Install Wyze Weatherproof Sprinkler Controller Box Outdoors Safely
How to Install Wyze Weatherproof Sprinkler Controller Box Outdoors Using Secure Hardwiring Tips
Installing your Wyze Weatherproof Sprinkler Controller Box outdoors ensures your sprinkler system is protected from the elements while maintaining reliable operation. This guide will walk you through the installation process with secure hardwiring tips to keep your setup safe, durable, and weather-resistant.
Wyze Weatherproof Sprinkler Controller Box Overview
The Wyze Weatherproof Sprinkler Controller Box is designed specifically to house your Wyze Sprinkler Controller outdoors with confidence. It features:
  • IP65 Fully Weatherproof Rating: Protects against dust, oil, and water jets, making it ideal for outdoor use.
  • Durable Construction: Equipped with 4 secure clasps and a gridded cover for extra strength and protection.
  • Flexible Power Options: Supports both hardwired power connections and outdoor outlet power.
  • Compatibility: Exclusively designed for the Wyze Sprinkler Controller to ensure a perfect fit and secure mounting.
This box is essential if you want to replace an existing outdoor sprinkler controller with the Wyze system, providing a safe enclosure that withstands harsh weather conditions.
Step-by-Step Installation Guide for Outdoor Hardwiring
1. Prepare for Installation
  • Turn Off Power: Before starting, switch off power to your existing sprinkler controller to avoid electrical hazards.
  • Gather Tools: You will need a power drill with a Phillips head and a 7/32" drill bit, hammer, pencil, electrical tape, wire connector caps, and mounting screws (included).
  • Unpack the Box: Remove the weatherproof box from packaging, unlock the side clips, and take out the accessories.
2. Document Existing Wiring
  • Take a clear photo of your current sprinkler controller wiring.
  • Label each wire using the included stickers to ensure correct reconnection.
3. Mount the Weatherproof Box
  • Use a pencil to mark drilling holes on your desired mounting surface.
  • Drill holes with a 7/32" bit to a depth of about 1.575 inches.
  • Insert anchors with a hammer and secure the box using the provided screws.
  • Ensure the box is mounted firmly and level.
4. Wiring the Power
  • Pull the electrical wires through the 1/2" conduit housing on the left side of the box.
  • Pull the sprinkler controller wires through the 3/4" conduit housing on the right.
  • With power still off, connect the electrical wires to your power source wires inside the box.
  • Use wire connector caps to secure connections and wrap them with electrical tape for extra protection.
  • Wire color codes to remember:
  • White: Neutral wire
  • Black: Phase (live) wire
  • Green: Ground wire
5. Install the Controller and Seal the Box
  • Attach the mounting plate inside the box using the included screws.
  • Connect the power adapter and labeled wires to the Wyze Sprinkler Controller.
  • Mount the controller onto the plate until it snaps securely.
  • Place the gasket and tighten the gasket cap to maintain the weatherproof seal.
  • Close the cover and lock all four clips to ensure full protection.
Tip: Always double-check that all wire connections are tight and insulated to prevent moisture ingress and electrical shorts.
Additional Tips for Secure Hardwiring Outdoors
  • Use PVC conduit pipes and connectors to protect wires running from your power source to the box.
  • Keep exposed wire ends trimmed to about ¼ to ⅜ inches for optimal terminal connection.
  • Avoid installing the box near sources of electrical interference such as pump relays; maintain at least 15 feet distance.
  • Regularly inspect the box and wiring for wear or damage, especially after severe weather.
  • If unsure about electrical wiring, consult a licensed electrician to ensure safety and code compliance.
Enhance Your Outdoor Setup with Wyze Security Cameras
While securing your sprinkler system, consider complementing your outdoor space with Wyze’s weather-resistant security cameras for added peace of mind.
Wyze Cam Pan v3
  • 360° Pan and 180° Tilt: Covers every angle of your yard.
  • IP65 Weather Resistance: Built to withstand rain, snow, and dust.
  • 1080p HD Video: Clear, detailed footage day and night.
  • Two-Way Audio: Communicate through the camera remotely.
  • Requires Wyze Outdoor Power Adapter for safe outdoor use.
Wyze Cam Pan v3 in snowy outdoor setting
Wyze Cam v4
  • 2.5K QHD Resolution: Ultra-clear video quality.
  • Enhanced Color Night Vision: See vibrant colors even in low light.
  • Motion-Activated Spotlight: Deters unwanted visitors.
  • IP65 Weatherproof: Perfect for outdoor monitoring.
  • Compatible with Alexa and Google Assistant for smart home integration.
Summary
Installing the Wyze Weatherproof Sprinkler Controller Box outdoors with secure hardwiring is straightforward when following these detailed steps. The box’s robust weatherproof design ensures your sprinkler controller stays protected year-round. Pairing it with Wyze’s outdoor cameras like the Cam Pan v3 or Cam v4 can further secure your property with smart surveillance. By carefully labeling wires, using proper tools, and sealing connections, you can enjoy a reliable, weatherproof sprinkler system that integrates seamlessly into your smart home.
