Wyze Refurbished Telephoto Security Cameras for Long Range
Wyze Refurbished Telephoto Security Cameras for Long Range Surveillance
When it comes to long-range surveillance, Wyze offers a standout option with its Wyze Cam OG Telephoto. Designed for users who need enhanced zoom capabilities and crystal-clear video quality, this camera is perfect for monitoring distant areas with precision. Alongside it, other Wyze cameras provide complementary features for versatile security setups.
Wyze Cam OG Telephoto: Precision Zoom for Long Distance Monitoring
The Wyze Cam OG Telephoto is the ideal choice for long-range surveillance thanks to its powerful 3x telephoto lens, which significantly narrows the field of view to focus on distant subjects without losing clarity.
Key Features:
  • 3x Telephoto Lens: Offers a diagonal field of view of 27°, horizontal 23.6°, and vertical 13.6°, enabling detailed zoomed-in views.
  • 1080p Full HD Video: Crisp 1920 x 1080 resolution ensures clear images day and night.
  • Improved Live Streaming: Experience 3x faster notifications and quicker live video streaming for real-time monitoring.
  • Night Vision: Equipped with 4 IR LEDs (850nm) for clear black-and-white night vision.
  • 8x Digital Zoom: Further zoom into areas of interest with digital enhancement.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for clear communication.
  • Weather Resistant (IP65): Suitable for indoor and outdoor use, operating in temperatures from -4°F to 131°F.
  • Local Storage Support: Compatible with microSD cards up to 256 GB in exFAT format.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Dimensions & Power:
  • Compact size: 1.89in x 1.89in x 1.89in (48mm cube)
  • Lightweight at 4.1 oz (116 g)
  • Powered via 6 ft micro USB cable (5V/1A adapter included)
This camera is perfect for users who want to keep a close eye on distant areas such as driveways, backyards, or large properties without sacrificing image quality.
Complementary Wyze Cameras for Enhanced Security
While the Wyze Cam OG Telephoto excels at long-range zoom, other Wyze cameras offer additional features that can complement your surveillance system.
Wyze Cam OG: Reliable Full HD with Spotlight
  • 1080p HD Video with 120° field of view for wide coverage.
  • Built-in 40-lumen spotlight and 90-decibel siren for deterrence.
  • Fast live streaming with 3x quicker notifications.
  • Two-way audio with upgraded microphone and speaker.
  • Weather resistant (IP65) for indoor/outdoor use.
  • Supports microSD storage up to 256 GB.
This camera is a versatile option for general surveillance with added security features like spotlight and siren.
Wyze Cam v4: High-Resolution Outdoor Security
  • Stunning 2.5K QHD (2560x1440) video resolution.
  • Enhanced Color Night Vision with 4 IR LEDs plus 2 white spotlight LEDs.
  • Motion-activated spotlight and built-in siren.
  • Supports Wi-Fi 6 for faster, more reliable connectivity.
  • Wide 115.8° diagonal field of view for broad coverage.
  • Local storage up to 512 GB microSD and cloud storage options.
  • IP65 weather resistance for all-season outdoor use.
Ideal for users who want ultra-clear video and advanced night vision for outdoor security.
Wyze Cam Pan v3: 360° Pan and Tilt Coverage
  • Full 360° horizontal and 180° vertical viewing range.
  • 1080p HD video with 8x digital zoom.
  • IP65 weatherproof for outdoor use (requires separate outdoor power adapter).
  • Two-way audio with noise and echo cancellation.
  • Fast pan speed up to 110° per second for tracking movement.
  • Supports microSD cards up to 256 GB.
Perfect for monitoring large areas with flexible camera movement.
Why Choose Wyze Refurbished Telephoto Cameras?
Wyze refurbished cameras offer excellent value by combining advanced features with affordable pricing, backed by a 1-year warranty. The Wyze Cam OG Telephoto stands out for long-range surveillance needs, delivering sharp zoomed-in footage without compromising on speed or night vision.
