Wyze IP65 Weatherproof Sprinkler Controller Box for Outdoor Use
Wyze IP65 Weatherproof Sprinkler Controller Box for Outdoor Wiring and Replacement
When it comes to managing your outdoor irrigation system, having a reliable, weatherproof enclosure is essential. The Wyze Weatherproof Sprinkler Controller Box offers a robust solution designed specifically for outdoor use, ensuring your Wyze Sprinkler Controller stays protected from the elements while providing easy installation and durable performance.
Wyze Weatherproof Sprinkler Controller Box: Ultimate Outdoor Protection
Fully Weatherproof with IP65 Rating
The Wyze Sprinkler Controller Box boasts an IP65 rating, meaning it is completely protected against dust ingress and water jets from any direction. This makes it ideal for outdoor environments where exposure to rain, dust, and other weather conditions is inevitable. You can confidently mount your sprinkler controller outdoors without worrying about damage.
Durable Design for Long-Lasting Use
Constructed with a gridded cover and secured by 4 strong clasps, this box offers extra durability and protection. Its design ensures that your sprinkler controller remains safe from physical impacts and environmental wear, extending the life of your irrigation system components.
Flexible Power Options
Whether you prefer to hardwire your sprinkler controller or use an outdoor outlet, the box supports both power methods. This flexibility makes it easy to integrate into your existing outdoor wiring setup.
"Mount Wyze Sprinkler Controller anywhere, worry-free."
Compatibility
This box is specifically designed for the Wyze Sprinkler Controller, ensuring a perfect fit and easy installation. While it can be used with other brands, the internal attachment methods are optimized for Wyze products.
Wyze Sprinkler Controller: Smarter, Simpler Lawn Irrigation
Smart Zoned Control for Up to 8 Zones
Control your lawn watering with precision using the Wyze Sprinkler Controller’s 8 customizable irrigation zones. Assign unique names and photos to each zone in the Wyze app, making it easy to manage different areas of your garden or lawn.
Weather-Based Watering with Sprinkler Plus
Included with your purchase is a 1-year free subscription to Sprinkler Plus, Wyze’s weather service that adjusts watering schedules based on hyper-local weather data. This intelligent feature helps you save water by skipping watering during rain or when soil moisture is sufficient, earning the controller the EPA WaterSense certification.
Remote Control and Scheduling
Manage your sprinkler system from anywhere using the Wyze app. Start or stop watering schedules with a tap, customize weekly routines, and receive notifications about your system’s status. This convenience eliminates the need for manual timers and reduces water waste.
Easy DIY Installation
Replace your existing sprinkler controller in under 20 minutes with a straightforward installation process. The Wyze Sprinkler Controller automatically creates a watering schedule after setup, making it accessible even for beginners. Wyze Sprinkler Controller in Use Control your lawn watering remotely with Wyze Sprinkler Controller
Why Choose Wyze for Your Outdoor Sprinkler Needs?
  • Complete Weatherproof Solution: The combination of the Wyze Sprinkler Controller and the IP65-rated Weatherproof Sprinkler Controller Box ensures your irrigation system is protected and functional in all weather conditions.
  • Smart Water Management: Save water and money with intelligent weather-based watering schedules.
  • User-Friendly App: Manage your sprinkler zones, schedules, and monitor watering activity easily from your smartphone.
  • Durability and Flexibility: The weatherproof box’s rugged design and flexible power options make it a perfect replacement for outdoor sprinkler controller enclosures.
Additional Outdoor Smart Home Accessories
While focusing on your sprinkler system, consider complementing your outdoor setup with the Wyze Plug Outdoor. This smart outdoor plug is rated IP64 for weather resistance and allows you to control garden lights, holiday inflatables, or other outdoor devices remotely via the Wyze app.
