Wyze LS Mount: Secure, Versatile Mounting Solution for Wyze Cameras – Universal Long Mount for Indoor & Outdoor Use
Wyze LS Mount: The Ultimate Mounting Solution for Wyze Cameras
Looking for the best way to securely mount your Wyze cameras for optimal coverage and flexibility? The Wyze Universal Mount (Long)—often referred to as the Wyze LS Mount—is designed to provide a durable, versatile, and easy-to-install solution for your home security setup. Discover why this mount is the perfect accessory for your Wyze cameras and how it can enhance your smart home experience.
Why Choose the Wyze Universal Mount (Long)?
Versatile Mounting for Every Scenario
The Wyze Universal Mount (Long) is engineered for maximum flexibility, allowing you to install your Wyze cameras in a variety of locations—indoors or outdoors. Whether you want to mount your camera on the ceiling, wall, or patio, this mount’s longer neck and adjustable design make it easy to achieve the perfect angle for your surveillance needs.
"A durable camera mount with a longer neck. Designed to provide versatile mounting applications such as the ceiling or patio."
  • Heavy-Duty Metal Construction: Built to last, the mount supports up to 2 kg (70 oz), ensuring your camera stays securely in place.
  • Adjustable Design: Easily adjust the angle and direction of your camera for optimal coverage.
  • Easy Installation: Comes with all necessary hardware, including three wall anchors and three Philips screws, making setup a breeze.
Compatibility: Made for Wyze Cams
The Wyze Universal Mount (Long) is compatible with a wide range of Wyze cameras that use a standard 1/4”-20 mount, including:
  • Wyze Cam v1, v2, v3, v3 Pro
  • Wyze Cam Pan v1, v2, v3
  • Wyze Cam Outdoor v1, v2
  • Wyze Battery Cam Pro
Note: This mount is not compatible with Wyze Cam OG or OG Telephoto.
Key Features at a Glance
  • Model Number: WYZEUMML
  • Color & Finish: White, Matte
  • Weight: 2 oz (57 g)
  • Dimensions: 2 in x 2 in x 3.8 in
  • Mount Load Bearing: 70 oz (2 kg)
  • Included Items: Wyze Universal Metal Mount x1, Screw Assembly x1
Perfect for Home Security and Lifestyle Integration
Wyze camera mounted outdoors on a patio, providing home security and peace of mind. The Wyze Universal Mount (Long) is ideal for both indoor and outdoor use, making it a top choice for homeowners who want to maximize their camera’s field of view. Its sleek, unobtrusive design blends seamlessly with any décor, while its robust construction ensures your camera remains stable in various environments.
Installation Made Simple
Setting up your Wyze Universal Mount (Long) is straightforward: 1. Choose Your Location: Select a spot on your ceiling, wall, or patio. 2. Drill and Secure: Use the included wall anchors and screws for a secure fit. 3. Attach Your Camera: Simply screw your compatible Wyze camera onto the mount and adjust as needed.
"Made for Wyze Cams. Compatible with Wyze Cams with 1/4”-20 mount. Heavy-Duty Metal Mount. Adjustable. Easy Installation."
Enhance Your Wyze Camera Experience
With the Wyze Universal Mount (Long), you can:
  • Achieve the perfect viewing angle for your security needs.
  • Install your camera in hard-to-reach or unconventional locations.
  • Enjoy peace of mind knowing your camera is securely mounted.
Frequently Asked Questions
Q: Is the Wyze Universal Mount (Long) weatherproof? A: The mount itself is made of heavy-duty metal and is suitable for both indoor and outdoor use. However, always ensure your camera is rated for outdoor use if installing outside. Q: What is included in the box? A: Each package contains one Wyze Universal Metal Mount and a screw assembly kit (three wall anchors and three Philips screws). Q: Can I use this mount with non-Wyze cameras? A: The mount is designed for cameras with a standard 1/4”-20 mount, so it may be compatible with other brands that use this standard.
Conclusion
The Wyze Universal Mount (Long) is the go-to solution for anyone seeking a reliable, flexible, and easy-to-install mounting option for their Wyze cameras. Upgrade your home security setup today and enjoy the peace of mind that comes with optimal camera placement.
Keywords: Wyze LS Mount, Wyze Universal Mount Long, Wyze camera mount, Wyze camera accessories, home security, smart home, camera installation, Wyze Cam mount, outdoor camera mount, ceiling camera mount
Related Product Tag:
What is the Wyze Universal Mount (Long) and what makes it the best mounting solution for Wyze cameras?The Wyze Universal Mount (Long), also known as the Wyze LS Mount, is a heavy-duty, versatile, and easy-to-install camera mount designed specifically for Wyze cameras. Its longer neck and adjustable design allow for flexible installation on ceilings, walls, or patios, making it ideal for achieving the perfect camera angle for home security and smart home integration.
Which Wyze cameras are compatible with the Wyze Universal Mount (Long)?The Wyze Universal Mount (Long) is compatible with Wyze cameras that use a standard 1/4”-20 mount, including Wyze Cam v1, v2, v3, v3 Pro, Wyze Cam Pan v1, v2, v3, Wyze Cam Outdoor v1, v2, and Wyze Battery Cam Pro. It is not compatible with Wyze Cam OG or OG Telephoto.
Is the Wyze Universal Mount (Long) suitable for outdoor use?Yes, the Wyze Universal Mount (Long) is made of heavy-duty metal and is suitable for both indoor and outdoor use. However, ensure that your camera is rated for outdoor use if you plan to install it outside.
What is included in the Wyze Universal Mount (Long) package?Each Wyze Universal Mount (Long) package includes one Wyze Universal Metal Mount and a screw assembly kit, which contains three wall anchors and three Philips screws for easy installation.
How much weight can the Wyze Universal Mount (Long) support?The Wyze Universal Mount (Long) is built with heavy-duty metal construction and can support up to 2 kg (70 oz), ensuring your Wyze camera stays securely in place.
Can I use the Wyze Universal Mount (Long) with non-Wyze cameras?The Wyze Universal Mount (Long) is designed for cameras with a standard 1/4”-20 mount, so it may be compatible with other camera brands that use this standard mounting system.
What are the dimensions and color of the Wyze Universal Mount (Long)?The Wyze Universal Mount (Long) has dimensions of 2 inches x 2 inches x 3.8 inches, weighs 2 oz (57 g), and comes in a white matte finish.
How do I install the Wyze Universal Mount (Long)?To install the Wyze Universal Mount (Long), choose your desired location (ceiling, wall, or patio), use the included wall anchors and screws to secure the mount, then attach your compatible Wyze camera and adjust the angle as needed.
What are the key features of the Wyze Universal Mount (Long)?Key features of the Wyze Universal Mount (Long) include heavy-duty metal construction, adjustable design for optimal camera angles, compatibility with a wide range of Wyze cameras, easy installation with included hardware, and suitability for both indoor and outdoor use.
What are the installation steps for the Wyze Universal Mount (Long)?Is the Wyze Universal Mount (Long) compatible with all Wyze cameras?Do you have any ongoing sales or discounts for the Wyze Universal Mount (Long)?