Visualizing Wyze Security in Action
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 providing weather-resistant outdoor security in winter conditions. Two-way audio interaction with Wyze camera Clear two-way audio communication with Wyze cameras enhances home security and interaction. Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam combines lighting and security for versatile outdoor protection.
Summary of Wyze Telephoto and Security Cameras
ProductResolutionZoomNight VisionWeather ResistanceSpecial Features
Wyze Cam OG Telephoto1080p Full HD3x Optical + 8x Digital4 IR LEDs (850nm)IP65Fast live streaming, 2-way audio
Wyze Cam OG1080p Full HD8x Digital4 IR LEDs + SpotlightIP65Built-in spotlight & siren
Wyze Cam v42.5K QHD8x DigitalColor Night VisionIP65Wi-Fi 6, motion spotlight, siren
Wyze Cam Pan v31080p Full HD8x Digital4 IR LEDsIP65360° pan & 180° tilt, fast rotation
Wyze’s refurbished telephoto and security cameras provide a comprehensive solution for long-range and general surveillance needs, combining affordability, advanced features, and reliable performance for your home or business security.
FeatureWyze Cam OG TelephotoWyze Cam OGWyze Cam v4Wyze Cam Pan v3Wyze Bulb Cam
Resolution1080p (1920 x 1080)1080p (1920 x 1080)2.5K QHD (2560 x 1440)1080p (1920 x 1080)2K HD (2304 x 1296)
Field of View (FOV)27° (3x Telephoto lens)120°115.9° (D) x 98.5° (H) x 53.1° (V)120°160° (Diagonal 166°, Horizontal 144°, Vertical 82.5°)
Zoom3x Telephoto zoom8x Digital zoom8x Digital zoom8x Digital zoomDigital zoom (not specified)
Night VisionColor Night VisionColor Night VisionEnhanced Color Night VisionIR Night Vision (4 IR LEDs, 850 nm)Color Night Vision + IR Night Vision
AudioImproved 2-way audioBuilt-in speaker & mic; noise & echo cancellationEnhanced two-way talk; AAC codecBuilt-in speaker & mic; 2-way audio; noise & echo cancellationBuilt-in digital mic; 2-way audio
Siren90 dB user-activated siren90 dB user-activated siren99 dB built-in sirenNot specified95 dB siren at 4 in
SpotlightNo built-in spotlightBuilt-in spotlight (40 lumens)Motion-activated spotlightNo spotlightIntegrated smart LED light bulb
Weather ResistanceIP65 (Indoor/Outdoor)IP65 (Indoor/Outdoor)IP65IP65IP65
Power SourceWiredWiredWiredWired120V AC (standard E26 bulb socket)
Connectivity2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi + Wi-Fi 6 support2.4 GHz Wi-Fi (no 5 GHz)2.4 GHz Wi-Fi
Local StorageSupports microSD up to 256GBSupports microSD up to 256GBSupports microSD up to 512GBSupports microSD up to 256GBSupports microSD up to 256GB
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionCloud storage via AWS (subscription)
Smart FeaturesCustom detection zones, smoke & CO alertsCustom detection zones, smoke & CO alertsMotion & sound detection, detection zones, smoke & CO alertsPush notifications, Alexa/Google/IFTTT integrationMotion alerts, Wyze Automations
IntegrationAlexa, Google Assistant, Wyze Stack KitAlexa, Google Assistant, Wyze Stack KitAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant (via Wyze app)
DimensionsNot specified1.89 in x 1.89 in x 1.89 in2 in x 2 in x 2 3/8 in124 mm x 60 mm x 63 mmStandard bulb size (E26 socket)
WeightNot specified4.1 oz (116 g)0.49 lb (222 g)11.29 oz (320 g)Not specified
Price (1 Pack)$25.98$29.98$35.98$39.98$49.98
Special Features3x telephoto lens, 3x faster notifications, 50% faster live streamingBuilt-in spotlight, 3x faster notifications, 50% faster live streaming2.5K QHD, Wi-Fi 6, motion-activated spotlight, 24/7 local recording360° pan, 180° tilt, 110°/sec rotation speed2-in-1 camera and smart LED bulb, motion-activated light, up to 800 lm brightness
What is the Wyze Cam OG Telephoto and how is it used for long-range surveillance?The Wyze Cam OG Telephoto is a security camera designed specifically for long-range surveillance. It features a powerful 3x telephoto lens that narrows the field of view to focus on distant subjects, making it ideal for monitoring areas like driveways, backyards, or large properties. With 1080p Full HD video, night vision, and 8x digital zoom, it delivers clear, detailed footage even from a distance.
