Wyze Refurbished Cordless Vacuum: Perfect for Dry Carpet and Bare Floor Cleaning
When it comes to keeping your home spotless, especially on dry carpets and bare floors, the
Wyze Cordless Vacuum S stands out as an exceptional choice. This refurbished cordless vacuum combines powerful suction, lightweight design, and smart features to deliver a cleaning experience that’s both efficient and convenient.
Why Choose Wyze Cordless Vacuum S for Your Floors?
Powerful Suction for Deep Cleaning
The Wyze Cordless Vacuum S boasts an impressive suction power of up to
20,000 Pa in Turbo Mode, ensuring it can lift dirt, dust, and pet hair from both dry carpets and hard floors with ease. It offers three suction modes to suit your cleaning needs:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
This versatility means you can switch between powerful deep cleans and longer, quieter sessions depending on your floor type and mess.
Lightweight and Ergonomic Design
Weighing just
2.8 lbs for the main unit and
4.9 lbs when fully assembled, this vacuum is as light as 2.8 pounds of feathers, making it easy to maneuver around furniture and up stairs without fatigue. Its compact size (12.4 x 4.5 x 8.7 inches main unit) and cordless design free you from the hassle of cords and bulky machines.
Long-Lasting Battery and Quick Charging
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the vacuum offers up to
40 minutes of runtime in ECO mode. When it’s time to recharge, it takes only
4-6 hours to reach 100%, so you can get back to cleaning quickly.
Advanced Features for a Thorough Clean
- Dual Motors: Two motors work together to maximize suction and cleaning efficiency.
- 3-Stage Filtration System: Captures fine dust and allergens, improving air quality.
- LED Screen: Displays battery life and suction mode for easy monitoring.
- 6 Daylight-Bright LED Lights: Illuminate the brush head to reveal hidden dust and debris, especially useful on bare floors and carpets.
Versatile Attachments Included
The vacuum comes with a variety of attachments to tackle different cleaning challenges:
- Crevice Tool for tight spaces
- Floor Brush for carpets and hard floors
- HEPA Filter and Filter Housing for clean air
- Dust Cap and Standard Tube for easy maintenance
Lightweight and pet-friendly cordless vacuum in action
Ideal for Dry Carpet and Bare Floor Cleaning
The Wyze Cordless Vacuum S is specially designed to handle the unique demands of dry carpet and bare floor surfaces. Its powerful suction and brush head LED lights ensure that even fine dust and pet hair are effectively removed. Whether you have hardwood, tile, laminate, or low-pile carpet, this vacuum adapts to your cleaning needs without damaging delicate floors.
“Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support.” – Wyze
Additional Benefits of Choosing a Refurbished Wyze Vacuum
Opting for a refurbished Wyze Cordless Vacuum S means you get the same high-quality performance at a more affordable price point. Each unit undergoes rigorous testing to ensure it meets Wyze’s standards, so you can enjoy powerful cleaning without compromise.
Summary of Wyze Cordless Vacuum S Specs
Feature | Specification |
Suction Power | 20,000 Pa (Turbo), 9,000 Pa (Med), 6,000 Pa (ECO) |
Weight | 2.8 lbs (main), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | Up to 40 minutes (ECO mode) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo mode) |
Dimensions (Main Unit) | 12.4 x 4.5 x 8.7 inches |
Color | Steel grey with Wyze green accents |
Attachments Included | Crevice Tool, Floor Brush, HEPA Filter, Dust Cap, Standard Tube |
Effortless cleaning on carpets and floors with Wyze Cordless Vacuum S
Conclusion
For anyone seeking a
refurbished cordless vacuum that excels on dry carpets and bare floors, the
Wyze Cordless Vacuum S is a top-tier choice. Its combination of powerful suction, lightweight design, long battery life, and smart features makes it perfect for maintaining a clean, healthy home environment.
Experience the freedom of cordless cleaning with Wyze — powerful, portable, and perfectly suited for your floors.
Wyze Cordless Vacuum S cleaning bare floors with precision
What makes the Wyze Refurbished Cordless Vacuum S ideal for dry carpet and bare floor cleaning?
The Wyze Refurbished Cordless Vacuum S is designed with powerful suction up to 20,000 Pa in Turbo Mode, a lightweight and ergonomic build, and specialized attachments. Its brush head features LED lights to reveal hidden dust and debris, making it highly effective on both dry carpets and bare floors without damaging delicate surfaces.How long does the Wyze Cordless Vacuum S battery last and how quickly does it recharge?
The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The vacuum’s 6-cell lithium-ion battery fully recharges in just 4-6 hours, allowing you to get back to cleaning quickly.What are the main features of the Wyze Cordless Vacuum S?
Key features include powerful suction (up to 20,000 Pa), a lightweight design (2.8 lbs main unit), dual motors for enhanced cleaning, a 3-stage filtration system with HEPA filter, an LED screen for battery and mode display, and 6 daylight-bright LED lights on the brush head. It also comes with multiple attachments for versatile cleaning.What attachments are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a Crevice Tool for tight spaces, a Floor Brush for carpets and hard floors, a HEPA Filter and Filter Housing for improved air quality, a Dust Cap, and a Standard Tube for easy maintenance.Is the Wyze Cordless Vacuum S easy to maneuver and store?
Yes, the vacuum is lightweight (2.8 lbs for the main unit, 4.9 lbs fully assembled) and compact (12.4 x 4.5 x 8.7 inches for the main unit), making it easy to carry, maneuver around furniture, and store in small spaces.What are the benefits of choosing a refurbished Wyze Cordless Vacuum S?
Choosing a refurbished Wyze Cordless Vacuum S provides the same high-quality performance as a new unit at a more affordable price. Each refurbished vacuum undergoes rigorous testing to ensure it meets Wyze’s standards, offering reliable and powerful cleaning without compromise.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system that includes a HEPA filter, which helps capture fine dust and allergens, improving the air quality in your home.What is the noise level of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo mode, making it relatively quiet compared to many other vacuums.What floor types is the Wyze Cordless Vacuum S suitable for?
The Wyze Cordless Vacuum S is ideal for dry carpets, hardwood, tile, laminate, and other bare floor surfaces. Its powerful suction and versatile attachments ensure effective cleaning on a variety of floor types.How much dust can the Wyze Cordless Vacuum S hold?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing you to clean multiple rooms before needing to empty it.
