera covers more area, reducing blind spots. The CMOS-Starlight sensor ensures clear video quality in various lighting conditions.
IP65 Weather Resistance
Designed for both indoor and outdoor use, the Wyze Cam OG withstands temperatures from -4°F to 131°F and resists dust and water, making it a versatile security solution.
Advanced Two-Way Audio with Noise Cancellation
Communicate effortlessly with built-in speaker and microphone featuring noise and echo cancellation for crystal-clear conversations.
Local Storage and Smart Alerts
Supports microSD cards up to 256GB for continuous recording. Receive smart notifications for motion, sound, and even smoke or carbon monoxide alarms.
Why Choose Refurbished Wyze Telephoto Cameras?
Refurbished Wyze cameras offer like-new performance at a fraction of the price. Each unit is fully tested and guaranteed to work, providing you with reliable security without breaking the bank. With features like fast notifications, two-way audio, telephoto zoom, and weather resistance, these cameras are perfect for anyone seeking smart, affordable home monitoring.
Experience detailed home security with Wyze Cam OG Telephoto’s 3x zoom and fast alerts.
Stay connected with family and visitors using Wyze’s clear two-way audio feature.
Illuminate and protect your property day and night with Wyze Cam OG’s built-in spotlight.
Summary of Key Features
Feature | Wyze Cam OG Telephoto | Wyze Cam v2 | Wyze Cam OG |
Video Resolution | 1080p Full HD | 1080p Full HD | 1080p Full HD |
Telephoto Zoom | 3x Zoom | No | No |
Field of View | 27º (Telephoto) | 110º Wide Angle | 121.4º Diagonal |
Night Vision | Color Night Vision | IR Night Vision (up to 30 ft) | IR Night Vision + Spotlight |
Two-Way Audio | Enhanced Mic & Speaker | Built-in Speaker & Mic | Noise & Echo Cancellation |
Weather Resistance | IP65 | Indoor Use | IP65 |
Fast Notifications | 3x Faster | Standard | 3x Faster |
Additional Features | 90dB Siren, Outdoor Ready | Smoke & CO Alarm Alerts | Built-in Spotlight |
Choose the Wyze refurbished telephoto camera that fits your security needs and enjoy fast notifications, clear two-way audio, and reliable performance at a great price.
What are the benefits of buying a refurbished Wyze telephoto camera?
Refurbished Wyze telephoto cameras offer like-new performance at a fraction of the price. Each unit is fully tested and guaranteed to work, providing reliable home security with advanced features such as fast notifications, two-way audio, telephoto zoom, and weather resistance.What is the Wyze Cam OG Telephoto and what features does it offer?
The Wyze Cam OG Telephoto is a refurbished security camera featuring a powerful 3x telephoto zoom lens for detailed surveillance, fast motion notifications, enhanced two-way audio, IP65 weather resistance for indoor and outdoor use, color night vision, and a 90-decibel user-activated siren.How fast are the notifications on Wyze refurbished cameras?
Refurbished Wyze Cam OG Telephoto and Wyze Cam OG models send motion notifications up to 3 times faster than previous Wyze models, ensuring you receive instant alerts when activity is detected.Can I use Wyze refurbished cameras outdoors?
Yes, both the Wyze Cam OG Telephoto and Wyze Cam OG are IP65 weather resistant, making them suitable for both indoor and outdoor use. They are designed to withstand harsh weather conditions, including rain and dust.Does the Wyze Cam OG Telephoto have night vision?
Yes, the Wyze Cam OG Telephoto features vivid color night vision, allowing you to capture clear details even in low-light conditions.What is the difference between Wyze Cam OG Telephoto, Wyze Cam v2, and Wyze Cam OG?
The Wyze Cam OG Telephoto offers 3x telephoto zoom and color night vision, making it ideal for detailed surveillance. The Wyze Cam v2 is a classic model with 1080p HD video, 110º wide-angle lens, and IR night vision up to 30 feet. The Wyze Cam OG features a built-in spotlight, wide 121.4º field of view, and advanced two-way audio with noise cancellation.Do Wyze refurbished cameras support two-way audio?
Yes, all refurbished Wyze cameras support two-way audio. The Wyze Cam OG Telephoto and Wyze Cam OG offer enhanced audio clarity, while the Wyze Cam OG also features noise and echo cancellation for crystal-clear conversations.Can I store video locally on Wyze refurbished cameras?
Yes, the Wyze Cam OG supports local storage with microSD cards up to 256GB for continuous recording. This allows you to review footage even if your internet connection is interrupted.Are Wyze refurbished cameras compatible with Alexa and Google Assistant?
Yes, the Wyze Cam v2 is compatible with Alexa and Google Assistant, allowing you to use voice commands to view live streams on compatible devices for hands-free home monitoring.What kind of alerts do Wyze refurbished cameras provide?
Wyze refurbished cameras provide fast motion and sound alerts. The Wyze Cam v2 and Wyze Cam OG can also detect smoke and carbon monoxide alarms, sending immediate notifications to your phone for quick action.How does the spotlight feature work on the Wyze Cam OG?
The Wyze Cam OG features two built-in 5000K, 40-lumen spotlights that illuminate your space, enhancing security and visibility during nighttime or low-light conditions.
