How to Install and Secure a Wyze Weatherproof Sprinkler Box
How to Install Wire and Secure a Wyze Weatherproof Outdoor Sprinkler Controller Box
Installing a Wyze Weatherproof Sprinkler Controller Box is essential for protecting your smart sprinkler system outdoors while ensuring reliable, weatherproof operation. This guide will walk you through wiring and securing the Wyze Weatherproof Sprinkler Controller Box, paired with the Wyze Sprinkler Controller, for a seamless and durable outdoor irrigation setup.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
Key Features and Benefits
- IP65 Weatherproof Rating: Fully protects your sprinkler controller from dust, rain, and outdoor elements, making it ideal for outdoor installation.
- Robust Construction: Equipped with 4 secure clasps and a gridded cover for extra durability and protection.
- Flexible Power Options: Supports both hardwire power connections and outdoor outlet power, giving you installation flexibility.
- Designed for Wyze Sprinkler Controller: Perfectly compatible with the Wyze Sprinkler Controller for a neat, weatherproof setup.
The Wyze Weatherproof Sprinkler Controller Box ensures your smart irrigation system stays safe and functional outdoors, no matter the weather.
Installation Essentials
- Comes with screws, anchors, connector caps, and waterproof gaskets for a secure and sealed installation.
- Requires basic tools: power drill with Phillips head and 7/32 drill bit, hammer, pencil, electrical tape, and wire connector caps.
- Includes detailed instructions for mounting and wiring to ensure a professional-grade setup.
Wyze Sprinkler Controller: Smart, Efficient Lawn Irrigation
Features That Make a Difference
- Smart Zoned Control: Manage up to 8 customizable irrigation zones remotely via the Wyze app.
- Personalized Watering Schedules: Tailor watering routines to your lawn’s needs for optimal care.
- Weather-Based Watering: Automatically adjusts watering based on local weather data with Sprinkler Plus subscription.
- WaterSense Certified: Environmentally friendly and water-efficient irrigation.
- Easy Installation: Most users can install the controller in about 20 minutes.
Installation Overview
- Before installation, turn off power to your existing sprinkler controller.
- Label and photograph existing wiring for easy reference.
- Mount the included wall plate and connect labeled wires to the corresponding terminals on the Wyze Sprinkler Controller.
- Plug in the power adapter and mount the controller onto the plate until it snaps securely.
- Pair the controller with the Wyze app to configure zones and schedules.
Alt text: Person using smartphone app to control outdoor sprinkler system
Step-by-Step Wiring and Securing Your Wyze Weatherproof Sprinkler Controller Box
1. Prepare for Installation
- Turn off power to your existing sprinkler controller.
- Remove the old controller and take a photo of the wiring setup.
- Label each wire with the included stickers for easy identification.
2. Mount the Weatherproof Box
- Use a pencil to mark drill holes on your desired mounting surface.
- Drill holes with a 7/32 inch drill bit and insert anchors.
- Secure the weatherproof box to the wall using the provided screws.
- Ensure the Wyze logo is right-side up for proper orientation.
3. Wire the Power Safely
- Pull electrical wires through the 1/2" conduit on the left side of the box.
- Pull sprinkler controller wires through the 3/4" conduit on the right side.
- With power OFF, connect the electrical wires to the power outlet wires inside the box:
- White = Neutral wire
- Black = Phase (live) wire
- Green = Ground wire
- Use the provided connector caps to secure wire connections.
- Wrap connections with electrical tape for added protection.
- Replace the hardwiring bay cover and tighten screws.
4. Install the Wyze Sprinkler Controller
- Mount the controller’s wall plate inside the weatherproof box.
- Connect the pre-labeled sprinkler wires to the controller terminals.
- Attach the controller to the mounting plate until it clicks into place.
- Connect the power adapter to an outdoor outlet or hardwired power source.
5. Seal and Secure the Box
- Place the waterproof gasket around the cover and tighten the gasket cap.
- Close the weatherproof box cover and lock all four clasps.
- This ensures a fully sealed, weatherproof enclosure protecting your smart sprinkler system.
Enhance Your Smart Sprinkler Experience with Wyze Sprinkler Plus
Why Activate Sprinkler Plus?
- Unlocks advanced weather intelligence for smarter watering.
- Provides zone moisture information and advanced insights.
- Enables intelligent weather skips to conserve water.
- Comes with a 1-year free subscription included with your Wyze Sprinkler Controller.
Sprinkler Plus helps keep your lawn green and healthy while saving water and reducing your irrigation costs.
Alt text: Smartphone displaying personalized watering schedule in Wyze app
Final Tips for a Successful Installation
- Always ensure power is off before handling wiring.
- Keep exposed wire ends about ¼ to ⅜ inches long for secure terminal connections.
- Maintain at least 15 feet distance between pump relays and the Wyze Sprinkler Controller to avoid electrical interference.
- Use the included Velcro cable wraps to organize wires neatly inside the box.
- Follow the Wyze app prompts to complete pairing and zone setup after installation.
