Affordable Refurbished Wyze Outdoor Cams with AI & Telephoto Zoom
Affordable Refurbished Wyze Security Cameras for Outdoor Use with AI and Telephoto Zoom
Looking for an affordable, reliable Wyze security camera that supports outdoor use, AI features, and telephoto zoom? Whether you want a budget-friendly refurbished option or a cutting-edge outdoor camera with AI-powered lighting and zoom capabilities, Wyze offers a range of products tailored to your needs. This guide highlights the best Wyze security cams, including refurbished models and advanced outdoor cameras, to help you secure your home smartly and affordably.
(Refurbished) Wyze Cam v2: Classic Affordable Security Camera
Key Features and Specs
  • 1080p Full HD Video: Crisp 1920×1080 resolution with a 2.8mm focal length lens.
  • 110º Wide Angle Lens: Covers a broad field of view to monitor large areas.
  • 8x Digital Zoom: Zoom in on details remotely via the Wyze app.
  • Night Vision: Enhanced night vision with four 850nm infrared LEDs and IR-CUT filter, clear up to 30 feet in total darkness.
  • Motion & Sound Detection: Customizable zones and sensitivity settings alert you to activity, including smoke and CO alarms.
  • 2-Way Audio: Built-in microphone and speaker for real-time communication.
  • Flexible Mounting: Innovative 3-axis design with magnetic base for easy installation anywhere without screws.
  • Works with Alexa & Google Assistant: Voice control to view live streams on smart displays.
  • Continuous Recording: Supports microSD cards for 24/7 recording (card not included).
Why Choose Refurbished Wyze Cam v2?
This refurbished model offers the classic Wyze experience at a budget-friendly price of $19.99. It’s perfect for users who want dependable wired security cameras with essential features like night vision and two-way audio without breaking the bank.
Wyze Cam v4: Advanced Outdoor Camera with AI and Telephoto Zoom
Cutting-Edge Outdoor Security
  • 2.5K QHD Video Resolution (2560x1440): Ultra-clear video quality for detailed monitoring.
  • 115.8º Diagonal Field of View: Wide coverage with sharp focus.
  • 8x Digital Zoom: Zoom in on distant objects with clarity.
  • CMOS Starlight Sensor: Superior low-light performance for crisp night vision.
  • Color Night Vision: See colors even in low light, enhanced by 4 IR LEDs and 2 white spotlight LEDs.
  • IP65 Weather Resistance: Built to withstand outdoor elements from -4ºF to 122ºF.
  • AI-Powered Detection: Smart motion alerts reduce false alarms.
  • Two-Way Talk & Built-in Siren: Communicate and deter intruders instantly.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for versatile placement.
  • Wi-Fi 6 & Bluetooth 5.2: Fast, reliable connectivity.
  • Local & Cloud Storage: Supports microSD cards up to 512GB and cloud subscriptions.
Ideal for Outdoor Use
Wyze Cam v4 is designed specifically for outdoor environments, combining AI-powered features with robust weatherproofing. Its telephoto zoom and color night vision make it a standout choice for detailed, round-the-clock surveillance.
Wyze Cam Floodlight v2: Bright, AI-Powered Outdoor Security with Telephoto Zoom
Wyze Cam Floodlight v2 illuminating driveway at night
Powerful Lighting Meets Smart Security
  • 2K Video with Color Night Vision: 2304 x 1296 resolution with vivid color even at night.
  • 2800 Lumens LED Brightness: Two dimmable LED panels flood your yard with light.
  • 160º Wide-Angle View: Covers large outdoor areas with ease.
  • AI-Powered Light Control: Lights activate only for selected objects like people or vehicles.
  • IP65 Weatherproof Rating: Durable for all weather conditions.
  • Two-Way Audio & 105dB Siren: Communicate and scare off intruders.
  • 24/7 Local Recording: Supports up to 256GB microSD card.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
  • Dusk-to-Dawn Automation: Automatically adjusts lighting based on ambient light.
Why Choose Wyze Cam Floodlight v2?
This camera is perfect for those who want a security camera combined with powerful floodlighting and AI detection. It’s ideal for driveways, porches, and yards where bright illumination and detailed video are essential.
Summary: Which Wyze Security Camera Fits Your Needs?
ProductPrice (Approx.)Outdoor UseAI FeaturesTelephoto ZoomNight VisionWeather ResistanceSpecial Features
(Refurbished) Wyze Cam v2$19.99Limited*Basic8x DigitalYesNoBudget-friendly, classic design
Wyze Cam v4$100YesAdvanced8x DigitalColor NightIP65AI detection, color night vision
Wyze Cam Floodlight v2$89.98YesAI-PoweredDigital ZoomColor NightIP652800 lumens floodlight, siren
*Note: The refurbished Wyze Cam v2 is primarily designed for indoor use but can be used outdoors if protected from weather.
Enhance Your Outdoor Security with Wyze
Wyze offers a range of security cameras that combine affordability, advanced AI features, and telephoto zoom capabilities for outdoor use. Whether you choose the budget-friendly refurbished Wyze Cam v2 or the feature-rich Wyze Cam v4 and Floodlight v2, you get reliable protection and smart home integration to keep your property safe day and night. Wyze Cam Floodlight v2 lifestyle with two-way audio
Additional Options: Power and Mounting Accessories
For enhanced outdoor installation, consider the Cam v4 + Lamp Socket v2 Bundle which powers your Wyze Cam v4 through existing lamp sockets without needing an outlet. This bundle supports motion-activated lights and dusk-to-dawn scheduling, making your outdoor security setup even smarter and more convenient.
