Lightweight Cordless Vacuum for Quick Post-Meal Floor Cleanups
When it comes to fast and efficient floor cleaning after meals, a lightweight cordless vacuum is a must-have. The
Wyze Cordless Vacuum S stands out as an exceptional choice for quick post-meal cleanups, combining powerful suction, portability, and smart features to keep your floors spotless with minimal effort.
Wyze Cordless Vacuum S: Power Meets Portability
Ultra-Lightweight Design for Effortless Cleaning
Weighing just
2.8 pounds for the main unit and
4.9 pounds when fully assembled, the Wyze Cordless Vacuum S is as light as a couple of feathers. This featherweight design makes it incredibly easy to maneuver around your dining area, kitchen, or living room for quick cleanups without fatigue.
Exceptional Suction Power
Despite its light frame, this vacuum packs a punch with
20,000 Pa suction power in Turbo Mode and multiple suction settings:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
This range allows you to tailor the cleaning power to your needs, whether it’s crumbs on hardwood floors or dust on carpets.
Long-Lasting Battery Life
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the Wyze Cordless Vacuum S offers up to
40 minutes of runtime in ECO mode, perfect for quick or extended cleaning sessions. The battery is interchangeable, so you can swap in a fresh pack for uninterrupted cleaning.
Smart Features for Enhanced Usability
- LED screen displays suction mode and battery life clearly.
- Two motors ensure consistent and powerful suction.
- 3-stage filtration system captures fine dust and allergens.
- 6 daylight-bright LED lights on the brush head illuminate hidden debris under tables and chairs.
Convenient Attachments Included
The vacuum comes with a
crevice tool, floor brush, dust cap, HEPA filter, filter housing, and standard tube, making it versatile for various surfaces and tight spots.
Lightweight cordless vacuum perfect for quick cleanups around the sofa and pet areas
Enhance Your Wyze Cordless Vacuum S Experience with Accessories
Wyze Cordless Vacuum S - Battery Pack
Need extra juice for longer cleaning sessions? The
Wyze Cordless Vacuum S Battery Pack is designed specifically for this model, allowing you to extend your vacuuming time without waiting for a recharge.
Wyze Cordless Vacuum - HEPA Filter
Maintain peak performance and air quality by regularly replacing the
HEPA filter. Available in convenient 2-packs, these filters ensure your vacuum continues to trap allergens and fine dust effectively.
The
foldable vacuum tube bends to reach awkward spaces without straining your wrist or back, making it easier to clean under furniture or in tight corners.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Ideal for cleaning
car seats, sofas, and upholstery, this mini brush head attachment tackles pet hair and crumbs with ease, complementing your vacuum’s versatility.
Perfect for pet owners needing quick and thorough cleanups
Why Choose Wyze Cordless Vacuum S for Post-Meal Cleanups?
The Wyze Cordless Vacuum S is designed for independence and power, making it the ideal lightweight vacuum for quick, efficient cleaning after meals. Its combination of strong suction, long battery life, and smart features ensures your floors stay clean without the hassle of cords or heavy equipment.
- Lightweight and portable for easy handling
- Powerful suction modes for all mess sizes
- Long-lasting battery with optional extra packs
Smart LED display and bright brush lights
- Versatile attachments for every cleaning need
Effortless cleaning on hardwood floors after meals
Summary of Wyze Cordless Vacuum S Specs
Feature | Specification |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Suction Power | 20,000 Pa (Turbo), 9,000 Pa (Medium), 6,000 Pa (ECO) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | 40 min (ECO), 23 min (Medium), 10 min (Turbo) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Dimensions | 12.4 x 4.5 x 8.7 in (main unit) |
Color | Steel grey with Wyze green accents |
Filtration | 3-stage filtration with HEPA filter |
Attachments Included | Crevice tool, floor brush, HEPA filter, dust cap, filter housing, standard tube |
Make your post-meal floor cleanups quick, easy, and efficient with
What makes the Wyze Cordless Vacuum S ideal for quick post-meal cleanups?
The Wyze Cordless Vacuum S is lightweight, cordless, and features powerful suction modes, making it perfect for fast and efficient floor cleaning after meals. Its portability and smart features allow you to clean up crumbs and debris with minimal effort.How much does the Wyze Cordless Vacuum S weigh?
The main unit of the Wyze Cordless Vacuum S weighs just 2.8 pounds, and it weighs 4.9 pounds when fully assembled, making it easy to maneuver for quick cleanups.What suction power does the Wyze Cordless Vacuum S offer?
The Wyze Cordless Vacuum S offers three suction modes: Turbo Mode with 20,000 Pa, Medium Mode with 9,000 Pa, and ECO Mode with 6,000 Pa. This allows you to adjust the cleaning power based on your needs.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery is also interchangeable for extended cleaning sessions.What smart features does the Wyze Cordless Vacuum S include?
Smart features of the Wyze Cordless Vacuum S include an LED screen displaying suction mode and battery life, two motors for consistent suction, a 3-stage filtration system with HEPA filter, and 6 LED lights on the brush head to illuminate hidden debris.What attachments come with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a crevice tool, floor brush, dust cap, HEPA filter, filter housing, and a standard tube, making it versatile for cleaning various surfaces and tight spaces.Are there additional accessories available for the Wyze Cordless Vacuum S?
Yes, you can enhance your vacuum with accessories such as an extra battery pack, replacement HEPA filters, a foldable vacuum tube for hard-to-reach areas, and a mini motorized brush head for cleaning upholstery and car seats.How does the HEPA filter in the Wyze Cordless Vacuum S improve air quality?
The 3-stage filtration system with a HEPA filter captures fine dust and allergens, helping to maintain cleaner air in your home. Regularly replacing the HEPA filter ensures optimal performance and air quality.Is the Wyze Cordless Vacuum S suitable for pet owners?
Yes, the Wyze Cordless Vacuum S is ideal for pet owners. Its powerful suction and mini motorized brush head attachment make it easy to clean up pet hair and crumbs from floors, sofas, and car seats.What are the main specifications of the Wyze Cordless Vacuum S?
Key specifications include: 2.8 lbs (main unit) weight, 20,000 Pa maximum suction, 6-cell lithium-ion battery, up to 40 minutes runtime, 0.7 L dust cup volume, 65 dBA noise level in Turbo mode, and a 3-stage HEPA filtration system.How long does it take to charge the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S takes approximately 4-6 hours to fully charge.Can the Wyze Cordless Vacuum S clean under furniture and in tight spaces?
Yes, the lightweight design, included crevice tool, and optional foldable vacuum tube make it easy to clean under furniture and in tight corners without straining your wrist or back.
