Wyze Cam v4 Motion Activated Spotlight for Smart Home Security
Wyze Cam v4 Motion Activated Spotlight: Ultimate Home Security Solution
When it comes to securing your home with smart technology, the Wyze Cam v4 series stands out as a top choice. Featuring a motion-activated spotlight, enhanced color night vision, and crystal-clear 2.5K QHD video resolution, these cameras provide unmatched security both day and night. Whether you need an indoor or outdoor solution, Wyze offers versatile options tailored to your needs.
Explore the Wyze Cam v4 Product Lineup
Wyze Cam v4 – Core Features and Specs
The Wyze Cam v4 is designed to deliver high-quality video and smart security features in a compact, durable package.
  • Video Quality: 2.5K QHD (2560x1440) resolution with 8x digital zoom for detailed footage.
  • Field of View: Wide angles with 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
  • Sensor: CMOS Starlight Sensor for superior low-light performance.
  • Night Vision: Enhanced with 4 IR LEDs (850 nm) plus 2 white spotlight LEDs (72 lumens) for color night vision.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring intruders and improving video clarity.
  • Audio: Waterproof 99dB speaker with two-way talk and built-in siren.
  • Connectivity: Supports both 2.4 GHz Wi-Fi and Wi-Fi 6 for reliable streaming.
  • Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Mounting Options: Flexible installation with stand, wall mount, ceiling mount, or magnetic adhesive mount.
  • Weather Resistance: Rated IP65, suitable for indoor and outdoor use.
  • Storage: Supports microSD cards up to 512GB for local recording; cloud storage available with subscription.
  • Dimensions & Weight: Compact 2in x 2in x 2 3/8in, weighing 0.49 lb (222 g).
Included in the box are the camera, mounting hardware, indoor power adapter, and a 6-foot flat micro USB to USB-A cable.
Experience peace of mind with a camera that not only records but actively protects your home with its motion-activated spotlight and color night vision.
Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 protecting your home with motion-activated spotlight and night vision
Wyze Cam v4 Outdoor Bundle – Enhanced Security for Your Exterior
For those seeking a complete outdoor security solution, the Wyze Cam v4 Outdoor Bundle offers everything you need:
  • Includes: Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB Wyze MicroSD Card.
  • Resolution: Crystal-clear 2.5K QHD video.
  • Night Vision: Enhanced Color Night Vision for vivid, detailed images even in darkness.
  • Motion Detection: Advanced motion detection with customizable zones.
  • Sound Detection: Alerts you to unusual sounds.
  • Smoke & CO Alerts: Integrated safety notifications.
  • Wi-Fi Support: Latest Wi-Fi 6 for faster, more stable connections.
  • Compatibility: Alexa and Google Assistant enabled.
  • Power Source: Wired for continuous power outdoors.
  • Local Recording: 24/7 local recording with included microSD card.
  • Weatherproof: IP65 rating ensures durability in harsh weather.
This bundle is perfect for securing your yard, driveway, or any outdoor area with reliable, high-quality surveillance and smart alerts.
Wyze Cam v4 Home Security Bundle – Comprehensive Protection
The Wyze Cam v4 Home Security Bundle is an all-in-one package designed for both indoor and outdoor use, combining advanced features for maximum security:
  • Video Resolution: 2.5K QHD with Wide Dynamic Range (WDR) for vibrant, clear images.
  • Motion-Activated Spotlight: Bright white LEDs activate on motion detection to illuminate and deter.
  • Person Detection: Smart AI to reduce false alarms by distinguishing people from other motion.
  • Audio: Improved two-way audio for clear communication.
  • Storage: Includes a 128GB microSD card (Class 10, UHS-3) for extensive local video storage.
  • Mounting: Multiple mounting options including magnetic adhesive.
  • Weather Resistance: IP65 rated for outdoor durability.
  • Connectivity: Wi-Fi 6 support and compatibility with Alexa and Google Assistant.
  • Video FPS: 20 FPS daytime, 15 FPS nighttime for smooth video playback.
This bundle is ideal for users who want a robust, ready-to-go security system with all essential accessories included.
Wyze Cam v4 + FREE 32GB MicroSD Card – Great Value Offer
For budget-conscious buyers, the Wyze Cam v4 with a free 32GB microSD card provides excellent value without compromising on features:
  • Resolution: 2.5K QHD video quality.
  • Motion-Activated Spotlight: Brightens your property when motion is detected.
  • Color Night Vision: See vivid colors even in low light.
  • Person Detection & Motion Zones: Smart alerts tailored to your home.
  • Wi-Fi 6 Support: Fast and reliable wireless connection.
  • Weatherproof: IP65 rating for outdoor use.
  • Storage: Comes with a free 32GB microSD card for local recording.
  • Compatibility: Works with Alexa and Google Assistant.
This option is perfect for those who want the core benefits of Wyze Cam v4 with added local storage included.
Why Choose Wyze Cam v4 for Motion Activated Spotlight Security?
Wyze Cam v4 cameras combine cutting-edge technology with user-friendly features to provide a smart, reliable security solution. The motion-activated spotlight is a standout feature that not only enhances video quality at night but also acts as a deterrent to unwanted visitors.
  • Enhanced Night Security: Color night vision plus spotlight ensures clear footage and visibility.
  • Smart Alerts: Person detection and motion zones reduce false alarms.
  • Flexible Installation: Multiple mounting options for any home setup.
  • Robust Build: Weather-resistant design suitable for all climates.
  • Seamless Integration: Works with popular smart home assistants.
