Wyze Cam v4: Smart Security Camera with Built-In Spotlight
Discover the Wyze Cam v4 with Built-In Spotlight
If you're searching for a smart security camera that combines crystal-clear video quality with a powerful built-in spotlight, the Wyze Cam v4 lineup is your perfect match. Designed to keep your home safe day and night, these cameras feature motion-activated spotlights, enhanced color night vision, and robust weather resistance, making them ideal for both indoor and outdoor use.
Wyze Cam v4: Advanced Spotlight and Night Vision Technology
The Wyze Cam v4 stands out with its integrated motion-activated spotlight that delivers 72 lumens of bright white light, illuminating your property when motion is detected. This feature enhances security by deterring unwanted visitors and providing clear, colorful video footage even in complete darkness.
Key Specifications:
  • Video Resolution: 2.5K QHD (2560x1440) for sharp, detailed images
  • Night Vision: 4 IR LEDs (850 nm) plus 2 white spotlight LEDs (72 lumens) for enhanced color night vision
  • Field of View: Wide 115.8° diagonal, 98.5° horizontal, and 53.1° vertical
  • Sensor: CMOS Starlight Sensor for superior low-light performance
  • Audio: 99dB waterproof speaker with two-way talk and built-in siren
  • Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for fast, reliable connections
  • Mounting Options: Stand, wall mount, ceiling mount, and magnetic wall mount with adhesive
  • Weather Resistance: IP65 rating, suitable for outdoor environments
  • Storage: Supports microSD cards up to 512GB and cloud storage with subscription
This camera is compact and lightweight (0.49 lb), making it easy to install anywhere around your home.
Experience peace of mind with a camera that not only sees in the dark but lights up the night with its built-in spotlight.
Wyze Cam v4 mounted outdoors illuminating a driveway at night Wyze Cam v4 spotlight in action outdoors
Wyze Cam v4 Outdoor Bundle: Complete Security Solution
For those who want an all-in-one package, the Wyze Cam v4 Outdoor Bundle includes everything you need for seamless outdoor security:
  • Wyze Cam v4 with built-in spotlight and enhanced color night vision
  • Wyze Outdoor Power Adapter for reliable wired power supply
  • Wyze MicroSD Card 128GB for 24/7 local recording
Why Choose the Outdoor Bundle?
  • 24/7 Local Recording: Never miss a moment with continuous video capture
  • Motion & Sound Detection: Smart alerts for movement and unusual sounds
  • Motion Detection Zones: Customize areas to monitor for activity
  • Smoke & CO Alerts: Integrated safety notifications for your home
  • Wi-Fi 6 Support: Faster, more stable wireless connection
  • Compatibility: Works with Alexa and Google Assistant for voice control
This bundle is perfect for users who want to maximize their home security with a wired, weather-resistant setup that leverages the Wyze Cam v4’s spotlight and color night vision capabilities.
Wyze Cam v4 Home Security Bundle: Enhanced Features for Ultimate Protection
The Wyze Cam v4 Home Security Bundle offers an upgraded experience with improved two-way audio and a pre-installed 128GB microSD card (Class 10, UHS-3) for extended video storage.
Highlights:
  • Motion-Activated Spotlight: Bright 72-lumen LEDs to illuminate and deter intruders
  • Person Detection: Advanced AI to distinguish people from other motion
  • Wide Dynamic Range (WDR): Ensures vibrant, balanced video in challenging lighting
  • Indoor/Outdoor Use: IP65 weather resistance for versatile placement
  • Multiple Mounting Options: Flexible installation on walls, ceilings, or magnetic mounts
This bundle is ideal for homeowners seeking a comprehensive security system with enhanced audio and video storage capabilities.
Wyze Cam v4 + FREE 32GB MicroSD Card: Great Value with Essential Features
For budget-conscious buyers, the Wyze Cam v4 with a free 32GB microSD card offers the same powerful spotlight and color night vision features at an affordable price.
Features Include:
2.5K QHD Video Resolution Motion-Activated Spotlight & Person Detection Wide Dynamic Range (WDR) Wi-Fi 6 Support IP65 Weather Resistance This option requires the outdoor power adapter (sold separately) and a microSD card for local storage, making it a flexible choice for both new and existing Wyze users.
Why Choose Wyze Cam v4 with Built-In Spotlight?
The Wyze Cam v4 series redefines home security by combining high-resolution video, intelligent spotlighting, and smart home integration into a compact, weatherproof design. Whether you want to monitor your front porch, backyard, or indoor spaces, these cameras provide clear, colorful footage day and night, enhanced by motion-activated lighting that keeps your property safe and visible.