By following these steps and using the Wyze Weatherproof Sprinkler Controller Box with the Wyze Sprinkler Controller, you can enjoy a reliable, weatherproof, and smart irrigation system that keeps your lawn perfectly watered year-round.
Feature | Wyze Weatherproof Sprinkler Controller Box | Wyze Sprinkler Controller | Wyze Sprinkler Plus |
Type | Accessory | Connected Home | Service Subscription |
Price | $39.99 | $59.99 (Controller only) / $99.98 (Controller + Box) | $9.99 (Annual License) |
Purpose | Weatherproof enclosure for Wyze Sprinkler Controller | Smart 8-zone WiFi sprinkler controller | Weather-based smart watering features subscription |
Weatherproof Rating | IP65 | Not specified (controller designed for outdoor use) | N/A |
Compatibility | Only with Wyze Sprinkler Controller | Compatible with most residential irrigation systems in North America | Digital license for Sprinkler Plus service |
Zones Controlled | N/A | Up to 8 irrigation zones | N/A |
Power Options | Hardwire or outdoor outlet power | Requires power to operate irrigation system | N/A |
Key Features | 4 clasps, gridded cover for durability, outdoor use | Remote control via app, personalized schedules, EPA WaterSense certified, weather-based watering with Sprinkler Plus included for 1 year | Weather intelligence, advanced insights, smart weather skips, zone moisture info |
Installation Time | N/A | About 20 minutes | N/A |
Subscription Required | No | No (includes 1 year free Sprinkler Plus) | No |
Return Policy | 30-day hassle-free returns | 30-day hassle-free returns | N/A |
What is the Wyze Weatherproof Sprinkler Controller Box and why do I need it?
The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from dust, rain, and outdoor elements. It ensures your smart irrigation system remains safe and functional outdoors, providing reliable, weatherproof operation for your lawn or garden.Is the Wyze Weatherproof Sprinkler Controller Box compatible with the Wyze Sprinkler Controller?
Yes, the Wyze Weatherproof Sprinkler Controller Box is specifically designed for seamless compatibility with the Wyze Sprinkler Controller, ensuring a neat and weatherproof installation for your smart irrigation system.What tools and materials are required to install the Wyze Weatherproof Sprinkler Controller Box?
To install the Wyze Weatherproof Sprinkler Controller Box, you will need a power drill with a Phillips head and 7/32 inch drill bit, a hammer, a pencil, electrical tape, and wire connector caps. The box comes with screws, anchors, connector caps, and waterproof gaskets for a secure installation.How do I wire and secure the Wyze Weatherproof Sprinkler Controller Box?
First, turn off power to your existing sprinkler controller. Remove the old controller, label and photograph the wiring, and mount the weatherproof box using the provided screws and anchors. Pull electrical and sprinkler wires through the designated conduits, connect wires using the provided caps and electrical tape, and mount the Wyze Sprinkler Controller inside the box. Finally, seal the box with the waterproof gasket and lock all four clasps for a weatherproof enclosure.Can I use both hardwired and outlet power with the Wyze Weatherproof Sprinkler Controller Box?
Yes, the Wyze Weatherproof Sprinkler Controller Box supports both hardwire power connections and outdoor outlet power, giving you flexibility in how you power your Wyze Sprinkler Controller.What are the key features of the Wyze Sprinkler Controller?
The Wyze Sprinkler Controller offers smart zoned control for up to 8 irrigation zones, personalized watering schedules, weather-based watering with a Sprinkler Plus subscription, WaterSense certification for water efficiency, and easy installation that most users can complete in about 20 minutes.How do I install the Wyze Sprinkler Controller?
Turn off power to your existing controller, label and photograph the wiring, mount the included wall plate, and connect the labeled wires to the corresponding terminals on the Wyze Sprinkler Controller. Plug in the power adapter, mount the controller onto the plate, and pair it with the Wyze app to configure zones and schedules.What is Wyze Sprinkler Plus and what benefits does it offer?
Wyze Sprinkler Plus is a subscription service that unlocks advanced weather intelligence, zone moisture information, and intelligent weather skips to conserve water. It helps keep your lawn healthy while reducing irrigation costs, and a 1-year free subscription is included with your Wyze Sprinkler Controller.What safety tips should I follow during installation?
Always ensure the power is off before handling any wiring. Keep exposed wire ends about ¼ to ⅜ inches long for secure connections, maintain at least 15 feet between pump relays and the Wyze Sprinkler Controller to avoid electrical interference, and use the included Velcro cable wraps to organize wires neatly inside the box.How do I set up and configure my Wyze Sprinkler Controller after installation?
After installing and powering your Wyze Sprinkler Controller, use the Wyze app to pair the device, configure your irrigation zones, and set up personalized watering schedules. The app will guide you through the setup process for optimal lawn care.
What tools do I need to install the Wyze Weatherproof Sprinkler Controller Box?Can you explain the process of sealing and securing the weatherproof box after installation?How do I pair the Wyze Sprinkler Controller with the Wyze app?
