Wyze Outdoor Sprinkler Controller Box: Mounting & Installation Guide
Wyze Outdoor Weatherproof Sprinkler Controller Box: Mounting and Installation Instructions
If you are looking to install the Wyze Sprinkler Controller outdoors, protecting it from weather elements is essential. The
Wyze Weatherproof Sprinkler Controller Box is designed specifically for this purpose, providing a durable, weather-resistant enclosure that keeps your sprinkler controller safe and functional in all conditions.
Why Use the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box is an IP65-rated enclosure, meaning it offers:
- Full protection from dust, oil, and other non-corrosive materials.
- Complete protection from contact with enclosed equipment.
- Reliable weather resistance to keep your sprinkler controller safe outdoors.
This box is ideal if your existing sprinkler controller is mounted outside and you want to upgrade to the Wyze Sprinkler Controller without worrying about exposure to rain, dust, or other environmental factors.
While it is designed for the Wyze Sprinkler Controller, it can be adapted for use with other brands, though mounting methods may vary.
What’s Included in the Wyze Weatherproof Sprinkler Controller Box Package?
- Wyze Weatherproof Sprinkler Controller Box x1
- Screws x6 (3 ST4x30-C-H; 3 ST3.5x10-C-H)
- Connector Caps x3
- Anchors x3
- Waterproof Gaskets x3
- Quick Start Guide x1
Required Tools for Installation
- Power drill with Phillips head and 7/32 drill bit
- Hammer
- Pencil
- Electrical tape
- Wire connector caps
- PVC pipes and connectors (optional, for wiring protection)
Step-by-Step Installation Instructions
1. Preparation
- Turn off power to your existing sprinkler controller to ensure safety.
- Remove the weatherproof box from packaging and unlock the clips on both sides to remove accessories.
- Take a clear photo of the wiring connected to your existing controller for reference.
- Label each wire using the included wire stickers to avoid confusion during reinstallation.
- Keep exposed wire ends about ¼ to ⅜ inches long for proper connection.
2. Mounting the Weatherproof Box
- Hold the box in the desired outdoor location.
- Use a pencil to mark the drilling holes on the wall.
- Drill holes with a 7/32 inch diameter and approximately 1.575 inches deep.
- Insert the wall anchors by gently hammering them into place.
- Secure the weatherproof box to the wall using the provided screws.
- Ensure the Wyze logo is right-side up for proper orientation.
3. Wiring Inside the Box
- Pull the electrical wires through the 1/2" housing on the left side of the box.
- Pull the sprinkler controller wires through the 3/4" housing on the right side.
- With power still OFF, connect the electrical wires to the power outlet wires inside the box.
- Use the connector caps to secure wire connections and wrap them with electrical tape for added protection.
Wire color codes:
- White: Neutral wire
- Black: Phase wire
- Green: Ground wire
- Replace the hardwiring bay cover and tighten the screws.
4. Mounting the Wyze Sprinkler Controller
- Use the screwdriver to mount the included mounting plate inside the weatherproof box.
- Connect the power adapter and pre-labeled sprinkler wires to the Wyze Sprinkler Controller.
- Place the controller onto the mounting plate by inserting the top first, then snapping the bottom into place.
- Use the included cord wraps to neatly organize zone wires.
5. Finalizing Installation
- Place the waterproof gasket through the housing and tighten the gasket cap to ensure a weatherproof seal.
- Close the cover of the weatherproof box and lock all clips securely.
- Connect the power adapter to a power outlet.
- Your Wyze Sprinkler Controller is now protected and ready for pairing with the Wyze app.
Additional Tips for a Successful Installation
- Ensure the power is OFF before handling any wiring to avoid electrical hazards.
- Keep pump relays at least 15 feet away from the Wyze Sprinkler Controller to prevent electrical interference.
- Check that all wires are fully inserted and secure in their terminals to avoid loose connections.
- Use the Wyze app to label and verify wiring terminals during setup.
- If you experience connectivity issues, verify Wi-Fi signal strength and update the controller firmware as needed.
Benefits of Using Wyze Sprinkler Controller with the Weatherproof Box
- Outdoor durability: The IP65 rating ensures your controller withstands rain, dust, and outdoor conditions.
- Easy installation: Designed to replace your existing controller in under 30 minutes.
- Smart watering: Control your irrigation from anywhere using the Wyze app.
- Organized wiring: Includes cord wraps and wire labels for neat and safe wiring.
- Peace of mind: Secure enclosure protects against weather damage and accidental contact.
