WiFi Backup Smart Lock with Bluetooth Connectivity: Secure Your Home Even When Internet Goes Out
When it comes to home security, having a smart lock that works seamlessly—even when your internet connection fails—is essential. If you’re searching for a
WiFi backup smart lock with Bluetooth connectivity, the
Wyze Lock Bolt stands out as a top choice. This smart lock ensures you never get locked out, providing reliable access through Bluetooth even when WiFi is down.
Wyze Lock Bolt: The Ultimate Bluetooth Smart Lock with WiFi Backup
Key Features and Benefits
Bluetooth Connectivity for Offline Access
The Wyze Lock Bolt operates primarily via Bluetooth, allowing you to unlock your door instantly with your fingerprint or the Wyze app without relying on WiFi. This means even if your internet goes out, your lock remains fully functional.
Fingerprint Unlock & Backlit Keypad
Say goodbye to fumbling for keys. The ultra-fast fingerprint reader lets you unlock your door in less than a second. The luxurious backlit keypad ensures easy code entry at night, enhanced with anti-peep technology so you can enter your code discreetly.
Auto-Lock for Peace of Mind
Never worry about forgetting to lock your door. Set an auto-lock timer in the Wyze app, and the lock will secure your door automatically after your chosen delay.
Robust Security & Privacy
The lock uses hardware encryption to protect your fingerprint and code data. It requires two-factor authentication in the app, ensuring only authorized users can control the lock.
Long Battery Life with Emergency Power
Powered by 4 AA batteries lasting up to 12 months, the Wyze Lock Bolt alerts you when battery levels are low. If batteries die, a USB-C port allows a quick emergency charge so you can still enter your access code.
Weatherproof and Pick-Proof Design
Built with solid metal and IPX5 weatherproofing, the lock withstands harsh outdoor conditions and eliminates the risk of lock picking by removing physical keys.
Easy Installation
Replaces your existing deadbolt in about 20 minutes and fits almost all exterior doors.
Smart App Control with Local Bluetooth Access
The Wyze app acts as your command center, connecting to the lock via Bluetooth. You can:
- View lock/unlock history with timestamps and method of entry
- Create and store up to 20 access codes and 50 fingerprints
- Generate emergency one-time codes remotely (even without Bluetooth connection)
- Set auto-expiring codes and access schedules for guests
“Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans.”
Secure your home effortlessly with Wyze Lock Bolt.
Additional Smart Home Integration: Wyze Switch
While the Wyze Lock Bolt secures your door, complement your smart home ecosystem with the
Wyze Switch to control your lighting and other devices remotely.
Why Choose Wyze Switch?
- Turn regular lights into smart lights controllable from anywhere
- Multi-tap functionality to control other Wyze devices like cameras, locks, and robot vacuums
- Create automations, schedules, and timers for convenience and energy savings
- Vacation mode to simulate occupancy when you’re away
- Power loss recovery ensures your settings remain intact after outages
Control your home lighting smartly with Wyze Switch.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt in perfect working condition, Wyze offers essential replacement parts:
- Wyze Lock Replacement Part Kit – Includes screws, cables, and components to restore your lock to like-new condition.
- Wyze Lock Bolt Screws – Replacement screws compatible with the Wyze Lock Bolt.
- Wyze Lock Bolt Interior Assembly Battery Cover – Replacement cover for the battery compartment.
- Wyze Lock Bolt Interior Assembly Metal Plate – Metal plate to anchor the interior assembly securely to your door.
These parts ensure your smart lock remains durable and reliable over time.
Why Choose Wyze Lock Bolt for Your WiFi Backup Smart Lock?
Reliable Bluetooth Access When WiFi Fails
Fast, Secure Fingerprint and Keypad Entry
Auto-Lock and Emergency Power Features
Robust Security with Hardware Encryption
Easy Installation and App Control
Protect your home with a smart lock that never leaves you stranded—even when the internet goes out.
Control your lock effortlessly from your smartphone.
Summary
For a
Wyze Lock Bolt is an excellent choice. It combines convenience, security, and reliability, ensuring your home stays protected even during internet outages. Paired with Wyze’s smart home ecosystem, including the Wyze Switch, you can create a fully connected, secure, and automated home environment.
What is a WiFi backup smart lock with Bluetooth connectivity?
A WiFi backup smart lock with Bluetooth connectivity is a smart door lock that allows you to unlock and control your door using Bluetooth when your WiFi or internet connection is unavailable. This ensures you always have access to your home, even during internet outages.How does the Wyze Lock Bolt work when WiFi is down?
The Wyze Lock Bolt operates primarily via Bluetooth, allowing you to unlock your door with your fingerprint or the Wyze app even if your WiFi is down. This ensures you never get locked out due to internet issues.What are the main features of the Wyze Lock Bolt smart lock?
Key features of the Wyze Lock Bolt include Bluetooth connectivity for offline access, ultra-fast fingerprint unlock, a backlit anti-peep keypad, auto-lock functionality, robust security with hardware encryption, long battery life with emergency USB-C charging, weatherproof and pick-proof design, and easy installation.Can I unlock the Wyze Lock Bolt with my fingerprint?
Yes, the Wyze Lock Bolt features an ultra-fast fingerprint reader that lets you unlock your door in less than a second, providing secure and convenient access.Does the Wyze Lock Bolt have a keypad for code entry?
Yes, the Wyze Lock Bolt has a backlit keypad with anti-peep technology, allowing you to enter your access code discreetly and easily, even at night.What happens if the Wyze Lock Bolt batteries die?
If the Wyze Lock Bolt's batteries run out, you can use the built-in USB-C port to provide a quick emergency charge, allowing you to enter your access code and unlock the door.Is the Wyze Lock Bolt weatherproof and pick-proof?
Yes, the Wyze Lock Bolt is built with solid metal and features IPX5 weatherproofing to withstand harsh outdoor conditions. It is also pick-proof, as it eliminates the need for physical keys.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes and fitting almost all exterior doors.What smart features does the Wyze app offer for the Lock Bolt?
The Wyze app allows you to view lock/unlock history, create and store up to 20 access codes and 50 fingerprints, generate emergency one-time codes remotely, set auto-expiring codes and access schedules for guests, and control the lock via Bluetooth.Can I generate one-time or guest access codes with the Wyze Lock Bolt?
Yes, you can generate emergency one-time codes and set auto-expiring codes or access schedules for guests using the Wyze app, even without a Bluetooth connection.What replacement parts are available for the Wyze Lock Bolt?
Wyze offers a Lock Replacement Part Kit (including screws, cables, and components), replacement screws, a battery cover, and an interior assembly metal plate to keep your Wyze Lock Bolt in top condition.How does the Wyze Switch complement the Wyze Lock Bolt?
The Wyze Switch allows you to control your home lighting and other Wyze devices remotely, create automations and schedules, and simulate occupancy with vacation mode, enhancing your smart home ecosystem alongside the Wyze Lock Bolt.Is the Wyze Lock Bolt secure?
Yes, the Wyze Lock Bolt uses hardware encryption to protect your fingerprint and code data, and requires two-factor authentication in the app, ensuring only authorized users can control the lock.How long does the Wyze Lock Bolt battery last?
The Wyze Lock Bolt is powered by 4 AA batteries that can last up to 12 months. The lock will alert you when battery levels are low.Why should I choose the Wyze Lock Bolt for my home security?
The Wyze Lock Bolt offers reliable Bluetooth access when WiFi fails, fast and secure fingerprint and keypad entry, auto-lock and emergency power features, robust security, weatherproof and pick-proof design, easy installation, and comprehensive app control, making it an excellent choice for home security.