Secure your home affordably and smartly with Wyze’s range of security cameras designed for outdoor use, AI-powered detection, and telephoto zoom. Choose the model that fits your budget and security needs today!
Feature(Refurbished) Wyze Cam v2Wyze Cam v4Wyze Cam Floodlight v2
Price$19.99$100.00 (regular), $35.98 (some bundles)$89.98
Resolution1080p Full HD (1920×1080)2.5K QHD (2560×1440)2K (2304×1296)
Field of View110º wide angle lens115.9° (D) x 98.5° (H) x 53.1° (V)160° diagonal
Night VisionIR-CUT filter, 4x 850nm IR LEDs (B&W)Enhanced Color Night Vision, 4 IR LEDs + 2 white spotlight LEDsColor Night Vision
Digital Zoom8x Digital Zoom8x Digital ZoomNot specified
Audio2-Way Audio (built-in speaker & mic)Enhanced 2-Way Talk2-Way Audio (built-in speaker & mic)
Motion & Sound DetectionYes, with custom zones and sensitivityYes, with motion detection zonesAdvanced motion detection
Smoke & CO Alarm AlertsYesYesNot specified
Continuous RecordingmicroSD card (not included)microSD card up to 512GBSupports up to 256GB microSD (local storage)
Cloud Storage14 days free cloud storageAvailable with subscriptionNot specified
Design & Mounting3-axis design, magnetic base with metal plate & adhesive tapeMagnetic mount, screw-freeWall or ceiling mount, hardwired
Weather ResistanceNoIP65 ratedIP65 rated
Power SourceWiredWiredHardwired
Spotlight & SirenNoMotion-activated spotlight, built-in siren2800 Lumens LEDs, 105dB siren
Audio SirenNoYes (built-in siren)Yes (105dB siren)
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Dimensions & WeightNot specified2in x 2in x 2 3/8in; 0.49 lb (222 g)9.5in x 7.7in x 7.0in; 2.76 lbs (1.25 kg)
Additional FeaturesNight vision up to 30 feet, CO2 & smoke alarm sound detectionWi-Fi 6 support, Auto-zoom with AI, Wide Dynamic Range (WDR)Ambient Light Mode, AI-Powered Light Control, Dusk-to-dawn automation
WarrantyNot specified1 Year1 Year
What are the benefits of buying a refurbished Wyze Cam v2 security camera?A refurbished Wyze Cam v2 offers the classic Wyze experience at a budget-friendly price, typically around $19.99. It provides essential features such as 1080p HD video, night vision, two-way audio, motion and sound detection, and flexible mounting options. This makes it an affordable and reliable choice for users seeking dependable security without breaking the bank.
Is the refurbished Wyze Cam v2 suitable for outdoor use?The refurbished Wyze Cam v2 is primarily designed for indoor use. However, it can be used outdoors if it is properly protected from weather elements, as it does not have weather resistance like other outdoor-specific Wyze cameras.
What advanced features does the Wyze Cam v4 offer for outdoor security?The Wyze Cam v4 is designed for outdoor use and features 2.5K QHD video resolution, 8x digital zoom, a CMOS starlight sensor for superior low-light performance, color night vision, IP65 weather resistance, AI-powered motion detection, two-way talk, a built-in siren, and multiple mounting options. It also supports both local and cloud storage and offers fast connectivity with Wi-Fi 6 and Bluetooth 5.2.
How does the Wyze Cam Floodlight v2 enhance outdoor security?The Wyze Cam Floodlight v2 combines a high-resolution 2K camera with powerful 2800 lumens LED floodlights. It features AI-powered light control that activates only for selected objects like people or vehicles, color night vision, a 160º wide-angle view, two-way audio, a 105dB siren, and IP65 weatherproofing. It is ideal for illuminating and monitoring large outdoor areas such as driveways, porches, and yards.
Do Wyze security cameras support AI-powered detection?Yes, both the Wyze Cam v4 and Wyze Cam Floodlight v2 offer advanced AI-powered detection features. These include smart motion alerts that help reduce false alarms by distinguishing between people, vehicles, and other objects.
Can Wyze security cameras zoom in on distant objects?Yes, Wyze security cameras such as the Cam v2, Cam v4, and Floodlight v2 offer digital zoom capabilities. The Cam v2 and Cam v4 both provide up to 8x digital zoom, allowing you to focus on details remotely through the Wyze app.
Are Wyze security cameras weatherproof for outdoor use?The Wyze Cam v4 and Wyze Cam Floodlight v2 are both IP65 weather-resistant, making them suitable for outdoor use in various weather conditions. The refurbished Wyze Cam v2 is not weatherproof and should only be used outdoors if adequately protected from the elements.
What storage options are available for Wyze security cameras?Wyze security cameras support both local and cloud storage. Local storage is available via microSD cards (up to 512GB for Cam v4 and up to 256GB for Floodlight v2), allowing for continuous 24/7 recording. Cloud storage is also available through Wyze subscription plans.
Do Wyze security cameras work with smart home systems?Yes, Wyze security cameras are compatible with popular smart home platforms, including Alexa, Google Assistant, and IFTTT. This allows for voice control and integration with other smart devices in your home.
What accessories are available for enhancing Wyze outdoor camera installations?Wyze offers accessories such as the Cam v4 + Lamp Socket v2 Bundle, which allows you to power your Wyze Cam v4 through existing lamp sockets. This bundle supports motion-activated lighting and dusk-to-dawn scheduling, making outdoor installation more convenient and smart.
What are the key features of the Wyze Cam v2?Can the refurbished Wyze Cam v2 be used outdoors?What is the warranty policy for the Wyze security cameras?