Outdoor lifestyle image showing a family enjoying their backyard with Wyze Cam v4 mounted Wyze Cam v4 protecting your home day and night
Summary of Wyze Cam v4 Spotlight Models
Product NameSpotlightNight Vision TypeStoragePower SourcePrice Range
Wyze Cam v4YesIR + White SpotlightmicroSD up to 512GBWired (Indoor)$100
Wyze Cam v4 Outdoor BundleYesEnhanced Color Night128GB microSD includedWired (Outdoor)$69.99
Wyze Cam v4 Home Security BundleYesIR + White Spotlight128GB microSD includedWired (Indoor/Outdoor)$169.99
Wyze Cam v4 + FREE 32GB MicroSDYesEnhanced Color Night32GB microSD includedWired (Outdoor adapter required)$35.98
Conclusion
The Wyze Cam v4 with built-in spotlight is a versatile and powerful security camera that offers exceptional video quality, smart lighting, and reliable performance in all weather conditions. Whether you choose the standalone camera, the outdoor bundle, or the home security bundle, you get advanced features like motion-activated spotlights, color night vision, and seamless smart home integration to keep your home safe and secure. Upgrade your home security today with Wyze Cam v4 — where innovation meets peace of mind.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$35.98 (1 Pack)$69.99$169.99$35.98
Color OptionsBlack, Clear, Grey, WhiteBlack, Grey, WhiteNot specifiedBlack, Grey, White
Resolution2.5K QHD (2560x1440)2.5K QHD2.5K QHD (2560x1440)2.5K QHD
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionColor Night VisionEnhanced Color Night Vision
Weather ResistanceIP65IP65IP65IP65
Motion-Activated SpotlightYesYesYesYes
Siren Volume99 dBNot specifiedNot specifiedNot specified
AudioEnhanced Two-Way TalkImproved 2-way audioImproved 2-way audioEnhanced Two-Way Talk
Local RecordingUp to 256GB microSD (sold separately)24/7 local recording with 128GB microSD included24/7 local recording with 128GB microSD includedUnlimited video length with microSD (sold separately)
MicroSD Card IncludedNoYes (128GB)Yes (128GB)Yes (32GB)
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Motion & Sound DetectionYesYesYesYes
Motion Detection ZonesYesYesYesYes
Smoke & CO AlertsYesYesYesYes
Power SourceWiredWiredWiredWired
Outdoor UseYes (with Outdoor Power Adapter)YesIndoor/OutdoorYes (with Outdoor Power Adapter)
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)Not specifiedDFOV 115.8°, HFOV 98.5°, VFOV 53.1°Not specified
Additional Included ItemsNoneWyze Outdoor Power Adapter, 128GB microSDNot specifiedNone
Release Year2024202420242024
What is the Wyze Cam v4 with built-in spotlight?The Wyze Cam v4 is a smart security camera featuring a powerful built-in, motion-activated spotlight. It offers 2.5K QHD video resolution, enhanced color night vision, and robust weather resistance, making it ideal for both indoor and outdoor home security.
How does the motion-activated spotlight work on Wyze Cam v4?The Wyze Cam v4’s integrated spotlight automatically turns on when motion is detected, delivering 72 lumens of bright white light. This not only illuminates your property but also helps deter unwanted visitors and provides clear, colorful video footage even in complete darkness.
What are the key features of the Wyze Cam v4?Key features of the Wyze Cam v4 include 2.5K QHD video resolution, enhanced color night vision with IR and white spotlight LEDs, a wide 115.8° field of view, CMOS Starlight Sensor, two-way audio with a built-in siren, Wi-Fi 6 and Bluetooth 5.2 connectivity, IP65 weather resistance, and support for microSD cards up to 512GB.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is IP65 weather-resistant, making it suitable for both indoor and outdoor environments. It can withstand various weather conditions and is designed for flexible installation around your home.
What storage options are available for Wyze Cam v4?The Wyze Cam v4 supports local storage with microSD cards up to 512GB for continuous or event-based recording. It also offers cloud storage options with a subscription for added convenience and backup.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 with built-in spotlight, a Wyze Outdoor Power Adapter for reliable wired power, and a 128GB Wyze microSD card for 24/7 local video recording.
What are the benefits of the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle offers enhanced two-way audio, a pre-installed 128GB microSD card for extended storage, motion-activated spotlight, person detection, wide dynamic range (WDR), and flexible mounting options for comprehensive home protection.
Does the Wyze Cam v4 support smart home integration?Yes, the Wyze Cam v4 is compatible with Alexa and Google Assistant, allowing you to control the camera and view live feeds using voice commands for seamless smart home integration.
What is the difference between the Wyze Cam v4 bundles?The main differences are in included accessories and storage. The Outdoor Bundle comes with a power adapter and 128GB microSD card for outdoor use, while the Home Security Bundle offers enhanced audio and a pre-installed 128GB card for extended storage. The Wyze Cam v4 + FREE 32GB microSD Card is a budget-friendly option with essential features and a smaller storage card.
Does the Wyze Cam v4 offer person detection and motion detection zones?Yes, the Wyze Cam v4 features advanced AI-powered person detection and customizable motion detection zones, allowing you to monitor specific areas and receive smart alerts for relevant activity.
What power sources are supported by Wyze Cam v4?The Wyze Cam v4 supports wired power. For outdoor installations, the Wyze Outdoor Power Adapter is recommended. Some bundles include the power adapter, while others require it to be purchased separately.
How easy is it to install the Wyze Cam v4?The Wyze Cam v4 is compact and lightweight, offering multiple mounting options including stand, wall mount, ceiling mount, and magnetic wall mount with adhesive, making installation quick and flexible for any location.
What is the video quality of the Wyze Cam v4?The Wyze Cam v4 delivers sharp, detailed images with 2.5K QHD (2560x1440) video resolution, wide dynamic range (WDR), and enhanced color night vision for clear footage day and night.
Does the Wyze Cam v4 have two-way audio?Yes, the Wyze Cam v4 features a 99dB waterproof speaker with two-way talk and a built-in siren, allowing you to communicate with visitors or deter intruders directly from your mobile device.
What is the price range for Wyze Cam v4 models?The Wyze Cam v4 models range in price from $35.98 for the camera with a free 32GB microSD card, up to $169.99 for the Home Security Bundle with enhanced features and storage.
What are the key specifications of the Wyze Cam v4?Can you tell me more about the features of the Wyze Cam v4 Outdoor Bundle?Are there any ongoing sales or discounts for the Wyze Cam v4?
