Secure Outdoor Wyze Sprinkler Controller Box with 4 Clasp Mount
Secure Outdoor Wyze Sprinkler Controller Box with Four Clasp Mounting System
When it comes to protecting your Wyze Sprinkler Controller outdoors, the Wyze Weatherproof Sprinkler Controller Box is the ultimate solution. Designed specifically for outdoor use, this box offers a secure, durable, and weather-resistant enclosure that ensures your sprinkler controller stays safe and functional no matter the weather conditions.
Wyze Weatherproof Sprinkler Controller Box: Durable and Secure Protection
Fully Weatherproof with IP65 Rating
The Wyze Sprinkler Controller Box boasts an IP65 rating, meaning it is fully protected against dust and water jets from any direction. This makes it ideal for outdoor environments where exposure to rain, dust, and other elements is inevitable.
Four Clasp Mounting System for Extra Security
Equipped with a robust four clasp mounting system, this box ensures a tight and secure closure. The gridded cover adds extra durability, preventing accidental openings and protecting the controller from tampering or damage.
Flexible Power Options
The box supports both hardwired power and outdoor outlet power, giving you flexibility in installation depending on your outdoor setup.
Mount your Wyze Sprinkler Controller anywhere with confidence, knowing it’s shielded from the elements and securely fastened.
Wyze Sprinkler Controller: Smarter Lawn Irrigation Control
Smart Zoned Control for Up to 8 Zones
The Wyze Sprinkler Controller allows you to customize watering schedules for up to 8 different irrigation zones. Each zone can be named and personalized with photos in the Wyze app, making it easy to manage your lawn or garden watering efficiently.
Weather-Based Watering with Sprinkler Plus
Included with the controller is a 1-year free subscription to Sprinkler Plus, a weather service that uses hyper-local weather data to skip unnecessary watering. This smart feature helps conserve water and protect your plants by watering only when needed.
Remote Control and Monitoring
Control your sprinkler system from anywhere using the Wyze app. Start or stop watering schedules with a tap, and receive notifications when your system is running. Plus, integration with Wyze Cam lets you visually monitor your lawn and ensure everything is working as expected.
Easy DIY Installation
Wyze Sprinkler Controller replaces your existing controller in under 20 minutes, automatically creating a watering schedule tailored to your yard.
Smarter, simpler, and greener irrigation control that saves water and time.
Wyze Sprinkler Controller in Use Enjoy smart sprinkler control from your smartphone anywhere.
Why Choose the Wyze Sprinkler Controller Box and Controller Combo?
  • Complete Protection & Control: The weatherproof box safeguards your controller, while the controller itself offers intelligent, app-based irrigation management.
  • Durability Meets Convenience: The four clasp system and gridded cover provide rugged protection, and the controller’s easy app interface makes lawn care effortless.
  • Eco-Friendly Watering: WaterSense certification and Sprinkler Plus integration ensure you use water responsibly, saving money and resources.
  • Flexible Installation: Compatible with hardwired or outdoor outlet power, and easy to mount anywhere outdoors.
Summary of Key Features
FeatureWyze Sprinkler Controller BoxWyze Sprinkler Controller
Weatherproof RatingIP65 Fully WeatherproofIndoor/Outdoor use with box
Mounting SystemFour Clasp Secure MountingN/A
Zones ControlledN/AUp to 8 customizable irrigation zones
Power OptionsHardwire or Outdoor OutletRequires power to operate
Smart FeaturesN/AWeather-based watering, remote control
Installation TimeSimple mountingDIY install in 20 minutes
CompatibilityCompatible only with Wyze Sprinkler ControllerCompatible with most residential irrigation systems
Protect your investment and optimize your lawn watering with the Wyze Weatherproof Sprinkler Controller Box paired with the Wyze Sprinkler Controller — the perfect duo for secure, smart outdoor irrigation management.
FeatureWyze Weatherproof Sprinkler Controller BoxWyze Sprinkler Controller
TypeAccessoryConnected Home
Price$39.99$59.99
CompatibilityOnly compatible with Wyze Sprinkler ControllerCompatible with most residential irrigation systems in North America, supports up to 8 zones
Weatherproof RatingIP65 (fully weatherproof for outdoor use)Not specified (designed for outdoor use)
Power SourceHardwire or outdoor outlet powerRequires power to operate irrigation system
Zones ControlledN/A (Accessory for controller)8 customizable irrigation zones
FeaturesMount controller anywhere, 4 clasps, gridded cover for durabilitySmart zoned control, personalized schedules, weather-based watering with Sprinkler Plus, remote control via app
Weather-Based WateringN/AIncluded with 1-year free Sprinkler Plus subscription
Installation TimeN/ADIY installation in 20 minutes
DurabilityExtra durable with 4 clasps and gridded coverN/A
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Weatherproof Sprinkler Controller Box?The Wyze Weatherproof Sprinkler Controller Box is a durable, weather-resistant enclosure designed to protect your Wyze Sprinkler Controller outdoors. It features an IP65 rating for full protection against dust and water, making it ideal for outdoor environments.
Is the Wyze Sprinkler Controller Box weatherproof?Yes, the Wyze Sprinkler Controller Box is fully weatherproof with an IP65 rating, ensuring protection against dust and water jets from any direction. This makes it suitable for all outdoor weather conditions.
How does the four clasp mounting system work?The Wyze Sprinkler Controller Box uses a robust four clasp mounting system that ensures a tight and secure closure. This system, along with a gridded cover, prevents accidental openings and protects the controller from tampering or damage.
What power options are available for the Wyze Sprinkler Controller Box?The Wyze Sprinkler Controller Box supports both hardwired power and outdoor outlet power, giving you flexibility in how you install and power your sprinkler controller outdoors.
How many zones can the Wyze Sprinkler Controller manage?The Wyze Sprinkler Controller can manage up to 8 customizable irrigation zones. Each zone can be named and personalized with photos in the Wyze app for easy management.
What is Sprinkler Plus and how does it help with watering?Sprinkler Plus is a weather service included with the Wyze Sprinkler Controller, offering a 1-year free subscription. It uses hyper-local weather data to automatically skip unnecessary watering, helping you conserve water and protect your plants.
Can I control the Wyze Sprinkler Controller remotely?Yes, you can control and monitor your Wyze Sprinkler Controller from anywhere using the Wyze app. You can start or stop watering schedules, receive notifications, and even integrate with Wyze Cam for visual monitoring.
Is the Wyze Sprinkler Controller easy to install?Yes, the Wyze Sprinkler Controller is designed for easy DIY installation. It can replace your existing controller in under 20 minutes and automatically creates a watering schedule tailored to your yard.
Is the Wyze Sprinkler Controller Box compatible with other sprinkler controllers?The Wyze Sprinkler Controller Box is specifically designed to be compatible only with the Wyze Sprinkler Controller.
What are the main benefits of using the Wyze Sprinkler Controller and Box combo?The Wyze Sprinkler Controller and Box combo offers complete protection and smart control for your irrigation system. The weatherproof box safeguards your controller, while the controller provides intelligent, app-based management, eco-friendly watering with WaterSense certification, and flexible installation options.
What are the installation requirements for the Wyze Weatherproof Sprinkler Controller Box?Can the Wyze Sprinkler Controller be used with other brands of irrigation systems?Are there any ongoing promotions or discounts for the Wyze Sprinkler Controller or its accessories?
