Extra Wall Plate Kit for Wyze Cam v3 Pro – Secure Mounting
Extra Wall Plate Kit for Wyze Cam v3 Pro Installation
When installing your Wyze Cam v3 Pro, having the right mounting accessories can make all the difference. The extra wall plate kit is an essential accessory designed to simplify and secure your camera installation, ensuring optimal placement and stability. Whether you want to mount your camera indoors or outdoors, this kit provides versatile mounting options tailored for the Wyze Cam v3 Pro.
Wyze Cam v3 Pro: The Ultimate Smart Security Camera
The Wyze Cam v3 Pro is the latest pro version of Wyze’s best-selling smart camera, packed with advanced features to keep your home safe and connected.
Key Features:
  • 2.5K Resolution: Crystal-clear video quality at 2560x1440 pixels for detailed monitoring.
  • Built-in Spotlight & Integrated Siren: Enhances security with a bright spotlight and loud siren to deter intruders.
  • Edge AI: Intelligent detection with customizable zones to reduce false alerts.
  • Color Night Vision: See vibrant colors even in low light conditions.
  • Weatherproof (IP65 Rated): Suitable for both indoor and outdoor use (requires Wyze Outdoor Power Adapter v2 for outdoor).
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for seamless communication.
  • Local Storage: Supports up to 256GB microSD cards for continuous recording.
  • Multiple Mounting Methods: Magnetic, screw, and tape mounting options for flexible installation.
Dimensions & Build:
  • Compact size: 2.05 in x 2.05 in x 2.3 in (52 mm x 52 mm x 58.5 mm)
  • Lightweight at 4.23 oz (120 g), making it easy to mount anywhere.
The Wyze Cam v3 Pro is perfect for monitoring pets, children, or securing your home with professional-grade features at an affordable price.
Wyze Cam v3 Pro lifestyle image showing child playing guitar with camera monitoring Wyze Cam v3 Pro capturing everyday moments with 24/7 recording
Extra Wall Plate Kit: Secure and Flexible Mounting Solution
The Wyze Cam Mounting Kit is the ideal accessory to complement your Wyze Cam v3 Pro installation. It includes everything you need to mount your camera securely and neatly.
What’s Included:
  • Wall Plate: Provides a sturdy base for mounting on walls or ceilings.
  • USB Extension Cable (5 feet): Extends your camera’s reach for flexible placement.
  • Adhesive Tape: For quick, no-drill mounting options.
  • Screw Set: For a more permanent and secure installation.
Benefits of Using the Wall Plate Kit:
  • Enhanced Stability: The wall plate ensures your camera stays firmly in place, reducing the risk of accidental falls.
  • Versatile Mounting Options: Use screws for a permanent mount or adhesive tape for temporary setups.
  • Cable Management: The included USB extension cable helps keep power cables tidy and out of sight.
  • Compatibility: Designed specifically for Wyze Cam v2, v3, and v3 Pro models.
This kit is perfect for users who want a neat, professional-looking installation with multiple mounting options.
Additional Accessories to Enhance Your Wyze Cam v3 Pro Setup
Wyze Cam USB Extension Cable - 20ft
If you need even more flexibility in camera placement, the 20ft USB extension cable is a great addition. It allows you to position your Wyze Cam v3 Pro farther from power outlets without compromising performance.
  • Length: 20 feet for extended reach.
  • Compatibility: Works with Wyze Cam v2, v3, v3 Pro, v4, and other Wyze cameras.
  • Weather Resistant: Rated IP67, suitable for outdoor use.
  • Connector Type: USB Type A Male to Female.
This cable is perfect for outdoor installations or hard-to-reach indoor locations where power outlets are limited.
For outdoor use of your Wyze Cam v3 Pro, the Wyze Outdoor Power Adapter is essential. It is weather-resistant (IP67 rated) and designed to keep your camera powered safely in all weather conditions.
  • Includes: Outdoor power adapter, L-shaped Micro USB adapter, wire clips, screws, and anchors.
  • Cable Length: 12.5 ft power cable plus 3.9 ft AC cable.
  • Compatibility: Required for Wyze Cam v3 Pro outdoor installations.
  • Durability: Built to withstand rain, snow, and extreme temperatures.
Mounting Your Wyze Cam v3 Pro with the Extra Wall Plate Kit
Mounting your Wyze Cam v3 Pro is straightforward with the extra wall plate kit. Here’s a quick overview of the mounting options:
Magnetic Mounting
  • Use the included metal plate with adhesive backing.
  • Stick the plate to your desired surface.
  • Attach the camera magnetically and adjust the angle via the Wyze app.
Screw Mounting
  • Mark the screw holes using the camera base.
  • Drill pilot holes and insert drywall anchors if needed.
  • Screw in the included screws, leaving a small gap.
  • Slide the camera base onto the screws for a secure fit.
1/4"-20 Threaded Mount
  • Remove the base screw.
  • Attach the camera to any standard 1/4"-20 mount for tripods or other mounts.
These mounting options provide flexibility to install your camera exactly where you need it, whether on walls, ceilings, or metal surfaces.
Wyze Cam v3 Pro lifestyle image showing father and child communicating via two-way audio Two-way audio keeps you connected with loved ones
Why Choose Wyze Cam v3 Pro with the Extra Wall Plate Kit?
  • Professional Installation Made Easy: The wall plate kit simplifies mounting and cable management.
  • Durable and Weatherproof: Perfect for indoor and outdoor use with the right accessories.
  • Advanced Features: High-resolution video, spotlight, siren, and AI detection.