What are the key features of the Wyze Cam OG Telephoto?Key features of the Wyze Cam OG Telephoto include a 3x telephoto lens, 1080p Full HD video, 8x digital zoom, improved live streaming with faster notifications, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, IP65 weather resistance, local storage support up to 256 GB, and smart home integration with Alexa, Google Assistant, and IFTTT.
Is the Wyze Cam OG Telephoto weather resistant?Yes, the Wyze Cam OG Telephoto is IP65 weather resistant, making it suitable for both indoor and outdoor use. It can operate in temperatures ranging from -4°F to 131°F, ensuring reliable performance in various weather conditions.
Does the Wyze Cam OG Telephoto support local storage?Yes, the Wyze Cam OG Telephoto supports local storage with microSD cards up to 256 GB in exFAT format, allowing you to record and review footage directly from the camera.
What is the difference between the Wyze Cam OG Telephoto and other Wyze cameras?The Wyze Cam OG Telephoto is optimized for long-range surveillance with its 3x telephoto lens and focused field of view. Other Wyze cameras, such as the Wyze Cam OG, Wyze Cam v4, and Wyze Cam Pan v3, offer features like wider fields of view, higher resolution (up to 2.5K QHD), color night vision, motion-activated spotlights, sirens, and 360° pan and tilt coverage for general and outdoor security needs.
What are the benefits of buying a refurbished Wyze telephoto camera?Refurbished Wyze telephoto cameras offer excellent value by combining advanced features with affordable pricing. They are backed by a 1-year warranty and undergo thorough testing to ensure reliable performance, making them a cost-effective choice for long-range surveillance.
Can Wyze security cameras be integrated with smart home systems?Yes, Wyze security cameras, including the Wyze Cam OG Telephoto, are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.
What is the video resolution of Wyze security cameras?Wyze security cameras offer various video resolutions: the Wyze Cam OG Telephoto and Wyze Cam OG provide 1080p Full HD video, while the Wyze Cam v4 delivers higher 2.5K QHD (2560x1440) resolution for ultra-clear footage.
Do Wyze cameras have night vision capabilities?Yes, Wyze cameras are equipped with night vision. The Wyze Cam OG Telephoto and Wyze Cam OG use 4 IR LEDs for clear black-and-white night vision, while the Wyze Cam v4 features enhanced color night vision with additional white spotlight LEDs for improved visibility in low-light conditions.
What storage options are available for Wyze security cameras?Wyze security cameras support local storage via microSD cards (up to 256 GB for most models and up to 512 GB for Wyze Cam v4) and also offer cloud storage options for added flexibility and security.
Which Wyze camera is best for monitoring large areas?The Wyze Cam Pan v3 is ideal for monitoring large areas, thanks to its 360° horizontal and 180° vertical pan and tilt capabilities, 1080p HD video, and fast rotation speed. It provides flexible coverage for wide spaces such as yards, warehouses, or open-plan offices.
What are the key features of the Wyze Cam OG Telephoto?Can you tell me more about the night vision capabilities of the Wyze Cam OG Telephoto?What is the warranty policy for the Wyze Cam OG Telephoto?