  • Local & Cloud Storage: Choose your preferred video storage method.
Wyze Cam v4 Lifestyle Wyze Cam v4 installed outdoors for smart home security
Conclusion
For anyone searching for a motion activated spotlight camera, the Wyze Cam v4 lineup offers versatile, high-quality options that fit various budgets and security needs. From the standalone Wyze Cam v4 to comprehensive bundles with power adapters and microSD cards, these cameras provide crystal-clear video, smart detection, and reliable performance in all conditions. Invest in Wyze Cam v4 today to protect your home with advanced motion-activated spotlight technology and enjoy peace of mind around the clock.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$100.00$69.99$169.99$35.98
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Color Night VisionYesYesYesYes
Night Vision Type4 IR LEDs + 2 white spotlight LEDs4 IR LEDs + 2 white spotlight LEDs4 IR LEDs + 2 white spotlight LEDsYes
Motion-Activated SpotlightYesYesYesYes
Weather ResistanceIP65IP65IP65IP65
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
AudioEnhanced Two-Way Talk, 99dB SirenEnhanced Two-Way Talk, 99dB SirenImproved 2-way audio, 99dB SirenEnhanced Two-Way Talk, 99dB Siren
Local Storage SupportmicroSD card up to 512 GBmicroSD card (128GB included)microSD card (128GB included)microSD card required (32GB included)
Continuous RecordingYesYesYesYes
Smart DetectionAvailable with subscriptionAvailable with subscriptionAvailable with subscriptionAvailable with subscription
Motion & Sound DetectionYesYesYesYes
Motion Detection ZonesYesYesYesYes
Smoke & CO AlertsYesYesYesYes
AI Auto-Zoom & Smart FocusYesYesYesYes
Field of View (DFOV x HFOV x VFOV)115.8° x 98.5° x 53.1°115.9° x 98.5° x 53.1°115.8° x 98.5° x 53.1°Not specified
PowerWired (Indoor 5V/1A)Wired + Outdoor Power AdapterWired (Indoor/Outdoor)Wired (requires Outdoor Power Adapter)
Included AccessoriesNoneOutdoor Power Adapter, 128GB microSD128GB microSD CardFREE 32GB microSD Card included
Mounting OptionsStand, Wall, Ceiling, MagneticSame as Wyze Cam v4Same as Wyze Cam v4Same as Wyze Cam v4
Warranty1 Year1 Year1 YearNot specified
Additional Bundle ItemsN/AOutdoor Power Adapter, 128GB microSDPart of Home Security Bundle (includes other devices)32GB microSD Card
What is the video resolution of the Wyze Cam v4?The Wyze Cam v4 features a 2.5K QHD (2560x1440) video resolution, providing crystal-clear footage with 8x digital zoom for detailed monitoring.
Does the Wyze Cam v4 have color night vision?Yes, the Wyze Cam v4 is equipped with enhanced color night vision, utilizing 4 IR LEDs and 2 white spotlight LEDs to deliver vivid, detailed images even in low-light conditions.
How does the motion-activated spotlight work on Wyze Cam v4?The Wyze Cam v4 features a motion-activated spotlight that automatically illuminates when motion is detected, deterring intruders and improving video clarity, especially at night.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is IP65 weather-resistant, making it suitable for both indoor and outdoor installation, and it can withstand various weather conditions.
What smart home systems is Wyze Cam v4 compatible with?Wyze Cam v4 works seamlessly with Alexa, Google Assistant, and IFTTT, allowing for easy integration into your smart home ecosystem.
What are the storage options for Wyze Cam v4?Wyze Cam v4 supports local storage with microSD cards up to 512GB and offers cloud storage options with a subscription for added flexibility.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB Wyze MicroSD Card, providing everything needed for reliable outdoor security.
Does Wyze Cam v4 support Wi-Fi 6?Yes, Wyze Cam v4 supports both 2.4 GHz Wi-Fi and the latest Wi-Fi 6 standard for faster, more stable wireless connections.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers flexible installation options, including stand, wall mount, ceiling mount, and magnetic adhesive mount, making it easy to set up in any location.
Does Wyze Cam v4 have two-way audio?Yes, Wyze Cam v4 features a waterproof 99dB speaker with two-way talk and a built-in siren, allowing for clear communication and active deterrence.
What is the difference between the Wyze Cam v4 Home Security Bundle and the Outdoor Bundle?The Wyze Cam v4 Home Security Bundle is designed for both indoor and outdoor use and includes advanced features like person detection, improved two-way audio, and a 128GB microSD card. The Outdoor Bundle is focused on outdoor security and includes a power adapter and microSD card for continuous outdoor surveillance.
Is there a budget-friendly Wyze Cam v4 option available?Yes, the Wyze Cam v4 + FREE 32GB MicroSD Card offer provides excellent value, including all core features and a free 32GB microSD card for local video storage.
How does person detection work on Wyze Cam v4?Wyze Cam v4 uses smart AI to distinguish people from other types of motion, reducing false alarms and ensuring you receive relevant security alerts.
Can Wyze Cam v4 record 24/7 locally?Yes, with a compatible microSD card inserted, Wyze Cam v4 supports continuous 24/7 local video recording.
What is the field of view for Wyze Cam v4?Wyze Cam v4 offers a wide field of view with 115.8° diagonal, 98.5° horizontal, and 53.1° vertical coverage, ensuring comprehensive monitoring.
What are the key features of the Wyze Cam v4?Can you tell me more about the night vision capabilities of the Wyze Cam v4?Do you have any ongoing sales or promotions for the Wyze Cam v4?