Summary
For anyone looking to replace or upgrade their outdoor sprinkler controller setup, the Wyze Weatherproof Sprinkler Controller Box paired with the Wyze Sprinkler Controller offers a smart, durable, and weatherproof solution. Enjoy peace of mind knowing your irrigation system is protected and optimized for efficient watering year-round. Smart Sprinkler Control with Wyze App Manage your sprinkler zones and schedules easily with the Wyze app
FeatureWyze Weatherproof Sprinkler Controller BoxWyze Sprinkler Controller
TypeAccessoryConnected Home Device
Price$39.99$59.99 (Controller only), $99.98 (Controller + Box)
PurposeWeatherproof enclosure for Wyze Sprinkler ControllerSmart 8-zone WiFi sprinkler controller
Weatherproof RatingIP65 (fully weatherproof for outdoor use)Not specified (controller designed for outdoor use)
CompatibilityOnly compatible with Wyze Sprinkler ControllerCompatible with most residential irrigation systems in North America, supports up to 8 zones
Zones SupportedN/AUp to 8 customizable irrigation zones
Power OptionsHardwire or outdoor outlet powerRequires power to operate irrigation system
Installation TimeN/ADIY installation in about 20 minutes
Features4 clasps and gridded cover for extra durabilityRemote control via app, personalized schedules, weather-based watering with Sprinkler Plus, EPA WaterSense certified
Weather-Based Watering SupportNoYes, with Sprinkler Plus subscription (1 year free included)
Smart FeaturesNoIntelligent weather skips, advanced zone insights
WarrantyNot specifiedNot specified
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze IP65 Weatherproof Sprinkler Controller Box?The Wyze IP65 Weatherproof Sprinkler Controller Box is a durable outdoor enclosure designed to protect your Wyze Sprinkler Controller from dust, rain, and other harsh weather conditions. With its IP65 rating, it ensures your irrigation system remains safe and functional year-round.
Is the Wyze Sprinkler Controller Box fully weatherproof?Yes, the Wyze Sprinkler Controller Box is fully weatherproof with an IP65 rating, meaning it is protected against dust ingress and water jets from any direction, making it ideal for outdoor use.
What makes the Wyze Sprinkler Controller Box durable?The box features a gridded cover and is secured by four strong clasps, providing extra durability and protection against physical impacts and environmental wear, ensuring long-lasting use.
Can I use the Wyze Weatherproof Sprinkler Controller Box with other sprinkler controllers?While the box is specifically designed for the Wyze Sprinkler Controller for a perfect fit and easy installation, it may be compatible with other brands, though the internal attachment methods are optimized for Wyze products.
What power options does the Wyze Sprinkler Controller Box support?The Wyze Sprinkler Controller Box supports both hardwiring and the use of an outdoor outlet, offering flexible power options to suit your existing outdoor wiring setup.
How many irrigation zones can the Wyze Sprinkler Controller manage?The Wyze Sprinkler Controller can manage up to 8 customizable irrigation zones, allowing you to assign unique names and photos to each zone for easy management through the Wyze app.
Does the Wyze Sprinkler Controller offer weather-based watering?Yes, the Wyze Sprinkler Controller includes a 1-year free subscription to Sprinkler Plus, which uses hyper-local weather data to automatically adjust watering schedules, helping you save water and earn EPA WaterSense certification.
Can I control my Wyze Sprinkler Controller remotely?Absolutely. You can manage your sprinkler system from anywhere using the Wyze app, including starting or stopping watering schedules, customizing routines, and receiving notifications about your system’s status.
Is the Wyze Sprinkler Controller easy to install?Yes, the Wyze Sprinkler Controller is designed for easy DIY installation, allowing you to replace your existing controller in under 20 minutes. The system automatically creates a watering schedule after setup.
What are the benefits of using the Wyze Sprinkler Controller and Weatherproof Box together?Using both products together provides a complete weatherproof and smart irrigation solution, ensuring your system is protected from the elements, easy to manage via the app, and optimized for efficient water usage.
Are there other Wyze outdoor smart home accessories available?Yes, Wyze also offers the Wyze Plug Outdoor, an IP64-rated smart plug that allows you to control outdoor devices like garden lights and holiday inflatables remotely through the Wyze app.
What are the installation requirements for the Wyze Weatherproof Sprinkler Controller Box?Can the Wyze Weatherproof Sprinkler Controller Box be used with other brands of sprinkler controllers?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze products?