Image: A homeowner installing the Wyze Sprinkler Controller inside the weatherproof box mounted on an exterior wall.
Summary
Installing the
Wyze Weatherproof Sprinkler Controller Box is a straightforward process that ensures your sprinkler controller remains safe and functional outdoors. By following the step-by-step instructions and using the included hardware, you can protect your irrigation system from the elements while enjoying the smart features of the Wyze Sprinkler Controller.
For optimal performance, always ensure proper wiring, secure mounting, and use the Wyze app for setup and control.
Feature | Wyze Sprinkler Controller | Wyze Weatherproof Sprinkler Controller Box |
Type | Connected Home | Accessories |
Price | $59.99 (Controller), $99.98 (Controller + Box) | $39.99 |
Zones | 8 customizable irrigation zones | N/A |
Weatherproof Rating | Not specified | IP65 fully weatherproof |
Control | Wi-Fi remote control via Wyze app | N/A |
Installation Time | DIY installation in 20 minutes | Mounting box for controller |
Power | Hardwire or outdoor outlet power | Hardwire or outdoor outlet power |
Compatibility | Works with Wyze Sprinkler Controller only | Compatible only with Wyze Sprinkler Controller |
Features | Smart zoned control, weather-based watering, Sprinkler Plus subscription included (1 year), personalized schedules, weather skips, integration with Wyze Cam | Durable with 4 clasps and gridded cover for extra durability |
Warranty | Not specified | Not specified |
Availability | Sold out | In stock |
What is the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from rain, dust, and other outdoor elements. It ensures your controller remains safe and functional when installed outside.Why should I use a weatherproof box for my Wyze Sprinkler Controller?
Using a weatherproof box like the Wyze Weatherproof Sprinkler Controller Box protects your controller from environmental factors such as rain, dust, and accidental contact. This ensures reliable operation and extends the lifespan of your irrigation system when installed outdoors.What is included in the Wyze Weatherproof Sprinkler Controller Box package?
The package includes one Wyze Weatherproof Sprinkler Controller Box, six screws (3 ST4x30-C-H and 3 ST3.5x10-C-H), three connector caps, three anchors, three waterproof gaskets, and a quick start guide.Is the Wyze Weatherproof Sprinkler Controller Box compatible with other sprinkler controllers?
While the box is designed specifically for the Wyze Sprinkler Controller, it can be adapted for use with other brands. However, mounting methods may vary depending on the controller model.What tools are required to install the Wyze Weatherproof Sprinkler Controller Box?
You will need a power drill with a Phillips head and 7/32 drill bit, a hammer, a pencil, electrical tape, wire connector caps, and optionally PVC pipes and connectors for additional wiring protection.How do I install the Wyze Weatherproof Sprinkler Controller Box outdoors?
To install, turn off power to your existing controller, mark and drill holes for mounting, insert wall anchors, and secure the box with screws. Pull wires through the designated housings, connect them using the provided caps and electrical tape, mount the Wyze Sprinkler Controller inside, and ensure all gaskets and clips are securely fastened for a weatherproof seal.What are the benefits of using the Wyze Sprinkler Controller with the weatherproof box?
Benefits include outdoor durability with IP65 weather resistance, easy installation, smart irrigation control via the Wyze app, organized and safe wiring, and peace of mind knowing your controller is protected from weather and accidental contact.What safety precautions should I take during installation?
Always turn off power before handling any wiring to avoid electrical hazards. Ensure all wires are fully inserted and secure in their terminals, and keep pump relays at least 15 feet away from the controller to prevent electrical interference.How do I ensure a weatherproof seal during installation?
Place the waterproof gasket through the housing and tighten the gasket cap. Make sure the cover of the weatherproof box is closed and all clips are securely locked to prevent water and dust ingress.Can I control my Wyze Sprinkler Controller remotely after installation?
Yes, once installed and paired with the Wyze app, you can control your irrigation system from anywhere, schedule watering, and monitor your system remotely.What should I do if I experience connectivity issues with my Wyze Sprinkler Controller?
If you encounter connectivity issues, check your Wi-Fi signal strength near the controller, ensure all wiring is correct, and update the controller firmware using the Wyze app as needed.
Can you provide more details about the benefits of using the Wyze Weatherproof Sprinkler Controller Box?What tools do I need for the installation of the Wyze Weatherproof Sprinkler Controller Box?Are there any additional tips for a successful installation of the Wyze Sprinkler Controller?