FeatureWyze Weatherproof Sprinkler Controller BoxWyze Cam Pan v3Wyze Cam v4
TypeAccessoriesCameraCamera
Price$39.99$39.98 (1 Pack)$35.98 (1 Pack)
Weatherproof RatingIP65IP65IP65
UsageOutdoor mounting box for Wyze Sprinkler ControllerIndoor/Outdoor 360° pan and 180° tilt security camIndoor/Outdoor security camera
Power SourceHardwire or outdoor outlet powerRequires Wyze Outdoor Power Adapter (sold separately)Wired (Indoor USB power adapter included)
Video ResolutionN/A1080p (1920 x 1080)2.5K QHD (2560 x 1440)
Field of ViewN/A120° FOVDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Pan/TiltN/A360° pan, 180° tiltFixed angle
Night VisionN/AColor Night Vision, 4 IR LEDs (850 nm)Enhanced Color Night Vision, 4 IR LEDs + 2 white spotlight LEDs
AudioN/A2-way audio, built-in speaker and microphone2-way audio, 99dB waterproof speaker
Motion TrackingN/AAutomatic motion trackingMotion detection with person detection
ConnectivityN/A2.4 GHz Wi-Fi (no 5 GHz)2.4 GHz Wi-Fi, Wi-Fi 6
StorageN/ASupports up to 256 GB microSDmicroSD card up to 512 GB
DimensionsN/A124mm (H) x 60mm (W) x 63mm (D)2in x 2in x 2 3/8in
WeightN/A11.29 oz (320 g)0.49 lb (222 g)
Mounting OptionsN/AScrew 1/4" - 20 mountStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
WarrantyNot specified1 Year1 Year
Additional Features4 clasps and gridded cover for durabilityPrivacy Mode, Quiet tracking motor, Push notificationsMotion-activated spotlight, Alexa & Google Assistant compatibility
CompatibilityOnly with Wyze Sprinkler ControllerAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+
What is the Wyze Weatherproof Sprinkler Controller Box?The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed specifically to house your Wyze Sprinkler Controller outdoors. It protects your controller from dust, water, and harsh weather conditions, ensuring reliable operation year-round.
Is the Wyze Weatherproof Sprinkler Controller Box compatible with other sprinkler controllers?No, the Wyze Weatherproof Sprinkler Controller Box is exclusively designed for the Wyze Sprinkler Controller, ensuring a perfect fit and secure mounting.
How do I install the Wyze Weatherproof Sprinkler Controller Box outdoors?To install the Wyze Weatherproof Sprinkler Controller Box outdoors, turn off power to your existing controller, gather necessary tools, document and label existing wiring, mount the box using the provided screws and anchors, hardwire the power and sprinkler controller wires through the designated conduit housings, securely connect and insulate all wires, mount the controller, and seal the box by locking all four clips.
What tools are required for installing the Wyze Weatherproof Sprinkler Controller Box?You will need a power drill with a Phillips head and a 7/32" drill bit, a hammer, a pencil, electrical tape, wire connector caps, and the mounting screws included with the box.
What are the power wiring color codes for the Wyze Weatherproof Sprinkler Controller Box?The standard power wiring color codes are: White for neutral, Black for phase (live), and Green for ground. Always ensure power is off before connecting wires.
How do I ensure a weatherproof seal when installing the Wyze Sprinkler Controller outdoors?To ensure a weatherproof seal, use the included gasket and gasket cap, tighten them properly, and lock all four clips on the box. Additionally, use electrical tape and wire connector caps to insulate all wire connections and prevent moisture ingress.
What are some tips for secure hardwiring of the Wyze Sprinkler Controller outdoors?For secure hardwiring, use PVC conduit pipes and connectors to protect wires, trim exposed wire ends to ¼–⅜ inches, avoid installing near sources of electrical interference (maintain at least 15 feet distance), and regularly inspect the box and wiring for wear or damage. If unsure, consult a licensed electrician.
Can I use the Wyze Weatherproof Sprinkler Controller Box with an outdoor power outlet?Yes, the Wyze Weatherproof Sprinkler Controller Box supports both hardwired power connections and outdoor outlet power, offering flexible installation options.
How do I maintain my Wyze Weatherproof Sprinkler Controller Box after installation?Regularly inspect the box and wiring for signs of wear or damage, especially after severe weather. Ensure all seals and clips remain secure to maintain weatherproof protection.
What Wyze security cameras are recommended for outdoor use alongside the sprinkler controller?Wyze recommends the Cam Pan v3 and Cam v4 for outdoor use. Both cameras are IP65 weather-resistant, offer high-definition video, and provide features like two-way audio, color night vision, and smart home integration.
Do Wyze outdoor cameras require special power adapters for outdoor installation?Yes, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter for safe and reliable outdoor use.
What tools do I need to install the Wyze Weatherproof Sprinkler Controller Box?Can you explain the wiring color codes I should remember during installation?How do I ensure that the weatherproof seal is maintained after installing the controller?