  • Flexible Power Options: Use the USB extension cable and outdoor power adapter for optimal placement.
  • Trusted Brand: Wyze offers a 1-year warranty and excellent customer support.
Summary
For anyone looking to install the Wyze Cam v3 Pro with confidence and flexibility, the extra wall plate kit is a must-have accessory. Combined with the camera’s advanced features and additional accessories like the USB extension cable and outdoor power adapter, you can create a secure, professional-grade surveillance setup tailored to your home or business needs.
FeatureWyze Cam v3 ProWyze Cam Mounting KitWyze Cam USB Extension Cable - 20ft
TypeCameraAccessoryAccessory
Description2.5K resolution, built-in spotlight, integrated siren, Edge AI, IP65 indoor/outdoor, two-way audio, microSD-ready, Color Night VisionMounting bracket, adhesive, longer Micro USB cable for Wyze Cam v2, v3, v3 Pro20ft USB extension cable compatible with Wyze Cam v2/v3/v3 Pro/v4, Pan v2/v3, OG Standard/Telephoto
CompatibilityN/AWyze Cam v2, Wyze Cam v3, Wyze Cam v3 ProWyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG Standard, OG Telephoto
Price$34.98 - $104.94 (depending on pack size)$5.99$7.99
MountingMagnetic, screw, tapeMounting bracket, adhesive includedN/A
Cable IncludedMicro USB cable (standard length)Longer Micro USB cable included20ft USB Type A Male to Female extension cable
SpotlightBuilt-in 70 lumen spotlightN/AN/A
SirenIntegrated 89 dB sirenN/AN/A
Edge AIYesN/AN/A
Weather ResistanceIP65 (with Outdoor Power Adapter v2)N/AIP67
AudioTwo-way audioN/AN/A
StorageSupports microSD card (up to 128 GB recommended)N/AN/A
Dimensions2.05 in x 2.05 in x 2.3 in (52 mm x 52 mm x 58.5 mm)N/AOD Ø3.8 mm
Weight4.23 oz (120 g)N/A205 g (0.45 lbs)
Connectivity802.11 b/g/n, 2T2R 2.4 GHz Wi-FiN/AN/A
Operating Temperature-4°F to 131°F (-20°C to 55°C)N/A-22°F to 122°F (-30°C to 50°C)
Warranty1 year30-day hassle-free returns30-day hassle-free returns
What is the Extra Wall Plate Kit for Wyze Cam v3 Pro?The Extra Wall Plate Kit is an essential accessory designed to simplify and secure the installation of your Wyze Cam v3 Pro. It provides versatile mounting options, including wall and ceiling mounting, and ensures optimal placement and stability for your camera.
What is included in the Wyze Cam v3 Pro Extra Wall Plate Kit?The Extra Wall Plate Kit includes a sturdy wall plate, a 5-foot USB extension cable, adhesive tape for no-drill mounting, and a screw set for permanent installation. These components help you mount your Wyze Cam v3 Pro securely and manage cables neatly.
Is the Extra Wall Plate Kit compatible with other Wyze cameras?Yes, the Extra Wall Plate Kit is designed specifically for Wyze Cam v2, v3, and v3 Pro models, ensuring a secure and professional installation for these cameras.
What are the mounting options available with the Extra Wall Plate Kit?The kit supports multiple mounting methods: magnetic mounting using the included metal plate and adhesive, screw mounting for a permanent setup, and compatibility with standard 1/4"-20 threaded mounts for tripods or other accessories.
Can I use the Wyze Cam v3 Pro outdoors with the Extra Wall Plate Kit?Yes, the Wyze Cam v3 Pro is weatherproof (IP65 rated) and can be used outdoors when paired with the Wyze Outdoor Power Adapter v2. The Extra Wall Plate Kit provides secure mounting options for both indoor and outdoor installations.
What are the key features of the Wyze Cam v3 Pro?The Wyze Cam v3 Pro offers 2.5K resolution, built-in spotlight and siren, Edge AI for intelligent detection, color night vision, weatherproof design, two-way audio, local storage support up to 256GB, and multiple mounting methods.
How does the USB extension cable in the kit help with installation?The included 5-foot USB extension cable allows you to place your Wyze Cam v3 Pro farther from power outlets, providing more flexibility in camera placement and helping to keep power cables tidy and out of sight.
Are there longer USB extension cables available for Wyze Cam v3 Pro?Yes, a 20-foot Wyze Cam USB extension cable is available for purchase. It is weather-resistant (IP67 rated) and compatible with Wyze Cam v2, v3, v3 Pro, v4, and other Wyze cameras, making it ideal for outdoor or hard-to-reach indoor installations.
Is a special power adapter required for outdoor use of Wyze Cam v3 Pro?Yes, for outdoor installations, the Wyze Outdoor Power Adapter is required. It is weather-resistant (IP67 rated) and includes a 12.5 ft power cable, 3.9 ft AC cable, L-shaped Micro USB adapter, wire clips, screws, and anchors for secure and safe outdoor power supply.
Why should I use the Extra Wall Plate Kit for my Wyze Cam v3 Pro installation?The Extra Wall Plate Kit ensures a secure, stable, and professional-looking installation for your Wyze Cam v3 Pro. It offers multiple mounting options, improved cable management, and is compatible with both indoor and outdoor setups, making it a must-have accessory for optimal camera placement.
What are the different mounting methods available for the Wyze Cam v3 Pro?Can you explain how to use the adhesive tape for mounting the camera?Do you have any ongoing sales or discounts for the Wyze Cam v3 Pro?
